[PATCH v2] Use alias for rtems_task_self() and pthread_self()
Thu Apr 29 16:02:49 UTC 2021
ok
On Thu, Apr 29, 2021 at 7:18 AM Sebastian Huber
> This may reduce the code size a bit.
>  cpukit/Makefile.am                      |  3 +-
>  cpukit/include/rtems/score/threadimpl.h |  7 ++++
>  cpukit/posix/src/pthreadself.c          | 32 ---------------
>  cpukit/rtems/src/taskself.c             | 28 -------------
>  cpukit/score/src/threadselfid.c         | 53 +++++++++++++++++++++++++
>  spec/build/cpukit/librtemscpu.yml       |  3 +-
>  6 files changed, 62 insertions(+), 64 deletions(-)
>  delete mode 100644 cpukit/posix/src/pthreadself.c
>  delete mode 100644 cpukit/rtems/src/taskself.c
>  create mode 100644 cpukit/score/src/threadselfid.c
> diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
> index b0df610bed..096187c507 100644
> --- a/cpukit/Makefile.am
> +++ b/cpukit/Makefile.am
> @@ -620,7 +620,6 @@ librtemscpu_a_SOURCES += posix/src/pthreadgetschedparam.c
>  librtemscpu_a_SOURCES += posix/src/pthreadinitthreads.c
>  librtemscpu_a_SOURCES += posix/src/pthreadjoin.c
>  librtemscpu_a_SOURCES += posix/src/pthreadonce.c
> -librtemscpu_a_SOURCES += posix/src/pthreadself.c
>  librtemscpu_a_SOURCES += posix/src/pthreadsetaffinitynp.c
>  librtemscpu_a_SOURCES += posix/src/pthreadsetnamenp.c
>  librtemscpu_a_SOURCES += posix/src/pthreadsetschedparam.c
> @@ -800,7 +799,6 @@ librtemscpu_a_SOURCES += rtems/src/taskmode.c
>  librtemscpu_a_SOURCES += rtems/src/taskrestart.c
>  librtemscpu_a_SOURCES += rtems/src/taskresume.c
>  librtemscpu_a_SOURCES += rtems/src/tasks.c
> -librtemscpu_a_SOURCES += rtems/src/taskself.c
>  librtemscpu_a_SOURCES += rtems/src/tasksetaffinity.c
>  librtemscpu_a_SOURCES += rtems/src/tasksetpriority.c
>  librtemscpu_a_SOURCES += rtems/src/tasksetscheduler.c
> @@ -964,6 +962,7 @@ librtemscpu_a_SOURCES += score/src/threadinitialize.c
>  librtemscpu_a_SOURCES += score/src/threadidledefault.c
>  librtemscpu_a_SOURCES += score/src/threadloadenv.c
>  librtemscpu_a_SOURCES += score/src/threadrestart.c
> +librtemscpu_a_SOURCES += score/src/threadselfid.c
>  librtemscpu_a_SOURCES += score/src/threadsetstate.c
>  librtemscpu_a_SOURCES += score/src/threadstackallocate.c
>  librtemscpu_a_SOURCES += score/src/threadstackfree.c
> diff --git a/cpukit/include/rtems/score/threadimpl.h b/cpukit/include/rtems/score/threadimpl.h
> index 5dfd142b92..c861e8b119 100644
> --- a/cpukit/include/rtems/score/threadimpl.h
> +++ b/cpukit/include/rtems/score/threadimpl.h
> @@ -903,6 +903,13 @@ Thread_Control *_Thread_Get(
>    ISR_lock_Context  *lock_context
> + * @brief Gets the identifier of the calling thread.
> + * @return Returns the identifier of the calling thread.
> +Objects_Id _Thread_Self_id( void );
>   * @brief Gets the cpu of the thread's scheduler.
> diff --git a/cpukit/posix/src/pthreadself.c b/cpukit/posix/src/pthreadself.c
> deleted file mode 100644
> index db5f2f189d..0000000000
> --- a/cpukit/posix/src/pthreadself.c
> +++ /dev/null
> @@ -1,32 +0,0 @@
> - * @file
> - * @ingroup POSIXAPI
> - * @brief Function returns the ID of the Calling Thread
> - *  16.1.6 Get Calling Thread's ID, p1003.1c/Draft 10, p. 152
> - *  COPYRIGHT (c) 1989-1999.
> - *  On-Line Applications Research Corporation (OAR).
> - *  The license and distribution terms for this file may be
> - *  found in the file LICENSE in this distribution or at
> - *  http://www.rtems.org/license/LICENSE.
> -#ifdef HAVE_CONFIG_H
> -#include "config.h"
> -#endif
> -#include <pthread.h>
> -#include <rtems/score/percpu.h>
> -#include <rtems/score/thread.h>
> -pthread_t pthread_self( void )
> -  return _Thread_Get_executing()->Object.id;
> diff --git a/cpukit/rtems/src/taskself.c b/cpukit/rtems/src/taskself.c
> index 193e691ce5..0000000000
> --- a/cpukit/rtems/src/taskself.c
> +++ /dev/null
> @@ -1,28 +0,0 @@
> - * @file
> - * @ingroup RTEMSImplClassicTask
> - * @brief This source file contains the implementation of
> - *   rtems_task_self().
> - *  COPYRIGHT (c) 1989-2007.
> -#endif
> -#include <rtems/rtems/tasksimpl.h>
> -rtems_id rtems_task_self(void)
> diff --git a/cpukit/score/src/threadselfid.c b/cpukit/score/src/threadselfid.c
> new file mode 100644
> index 0000000000..f888a37619
> --- /dev/null
> +++ b/cpukit/score/src/threadselfid.c
> @@ -0,0 +1,53 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * @ingroup RTEMSScoreThread
> + * @brief This source file contains the implementation of _Thread_Self_id().
> + * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
> + * Copyright (C) 1995 On-Line Applications Research Corporation (OAR)
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <rtems/score/threadimpl.h>
> +#include <pthread.h>
> +#include <rtems/rtems/tasksimpl.h>
> +  return _Thread_Get_executing()->Object.id;
> +RTEMS_ALIAS( _Thread_Self_id ) pthread_t pthread_self( void );
> +RTEMS_ALIAS( _Thread_Self_id ) rtems_id rtems_task_self( void );
> diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
> index a3a9ee42e3..21fa6ea787 100644
> --- a/spec/build/cpukit/librtemscpu.yml
> +++ b/spec/build/cpukit/librtemscpu.yml
> @@ -1119,7 +1119,6 @@ source:
>  - cpukit/posix/src/pthreadinitthreads.c
>  - cpukit/posix/src/pthreadjoin.c
>  - cpukit/posix/src/pthreadonce.c
> -- cpukit/posix/src/pthreadself.c
>  - cpukit/posix/src/pthreadsetaffinitynp.c
>  - cpukit/posix/src/pthreadsetnamenp.c
>  - cpukit/posix/src/pthreadsetschedparam.c
> @@ -1299,7 +1298,6 @@ source:
>  - cpukit/rtems/src/taskrestart.c
>  - cpukit/rtems/src/taskresume.c
>  - cpukit/rtems/src/tasks.c
> -- cpukit/rtems/src/taskself.c
>  - cpukit/rtems/src/tasksetaffinity.c
>  - cpukit/rtems/src/tasksetpriority.c
>  - cpukit/rtems/src/tasksetscheduler.c
> @@ -1548,6 +1546,7 @@ source:
>  - cpukit/score/src/threadqtimeout.c
>  - cpukit/score/src/threadrestart.c
>  - cpukit/score/src/threadscheduler.c
> +- cpukit/score/src/threadselfid.c
>  - cpukit/score/src/threadsetstate.c
>  - cpukit/score/src/threadstackallocate.c
>  - cpukit/score/src/threadstackfree.c
> 2.26.2
> devel mailing list
> devel at rtems.org
