[PATCH] riscv/start: Startup sequence update.
Sebastian Huber
Fri Apr 30 13:22:20 UTC 2021
On 29/04/2021 20:53, Sebastian Huber wrote:
> On 29/04/2021 20:18, Hesham Almatary wrote:
>>>> I would place the device tree in a noinit section.
>>> That is probably a better solution.
>>> It should also be documented in this start.S file what are the
>>> assumptions about parameters coming from the bootloader since it is
>>> not obvious.
>> +1
> The recent GCC have an attribute for this:
> https://devel.rtems.org/ticket/3866
> We just need support for this in linkcmds.base and an RTEMS_NOINIT in
> basedefs.h.
The noinit attributes is a bit broken in GCC:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=100357
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
