Issues with rtems_waf on Windows 10 with gccdeps module
Robin Müller
robin.mueller.m at gmail.com
Thu Apr 29 19:01:01 UTC 2021
Yes that is the prefix. The rtems.h file is definitely located at the
location in the warning and it works on older commit of rtems_waf (where
gccdeps.py is not used).
I briefly looked through the gccdeps.py file and it is doing some string
stripping operations.
Maybe that is the issue but I am not sure.
Kind Regards
Robin
On Thu, 29 Apr 2021 at 18:00, Gedare Bloom <gedare at rtems.org> wrote:
> On Thu, Apr 29, 2021 at 9:59 AM Gedare Bloom <gedare at rtems.org> wrote:
> > On Thu, Apr 29, 2021 at 3:14 AM Robin Müller <robin.mueller.m at gmail.com>
> wrote:
> > > I replaced the file in rtems_waf manually but it still throws the same
> error:
> > > [1/2] Compiling
> build/conf_check_995d7bdd1834199278843e9a51c37759/test.c
> ['C:/Users/Robin/Documents/RTEMS/rtems-tools/rtems/6/bin/sparc-rtems6-gcc.exe',
> '-mcpu=cypress',
> '-IC:/Users/Robin/Documents/RTEMS/rtems-tools/rtems/6/sparc-rtems6/erc32/lib/include',
> '-MMD', '../test.c', '-c',
> '-oC:/Users/Robin/Documents/RTEMS/quickstart/build/conf_check_995d7bdd1834199278843e9a51c37759/testbuild/test.c.1.o']
> > > from C:/Users/Robin/Documents/RTEMS/quickstart: Test does not build:
> Traceback (most recent call last):
> > > File
> "C:/Users/Robin/Documents/RTEMS/quickstart/waf3-2.0.22-1241519b19b496207abef1f72bbf61c2/waflib/Configure.py",
> line 335, in run_build
> > > bld.compile()
> > > File
> "C:/Users/Robin/Documents/RTEMS/quickstart/waf3-2.0.22-1241519b19b496207abef1f72bbf61c2/waflib/Build.py",
> line 176, in compile
> > > raise Errors.BuildError(self.producer.error)
> > > waflib.Errors.BuildError: Build failed
> > > File
> "C:/Users/Robin/Documents/RTEMS/quickstart/waf3-2.0.22-1241519b19b496207abef1f72bbf61c2/waflib/Task.py",
> line 190, in process
> > > self.post_run()
> > > File
> "C:/Users/Robin/Documents/RTEMS/quickstart/rtems_waf/gccdeps.py", line 140,
> in post_run
> > > raise ValueError('could not find %r for %r' % (path, self))
> > > ValueError: could not find ['C', ':', 'Users', 'Robin', 'Documents',
> 'RTEMS', 'rtems-tools', 'rtems', '6', 'sparc-rtems6', 'erc32', 'lib',
> 'include', 'rtems.h'] for
> > > {task 2179590063376: c test.c -> test.c.1.o}
> > It's looking for rtems.h in your rtems-tools directory and not in your
> > prefix. how did you configure waf?
> Sorry, I should also ask, did you install rtems at
> C:\Users\Robin\Documents\RTEMS\rtems-tools/6
> > > no
> > > from C:/Users/Robin/Documents/RTEMS/quickstart: The configuration
> failed
> > > Kind Regards
> > > Robin
> > > On Wed, 28 Apr 2021 at 22:35, Chris Johns <chrisj at rtems.org> wrote:
> > >> On 28/4/21 7:59 pm, Robin Müller wrote:
> > >> > I think the following commit in rtems_waf breaks the waf build on
> Windows 10:
> > >> > commit 096372fc4504730e50b51b952ce47ca603b35f01
> > >> > Author: Chris Johns <chrisj at rtems.org <mailto:chrisj at rtems.org>>
> > >> > Date: Thu Oct 10 17:43:11 2019 +1100
> > >> > Use gccdeps for dependency scanning.
> > >> > I get the error that RTEMS is not able to find the rtems.h file in
> a certain
> > >> > directory when building the simple quick start application. The
> error does not
> > >> > occur on commits before that. I tried to run waf both in the
> WIndows CMD and in
> > >> > MinGW64, it is problematic for both.
> > >> Could you please update your local version with ...
> > >> https://gitlab.com/ita1024/waf/-/blob/master/waflib/extras/gccdeps.py
> > >> ... and report back how that goes?
> > >> Thanks
> > >> Chris
> > > _______________________________________________
> > > devel mailing list
> > > devel at rtems.org
> > > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210429/1e25ff17/attachment-0001.html>
