[PATCH v1 07/13] Remove outputDirectory global variable
Ryan Long ryan.long at oarcorp.com
Sun Aug 1 23:23:41 UTC 2021
- Replaced outputDirectory in app_common with a local variable in
  covoar()
- Created the outputDirectory_m member variable
- Added parameters to Reports* constructors to initialize
  outputDirectory_m and non member functions
 tester/covoar/ReportsBase.cc | 41 ++++++++++++++++++++++++++---------------
 tester/covoar/ReportsBase.h  | 19 +++++++++++++++----
 tester/covoar/ReportsHtml.cc | 18 +++++++++++++++---
 tester/covoar/ReportsHtml.h  |  3 ++-
 tester/covoar/ReportsText.cc | 11 +++++++++--
 tester/covoar/ReportsText.h  |  3 ++-
 tester/covoar/app_common.cc  |  1 -
 tester/covoar/app_common.h   |  1 -
 tester/covoar/covoar.cc      |  4 +++-
 9 files changed, 72 insertions(+), 29 deletions(-)
diff --git a/tester/covoar/ReportsBase.cc b/tester/covoar/ReportsBase.cc
index b2da71a..266a6ea 100644
--- a/tester/covoar/ReportsBase.cc
+++ b/tester/covoar/ReportsBase.cc
@@ -27,12 +27,14 @@ ReportsBase::ReportsBase(
   time_t                  timestamp,
   const std::string&      symbolSetName,
   Coverage::Explanations& allExplanations,
-  const std::string&      projectName
+  const std::string&      projectName,
+  const std::string&      outputDirectory
 ): reportExtension_m( "" ),
    symbolSetName_m( symbolSetName ),
    timestamp_m( timestamp ),
    allExplanations_m( allExplanations ),
-   projectName_m( projectName )
+   projectName_m( projectName ),
+   outputDirectory_m( outputDirectory )
@@ -43,7 +45,8 @@ ReportsBase::~ReportsBase()
 void ReportsBase::OpenFile(
   const std::string& fileName,
-  std::ofstream&     aFile
+  std::ofstream&     aFile,
   int         sc;
@@ -89,7 +92,7 @@ void ReportsBase::OpenAnnotatedFile(
-  OpenFile(fileName, symbolSetName_m, aFile);
+  OpenFile( fileName, symbolSetName_m, aFile, outputDirectory_m );
 void ReportsBase::OpenBranchFile(
@@ -98,7 +101,7 @@ void ReportsBase::OpenBranchFile(
 void ReportsBase::OpenCoverageFile(
@@ -106,7 +109,7 @@ void ReportsBase::OpenCoverageFile(
 void ReportsBase::OpenNoRangeFile(
@@ -114,7 +117,7 @@ void ReportsBase::OpenNoRangeFile(
@@ -123,7 +126,7 @@ void ReportsBase::OpenSizeFile(
 void ReportsBase::OpenSymbolSummaryFile(
@@ -131,7 +134,7 @@ void ReportsBase::OpenSymbolSummaryFile(
 void ReportsBase::CloseFile( std::ofstream& aFile )
@@ -466,7 +469,8 @@ void ReportsBase::WriteSymbolSummaryReport( const std::string& fileName )
 void  ReportsBase::WriteSummaryReport(
-  const std::string& symbolSetName
+  const std::string& symbolSetName,
     // Calculate coverage statistics and output results.
@@ -480,7 +484,7 @@ void  ReportsBase::WriteSummaryReport(
   std::ofstream              report;
   // Open the report file.
-  OpenFile( fileName, symbolSetName, report );
+  OpenFile( fileName, symbolSetName, report, outputDirectory );
   if ( !report.is_open() ) {
     return;
@@ -568,7 +572,8 @@ void GenerateReports(
   bool                    verbose,
   typedef std::list<ReportsBase *> reportList_t;
@@ -585,14 +590,16 @@ void GenerateReports(
     timestamp,
     symbolSetName,
     allExplanations,
-    projectName
+    projectName,
+    outputDirectory
   reportList.push_back( reports );
   reports = new ReportsHtml(
     timestamp,
     symbolSetName,
     allExplanations,
-    projectName
+    projectName,
+    outputDirectory
@@ -641,7 +648,11 @@ void GenerateReports(
     delete reports;
-  ReportsBase::WriteSummaryReport( "summary.txt", symbolSetName );
+  ReportsBase::WriteSummaryReport(
+    "summary.txt",
+    symbolSetName,
+    outputDirectory
diff --git a/tester/covoar/ReportsBase.h b/tester/covoar/ReportsBase.h
index 38b7c29..a0c6a32 100644
--- a/tester/covoar/ReportsBase.h
+++ b/tester/covoar/ReportsBase.h
@@ -31,7 +31,8 @@ class ReportsBase {
       time_t                  timestamp,
     virtual ~ReportsBase();
@@ -87,7 +88,8 @@ class ReportsBase {
     static void  WriteSummaryReport(
@@ -136,17 +138,24 @@ class ReportsBase {
     std::string projectName_m;
+     *  This variable stores the output directory.
+    std::string outputDirectory_m = "";
      *  This method Opens a report file and verifies that it opened
      *  correctly.  Upon failure NULL is returned.
      *  @param[in] fileName identifies the report file name
      *  @param[in] symbolSetName identifies the name of the report's symbol set
      *  @param[in] aFile identifies the file to open
+     *  @param[in] outputDirectory identifies the directory for the output
     static void OpenFile(
@@ -408,12 +417,14 @@ class ReportsBase {
  *  @param[in] allExplanations is the explanations to report on.
  *  @param[in] verbose specifies whether to be verbose with output
  *  @param[in] projectName specifies the name of the project
+ *  @param[in] outputDirectory specifies the directory for the output
   bool                    verbose,
diff --git a/tester/covoar/ReportsHtml.cc b/tester/covoar/ReportsHtml.cc
index 4f384d5..89067f7 100644
--- a/tester/covoar/ReportsHtml.cc
+++ b/tester/covoar/ReportsHtml.cc
@@ -41,8 +41,15 @@ namespace Coverage {
     time_t                  timestamp,
-  ): ReportsBase( timestamp, symbolSetName, allExplanations, projectName )
+  ): ReportsBase(
+       timestamp,
+       symbolSetName,
+       allExplanations,
+       projectName,
+       outputDirectory
     reportExtension_m = ".html";
     lastState_m = A_SOURCE;
@@ -105,7 +112,12 @@ namespace Coverage {
     // Open the file
-    ReportsBase::OpenFile( fileName, symbolSetName_m, aFile );
+    ReportsBase::OpenFile(
+      fileName,
+      symbolSetName_m,
+      aFile,
+      outputDirectory_m
     // Put Header information on the file
     aFile << "<html>" << std::endl
diff --git a/tester/covoar/ReportsHtml.h b/tester/covoar/ReportsHtml.h
index 46698f0..53e1897 100644
--- a/tester/covoar/ReportsHtml.h
+++ b/tester/covoar/ReportsHtml.h
@@ -29,7 +29,8 @@ class ReportsHtml: public ReportsBase {
       time_t                  timestamp,
    ~ReportsHtml();
diff --git a/tester/covoar/ReportsText.cc b/tester/covoar/ReportsText.cc
index 7318de3..535bf76 100644
--- a/tester/covoar/ReportsText.cc
+++ b/tester/covoar/ReportsText.cc
@@ -20,8 +20,15 @@ ReportsText::ReportsText(
   time_t                  timestamp,
-): ReportsBase( timestamp, symbolSetName, allExplanations, projectName )
+): ReportsBase(
+     timestamp,
+     symbolSetName,
+     allExplanations,
+     projectName,
+     outputDirectory
   reportExtension_m = ".txt";
diff --git a/tester/covoar/ReportsText.h b/tester/covoar/ReportsText.h
index c44591d..b3ffd83 100644
--- a/tester/covoar/ReportsText.h
+++ b/tester/covoar/ReportsText.h
@@ -25,7 +25,8 @@ class ReportsText: public ReportsBase {
       time_t                  timestamp,
     virtual ~ReportsText();
diff --git a/tester/covoar/app_common.cc b/tester/covoar/app_common.cc
index cedffdd..6f88f4b 100644
--- a/tester/covoar/app_common.cc
+++ b/tester/covoar/app_common.cc
@@ -57,7 +57,6 @@
  *  Global variables for the program
 Coverage::DesiredSymbols*   SymbolsToAnalyze    = NULL;
-const char*                 outputDirectory     = ".";
 bool                        BranchInfoAvailable = false;
 Target::TargetBase*         TargetInfo          = NULL;
 char                        inputBuffer[MAX_LINE_LENGTH];
diff --git a/tester/covoar/app_common.h b/tester/covoar/app_common.h
index 533a926..473d259 100644
--- a/tester/covoar/app_common.h
+++ b/tester/covoar/app_common.h
@@ -13,7 +13,6 @@
 #include "TargetBase.h"
 extern Coverage::DesiredSymbols*    SymbolsToAnalyze;
-extern const char*                  outputDirectory;
 extern bool                         BranchInfoAvailable;
 extern Target::TargetBase*          TargetInfo;
diff --git a/tester/covoar/covoar.cc b/tester/covoar/covoar.cc
index 5f8de5b..2d161aa 100644
--- a/tester/covoar/covoar.cc
+++ b/tester/covoar/covoar.cc
@@ -179,6 +179,7 @@ int covoar(
   bool                          verbose = false;
   std::string                   dynamicLibrary;
   std::string                   projectName;
+  std::string                   outputDirectory = ".";
   // Process command line options.
@@ -479,7 +480,8 @@ int covoar(
       setName,
       allExplanations,
       verbose,
-      projectName
+      projectName,
+      outputDirectory
1.8.3.1
