[PATCH] riscv/start: Startup sequence update.
Sebastian Huber
Thu Apr 29 18:53:26 UTC 2021
On 29/04/2021 20:18, Hesham Almatary wrote:
>>> I would place the device tree in a noinit section.
>> That is probably a better solution.
>> It should also be documented in this start.S file what are the
>> assumptions about parameters coming from the bootloader since it is
>> not obvious.
> +1
The recent GCC have an attribute for this:
https://devel.rtems.org/ticket/3866
We just need support for this in linkcmds.base and an RTEMS_NOINIT in
basedefs.h.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
