[PATCH v1 3/4] GcovFunctionData.cc: Fix formatting
Ryan Long
ryan.long at oarcorp.com
Tue Aug 3 20:30:58 UTC 2021
tester/covoar/GcovFunctionData.cc | 271 +++++++++++++++++++++++---------------
1 file changed, 162 insertions(+), 109 deletions(-)
diff --git a/tester/covoar/GcovFunctionData.cc b/tester/covoar/GcovFunctionData.cc
index 34af677..7c9e627 100644
--- a/tester/covoar/GcovFunctionData.cc
+++ b/tester/covoar/GcovFunctionData.cc
@@ -19,9 +19,9 @@ namespace Gcov {
GcovFunctionData::GcovFunctionData()
- numberOfArcs = 0;
+ numberOfArcs = 0;
numberOfBlocks = 0;
- coverageMap = NULL;
+ coverageMap = NULL;
GcovFunctionData::~GcovFunctionData()
@@ -49,9 +49,7 @@ namespace Gcov {
Coverage::DesiredSymbols& symbolsToAnalyze
- std::string symbolName;
- symbolName = fcnName;
+ std::string symbolName = fcnName;
if ( fcnName.length() >= FUNCTION_NAME_LENGTH ) {
std::cerr << "ERROR: Function name is too long to be correctly stored: "
@@ -63,8 +61,9 @@ namespace Gcov {
// Tie function to its coverage map
symbolInfo = symbolsToAnalyze.find( symbolName );
- if ( symbolInfo != NULL )
+ if ( symbolInfo != NULL ) {
coverageMap = symbolInfo->unifiedCoverageMap;
#if 0
if ( coverageMap == NULL ) {
@@ -79,7 +78,8 @@ namespace Gcov {
return true;
- bool GcovFunctionData::setFileName( const std::string& fileName ) {
+ bool GcovFunctionData::setFileName( const std::string& fileName )
if ( fileName.length() >= FILE_NAME_LENGTH ) {
std::cerr << "ERROR: File name is too long to be correctly stored: "
<< fileName.length() << std::endl;
@@ -107,13 +107,13 @@ namespace Gcov {
void GcovFunctionData::getCounters(
uint64_t* counterValues,
- uint32_t &countersFound,
- uint64_t &countersSum,
- uint64_t &countersMax
+ uint32_t& countersFound,
+ uint64_t& countersSum,
+ uint64_t& countersMax
- arcs_iterator_t currentArc;
- int i;
+ arcs_iterator_t currentArc;
+ int i;
countersFound = 0;
countersSum = 0;
@@ -121,19 +121,20 @@ namespace Gcov {
// Locate relevant counters and copy their values
i = 0;
- for(
- currentArc = arcs.begin();
- currentArc != arcs.end();
- currentArc++
- if ( currentArc->flags == 0 || currentArc->flags == 2 ||
- currentArc->flags == 4 ) {
+ for ( currentArc = arcs.begin(); currentArc != arcs.end(); currentArc++ ) {
+ if (
+ currentArc->flags == 0 ||
+ currentArc->flags == 2 ||
+ currentArc->flags == 4
countersFound++;
countersSum += currentArc->counter;
counterValues[i] = currentArc->counter;
- if ( countersMax <= currentArc->counter)
+ if ( countersMax <= currentArc->counter ) {
countersMax = currentArc->counter;
i++;
@@ -145,19 +146,19 @@ namespace Gcov {
void GcovFunctionData::addArc(
- uint32_t source,
- uint32_t destination,
- uint32_t flags
+ uint32_t source,
+ uint32_t destination,
+ uint32_t flags
gcov_arc_info arc;
numberOfArcs++;
- arc.sourceBlock = source;
+ arc.sourceBlock = source;
arc.destinationBlock = destination;
- arc.flags = flags;
- arc.counter = 0;
- arcs.push_back(arc);
+ arc.flags = flags;
+ arc.counter = 0;
+ arcs.push_back( arc );
void GcovFunctionData::addBlock(
@@ -169,12 +170,12 @@ namespace Gcov {
gcov_block_info block;
numberOfBlocks++;
- block.id = id;
- block.flags = flags;
- block.numberOfLines = 0;
- block.counter = 0;
+ block.id = id;
+ block.flags = flags;
+ block.numberOfLines = 0;
+ block.counter = 0;
block.sourceFileName = sourceFileName;
- blocks.push_back(block);
+ blocks.push_back( block );
void GcovFunctionData::printFunctionInfo(
@@ -182,8 +183,8 @@ namespace Gcov {
uint32_t function_number
- blocks_iterator_t currentBlock;
+ blocks_iterator_t currentBlock;
textFile << std::endl << std::endl
@@ -204,9 +205,10 @@ namespace Gcov {
textFile << std::endl;
// Print blocks info
- for ( currentBlock = blocks.begin();
- currentBlock != blocks.end();
- currentBlock++
+ for (
+ currentBlock = blocks.begin();
+ currentBlock != blocks.end();
+ currentBlock++
printBlockInfo( textFile, currentBlock );
@@ -217,22 +219,25 @@ namespace Gcov {
- uint32_t baseAddress = 0;
- uint32_t baseSize;
- uint32_t currentAddress;
- std::list<Coverage::objdumpLine_t>::iterator instruction;
+ uint32_t baseAddress = 0;
+ uint32_t baseSize;
+ uint32_t currentAddress;
+ std::list<Coverage::objdumpLine_t>::iterator instruction;
if ( coverageMap != NULL ) {
- for (instruction = symbolInfo->instructions.begin();
- instruction != symbolInfo->instructions.end();
- instruction++) {
+ for (
+ instruction = symbolInfo->instructions.begin();
+ instruction != symbolInfo->instructions.end();
+ instruction++
if( instruction->isInstruction ) {
baseAddress = instruction->address;
break;
- baseSize = coverageMap->getSize();
+ baseSize = coverageMap->getSize();
textFile << std::endl << "Instructions (Base address: 0x"
<< std::setfill( '0' ) << std::setw( 8 )
@@ -240,9 +245,10 @@ namespace Gcov {
<< ", Size: " << std::setw( 4 ) << baseSize
<< "):" << std::endl << std::endl;
- for ( instruction = symbolInfo->instructions.begin();
- instruction++
+ for (
+ instruction++
if ( instruction->isInstruction ) {
@@ -261,35 +267,37 @@ namespace Gcov {
<< coverageMap->getWasNotTaken( currentAddress )
- if ( instruction->isBranch )
+ if ( instruction->isBranch ) {
textFile << "| Branch ";
- else
+ } else {
textFile << " ";
- if ( instruction->isNop )
+ if ( instruction->isNop ) {
textFile << "| NOP(" << std::setw( 3 ) << instruction->nopSize
<< ") " << std::endl;
- else
+ } else {
textFile << " " << std::endl;
void GcovFunctionData::setBlockFileName(
- const blocks_iterator_t block,
- const std::string& fileName
+ const blocks_iterator_t block,
+ const std::string& fileName
block->sourceFileName = fileName;
void GcovFunctionData::addBlockLine(
- const uint32_t line
+ const uint32_t line
- block->lines.push_back(line);
+ block->lines.push_back( line );
(block->numberOfLines)++;
@@ -299,15 +307,18 @@ namespace Gcov {
if ( !blocks.empty() ) {
blockIterator = blocks.begin();
- while ( blockIterator != blocks.end() ){
- if ( blockIterator->id == id)
+ while ( blockIterator != blocks.end() ) {
+ if ( blockIterator->id == id ) {
break;
blockIterator++;
} else {
std::cerr << "ERROR: GcovFunctionData::findBlockById() failed"
<< ", no blocks present" << std::endl;
return blockIterator;
@@ -316,8 +327,8 @@ namespace Gcov {
arcs_iterator_t arc
- textFile << " > ARC " << std::setw( 3 ) << arc->sourceBlock
- << " -> " << arc->destinationBlock << " ";
+ textFile << " > ARC " << std::setw( 3 ) << arc->sourceBlock << " -> "
+ << arc->destinationBlock << " ";
textFile << "\tFLAGS: ";
switch ( arc->flags ) {
@@ -355,13 +366,15 @@ namespace Gcov {
- std::list<uint32_t>::iterator line;
+ std::list<uint32_t>::iterator line;
textFile << " > BLOCK " << std::setw( 3 ) << block->id
<< " from " << block->sourceFileName << std::endl
- << " -counter: " << std::setw( 5 ) << block->counter << std::endl
+ << " -counter: " << std::setw( 5 ) << block->counter
+ << std::endl
<< " -flags: 0x" << std::hex << block->flags << std::endl
- << " -lines: ";
+ << " -lines: "
+ << std::dec;
if ( !block->lines.empty() )
for ( line = block->lines.begin(); line != block->lines.end(); line++ ) {
@@ -371,21 +384,25 @@ namespace Gcov {
- bool GcovFunctionData::processFunctionCounters( void ) {
- uint32_t currentAddress = 0;
- blocks_iterator_t blockIterator;
- blocks_iterator_t blockIterator2;
- arcs_iterator_t arcIterator;
- arcs_iterator_t arcIterator2;
- std::list<uint64_t> taken; // List of taken counts for branches
- std::list<uint64_t> notTaken; // List of not taken counts for branches
+ bool GcovFunctionData::processFunctionCounters() {
+ uint32_t currentAddress = 0;
+ blocks_iterator_t blockIterator;
+ blocks_iterator_t blockIterator2;
+ arcs_iterator_t arcIterator;
+ arcs_iterator_t arcIterator2;
+ std::list<uint64_t> taken; // List of taken counts for branches
+ std::list<uint64_t> notTaken; // List of not taken counts for branches
//std::cerr << "DEBUG: Processing counters for file: " << sourceFileName
// << std::endl;
- if ( blocks.empty() || arcs.empty() || coverageMap == NULL || symbolInfo->instructions.empty()) {
+ if (
+ blocks.empty() ||
+ arcs.empty() ||
+ coverageMap == NULL ||
+ symbolInfo->instructions.empty()
//std::cerr << "DEBUG: sanity check returned false for function: "
// << functionName << " from file: " << sourceFileName
// << std::endl;
@@ -393,13 +410,13 @@ namespace Gcov {
// Reset iterators and variables
- blockIterator = blocks.begin();
- arcIterator = arcs.begin();
- arcIterator2 = arcIterator;
- arcIterator2++;
- instruction = symbolInfo->instructions.begin();
- baseAddress = coverageMap->getFirstLowAddress(); //symbolInfo->baseAddress;
+ blockIterator = blocks.begin();
+ arcIterator = arcs.begin();
+ arcIterator2 = arcIterator;
+ baseAddress = coverageMap->getFirstLowAddress(); //symbolInfo->baseAddress;
currentAddress = baseAddress;
+ arcIterator2++;
// Find taken/not taken values for branches
if ( !processBranches( &taken , ¬Taken ) )
@@ -419,17 +436,19 @@ namespace Gcov {
// << std::endl;
return false;
arcIterator++;
arcIterator2++;
// If no more branches break;
- if ( arcIterator2 == arcs.end() )
+ if ( arcIterator2 == arcs.end() ) {
break;
// If this is a branch without FAKE arcs process it
if (
- (arcIterator->sourceBlock == arcIterator2->sourceBlock ) &&
+ ( arcIterator->sourceBlock == arcIterator2->sourceBlock ) &&
!( arcIterator->flags & FAKE_ARC_FLAG ) &&
!( arcIterator2->flags & FAKE_ARC_FLAG )
@@ -447,34 +466,41 @@ namespace Gcov {
if ( arcIterator->flags & FALLTHROUGH_ARC_FLAG ) {
arcIterator->counter = notTaken.front();
notTaken.pop_front();
arcIterator2->counter = taken.front();
taken.pop_front();
} else {
arcIterator2->counter = notTaken.front();
arcIterator->counter = taken.front();
taken.pop_front();
blockIterator2 = blocks.begin();
//TODO: ADD FAILSAFE
- while ( arcIterator->destinationBlock != blockIterator2->id)
+ while ( arcIterator->destinationBlock != blockIterator2->id ) {
blockIterator2++;
blockIterator2->counter += arcIterator->counter;
- while ( arcIterator2->destinationBlock != blockIterator2->id)
+ while ( arcIterator2->destinationBlock != blockIterator2->id ) {
blockIterator2++;
- blockIterator2->counter += arcIterator2->counter;
+ blockIterator2->counter += arcIterator2->counter;
blockIterator++;
arcIterator2++;
// Set the first block
@@ -488,6 +514,7 @@ namespace Gcov {
<< std::endl;
return false;
arcIterator++;
arcIterator2++;
@@ -498,10 +525,13 @@ namespace Gcov {
// << arcIterator->sourceBlock << " -> " << std::setw( 3 )
// << arcIterator->destinationBlock << std::endl;
arcIterator->counter = blockIterator->counter;
- blockIterator2 = blocks.begin();
- while ( arcIterator->destinationBlock != blockIterator2->id) //TODO: ADD FAILSAFE
+ blockIterator2 = blocks.begin();
+ while ( arcIterator->destinationBlock != blockIterator2->id ) { //TODO: ADD FAILSAFE
blockIterator2++;
return true;
@@ -511,22 +541,30 @@ namespace Gcov {
- blockIterator2 = blocks.begin();;
blockIterator2++;
// If this is a branch with FAKE arc
- else if ( (arcIterator->sourceBlock == arcIterator2->sourceBlock ) && ( arcIterator2->flags & FAKE_ARC_FLAG ))
+ else if (
+ ( arcIterator2->flags & FAKE_ARC_FLAG )
//std::cerr << "DEBUG: Found fake branching arc " << std::setw( 3 )
blockIterator2++;
@@ -538,33 +576,48 @@ namespace Gcov {
bool GcovFunctionData::processBranches(
- std::list<uint64_t> * taken ,
- std::list<uint64_t> * notTaken
+ std::list<uint64_t>* taken ,
+ std::list<uint64_t>* notTaken
- if ( coverageMap == NULL )
+ if ( coverageMap == NULL ) {
return false;
//baseAddress = coverageMap->getFirstLowAddress(); //symbolInfo->baseAddress;
- for (instruction = symbolInfo->instructions.begin(); instruction != symbolInfo->instructions.end(); instruction++)
+ for (
+ instruction++
break;
// std::cerr << "DEBUG: Processing instructions in search of branches"
// << std::endl;
+ for (
+ instruction++
- if ( instruction->isInstruction) {
+ if ( instruction->isInstruction ) {
currentAddress = instruction-> address - baseAddress;
- taken->push_back ( (uint64_t) coverageMap->getWasTaken( currentAddress ) );
- notTaken->push_back ( (uint64_t) coverageMap->getWasNotTaken( currentAddress ) );
+ taken->push_back(
+ (uint64_t) coverageMap->getWasTaken( currentAddress )
+ notTaken->push_back(
+ (uint64_t) coverageMap->getWasNotTaken( currentAddress )
//std::cerr << "Added branch to list taken/not: " << std::setw( 4 )
// << coverageMap->getWasTaken( currentAddress )
1.8.3.1
