[PATCH v2] Use alias for rtems_task_self() and pthread_self()
Thu Apr 29 13:18:05 UTC 2021
This may reduce the code size a bit.
 cpukit/Makefile.am                      |  3 +-
 cpukit/include/rtems/score/threadimpl.h |  7 ++++
 cpukit/posix/src/pthreadself.c          | 32 ---------------
 cpukit/rtems/src/taskself.c             | 28 -------------
 cpukit/score/src/threadselfid.c         | 53 +++++++++++++++++++++++++
 spec/build/cpukit/librtemscpu.yml       |  3 +-
 6 files changed, 62 insertions(+), 64 deletions(-)
 delete mode 100644 cpukit/posix/src/pthreadself.c
 delete mode 100644 cpukit/rtems/src/taskself.c
 create mode 100644 cpukit/score/src/threadselfid.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index b0df610bed..096187c507 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -620,7 +620,6 @@ librtemscpu_a_SOURCES += posix/src/pthreadgetschedparam.c
 librtemscpu_a_SOURCES += posix/src/pthreadinitthreads.c
 librtemscpu_a_SOURCES += posix/src/pthreadjoin.c
 librtemscpu_a_SOURCES += posix/src/pthreadonce.c
-librtemscpu_a_SOURCES += posix/src/pthreadself.c
 librtemscpu_a_SOURCES += posix/src/pthreadsetaffinitynp.c
 librtemscpu_a_SOURCES += posix/src/pthreadsetnamenp.c
 librtemscpu_a_SOURCES += posix/src/pthreadsetschedparam.c
@@ -800,7 +799,6 @@ librtemscpu_a_SOURCES += rtems/src/taskmode.c
 librtemscpu_a_SOURCES += rtems/src/taskrestart.c
 librtemscpu_a_SOURCES += rtems/src/taskresume.c
 librtemscpu_a_SOURCES += rtems/src/tasks.c
-librtemscpu_a_SOURCES += rtems/src/taskself.c
 librtemscpu_a_SOURCES += rtems/src/tasksetaffinity.c
 librtemscpu_a_SOURCES += rtems/src/tasksetpriority.c
 librtemscpu_a_SOURCES += rtems/src/tasksetscheduler.c
@@ -964,6 +962,7 @@ librtemscpu_a_SOURCES += score/src/threadinitialize.c
 librtemscpu_a_SOURCES += score/src/threadidledefault.c
 librtemscpu_a_SOURCES += score/src/threadloadenv.c
 librtemscpu_a_SOURCES += score/src/threadrestart.c
+librtemscpu_a_SOURCES += score/src/threadselfid.c
 librtemscpu_a_SOURCES += score/src/threadsetstate.c
 librtemscpu_a_SOURCES += score/src/threadstackallocate.c
 librtemscpu_a_SOURCES += score/src/threadstackfree.c
diff --git a/cpukit/include/rtems/score/threadimpl.h b/cpukit/include/rtems/score/threadimpl.h
index 5dfd142b92..c861e8b119 100644
--- a/cpukit/include/rtems/score/threadimpl.h
+++ b/cpukit/include/rtems/score/threadimpl.h
@@ -903,6 +903,13 @@ Thread_Control *_Thread_Get(
   ISR_lock_Context  *lock_context
+ * @brief Gets the identifier of the calling thread.
+ * @return Returns the identifier of the calling thread.
+Objects_Id _Thread_Self_id( void );
  * @brief Gets the cpu of the thread's scheduler.
diff --git a/cpukit/posix/src/pthreadself.c b/cpukit/posix/src/pthreadself.c
deleted file mode 100644
index db5f2f189d..0000000000
--- a/cpukit/posix/src/pthreadself.c
+++ /dev/null
@@ -1,32 +0,0 @@
- * @file
- * @ingroup POSIXAPI
- * @brief Function returns the ID of the Calling Thread
- *  16.1.6 Get Calling Thread's ID, p1003.1c/Draft 10, p. 152
- *  COPYRIGHT (c) 1989-1999.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#ifdef HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <pthread.h>
-#include <rtems/score/percpu.h>
-#include <rtems/score/thread.h>
-pthread_t pthread_self( void )
-  return _Thread_Get_executing()->Object.id;
diff --git a/cpukit/rtems/src/taskself.c b/cpukit/rtems/src/taskself.c
index 193e691ce5..0000000000
--- a/cpukit/rtems/src/taskself.c
+++ /dev/null
@@ -1,28 +0,0 @@
- * @file
- * @ingroup RTEMSImplClassicTask
- * @brief This source file contains the implementation of
- *   rtems_task_self().
- *  COPYRIGHT (c) 1989-2007.
-#endif
-#include <rtems/rtems/tasksimpl.h>
-rtems_id rtems_task_self(void)
diff --git a/cpukit/score/src/threadselfid.c b/cpukit/score/src/threadselfid.c
new file mode 100644
index 0000000000..f888a37619
--- /dev/null
+++ b/cpukit/score/src/threadselfid.c
@@ -0,0 +1,53 @@
+ * @file
+ * @ingroup RTEMSScoreThread
+ * @brief This source file contains the implementation of _Thread_Self_id().
+ * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * Copyright (C) 1995 On-Line Applications Research Corporation (OAR)
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/threadimpl.h>
+#include <pthread.h>
+#include <rtems/rtems/tasksimpl.h>
+  return _Thread_Get_executing()->Object.id;
+RTEMS_ALIAS( _Thread_Self_id ) pthread_t pthread_self( void );
+RTEMS_ALIAS( _Thread_Self_id ) rtems_id rtems_task_self( void );
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index a3a9ee42e3..21fa6ea787 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -1119,7 +1119,6 @@ source:
 - cpukit/posix/src/pthreadinitthreads.c
 - cpukit/posix/src/pthreadjoin.c
 - cpukit/posix/src/pthreadonce.c
-- cpukit/posix/src/pthreadself.c
 - cpukit/posix/src/pthreadsetaffinitynp.c
 - cpukit/posix/src/pthreadsetnamenp.c
 - cpukit/posix/src/pthreadsetschedparam.c
@@ -1299,7 +1298,6 @@ source:
 - cpukit/rtems/src/taskrestart.c
 - cpukit/rtems/src/taskresume.c
 - cpukit/rtems/src/tasks.c
-- cpukit/rtems/src/taskself.c
 - cpukit/rtems/src/tasksetaffinity.c
 - cpukit/rtems/src/tasksetpriority.c
 - cpukit/rtems/src/tasksetscheduler.c
@@ -1548,6 +1546,7 @@ source:
 - cpukit/score/src/threadqtimeout.c
 - cpukit/score/src/threadrestart.c
 - cpukit/score/src/threadscheduler.c
+- cpukit/score/src/threadselfid.c
 - cpukit/score/src/threadsetstate.c
 - cpukit/score/src/threadstackallocate.c
 - cpukit/score/src/threadstackfree.c
2.26.2
