Issues with rtems_waf on Windows 10 with gccdeps module
Thu Apr 29 21:01:46 UTC 2021
On 30/4/21 5:01 am, Robin Müller wrote:
> Yes that is the prefix. The rtems.h file is definitely located at the location
> in the warning and it works on older commit of rtems_waf (where gccdeps.py is
> not used).
> I briefly looked through the gccdeps.py file and it is doing some string
> stripping operations.
> Maybe that is the issue but I am not sure.
Thank you for debugging this and I agree it look like something is a little off
in gccdeps.
I will need to try and reproduce this to have a chance of finding it. What
happens if you remove gccdeps.py? Will that you get past this point?
