[PATCH rtems-libbsd v2 4/5] libbsd.py: add usb template files
Ahamed Husni ahamedhusni73 at gmail.com
Sun Aug 1 19:48:57 UTC 2021
I don't get notified of the replies to my patch. Not sure why.
Replies don't go to spam either. That's why my replies are late.
I added the rtems.org to the whitelist. I hope next time I'll get notified
On Thu, Jul 29, 2021 at 5:38 AM Chris Johns <chrisj at rtems.org> wrote:
> On 28/7/21 9:56 pm, Husni Faiz wrote:
> > add the imported template files for CDC Ethernet
> > register the dev_usb_template module
> > enable usb template in default buildset
> > Signed-off-by: Husni Faiz <ahamedhusni73 at gmail.com>
> >  buildset/default.ini |  1 +
> >  buildset/minimal.ini |  3 ++-
> >  libbsd.py            | 25 +++++++++++++++++++++++++
> >  3 files changed, 28 insertions(+), 1 deletion(-)
> > diff --git a/buildset/default.ini b/buildset/default.ini
> > index 472c535d..117bacc3 100644
> > --- a/buildset/default.ini
> > +++ b/buildset/default.ini
> > @@ -34,6 +34,7 @@ dev_usb_net = on
> >  dev_usb_quirk = on
> >  dev_usb_serial = on
> >  dev_usb_storage = on
> > +dev_usb_template = on
> >  dev_usb_wlan = off
> >  dev_wlan_rtwn = off
> >  iic = on
> > diff --git a/buildset/minimal.ini b/buildset/minimal.ini
> > index 03dd96bb..060b1930 100644
> > --- a/buildset/minimal.ini
> > +++ b/buildset/minimal.ini
> > @@ -19,5 +19,6 @@ extends = default.ini
> >  [modules]
> >  crypto_openssl = off
> > +dev_usb_template = off
> >  netinet6 = off
> > -usr_bin_openssl = off
> > +usr_bin_openssl = off
> > \ No newline at end of file
> What happened here?
> That's auto generated by the git format-patch. I don't see it in my files.
(Not sure why but Github-like services seem to use that to show the end of
the file icon.
I assume they might get ignored when applying the patches.)
> > diff --git a/libbsd.py b/libbsd.py
> > index c9151901..049ec7f8 100644
> > --- a/libbsd.py
> > +++ b/libbsd.py
> > @@ -1162,6 +1162,30 @@ class dev_usb_storage(builder.Module):
> >              mm.generator['source']()
> > +# USB Template
> > +class dev_usb_template(builder.Module):
> > +    def __init__(self, manager):
> > +        super(dev_usb_template, self).__init__(manager,
> type(self).__name__)
> > +    def generate(self):
> > +        mm = self.manager
> > +        self.addDependency('dev_usb')
> > +        self.addKernelSpaceHeaderFiles(
> > +                'sys/dev/usb/template/usb_template.h',
> > +        self.addKernelSpaceSourceFiles(
> > +                'sys/dev/usb/template/usb_template.c',
> > +                'sys/dev/usb/template/usb_template_cdce.c',
> > +            mm.generator['source']()
> >  # BBB USB
> > @@ -5480,6 +5504,7 @@ def load(mm):
> >      mm.addModule(cam(mm))
> >      mm.addModule(dev_usb_storage(mm))
> > +    mm.addModule(dev_usb_template(mm))
> >      mm.addModule(dev_usb_controller_bbb(mm))
> >      mm.addModule(net(mm))
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210802/a3d777c3/attachment.html>
