[PATCH v1 4/4] GcovFunctionData:h: Fix formatting
Ryan Long ryan.long at oarcorp.com
Tue Aug 3 20:30:59 UTC 2021
 tester/covoar/GcovFunctionData.h | 113 +++++++++++++++++++--------------------
 1 file changed, 54 insertions(+), 59 deletions(-)
diff --git a/tester/covoar/GcovFunctionData.h b/tester/covoar/GcovFunctionData.h
index e1ad431..4a98abb 100644
--- a/tester/covoar/GcovFunctionData.h
+++ b/tester/covoar/GcovFunctionData.h
@@ -16,35 +16,35 @@
 namespace Gcov {
-#define FUNCTION_NAME_LENGTH    64
-#define FILE_NAME_LENGTH        256
+#define FUNCTION_NAME_LENGTH 64
+#define FILE_NAME_LENGTH     256
-#define ON_TREE_ARC_FLAG        0x1
-#define FAKE_ARC_FLAG           0x2
-#define FALLTHROUGH_ARC_FLAG    0x4
+#define ON_TREE_ARC_FLAG     0x1
+#define FAKE_ARC_FLAG        0x2
+#define FALLTHROUGH_ARC_FLAG 0x4
 struct gcov_arc_info
-  uint32_t    sourceBlock;
-  uint32_t    destinationBlock;
-  uint32_t    flags;
-  uint64_t    counter;
+  uint32_t sourceBlock;
+  uint32_t destinationBlock;
+  uint32_t flags;
+  uint64_t counter;
 struct gcov_block_info
-  uint32_t                    id;
-  uint32_t                    flags;
-  uint32_t                    numberOfLines;
-  uint64_t                    counter;
-  std::string                 sourceFileName;
-  std::list<uint32_t>         lines;
+  uint32_t            id;
+  uint32_t            flags;
+  uint32_t            numberOfLines;
+  uint64_t            counter;
+  std::string         sourceFileName;
+  std::list<uint32_t> lines;
-typedef std::list<gcov_arc_info>                arcs_t;
-typedef std::list<gcov_arc_info>::iterator      arcs_iterator_t;
-typedef std::list<gcov_block_info>              blocks_t;
-typedef std::list<gcov_block_info>::iterator    blocks_iterator_t;
+typedef std::list<gcov_arc_info>             arcs_t;
+typedef std::list<gcov_arc_info>::iterator   arcs_iterator_t;
+typedef std::list<gcov_block_info>           blocks_t;
+typedef std::list<gcov_block_info>::iterator blocks_iterator_t;
 class DesiredSymbols;
@@ -71,27 +71,21 @@ class DesiredSymbols;
      *  @param[in] chk stores the checksum value
-    void setChecksum(
-      const uint32_t              chk
+    void setChecksum( const uint32_t chk );
      *  This method stores id of function
      *  @param[in] idNumber stores the id value
-    void setId(
-      const uint32_t              idNumber
+    void setId( const uint32_t idNumber );
      *  This method stores checksum related to function
      *  @param[in] lineNo passes number of the line begining the function
-    void setFirstLineNumber(
-      const uint32_t              lineNo
+    void setFirstLineNumber( const uint32_t lineNo );
      *  This method stores name of the function and ties it to its
@@ -125,8 +119,8 @@ class DesiredSymbols;
      *  @return Returns TRUE if the method succeeded and FALSE if it failed.
     void setBlockFileName(
-      const blocks_iterator_t             block,
-      const std::string&                  fileName
+      const blocks_iterator_t block,
+      const std::string&      fileName
@@ -159,9 +153,9 @@ class DesiredSymbols;
     void getCounters(
       uint64_t* counterValues,
-      uint32_t &countersFound,
-      uint64_t &countersSum,
-      uint64_t &countersMax
+      uint32_t& countersFound,
+      uint64_t& countersSum,
+      uint64_t& countersMax
@@ -169,12 +163,9 @@ class DesiredSymbols;
      *  @param[in] source passes source block number
      *  @param[in] destination passes destination block number
+     *  @param[in] flags passes per block flags
-    void addArc(
-      uint32_t    source,
-      uint32_t    destination,
-      uint32_t    flags
+    void addArc( uint32_t source, uint32_t destination, uint32_t flags );
      *  This method adds new arc to arc list
@@ -182,10 +173,7 @@ class DesiredSymbols;
      *  @param[in] block identifies block
      *  @param[in] line passes the line number
-    void addBlockLine(
+    void addBlockLine( const blocks_iterator_t block, const uint32_t line );
      *  This method finds block by its ID
@@ -204,13 +192,16 @@ class DesiredSymbols;
      *  @param[in] sourceFileName passes containing file name
     void addBlock(
-      const uint32_t              id,
-      const uint32_t              flags,
-      const std::string&          sourceFileName
+      const uint32_t     id,
+      const uint32_t     flags,
+      const std::string& sourceFileName
      *  This method prints info about function
+     *  @param[in] textFile specifies output file
+     *  @param[in] function_number specifies the number of the function
     void printFunctionInfo(
       std::ofstream& textFile,
@@ -219,6 +210,9 @@ class DesiredSymbols;
      *  This method prints info about coverage of this function
     void printCoverageInfo(
@@ -236,6 +230,7 @@ class DesiredSymbols;
      *  This method prints info about chosen block in blocks list
      *  @param[in] block passes iterator identifying block
     void printBlockInfo( std::ofstream& textFile, blocks_iterator_t block );
@@ -243,26 +238,26 @@ class DesiredSymbols;
      *  This method calculates values of arc counters
-    bool processFunctionCounters( void );
+    bool processFunctionCounters();
   private:
-    uint32_t            id;
-    uint32_t            checksum;
-    uint32_t            firstLineNumber;
-    uint32_t            numberOfBlocks;
-    uint32_t            numberOfArcs;
-    arcs_t              arcs;
-    blocks_t            blocks;
-    std::string         functionName;
+    uint32_t    id;
+    uint32_t    checksum;
+    uint32_t    firstLineNumber;
+    uint32_t    numberOfBlocks;
+    uint32_t    numberOfArcs;
+    arcs_t      arcs;
+    blocks_t    blocks;
+    std::string functionName;
      *  This member contains the unified or merged coverage map
      *  and symbol info for the symbol.
-    Coverage::CoverageMapBase*          coverageMap;
-    Coverage::SymbolInformation*        symbolInfo;
+    Coverage::CoverageMapBase*   coverageMap;
+    Coverage::SymbolInformation* symbolInfo;
      *  This method creates list of taken/not taken values
@@ -272,8 +267,8 @@ class DesiredSymbols;
      *  @param[in] notTaken   used to return not taken counts list
     bool processBranches(
-      std::list<uint64_t> * taken,
-      std::list<uint64_t> * notTaken
+      std::list<uint64_t>* taken,
+      std::list<uint64_t>* notTaken
1.8.3.1
