[PATCH rtems-libbsd v2 0/5] Beagle BSP: USB Template Driver for CDC Ethernet
Ahamed Husni ahamedhusni73 at gmail.com
Sun Aug 1 17:59:59 UTC 2021
Hi Christian,
On Sun, Aug 1, 2021 at 4:57 PM Christian Mauderer <oss at c-mauderer.de> wrote:
> Hello Husni,
> just tested that and it works fine. With a simple curl I can reach about
> 8.5 MByte/s sending to the beagle and 19.5 MByte/s receiving from it.
> That's 68 Mbps for sending. That's an acceptable speed isn't it?
Please take a look at the points that Chris Johns asked. As soon as
> these are addressed, I think the patches could be merged.
I just replied to it now. Sorry for the delay.
> Please also make the documentation that you started for this more public
> visible. In other words: Send it as patches to the list and not only as
> a link to some branch!
Noted.
> Best regards
> Christian
> On 28/07/2021 13:56, Husni Faiz wrote:
> > This set of patches import the drivers from freebsd and
> > configures it for the beagle bsp.
> > Github Branch for the commits
> > https://github.com/drac98/rtems-libbsd/commits/usb-cdce
> > Patch for 6-freebsd-12 branch
> > https://github.com/drac98/rtems-libbsd/commits/usb-cdce12
> > Husni Faiz (5):
> >    usb_template:Import CDC Ethernet
> >    usb_template: Configure template driver only for CDC Ethernet
> >    nexus-devices: Include CDC Ethernet for Beagle
> >    libbsd.py: add usb template files
> >    create-kernel-namespace for USB Template driver
> >   buildset/default.ini                          |    1 +
> >   buildset/minimal.ini                          |    3 +-
> >   freebsd/sys/dev/usb/template/usb_template.c   | 1493 +++++++++++++++++
> >   freebsd/sys/dev/usb/template/usb_template.h   |  130 ++
> >   .../sys/dev/usb/template/usb_template_cdce.c  |  355 ++++
> >   freebsd/sys/dev/usb/usb_device.c              |    8 +-
> >   libbsd.py                                     |   25 +
> >   rtemsbsd/include/bsp/nexus-devices.h          |    5 +
> >   .../machine/rtems-bsd-kernel-namespace.h      |    5 +
> >   .../include/machine/rtems-bsd-nexus-bus.h     |   19 +
> >   10 files changed, 2041 insertions(+), 3 deletions(-)
> >   create mode 100644 freebsd/sys/dev/usb/template/usb_template.c
> >   create mode 100644 freebsd/sys/dev/usb/template/usb_template.h
> >   create mode 100644 freebsd/sys/dev/usb/template/usb_template_cdce.c
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210801/aa600199/attachment-0001.html>
