[PATCH v1 00/13] Remove the global variables in app_common
Ryan Long
ryan.long at oarcorp.com
Sun Aug 1 23:23:34 UTC 2021
Hi,
This is a tedious series of patches.
To remove the global variables, the process was generally:
1. Remove the global variable, reokace it with a variable in main()
2. Pass it to a constructor for the objects that were using the global
variable and initialize a newly created member variable
3. Pass it as a parameter to any non-class or static function
For some of the newly created member variables, I had to create a get
and set function. It may look like a lot was changed because when a new
parameter needed to be added, I had to adjust the formatting of the
parameters above.
All of the global variables were pointers before, and they have been
changed to reference variables. The only exception to this is
TargetInfo.
Thanks,
Ryan
Ryan Long (13):
Remove AllExplanations global variable
ReportsHtml.cc: Initialize lastState_m
Remove objdumpProcessor global variable
Remove Verbose global variable
Remove dynamicLibrary global variable
Remove projectName global variable
Remove outputDirectory global variable
Remove input buffer global variables
Remove SymbolsToAnalyze global variable
Remove BranchInfoAvailable global variable
Remove TargetInfo global variable
app_common: Remove functions and macros
Remove app_common and all references to it
tester/covoar/CoverageReaderBase.cc | 10 +++
tester/covoar/CoverageReaderBase.h | 22 +++++
tester/covoar/CoverageReaderQEMU.cc | 7 +-
tester/covoar/CoverageReaderTSIM.cc | 5 +-
tester/covoar/DesiredSymbols.cc | 28 +++---
tester/covoar/DesiredSymbols.h | 28 ++++--
tester/covoar/ExecutableInfo.cc | 23 ++---
tester/covoar/ExecutableInfo.h | 17 +++-
tester/covoar/Explanations.cc | 21 ++---
tester/covoar/GcovData.cc | 7 +-
tester/covoar/GcovData.h | 12 ++-
tester/covoar/GcovFunctionData.cc | 15 ++--
tester/covoar/GcovFunctionData.h | 6 +-
tester/covoar/Makefile | 6 +-
tester/covoar/ObjdumpProcessor.cc | 66 +++++++++-----
tester/covoar/ObjdumpProcessor.h | 113 +++++++++++++++---------
tester/covoar/ReportsBase.cc | 166 +++++++++++++++++++++++-------------
tester/covoar/ReportsBase.h | 69 +++++++++++++--
tester/covoar/ReportsHtml.cc | 64 +++++++++-----
tester/covoar/ReportsHtml.h | 10 ++-
tester/covoar/ReportsText.cc | 28 ++++--
tester/covoar/ReportsText.h | 10 ++-
tester/covoar/SymbolTable.cc | 1 -
tester/covoar/TraceConverter.cc | 39 ++++++---
tester/covoar/TraceReaderBase.h | 7 +-
tester/covoar/TraceReaderLogQEMU.cc | 25 +++++-
tester/covoar/TraceReaderLogQEMU.h | 6 +-
tester/covoar/TraceWriterBase.cc | 5 ++
tester/covoar/TraceWriterBase.h | 16 +++-
tester/covoar/TraceWriterQEMU.cc | 12 +--
tester/covoar/TraceWriterQEMU.h | 4 +-
tester/covoar/app_common.cc | 118 -------------------------
tester/covoar/app_common.h | 34 --------
tester/covoar/coverage_converter.cc | 1 -
tester/covoar/covmerge.cc | 8 +-
tester/covoar/covoar.cc | 124 ++++++++++++++++++---------
tester/covoar/wscript | 3 +-
37 files changed, 681 insertions(+), 455 deletions(-)
delete mode 100644 tester/covoar/app_common.cc
delete mode 100644 tester/covoar/app_common.h
1.8.3.1
