[PATCH rtems-libbsd v2 0/5] Beagle BSP: USB Template Driver for CDC Ethernet
Christian Mauderer
oss at c-mauderer.de
Sun Aug 1 11:27:28 UTC 2021
Hello Husni,
just tested that and it works fine. With a simple curl I can reach about
8.5 MByte/s sending to the beagle and 19.5 MByte/s receiving from it.
Please take a look at the points that Chris Johns asked. As soon as
these are addressed, I think the patches could be merged.
Please also make the documentation that you started for this more public
visible. In other words: Send it as patches to the list and not only as
a link to some branch!
Best regards
Christian
On 28/07/2021 13:56, Husni Faiz wrote:
> This set of patches import the drivers from freebsd and
> configures it for the beagle bsp.
> Github Branch for the commits
> https://github.com/drac98/rtems-libbsd/commits/usb-cdce
> Patch for 6-freebsd-12 branch
> https://github.com/drac98/rtems-libbsd/commits/usb-cdce12
> Husni Faiz (5):
> usb_template:Import CDC Ethernet
> usb_template: Configure template driver only for CDC Ethernet
> nexus-devices: Include CDC Ethernet for Beagle
> libbsd.py: add usb template files
> create-kernel-namespace for USB Template driver
> buildset/default.ini | 1 +
> buildset/minimal.ini | 3 +-
> freebsd/sys/dev/usb/template/usb_template.c | 1493 +++++++++++++++++
> freebsd/sys/dev/usb/template/usb_template.h | 130 ++
> .../sys/dev/usb/template/usb_template_cdce.c | 355 ++++
> freebsd/sys/dev/usb/usb_device.c | 8 +-
> libbsd.py | 25 +
> rtemsbsd/include/bsp/nexus-devices.h | 5 +
> .../machine/rtems-bsd-kernel-namespace.h | 5 +
> .../include/machine/rtems-bsd-nexus-bus.h | 19 +
> 10 files changed, 2041 insertions(+), 3 deletions(-)
> create mode 100644 freebsd/sys/dev/usb/template/usb_template.c
> create mode 100644 freebsd/sys/dev/usb/template/usb_template.h
> create mode 100644 freebsd/sys/dev/usb/template/usb_template_cdce.c
