[PATCH v1 09/13] Remove SymbolsToAnalyze global variable
Ryan Long
ryan.long at oarcorp.com
Sun Aug 1 23:23:43 UTC 2021
- Removed SymbolsToAnalyze from app_common and replaced it with the
symbolsToAnalyze_m member variable in DesiredSymbols, GcovData, and
ObjdumpProcessor
- Added a parameter to constructors to initialize symbolsToAnalyze_m
- Moved the definition of objdumpLine_t out of ObjdumpProcessor to make
it work with DesiredSymbols
tester/covoar/DesiredSymbols.cc | 12 +++--
tester/covoar/DesiredSymbols.h | 17 +++++--
tester/covoar/ExecutableInfo.cc | 14 +++---
tester/covoar/ExecutableInfo.h | 14 +++++-
tester/covoar/GcovData.cc | 7 +--
tester/covoar/GcovData.h | 12 ++++-
tester/covoar/GcovFunctionData.cc | 14 ++++--
tester/covoar/GcovFunctionData.h | 6 ++-
tester/covoar/ObjdumpProcessor.cc | 22 +++++----
tester/covoar/ObjdumpProcessor.h | 90 +++++++++++++++++++----------------
tester/covoar/ReportsBase.cc | 98 +++++++++++++++++++++------------------
tester/covoar/ReportsBase.h | 33 +++++++++----
tester/covoar/ReportsHtml.cc | 16 ++++---
tester/covoar/ReportsHtml.h | 11 +++--
tester/covoar/ReportsText.cc | 8 ++--
tester/covoar/ReportsText.h | 3 +-
tester/covoar/TraceConverter.cc | 17 +++++--
tester/covoar/app_common.cc | 1 -
tester/covoar/app_common.h | 1 -
tester/covoar/covoar.cc | 40 +++++++++-------
20 files changed, 271 insertions(+), 165 deletions(-)
diff --git a/tester/covoar/DesiredSymbols.cc b/tester/covoar/DesiredSymbols.cc
index 5d5e637..d76c5af 100644
--- a/tester/covoar/DesiredSymbols.cc
+++ b/tester/covoar/DesiredSymbols.cc
@@ -25,7 +25,6 @@
#include "DesiredSymbols.h"
#include "app_common.h"
#include "CoverageMap.h"
-#include "ObjdumpProcessor.h"
namespace Coverage {
@@ -116,10 +115,10 @@ namespace Coverage {
- void DesiredSymbols::preprocess( void )
+ void DesiredSymbols::preprocess( const DesiredSymbols& symbolsToAnalyze )
// Look at each symbol.
- for (auto& s : SymbolsToAnalyze->set) {
+ for (auto& s : symbolsToAnalyze.set) {
// If the unified coverage map does not exist, the symbol was
// never referenced by any executable. Just skip it.
CoverageMapBase* theCoverageMap = s.second.unifiedCoverageMap;
@@ -441,10 +440,13 @@ namespace Coverage {
return &set[ symbolName ];
- void DesiredSymbols::findSourceForUncovered( bool verbose )
+ void DesiredSymbols::findSourceForUncovered(
+ bool verbose,
+ const DesiredSymbols& symbolsToAnalyze
// Process uncovered ranges and/or branches for each symbol.
- for (auto& d : SymbolsToAnalyze->set) {
+ for (auto& d : symbolsToAnalyze.set) {
// First the unexecuted ranges, ...
CoverageRanges* theRanges = d.second.uncoveredRanges;
if (theRanges != nullptr) {
diff --git a/tester/covoar/DesiredSymbols.h b/tester/covoar/DesiredSymbols.h
index 791b4ea..70bc39b 100644
--- a/tester/covoar/DesiredSymbols.h
+++ b/tester/covoar/DesiredSymbols.h
@@ -19,6 +19,11 @@
+ class ObjdumpProcessor;
+ struct objdumpLine;
+ using objdumpLine_t = objdumpLine;
+ class ExecutableInfo;
@@ -139,7 +144,7 @@ namespace Coverage {
* This member contains the disassembly associated with a symbol.
- std::list<ObjdumpProcessor::objdumpLine_t> instructions;
+ std::list<objdumpLine_t> instructions;
* This member contains the executable that was used to
@@ -263,8 +268,12 @@ namespace Coverage {
* uncovered ranges or branches.
* @param[in] verbose specifies whether to be verbose with output
+ * @param[in] symbolsToAnalyze the symbols to be analyzed
- void findSourceForUncovered( bool verbose );
+ void findSourceForUncovered(
+ bool verbose,
* This method returns the total number of branches always taken
@@ -398,8 +407,10 @@ namespace Coverage {
* This method preprocesses each symbol's coverage map to mark nop
* and branch information.
- void preprocess( void );
+ void preprocess( const DesiredSymbols& symbolsToAnalyze );
private:
diff --git a/tester/covoar/ExecutableInfo.cc b/tester/covoar/ExecutableInfo.cc
index 9c3031e..328f970 100644
--- a/tester/covoar/ExecutableInfo.cc
+++ b/tester/covoar/ExecutableInfo.cc
@@ -10,9 +10,9 @@
#include <rld.h>
#include "ExecutableInfo.h"
+#include "ObjdumpProcessor.h"
-#include "DesiredSymbols.h"
#include "SymbolTable.h"
@@ -20,9 +20,11 @@ namespace Coverage {
ExecutableInfo::ExecutableInfo(
const char* const theExecutableName,
const std::string& theLibraryName,
- bool verbose
+ bool verbose,
+ DesiredSymbols& symbolsToAnalyze
) : fileName(theExecutableName),
- loadAddress(0)
+ loadAddress(0),
+ symbolsToAnalyze_m(symbolsToAnalyze)
if ( !theLibraryName.empty() )
libraryName = theLibraryName;
@@ -59,7 +61,7 @@ namespace Coverage {
continue;
- if (!SymbolsToAnalyze->isDesired(func.name())) {
+ if (!symbolsToAnalyze_m.isDesired(func.name())) {
continue;
@@ -209,8 +211,8 @@ namespace Coverage {
void ExecutableInfo::mergeCoverage( void ) {
for (auto& cm : coverageMaps) {
- if (SymbolsToAnalyze->isDesired( cm.first ))
- SymbolsToAnalyze->mergeCoverageMap( cm.first, cm.second );
+ if (symbolsToAnalyze_m.isDesired( cm.first ))
+ symbolsToAnalyze_m.mergeCoverageMap( cm.first, cm.second );
diff --git a/tester/covoar/ExecutableInfo.h b/tester/covoar/ExecutableInfo.h
index 851a59d..0adebcb 100644
--- a/tester/covoar/ExecutableInfo.h
+++ b/tester/covoar/ExecutableInfo.h
@@ -18,9 +18,12 @@
#include "AddressToLineMapper.h"
#include "CoverageMapBase.h"
+#include "DesiredSymbols.h"
+class DesiredSymbols;
/*! @class ExecutableInfo
* This class holds a collection of information for an executable
@@ -41,11 +44,13 @@ namespace Coverage {
* @param[in] theExecutableName specifies the name of the executable
* @param[in] theLibraryName specifies the name of the executable
ExecutableInfo(
- const std::string& theLibraryName = "",
- bool verbose = false
+ const std::string& theLibraryName,
+ bool verbose,
@@ -198,6 +203,11 @@ namespace Coverage {
SymbolTable theSymbolTable;
+ * This member variable contains the symbols to be analyzed.
+ DesiredSymbols& symbolsToAnalyze_m;
#endif
diff --git a/tester/covoar/GcovData.cc b/tester/covoar/GcovData.cc
index e8b8573..11c26ce 100644
--- a/tester/covoar/GcovData.cc
+++ b/tester/covoar/GcovData.cc
@@ -25,9 +25,10 @@
namespace Gcov {
- GcovData::GcovData()
+ GcovData::GcovData( Coverage::DesiredSymbols& symbolsToAnalyze ):
+ numberOfFunctions( 0 ),
+ symbolsToAnalyze_m( symbolsToAnalyze )
- numberOfFunctions = 0;
GcovData::~GcovData()
@@ -416,7 +417,7 @@ namespace Gcov {
function->setChecksum( intBuffer[1] );
header.length -= readString( buffer, gcovFile );
- function->setFunctionName( buffer );
+ function->setFunctionName( buffer, symbolsToAnalyze_m );
function->setFileName( buffer );
status = fread( &intBuffer, 4, header.length, gcovFile );
diff --git a/tester/covoar/GcovData.h b/tester/covoar/GcovData.h
index 0e74b02..b00b27a 100644
--- a/tester/covoar/GcovData.h
+++ b/tester/covoar/GcovData.h
@@ -11,6 +11,7 @@
#include <list>
#include <iostream>
#include "GcovFunctionData.h"
namespace Gcov {
@@ -56,6 +57,8 @@ struct gcov_statistics
uint64_t sumMax; // sum of individual runs max values
/*! @class GcovData
* This is the specification of the GcovData class.
@@ -66,8 +69,10 @@ struct gcov_statistics
* This method constructs a GcnoReader instance.
- GcovData();
+ GcovData( Coverage::DesiredSymbols& symbolsToAnalyze );
* This method destructs a GcnoReader instance.
@@ -194,6 +199,11 @@ struct gcov_statistics
* to a specified report file
void printGcnoFileInfo( FILE * textFile );
+ Coverage::DesiredSymbols& symbolsToAnalyze_m;
#endif
diff --git a/tester/covoar/GcovFunctionData.cc b/tester/covoar/GcovFunctionData.cc
index 90b1be0..1767f18 100644
--- a/tester/covoar/GcovFunctionData.cc
+++ b/tester/covoar/GcovFunctionData.cc
@@ -13,6 +13,7 @@
namespace Gcov {
@@ -44,7 +45,10 @@ namespace Gcov {
firstLineNumber = lineNo;
- bool GcovFunctionData::setFunctionName( const char* fcnName )
+ bool GcovFunctionData::setFunctionName(
+ const char* fcnName,
std::string symbolName;
@@ -62,7 +66,7 @@ namespace Gcov {
strcpy (functionName, fcnName);
// Tie function to its coverage map
- symbolInfo = SymbolsToAnalyze->find( symbolName );
+ symbolInfo = symbolsToAnalyze.find( symbolName );
if ( symbolInfo != NULL )
coverageMap = symbolInfo->unifiedCoverageMap;
@@ -237,7 +241,7 @@ namespace Gcov {
uint32_t baseAddress = 0;
uint32_t baseSize;
uint32_t currentAddress;
- std::list<Coverage::ObjdumpProcessor::objdumpLine_t>::iterator instruction;
+ std::list<Coverage::objdumpLine_t>::iterator instruction;
if ( coverageMap != NULL ) {
@@ -399,7 +403,7 @@ namespace Gcov {
uint32_t currentAddress = 0;
blocks_iterator_t blockIterator;
blocks_iterator_t blockIterator2;
arcs_iterator_t arcIterator;
@@ -567,7 +571,7 @@ namespace Gcov {
if ( coverageMap == NULL )
return false;
diff --git a/tester/covoar/GcovFunctionData.h b/tester/covoar/GcovFunctionData.h
index 812b45c..7d87b55 100644
--- a/tester/covoar/GcovFunctionData.h
+++ b/tester/covoar/GcovFunctionData.h
@@ -44,6 +44,8 @@ typedef std::list<gcov_arc_info>::iterator arcs_iterator_t;
typedef std::list<gcov_block_info> blocks_t;
typedef std::list<gcov_block_info>::iterator blocks_iterator_t;
/*! @class GcovFunctionData
* This is the specification of the GcovFunctionData class.
@@ -94,11 +96,13 @@ typedef std::list<gcov_block_info>::iterator blocks_iterator_t;
* unified coverage map.
* @param[in] functionName passes name of the the function
* @return Returns TRUE if the method succeeded and FALSE if it failed.
bool setFunctionName(
- const char* fcnName
diff --git a/tester/covoar/ObjdumpProcessor.cc b/tester/covoar/ObjdumpProcessor.cc
index d324440..f590ece 100644
--- a/tester/covoar/ObjdumpProcessor.cc
+++ b/tester/covoar/ObjdumpProcessor.cc
@@ -32,7 +32,8 @@ namespace Coverage {
ExecutableInfo* const executableInfo,
std::string& symbolName,
ObjdumpProcessor::objdumpLines_t instructions,
- bool verbose
+ bool verbose,
// Find the symbol's coverage map.
try {
@@ -88,7 +89,7 @@ namespace Coverage {
// If there are NOT already saved instructions, save them.
- SymbolInformation* symbolInfo = SymbolsToAnalyze->find( symbolName );
+ SymbolInformation* symbolInfo = symbolsToAnalyze.find( symbolName );
if (symbolInfo->instructions.empty()) {
symbolInfo->sourceFile = executableInfo;
symbolInfo->baseAddress = lowAddress;
@@ -107,7 +108,7 @@ namespace Coverage {
// Create a unified coverage map for the symbol.
- SymbolsToAnalyze->createCoverageMap(
+ symbolsToAnalyze.createCoverageMap(
executableInfo->getFileName().c_str(),
symbolName,
size,
@@ -122,7 +123,9 @@ namespace Coverage {
- ObjdumpProcessor::ObjdumpProcessor()
+ ObjdumpProcessor::ObjdumpProcessor(
+ ): symbolsToAnalyze_m( symbolsToAnalyze )
@@ -363,7 +366,8 @@ namespace Coverage {
executableInformation,
currentSymbol,
theInstructions,
- verbose
+ verbose,
fprintf(
stderr,
@@ -419,7 +423,8 @@ namespace Coverage {
currentSymbol,
theInstructions,
- verbose
+ verbose,
@@ -444,7 +449,7 @@ namespace Coverage {
// See if the new symbol is one that we care about.
- if (SymbolsToAnalyze->isDesired( symbol )) {
+ if (symbolsToAnalyze_m.isDesired( symbol )) {
currentSymbol = symbol;
processSymbol = true;
theInstructions.push_back( lineInfo );
@@ -462,7 +467,8 @@ namespace Coverage {
currentSymbol,
theInstructions,
- verbose
+ verbose,
processSymbol = false;
diff --git a/tester/covoar/ObjdumpProcessor.h b/tester/covoar/ObjdumpProcessor.h
index d60a768..c7fc8bb 100644
--- a/tester/covoar/ObjdumpProcessor.h
+++ b/tester/covoar/ObjdumpProcessor.h
@@ -12,11 +12,54 @@
#include "TargetBase.h"
#include "rld-process.h"
+ class DesiredSymbols;
+ * This type defines the elements of an objdump line.
+ typedef struct objdumpLine {
+ * This member variable contains the actual line from the object dump.
+ std::string line;
+ * This member variable contains the address from the object dump line.
+ uint32_t address;
+ * This member variable contains an indication of whether the line
+ * is an instruction.
+ bool isInstruction;
+ * is a nop instruction.
+ bool isNop;
+ * This member variable contains the size of the nop instruction.
+ int nopSize;
+ * is a branch instruction.
+ bool isBranch;
+ } objdumpLine_t;
/*! @class ObjdumpProcessor
* This class implements the functionality which reads the output of
@@ -32,45 +75,6 @@ namespace Coverage {
public:
- * This type defines the elements of an objdump line.
- typedef struct {
- * This member variable contains the actual line from the object dump.
- std::string line;
- * This member variable contains the address from the object dump line.
- uint32_t address;
- * This member variable contains an indication of whether the line
- * is an instruction.
- bool isInstruction;
- * is a nop instruction.
- bool isNop;
- * This member variable contains the size of the nop instruction.
- int nopSize;
- * is a branch instruction.
- bool isBranch;
- } objdumpLine_t;
* This object defines a list of object dump lines
* for a file.
@@ -86,7 +90,9 @@ namespace Coverage {
* This method constructs an ObjdumpProcessor instance.
- ObjdumpProcessor();
+ ObjdumpProcessor(
* This method destructs an ObjdumpProcessor instance.
@@ -169,6 +175,10 @@ namespace Coverage {
int& size
#endif
diff --git a/tester/covoar/ReportsBase.cc b/tester/covoar/ReportsBase.cc
index 266a6ea..11c22c9 100644
--- a/tester/covoar/ReportsBase.cc
+++ b/tester/covoar/ReportsBase.cc
@@ -28,13 +28,15 @@ ReportsBase::ReportsBase(
const std::string& symbolSetName,
Coverage::Explanations& allExplanations,
const std::string& projectName,
- const std::string& outputDirectory
+ const std::string& outputDirectory,
): reportExtension_m( "" ),
symbolSetName_m( symbolSetName ),
timestamp_m( timestamp ),
allExplanations_m( allExplanations ),
projectName_m( projectName ),
- outputDirectory_m( outputDirectory )
+ outputDirectory_m( outputDirectory ),
@@ -213,11 +215,11 @@ void ReportsBase::WriteAnnotatedReport( const std::string& fileName )
// Process uncovered branches for each symbol.
const std::vector<std::string>& symbols =
- SymbolsToAnalyze->getSymbolsForSet( symbolSetName_m );
+ symbolsToAnalyze_m.getSymbolsForSet( symbolSetName_m );
for ( const auto& symbol : symbols ) {
const SymbolInformation& info =
- SymbolsToAnalyze->allSymbols().at( symbol );
+ symbolsToAnalyze_m.allSymbols().at( symbol );
// If uncoveredRanges and uncoveredBranches don't exist, then the
// symbol was never referenced by any executable. Just skip it.
@@ -308,7 +310,7 @@ void ReportsBase::WriteBranchReport( const std::string& fileName )
bool hasBranches = true;
if (
- ( SymbolsToAnalyze->getNumberBranchesFound( symbolSetName_m ) == 0 ) ||
+ ( symbolsToAnalyze_m.getNumberBranchesFound( symbolSetName_m ) == 0 ) ||
( BranchInfoAvailable == false )
hasBranches = false;
@@ -322,17 +324,17 @@ void ReportsBase::WriteBranchReport( const std::string& fileName )
// If no branches were found then branch coverage is not supported
if (
- ( SymbolsToAnalyze->getNumberBranchesFound( symbolSetName_m ) != 0 ) &&
+ ( symbolsToAnalyze_m.getNumberBranchesFound( symbolSetName_m ) != 0 ) &&
( BranchInfoAvailable == true )
// Process uncovered branches for each symbol in the set.
count = 0;
theBranches = info.uncoveredBranches;
@@ -375,12 +377,12 @@ void ReportsBase::WriteCoverageReport( const std::string& fileName )
// Process uncovered ranges for each symbol.
count = 0;
theRanges = info.uncoveredRanges;
@@ -420,12 +422,12 @@ void ReportsBase::WriteSizeReport( const std::string& fileName )
count = 0;
@@ -440,7 +442,10 @@ void ReportsBase::WriteSizeReport( const std::string& fileName )
CloseSizeFile( report );
-void ReportsBase::WriteSymbolSummaryReport( const std::string& fileName )
+void ReportsBase::WriteSymbolSummaryReport(
+ const std::string& fileName,
std::ofstream report;
unsigned int count;
@@ -453,12 +458,12 @@ void ReportsBase::WriteSymbolSummaryReport( const std::string& fileName )
// Process each symbol.
count = 0;
PutSymbolSummaryLine( report, count, symbol, info );
count++;
@@ -468,9 +473,10 @@ void ReportsBase::WriteSymbolSummaryReport( const std::string& fileName )
void ReportsBase::WriteSummaryReport(
- const std::string& fileName,
- const std::string& symbolSetName,
+ const std::string& symbolSetName,
+ const Coverage::DesiredSymbols& symbolsToAnalyze
// Calculate coverage statistics and output results.
@@ -491,10 +497,10 @@ void ReportsBase::WriteSummaryReport(
- SymbolsToAnalyze->getSymbolsForSet( symbolSetName );
+ symbolsToAnalyze.getSymbolsForSet( symbolSetName );
- SymbolInformation info = SymbolsToAnalyze->allSymbols().at( symbol );
+ SymbolInformation info = symbolsToAnalyze.allSymbols().at( symbol );
// If the symbol's unified coverage map exists, scan through it
// and count bytes.
@@ -518,12 +524,12 @@ void ReportsBase::WriteSummaryReport(
percentageBranches = (double) (
- SymbolsToAnalyze->getNumberBranchesAlwaysTaken( symbolSetName ) +
- SymbolsToAnalyze->getNumberBranchesNeverTaken( symbolSetName ) +
- ( SymbolsToAnalyze->getNumberBranchesNotExecuted( symbolSetName ) * 2 )
+ symbolsToAnalyze.getNumberBranchesAlwaysTaken( symbolSetName ) +
+ symbolsToAnalyze.getNumberBranchesNeverTaken( symbolSetName ) +
+ ( symbolsToAnalyze.getNumberBranchesNotExecuted( symbolSetName ) * 2 )
percentageBranches /=
- (double) SymbolsToAnalyze->getNumberBranchesFound( symbolSetName ) * 2;
+ (double) symbolsToAnalyze.getNumberBranchesFound( symbolSetName ) * 2;
percentageBranches *= 100.0;
report << "Bytes Analyzed : " << totalBytes << std::endl
@@ -533,31 +539,31 @@ void ReportsBase::WriteSummaryReport(
<< 100.0 - percentage << std::endl
<< "Percentage Not Executed : " << percentage << std::endl
<< "Unreferenced Symbols : "
- << SymbolsToAnalyze->getNumberUnreferencedSymbols( symbolSetName )
+ << symbolsToAnalyze.getNumberUnreferencedSymbols( symbolSetName )
<< std::endl << "Uncovered ranges found : "
- << SymbolsToAnalyze->getNumberUncoveredRanges( symbolSetName )
+ << symbolsToAnalyze.getNumberUncoveredRanges( symbolSetName )
<< std::endl << std::endl;
if (
- ( SymbolsToAnalyze->getNumberBranchesFound( symbolSetName ) == 0 ) ||
+ ( symbolsToAnalyze.getNumberBranchesFound( symbolSetName ) == 0 ) ||
report << "No branch information available" << std::endl;
} else {
report << "Total conditional branches found : "
- << SymbolsToAnalyze->getNumberBranchesFound( symbolSetName )
+ << symbolsToAnalyze.getNumberBranchesFound( symbolSetName )
<< std::endl << "Total branch paths found : "
- << SymbolsToAnalyze->getNumberBranchesFound( symbolSetName ) * 2
+ << symbolsToAnalyze.getNumberBranchesFound( symbolSetName ) * 2
<< std::endl << "Uncovered branch paths found : "
- << SymbolsToAnalyze->getNumberBranchesAlwaysTaken( symbolSetName ) +
+ << symbolsToAnalyze.getNumberBranchesAlwaysTaken( symbolSetName ) +
<< std::endl << " "
<< " branches always taken" << std::endl << " "
- << SymbolsToAnalyze->getNumberBranchesNeverTaken( symbolSetName )
+ << symbolsToAnalyze.getNumberBranchesNeverTaken( symbolSetName )
<< " branches never taken" << std::endl << " "
- << SymbolsToAnalyze->getNumberBranchesNotExecuted( symbolSetName ) * 2
+ << symbolsToAnalyze.getNumberBranchesNotExecuted( symbolSetName ) * 2
<< " branch paths not executed" << std::endl
<< "Percentage branch paths covered : "
<< std::fixed << std::setprecision( 2 ) << std::setw( 4 )
@@ -569,11 +575,12 @@ void ReportsBase::WriteSummaryReport(
void GenerateReports(
- Coverage::Explanations& allExplanations,
- bool verbose,
- const std::string& projectName,
+ Coverage::Explanations& allExplanations,
+ bool verbose,
+ const std::string& projectName,
typedef std::list<ReportsBase *> reportList_t;
@@ -591,7 +598,8 @@ void GenerateReports(
symbolSetName,
allExplanations,
projectName,
- outputDirectory
+ outputDirectory,
+ symbolsToAnalyze
reportList.push_back( reports );
reports = new ReportsHtml(
@@ -599,7 +607,8 @@ void GenerateReports(
symbolSetName,
allExplanations,
projectName,
- outputDirectory
+ outputDirectory,
+ symbolsToAnalyze
@@ -640,7 +649,7 @@ void GenerateReports(
if ( verbose ) {
std::cerr << "Generate " << reportName << std::endl;
- reports->WriteSymbolSummaryReport( reportName );
+ reports->WriteSymbolSummaryReport( reportName, symbolsToAnalyze );
for ( ritr = reportList.begin(); ritr != reportList.end(); ritr++ ) {
@@ -651,7 +660,8 @@ void GenerateReports(
"summary.txt",
symbolSetName,
- outputDirectory
+ outputDirectory,
+ symbolsToAnalyze
diff --git a/tester/covoar/ReportsBase.h b/tester/covoar/ReportsBase.h
index a0c6a32..a6cf3bc 100644
--- a/tester/covoar/ReportsBase.h
+++ b/tester/covoar/ReportsBase.h
@@ -32,7 +32,8 @@ class ReportsBase {
virtual ~ReportsBase();
@@ -80,16 +81,21 @@ class ReportsBase {
* each symbol which did not achieve 100% coverage
* @param[in] fileName identifies the report file name
- void WriteSymbolSummaryReport( const std::string& fileName );
+ void WriteSymbolSummaryReport(
* This method produces a sumary report for the overall test run.
static void WriteSummaryReport(
@@ -143,6 +149,11 @@ class ReportsBase {
std::string outputDirectory_m = "";
+ const Coverage::DesiredSymbols& symbolsToAnalyze_m;
* This method Opens a report file and verifies that it opened
* correctly. Upon failure NULL is returned.
@@ -418,13 +429,15 @@ class ReportsBase {
* @param[in] projectName specifies the name of the project
* @param[in] outputDirectory specifies the directory for the output
- bool verbose,
+ bool verbose,
diff --git a/tester/covoar/ReportsHtml.cc b/tester/covoar/ReportsHtml.cc
index 89067f7..2142139 100644
--- a/tester/covoar/ReportsHtml.cc
+++ b/tester/covoar/ReportsHtml.cc
@@ -38,17 +38,19 @@ typedef rtems::utils::ostream_guard ostream_guard;
ReportsHtml::ReportsHtml(
- time_t timestamp,
+ time_t timestamp,
): ReportsBase(
timestamp,
symbolSetName,
allExplanations,
projectName,
- outputDirectory
+ outputDirectory,
+ symbolsToAnalyze
reportExtension_m = ".html";
@@ -441,7 +443,7 @@ namespace Coverage {
if (
BranchInfoAvailable &&
- SymbolsToAnalyze->getNumberBranchesFound( symbolSetName_m ) != 0
+ symbolsToAnalyze_m.getNumberBranchesFound( symbolSetName_m ) != 0
report << "All branch paths taken." << std::endl;
} else {
diff --git a/tester/covoar/ReportsHtml.h b/tester/covoar/ReportsHtml.h
index 53e1897..e9df060 100644
--- a/tester/covoar/ReportsHtml.h
+++ b/tester/covoar/ReportsHtml.h
@@ -26,11 +26,12 @@ class ReportsHtml: public ReportsBase {
public:
ReportsHtml(
- time_t timestamp,
+ time_t timestamp,
~ReportsHtml();
diff --git a/tester/covoar/ReportsText.cc b/tester/covoar/ReportsText.cc
index 535bf76..ab2b5f7 100644
--- a/tester/covoar/ReportsText.cc
+++ b/tester/covoar/ReportsText.cc
@@ -21,13 +21,15 @@ ReportsText::ReportsText(
): ReportsBase(
timestamp,
symbolSetName,
allExplanations,
projectName,
- outputDirectory
+ outputDirectory,
+ symbolsToAnalyze
reportExtension_m = ".txt";
@@ -61,7 +63,7 @@ bool ReportsText::PutNoBranchInfo( std::ofstream& report )
if (
} else {
diff --git a/tester/covoar/ReportsText.h b/tester/covoar/ReportsText.h
index b3ffd83..0d993c0 100644
--- a/tester/covoar/ReportsText.h
+++ b/tester/covoar/ReportsText.h
@@ -26,7 +26,8 @@ class ReportsText: public ReportsBase {
virtual ~ReportsText();
diff --git a/tester/covoar/TraceConverter.cc b/tester/covoar/TraceConverter.cc
index c997702..67edd11 100644
--- a/tester/covoar/TraceConverter.cc
+++ b/tester/covoar/TraceConverter.cc
@@ -89,9 +89,10 @@ int main(
Coverage::ExecutableInfo* executableInfo;
rld::process::tempfile objdumpFile( ".dmp" );
rld::process::tempfile err( ".err" );
- Coverage::ObjdumpProcessor objdumpProcessor;
+ Coverage::DesiredSymbols symbolsToAnalyze;
bool verbose = false;
std::string dynamicLibrary;
+ Coverage::ObjdumpProcessor objdumpProcessor( symbolsToAnalyze );
setup_signals();
@@ -132,9 +133,19 @@ int main(
TargetInfo = Target::TargetFactory( cpuname );
if ( !dynamicLibrary.empty() )
- executableInfo = new Coverage::ExecutableInfo( executable, dynamicLibrary );
+ executableInfo = new Coverage::ExecutableInfo(
+ executable,
+ dynamicLibrary,
+ false,
+ symbolsToAnalyze
else
- executableInfo = new Coverage::ExecutableInfo( executable );
+ executable,
+ false,
+ symbolsToAnalyze
// If a dynamic library was specified, determine the load address.
diff --git a/tester/covoar/app_common.cc b/tester/covoar/app_common.cc
index 53b5284..847fbf8 100644
--- a/tester/covoar/app_common.cc
+++ b/tester/covoar/app_common.cc
@@ -56,7 +56,6 @@
* Global variables for the program
-Coverage::DesiredSymbols* SymbolsToAnalyze = NULL;
bool BranchInfoAvailable = false;
Target::TargetBase* TargetInfo = NULL;
diff --git a/tester/covoar/app_common.h b/tester/covoar/app_common.h
index 4f3b798..0cef74a 100644
--- a/tester/covoar/app_common.h
+++ b/tester/covoar/app_common.h
@@ -12,7 +12,6 @@
#include "Explanations.h"
-extern Coverage::DesiredSymbols* SymbolsToAnalyze;
extern bool BranchInfoAvailable;
extern Target::TargetBase* TargetInfo;
diff --git a/tester/covoar/covoar.cc b/tester/covoar/covoar.cc
index 8ee3eb8..16cc4e1 100644
--- a/tester/covoar/covoar.cc
+++ b/tester/covoar/covoar.cc
@@ -178,11 +178,12 @@ int covoar(
int opt;
char inputBuffer[MAX_LINE_LENGTH];
Coverage::Explanations allExplanations;
std::string projectName;
std::string outputDirectory = ".";
// Process command line options.
@@ -278,13 +279,10 @@ int covoar(
// Create data based on target.
TargetInfo = Target::TargetFactory( buildTarget );
- // Create the set of desired symbols.
- SymbolsToAnalyze = new Coverage::DesiredSymbols();
// Read symbol configuration file and load needed symbols.
- SymbolsToAnalyze->load( symbolSet, buildTarget, buildBSP, verbose );
+ symbolsToAnalyze.load( symbolSet, buildTarget, buildBSP, verbose );
// If a single executable was specified, process the remaining
// arguments as coverage file names.
@@ -311,11 +309,17 @@ int covoar(
if (!coverageFileNames.empty()) {
if ( !dynamicLibrary.empty() ) {
- singleExecutable, dynamicLibrary, verbose
+ singleExecutable,
+ dynamicLibrary,
+ verbose,
+ symbolsToAnalyze
} else {
- singleExecutable, "", verbose
+ singleExecutable,
+ verbose,
+ symbolsToAnalyze
@@ -339,7 +343,10 @@ int covoar(
<< std::endl;
} else {
- argv[i], "", verbose
+ argv[i],
+ verbose,
+ symbolsToAnalyze
executablesToAnalyze.push_back( executableInfo );
coverageFileNames.push_back( coverageFileName );
@@ -359,7 +366,7 @@ int covoar(
throw rld::error( "executables and coverage name size mismatch", "covoar" );
if ( verbose )
- std::cerr << "Analyzing " << SymbolsToAnalyze->allSymbols().size()
+ std::cerr << "Analyzing " << symbolsToAnalyze.allSymbols().size()
<< " symbols" << std::endl;
// Create explanations.
@@ -418,7 +425,7 @@ int covoar(
if (verbose)
std::cerr << "Preprocess uncovered ranges and branches" << std::endl;
- SymbolsToAnalyze->preprocess();
+ symbolsToAnalyze.preprocess( symbolsToAnalyze );
// Generate Gcov reports
@@ -433,7 +440,7 @@ int covoar(
std::cerr << "Unable to open " << gcnosFileName << std::endl;
else {
while ( fscanf( gcnosFile, "%s", inputBuffer ) != EOF) {
- gcovFile = new Gcov::GcovData();
+ gcovFile = new Gcov::GcovData( symbolsToAnalyze );
strcpy( gcnoFileName, inputBuffer );
if ( verbose )
@@ -457,20 +464,20 @@ int covoar(
if (verbose)
std::cerr << "Computing uncovered ranges and branches" << std::endl;
- SymbolsToAnalyze->computeUncovered( verbose );
+ symbolsToAnalyze.computeUncovered( verbose );
// Calculate remainder of statistics.
if (verbose)
std::cerr << "Calculate statistics" << std::endl;
- SymbolsToAnalyze->calculateStatistics();
+ symbolsToAnalyze.calculateStatistics();
// Look up the source lines for any uncovered ranges and branches.
if (verbose)
std::cerr << "Looking up source lines for uncovered ranges and branches"
<< std::endl;
- SymbolsToAnalyze->findSourceForUncovered( verbose );
+ symbolsToAnalyze.findSourceForUncovered( verbose, symbolsToAnalyze );
// Report the coverage data.
@@ -478,13 +485,14 @@ int covoar(
if (verbose)
std::cerr << "Generate Reports" << std::endl;
- for (const auto& setName : SymbolsToAnalyze->getSetNames()) {
+ for (const auto& setName : symbolsToAnalyze.getSetNames()) {
Coverage::GenerateReports(
setName,
allExplanations,
verbose,
projectName,
- outputDirectory
+ outputDirectory,
+ symbolsToAnalyze
1.8.3.1
