[PATCH rtems-libbsd 0/5] RTEMS LibBSD Documentation
Wed Aug 4 07:28:17 UTC 2021
On 3/8/21 5:00 pm, Christian MAUDERER wrote:
> Hello,
> Am 03.08.21 um 04:07 schrieb Chris Johns:
>> On 3/8/21 3:24 am, Sebastian Huber wrote:
>>> On 02/08/2021 18:37, Vijay Kumar Banerjee wrote:
>>>> I think there should be a high-level user manual subsection for
>>>> networking that describes how the selection of the network stack
>>>> works. We can then add another subsection about lwip since legacy
>>>> already has one, and libbsd is getting added now.
>>> This sounds like a good approach.
>> I agree.
>> Chris
> Just so that we are all on the same page:
> That would be a number of new subsections in
> https://docs.rtems.org/branches/master/user/index.html:
> - 15. Selecting a Network Stack
> - 16. Add-on: libbsd Stack
> - 17. Add-on: lwIP
> - 18. Add-on: Legacy Network Stack
> Or was it meant to be only a section
I think a single section so all things networking are grouped.
> in https://docs.rtems.org/branches/master/user/index.html,
> - a new manual "libbsd" in the top level https://docs.rtems.org/,
> - a new manual "lwip" in the top level https://docs.rtems.org/
> By the way: I think we maybe should keep in mind that there can be more add-on
> packages added some-when in the future that are not network stacks. We could for
> example add documentation for a CAN library, a display library or a weather
> control station. So if we need a top level name for all packages, we maybe
> should call it "add-on packages" instead of "network libraries".
> Best regards
> Christian
