[PATCH v1 08/13] Remove input buffer global variables
Ryan Long
ryan.long at oarcorp.com
Sun Aug 1 23:23:42 UTC 2021
- Removed input buffers from app_common and added them as a local variable
to functions where inputBuffer was being used
- Added #define for MAX_LINE_LENGTH in files where it is used
- Changed Explanations::load to use a string instead of a C-string
tester/covoar/Explanations.cc | 20 +++++++++-----------
tester/covoar/ObjdumpProcessor.cc | 3 +++
tester/covoar/TraceReaderLogQEMU.cc | 3 +++
tester/covoar/app_common.cc | 2 --
tester/covoar/app_common.h | 4 ----
tester/covoar/covoar.cc | 3 +++
6 files changed, 18 insertions(+), 17 deletions(-)
diff --git a/tester/covoar/Explanations.cc b/tester/covoar/Explanations.cc
index 681ffd6..0371666 100644
--- a/tester/covoar/Explanations.cc
+++ b/tester/covoar/Explanations.cc
@@ -31,7 +31,6 @@ namespace Coverage {
const char* const explanations
- #define MAX_LINE_LENGTH 512
std::ifstream explain;
Explanation e;
int line = 1;
@@ -46,44 +45,44 @@ namespace Coverage {
throw rld::error( what, "Explanations::load" );
+ std::string input_line;
while ( 1 ) {
// Read the starting line of this explanation and
// skip blank lines between
do {
- inputBuffer[0] = '\0';
- explain.getline( inputBuffer, MAX_LINE_LENGTH );
+ std::getline( explain, input_line );
if (explain.fail()) {
return;
line++;
- } while ( inputBuffer[0] == '\0' );
+ } while ( input_line.empty() );
// Have we already seen this one?
- if (set.find( inputBuffer ) != set.end()) {
+ if (set.find( input_line ) != set.end()) {
std::ostringstream what;
what << "line " << line
<< "contains a duplicate explanation ("
- << inputBuffer << ")";
+ << input_line << ")";
// Add the starting line and file
- e.startingPoint = std::string(inputBuffer);
+ e.startingPoint = input_line;
e.found = false;
// Get the classification
<< "out of sync at the classification";
- e.classification = inputBuffer;
+ e.classification = input_line;
line++;
// Get the explanation
- for (std::string input_line; std::getline( explain, input_line ); ) {
+ while ( std::getline( explain, input_line ) ) {
line++;
const std::string delimiter = "+++";
@@ -105,7 +104,6 @@ namespace Coverage {
set[ e.startingPoint ] = e;
- #undef MAX_LINE_LENGTH
const Explanation *Explanations::lookupExplanation(
diff --git a/tester/covoar/ObjdumpProcessor.cc b/tester/covoar/ObjdumpProcessor.cc
index 2bf1685..d324440 100644
--- a/tester/covoar/ObjdumpProcessor.cc
+++ b/tester/covoar/ObjdumpProcessor.cc
@@ -24,6 +24,8 @@
#include "rld.h"
#include "rld-process.h"
+#define MAX_LINE_LENGTH 512
void finalizeSymbol(
@@ -136,6 +138,7 @@ namespace Coverage {
FILE* loadAddressFile = NULL;
char* cStatus;
uint32_t offset;
+ char inputBuffer[MAX_LINE_LENGTH];
// This method should only be call for a dynamic library.
if (!theExecutable->hasDynamicLibrary())
diff --git a/tester/covoar/TraceReaderLogQEMU.cc b/tester/covoar/TraceReaderLogQEMU.cc
index 0a61ea5..37952a3 100644
--- a/tester/covoar/TraceReaderLogQEMU.cc
+++ b/tester/covoar/TraceReaderLogQEMU.cc
@@ -61,6 +61,8 @@
#define OPEN fopen
#endif
namespace Trace {
TraceReaderLogQEMU::TraceReaderLogQEMU()
@@ -85,6 +87,7 @@ namespace Trace {
int status;
FILE* logFile;
int result;
// Verify that the log file has a non-zero size.
diff --git a/tester/covoar/app_common.cc b/tester/covoar/app_common.cc
index 6f88f4b..53b5284 100644
--- a/tester/covoar/app_common.cc
+++ b/tester/covoar/app_common.cc
@@ -59,8 +59,6 @@
Coverage::DesiredSymbols* SymbolsToAnalyze = NULL;
bool BranchInfoAvailable = false;
Target::TargetBase* TargetInfo = NULL;
-char inputBuffer[MAX_LINE_LENGTH];
-char inputBuffer2[MAX_LINE_LENGTH];
bool FileIsNewer(
diff --git a/tester/covoar/app_common.h b/tester/covoar/app_common.h
index 473d259..4f3b798 100644
--- a/tester/covoar/app_common.h
+++ b/tester/covoar/app_common.h
@@ -16,10 +16,6 @@ extern Coverage::DesiredSymbols* SymbolsToAnalyze;
extern bool BranchInfoAvailable;
extern Target::TargetBase* TargetInfo;
-#define MAX_LINE_LENGTH 512
-extern char inputBuffer[MAX_LINE_LENGTH];
-extern char inputBuffer2[MAX_LINE_LENGTH];
bool FileIsNewer( const char *f1, const char *f2 );
bool FileIsReadable( const char *f1 );
diff --git a/tester/covoar/covoar.cc b/tester/covoar/covoar.cc
index 2d161aa..8ee3eb8 100644
--- a/tester/covoar/covoar.cc
+++ b/tester/covoar/covoar.cc
@@ -34,6 +34,8 @@
#define kill(p,s) raise(s)
#endif
typedef std::list<std::string> CoverageNames;
typedef std::list<Coverage::ExecutableInfo*> Executables;
typedef std::string option_error;
@@ -174,6 +176,7 @@ int covoar(
std::string symbolSet;
std::string option;
int opt;
Coverage::Explanations allExplanations;
Coverage::ObjdumpProcessor objdumpProcessor;
bool verbose = false;
1.8.3.1
