[PATCH rtems-libbsd v2 5/5] create-kernel-namespace for USB Template driver
Ahamed Husni ahamedhusni73 at gmail.com
Sun Aug 1 18:24:43 UTC 2021
Hello Chris,
On Thu, Jul 29, 2021 at 5:41 AM Chris Johns <chrisj at rtems.org> wrote:
> On 28/7/21 9:56 pm, Husni Faiz wrote:
> > Signed-off-by: Husni Faiz <ahamedhusni73 at gmail.com>
> >  rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h | 5 +++++
> >  1 file changed, 5 insertions(+)
> > diff --git a/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
> b/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
> > index 97cdb625..ae56ad9c 100644
> > --- a/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
> > +++ b/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
> > @@ -5279,6 +5279,7 @@
> >  #define      usbd_do_request_proc _bsd_usbd_do_request_proc
> >  #define      usbd_dummy_timeout _bsd_usbd_dummy_timeout
> >  #define      usb_debug _bsd_usb_debug
> > +#define      usb_decode_str_desc _bsd_usb_decode_str_desc
> >  #define      usbd_enum_is_locked _bsd_usbd_enum_is_locked
> >  #define      usbd_enum_lock _bsd_usbd_enum_lock
> >  #define      usbd_enum_lock_sig _bsd_usbd_enum_lock_sig
> > @@ -5515,8 +5516,12 @@
> >  #define      usb_suspend_resume _bsd_usb_suspend_resume
> >  #define      usb_temp_get_desc_p _bsd_usb_temp_get_desc_p
> >  #define      usb_template _bsd_usb_template
> > +#define      usb_template_cdce _bsd_usb_template_cdce
> > +#define      usb_temp_setup _bsd_usb_temp_setup
> >  #define      usb_temp_setup_by_index_p _bsd_usb_temp_setup_by_index_p
> > +#define      usb_temp_sysctl _bsd_usb_temp_sysctl
> >  #define      usb_temp_unload _bsd_usb_temp_unload
> > +#define      usb_temp_unsetup _bsd_usb_temp_unsetup
> >  #define      usb_temp_unsetup_p _bsd_usb_temp_unsetup_p
> >  #define      usb_test_quirk _bsd_usb_test_quirk
> >  #define      usb_test_quirk_p _bsd_usb_test_quirk_p
> How were these additions done?
I used the create-kernel-namespace.sh script which auto genarates these
definitions.
That generated more definitions than I have added here. I only filtered out
the
definitions for the codes I imported.
> I ask because I see these externs in the template code ...
> extern struct usb_temp_device_desc usb_template_audio;
> extern struct usb_temp_device_desc usb_template_cdce;
> extern struct usb_temp_device_desc usb_template_kbd;
> extern struct usb_temp_device_desc usb_template_modem;
> extern struct usb_temp_device_desc usb_template_mouse;
> extern struct usb_temp_device_desc usb_template_msc;
> extern struct usb_temp_device_desc usb_template_mtp;
> extern struct usb_temp_device_desc usb_template_phone;
> extern struct usb_temp_device_desc usb_template_serialnet;
> extern struct usb_temp_device_desc usb_template_midi;
> extern struct usb_temp_device_desc usb_template_multi;
> extern struct usb_temp_device_desc usb_template_cdceem;
These externs are for all the usb templates supported by freebsd.
I only have imported the usb_template_cdce. Other templates are
not imported yet. Shall I exclude them?
Regards,
Husni.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210801/11f590f2/attachment.html>
