[PATCH rtems-libbsd 0/5] RTEMS LibBSD Documentation
Christian MAUDERER christian.mauderer at embedded-brains.de
Tue Aug 3 07:00:27 UTC 2021
Hello,
Am 03.08.21 um 04:07 schrieb Chris Johns:
> On 3/8/21 3:24 am, Sebastian Huber wrote:
>> On 02/08/2021 18:37, Vijay Kumar Banerjee wrote:
>>> I think there should be a high-level user manual subsection for
>>> networking that describes how the selection of the network stack
>>> works. We can then add another subsection about lwip since legacy
>>> already has one, and libbsd is getting added now.
>> This sounds like a good approach.
> I agree.
> Chris
Just so that we are all on the same page:
That would be a number of new subsections in
https://docs.rtems.org/branches/master/user/index.html:
- 15. Selecting a Network Stack
- 16. Add-on: libbsd Stack
- 17. Add-on: lwIP
- 18. Add-on: Legacy Network Stack
Or was it meant to be only a section
in https://docs.rtems.org/branches/master/user/index.html,
- a new manual "libbsd" in the top level https://docs.rtems.org/,
- a new manual "lwip" in the top level https://docs.rtems.org/
By the way: I think we maybe should keep in mind that there can be more
add-on packages added some-when in the future that are not network
stacks. We could for example add documentation for a CAN library, a
display library or a weather control station. So if we need a top level
name for all packages, we maybe should call it "add-on packages" instead
of "network libraries".
Best regards
Christian
