[PATCH v1 03/13] Remove objdumpProcessor global variable
Ryan Long
ryan.long at oarcorp.com
Sun Aug 1 23:23:37 UTC 2021
- Replaced objdumpProcessor in app_common with a local variable in
TraceConverter.cc and covoar.cc
- Added objdumpProcessor as a parameter for GenerateReports() and
the processFile() member function of TraceReaderBase and its derived
classes
- Changed previous objdumpProcessor member functions calls from pointer
to direct call syntax
tester/covoar/ReportsBase.h | 2 +-
tester/covoar/TraceConverter.cc | 9 ++++-----
tester/covoar/TraceReaderBase.h | 7 ++++---
tester/covoar/TraceReaderLogQEMU.cc | 7 ++++---
tester/covoar/TraceReaderLogQEMU.h | 6 +++---
tester/covoar/app_common.cc | 1 -
tester/covoar/app_common.h | 1 -
tester/covoar/covoar.cc | 8 +++-----
8 files changed, 19 insertions(+), 22 deletions(-)
diff --git a/tester/covoar/ReportsBase.h b/tester/covoar/ReportsBase.h
index a2856e3..efc110d 100644
--- a/tester/covoar/ReportsBase.h
+++ b/tester/covoar/ReportsBase.h
@@ -402,7 +402,7 @@ class ReportsBase {
* @param[in] allExplanations is the explanations to report on.
void GenerateReports(
- const std::string& symbolSetName,
+ const std::string& symbolSetName,
Coverage::Explanations& allExplanations
diff --git a/tester/covoar/TraceConverter.cc b/tester/covoar/TraceConverter.cc
index 7015e28..cd64faf 100644
--- a/tester/covoar/TraceConverter.cc
+++ b/tester/covoar/TraceConverter.cc
@@ -89,6 +89,7 @@ int main(
Coverage::ExecutableInfo* executableInfo;
rld::process::tempfile objdumpFile( ".dmp" );
rld::process::tempfile err( ".err" );
+ Coverage::ObjdumpProcessor objdumpProcessor;
setup_signals();
@@ -133,14 +134,12 @@ int main(
else
executableInfo = new Coverage::ExecutableInfo( executable );
- objdumpProcessor = new Coverage::ObjdumpProcessor();
// If a dynamic library was specified, determine the load address.
if (dynamicLibrary)
executableInfo->setLoadAddress(
- objdumpProcessor->determineLoadAddress( executableInfo )
+ objdumpProcessor.determineLoadAddress( executableInfo )
- objdumpProcessor->loadAddressTable( executableInfo, objdumpFile, err );
- log.processFile( logname );
+ objdumpProcessor.loadAddressTable( executableInfo, objdumpFile, err );
+ log.processFile( logname, objdumpProcessor );
trace.writeFile( tracefile, &log );
diff --git a/tester/covoar/TraceReaderBase.h b/tester/covoar/TraceReaderBase.h
index 6ad488e..3005c62 100644
--- a/tester/covoar/TraceReaderBase.h
+++ b/tester/covoar/TraceReaderBase.h
@@ -8,6 +8,7 @@
#define __TRACE_READER_BASE_H__
#include "TraceList.h"
+#include "ObjdumpProcessor.h"
namespace Trace {
@@ -41,13 +42,13 @@ namespace Trace {
* @a file and adds it to the specified @a executableInformation.
* @param[in] file is the coverage file to process
- * @param[in] executableInformation is the information for an
- * associated executable
+ * @param[in] objdumpProcessor the processor for the object dump
* @return Returns TRUE if the method succeeded and FALSE if it failed.
virtual bool processFile(
- const char* const file
+ const char* const file,
+ Coverage::ObjdumpProcessor& objdumpProcessor
) = 0;
diff --git a/tester/covoar/TraceReaderLogQEMU.cc b/tester/covoar/TraceReaderLogQEMU.cc
index b64a149..0a61ea5 100644
--- a/tester/covoar/TraceReaderLogQEMU.cc
+++ b/tester/covoar/TraceReaderLogQEMU.cc
@@ -72,7 +72,8 @@ namespace Trace {
bool TraceReaderLogQEMU::processFile(
bool done = false;
@@ -160,7 +161,7 @@ namespace Trace {
} while( result > 1);
- nextlogical = objdumpProcessor->getAddressAfter(last.address);
+ nextlogical = objdumpProcessor.getAddressAfter(last.address);
if (! ReadUntilFound( logFile, QEMU_LOG_IN_KEY )) {
done = true;
@@ -185,7 +186,7 @@ namespace Trace {
if (nextlogical != 0) {
TraceList::exitReason_t reason = TraceList::EXIT_REASON_OTHER;
- if ( objdumpProcessor->IsBranch( last.instruction ) ) {
+ if ( objdumpProcessor.IsBranch( last.instruction ) ) {
if ( nextExecuted.address == nextlogical ) {
reason = TraceList::EXIT_REASON_BRANCH_NOT_TAKEN;
} else {
diff --git a/tester/covoar/TraceReaderLogQEMU.h b/tester/covoar/TraceReaderLogQEMU.h
index fb1d020..8ee5651 100644
--- a/tester/covoar/TraceReaderLogQEMU.h
+++ b/tester/covoar/TraceReaderLogQEMU.h
@@ -38,13 +38,13 @@ namespace Trace {
diff --git a/tester/covoar/app_common.cc b/tester/covoar/app_common.cc
index f878fb6..1c49c72 100644
--- a/tester/covoar/app_common.cc
+++ b/tester/covoar/app_common.cc
@@ -56,7 +56,6 @@
* Global variables for the program
-Coverage::ObjdumpProcessor* objdumpProcessor = NULL;
Coverage::DesiredSymbols* SymbolsToAnalyze = NULL;
bool Verbose = false;
const char* outputDirectory = ".";
diff --git a/tester/covoar/app_common.h b/tester/covoar/app_common.h
index 921bb71..eb250e8 100644
--- a/tester/covoar/app_common.h
+++ b/tester/covoar/app_common.h
@@ -12,7 +12,6 @@
#include "Explanations.h"
#include "TargetBase.h"
-extern Coverage::ObjdumpProcessor* objdumpProcessor;
extern Coverage::DesiredSymbols* SymbolsToAnalyze;
extern bool Verbose;
extern const char* outputDirectory;
diff --git a/tester/covoar/covoar.cc b/tester/covoar/covoar.cc
index 9295519..46ba348 100644
--- a/tester/covoar/covoar.cc
+++ b/tester/covoar/covoar.cc
@@ -175,6 +175,7 @@ int covoar(
std::string option;
int opt;
Coverage::Explanations allExplanations;
// Process command line options.
@@ -364,9 +365,6 @@ int covoar(
if (!coverageReader)
throw rld::error( "Unable to create coverage file reader", "covoar" );
- // Create the objdump processor.
// Prepare each executable for analysis.
for (auto& exe : executablesToAnalyze) {
if (Verbose)
@@ -375,11 +373,11 @@ int covoar(
if (dynamicLibrary) {
- exe->setLoadAddress( objdumpProcessor->determineLoadAddress( exe ) );
+ exe->setLoadAddress( objdumpProcessor.determineLoadAddress( exe ) );
// Load the objdump for the symbols in this executable.
- objdumpProcessor->load( exe, objdumpFile, err );
+ objdumpProcessor.load( exe, objdumpFile, err );
1.8.3.1
