[PATCH rtems-libbsd v4 08/19] sys/kern: Add lockmgr support
chrisj at rtems.org chrisj at rtems.org
Wed Aug 4 08:53:18 UTC 2021
- See `man lockmgr`
- Implement the lock_object and move the RTEMS mutex to that object
- Add debug support to track the locks with gdb
Update #4475
 freebsd/sys/kern/subr_lock.c                  |   2 -
 freebsd/sys/sys/_lock.h                       |  10 +-
 freebsd/sys/sys/_lockmgr.h                    |   6 +
 freebsd/sys/sys/_mutex.h                      |   5 -
 freebsd/sys/sys/_rwlock.h                     |   5 -
 freebsd/sys/sys/_sx.h                         |   5 -
 rtemsbsd/include/machine/_kernel_lock.h       |   2 +-
 rtemsbsd/include/machine/rtems-bsd-mutex.h    |   8 +-
 .../include/machine/rtems-bsd-muteximpl.h     |  87 ++-
 rtemsbsd/include/machine/rtems-bsd-thread.h   |   1 +
 rtemsbsd/rtems/rtems-kernel-epoch.c           |   2 +-
 rtemsbsd/rtems/rtems-kernel-jail.c            |  10 +-
 rtemsbsd/rtems/rtems-kernel-lockmgr.c         | 579 ++++++++++++++++++
 rtemsbsd/rtems/rtems-kernel-mutex.c           |  21 +-
 rtemsbsd/rtems/rtems-kernel-muteximpl.c       |   5 +-
 rtemsbsd/rtems/rtems-kernel-rwlock.c          |  28 +-
 rtemsbsd/rtems/rtems-kernel-sx.c              |  34 +-
 17 files changed, 727 insertions(+), 83 deletions(-)
 create mode 100644 rtemsbsd/rtems/rtems-kernel-lockmgr.c
diff --git a/freebsd/sys/kern/subr_lock.c b/freebsd/sys/kern/subr_lock.c
index c2587cd0..3a0dd40f 100644
--- a/freebsd/sys/kern/subr_lock.c
+++ b/freebsd/sys/kern/subr_lock.c
@@ -74,9 +74,7 @@ struct lock_class *lock_classes[LOCK_CLASS_MAX + 1] = {
 	&lock_class_rm_sleepable,
 #endif /* __rtems__ */
 	&lock_class_rw,
-#ifndef __rtems__
 	&lock_class_lockmgr,
-#endif /* __rtems__ */
 void
diff --git a/freebsd/sys/sys/_lock.h b/freebsd/sys/sys/_lock.h
index ae10254c..a375032b 100644
--- a/freebsd/sys/sys/_lock.h
+++ b/freebsd/sys/sys/_lock.h
@@ -32,15 +32,23 @@
 #ifndef _SYS__LOCK_H_
 #define	_SYS__LOCK_H_
+#ifdef __rtems__
+#include <machine/rtems-bsd-mutex.h>
+#endif /* __rtems__ */
 struct lock_object {
 #ifndef __rtems__
 	const	char *lo_name;		/* Individual lock name. */
+#else /* __rtems__ */
+	#define lo_name lo_mtx.queue.Queue.name
 	u_int	lo_flags;
+#ifndef __rtems__
 	u_int	lo_data;		/* General class specific data. */
 	struct	witness *lo_witness;	/* Data for witness. */
-	unsigned int lo_flags;
+	#define lo_data lo_mtx.nest_level
+	rtems_bsd_mutex lo_mtx;
diff --git a/freebsd/sys/sys/_lockmgr.h b/freebsd/sys/sys/_lockmgr.h
index 62e50df1..8e9ac276 100644
--- a/freebsd/sys/sys/_lockmgr.h
+++ b/freebsd/sys/sys/_lockmgr.h
@@ -34,7 +34,9 @@
 #define	_SYS__LOCKMGR_H_
 #ifdef DEBUG_LOCKS
+#ifndef __rtems__
 #include <sys/_stack.h>
 #endif
 struct lock {
@@ -44,7 +46,11 @@ struct lock {
 	int			lk_timo;
 	int			lk_pri;
 #ifdef DEBUG_LOCKS
+#ifndef __rtems__
 	struct stack		lk_stack;
+	void*			lk_stack;
 #endif
diff --git a/freebsd/sys/sys/_mutex.h b/freebsd/sys/sys/_mutex.h
index 5252aee1..418b62b4 100644
--- a/freebsd/sys/sys/_mutex.h
+++ b/freebsd/sys/sys/_mutex.h
@@ -32,9 +32,6 @@
 #ifndef _SYS__MUTEX_H_
 #define	_SYS__MUTEX_H_
-#ifdef __rtems__
-#include <machine/rtems-bsd-mutex.h>
 #include <machine/param.h>
@@ -51,8 +48,6 @@ struct mtx {
 	struct lock_object	lock_object;	/* Common lock properties. */
 #ifndef __rtems__
 	volatile uintptr_t	mtx_lock;	/* Owner and flags. */
-#else /* __rtems__ */
-	rtems_bsd_mutex mutex;
diff --git a/freebsd/sys/sys/_rwlock.h b/freebsd/sys/sys/_rwlock.h
index 318592d5..6110a494 100644
--- a/freebsd/sys/sys/_rwlock.h
+++ b/freebsd/sys/sys/_rwlock.h
@@ -30,9 +30,6 @@
 #ifndef _SYS__RWLOCK_H_
 #define	_SYS__RWLOCK_H_
-#ifdef __rtems__
@@ -49,8 +46,6 @@ struct rwlock {
 #ifndef __rtems__
 	volatile uintptr_t	rw_lock;
diff --git a/freebsd/sys/sys/_sx.h b/freebsd/sys/sys/_sx.h
index 328a43a4..d8f86296 100644
--- a/freebsd/sys/sys/_sx.h
+++ b/freebsd/sys/sys/_sx.h
@@ -32,9 +32,6 @@
 #ifndef	_SYS__SX_H_
 #define	_SYS__SX_H_
-#ifdef __rtems__
  * Shared/exclusive lock main structure definition.
@@ -43,8 +40,6 @@ struct sx {
 #ifndef __rtems__
 	volatile uintptr_t	sx_lock;
diff --git a/rtemsbsd/include/machine/_kernel_lock.h b/rtemsbsd/include/machine/_kernel_lock.h
index dc4f8255..32a41cb8 100644
--- a/rtemsbsd/include/machine/_kernel_lock.h
+++ b/rtemsbsd/include/machine/_kernel_lock.h
@@ -35,9 +35,9 @@
 #define _MACHINE__KERNEL_LOCK_H_
 #include <sys/queue.h>
-#include <sys/_lock.h>
 #include <sys/ktr_class.h>
+struct lock_object;
 struct lock_list_entry;
 struct thread;
diff --git a/rtemsbsd/include/machine/rtems-bsd-mutex.h b/rtemsbsd/include/machine/rtems-bsd-mutex.h
index dd728cdc..54873dc3 100644
--- a/rtemsbsd/include/machine/rtems-bsd-mutex.h
+++ b/rtemsbsd/include/machine/rtems-bsd-mutex.h
@@ -40,16 +40,20 @@
 #ifndef _RTEMS_BSD_MACHINE_RTEMS_BSD_MUTEX_H_
 #define _RTEMS_BSD_MACHINE_RTEMS_BSD_MUTEX_H_
-#include <rtems/score/thread.h>
+#include <sys/queue.h>
 #include <rtems/score/threadq.h>
 #ifdef __cplusplus
 extern "C" {
 #endif /* __cplusplus */
-typedef struct {
+typedef struct rtems_bsd_mutex {
 	Thread_queue_Control queue;
 	int nest_level;
+#if RTEMS_DEBUG
+	TAILQ_ENTRY(rtems_bsd_mutex) mutex_list;
+#endif /* RTEMS_DEBUG */
 } rtems_bsd_mutex;
 #ifdef __cplusplus
diff --git a/rtemsbsd/include/machine/rtems-bsd-muteximpl.h b/rtemsbsd/include/machine/rtems-bsd-muteximpl.h
index b362e524..43b06963 100644
--- a/rtemsbsd/include/machine/rtems-bsd-muteximpl.h
+++ b/rtemsbsd/include/machine/rtems-bsd-muteximpl.h
@@ -50,6 +50,8 @@
 #include <inttypes.h>
+#include <rtems/thread.h>
+#include <rtems/score/thread.h>
@@ -60,17 +62,48 @@ extern "C" {
 #define	RTEMS_BSD_MUTEX_TQ_OPERATIONS \
     &_Thread_queue_Operations_priority_inherit
+#if RTEMS_DEBUG
+ * Resource tracking. In GDB you can:
+ * define mutex-owned
+ *  set $m = $arg0
+ *  set $c = 0
+ *  while $m != 0
+ *   set $c = $c + 1
+ *   if $m->queue.Queue.owner != 0
+ *    printf "%08x %-40s\n", $m->queue.Queue.owner, $m->queue.Queue.name
+ *   end
+ *   set $m = $m->mutex_list.tqe_next
+ *  end
+ *  printf "Total: %d\n", $c
+ * end
+ * (gdb) mutex-owned _bsd_bsd_mutexlist->tqh_first
+extern TAILQ_HEAD(_bsd_mutex_list, rtems_bsd_mutex) _bsd_mutexlist;
+extern rtems_mutex _bsd_mutexlist_lock;
 static inline void
-rtems_bsd_mutex_init(struct lock_object *lock, rtems_bsd_mutex *m,
-    struct lock_class *class, const char *name, const char *type, int flags)
+rtems_bsd_mutex_init(struct lock_object *lk, struct lock_class *class,
+   const char *name, const char *type, int flags)
+	rtems_bsd_mutex *m = &lk->lo_mtx;
 	_Thread_queue_Initialize(&m->queue, name);
 	m->nest_level = 0;
-	lock_init(lock, class, name, type, flags);
+	lock_init(lk, class, name, type, flags);
+#if RTEMS_DEBUG
+	rtems_mutex_lock(&_bsd_mutexlist_lock);
+	TAILQ_INSERT_TAIL(&_bsd_mutexlist, m, mutex_list);
+	rtems_mutex_unlock(&_bsd_mutexlist_lock);
-void rtems_bsd_mutex_lock_more(struct lock_object *lock, rtems_bsd_mutex *m,
+void rtems_bsd_mutex_lock_more(struct lock_object *lk,
     Thread_Control *owner, Thread_Control *executing,
     Thread_queue_Context *queue_context);
@@ -117,12 +150,13 @@ rtems_bsd_mutex_set_isr_level(Thread_queue_Context *queue_context,
 static inline void
-rtems_bsd_mutex_lock(struct lock_object *lock, rtems_bsd_mutex *m)
+rtems_bsd_mutex_lock(struct lock_object *lk)
 	ISR_Level isr_level;
 	Thread_queue_Context queue_context;
 	Thread_Control *executing;
 	Thread_Control *owner;
 	_Thread_queue_Context_initialize(&queue_context);
 	rtems_bsd_mutex_isr_disable(isr_level, &queue_context);
@@ -137,19 +171,20 @@ rtems_bsd_mutex_lock(struct lock_object *lock, rtems_bsd_mutex *m)
 		rtems_bsd_mutex_release(m, isr_level, &queue_context);
 	} else {
 		rtems_bsd_mutex_set_isr_level(&queue_context, isr_level);
-		rtems_bsd_mutex_lock_more(lock, m, owner, executing,
+		rtems_bsd_mutex_lock_more(lk, owner, executing,
 		    &queue_context);
 static inline int
-rtems_bsd_mutex_trylock(struct lock_object *lock, rtems_bsd_mutex *m)
+rtems_bsd_mutex_trylock(struct lock_object *lk)
 	int success;
@@ -163,7 +198,7 @@ rtems_bsd_mutex_trylock(struct lock_object *lock, rtems_bsd_mutex *m)
 		_Thread_Resource_count_increment(executing);
 		success = 1;
 	} else if (owner == executing) {
-		if ((lock->lo_flags & LO_RECURSABLE) == 0) {
+		if ((lk->lo_flags & LO_RECURSABLE) == 0) {
 			panic("mutex trylock: %s: not LO_RECURSABLE\n",
 			    m->queue.Queue.name);
@@ -181,13 +216,14 @@ rtems_bsd_mutex_trylock(struct lock_object *lock, rtems_bsd_mutex *m)
 static inline void
-rtems_bsd_mutex_unlock(rtems_bsd_mutex *m)
+rtems_bsd_mutex_unlock(struct lock_object *lk)
 	int nest_level;
@@ -226,45 +262,52 @@ rtems_bsd_mutex_unlock(rtems_bsd_mutex *m)
 static inline Thread_Control *
-rtems_bsd_mutex_owner(const rtems_bsd_mutex *m)
+rtems_bsd_mutex_owner(struct lock_object *lk)
 	return (m->queue.Queue.owner);
 static inline int
-rtems_bsd_mutex_owned(const rtems_bsd_mutex *m)
+rtems_bsd_mutex_owned(struct lock_object *lk)
-	return (rtems_bsd_mutex_owner(m) == _Thread_Get_executing());
+	return (rtems_bsd_mutex_owner(lk) == _Thread_Get_executing());
 static inline int
-rtems_bsd_mutex_recursed(const rtems_bsd_mutex *m)
+rtems_bsd_mutex_recursed(struct lock_object *lk)
 	return (m->nest_level != 0);
 static inline const char *
-rtems_bsd_mutex_name(const rtems_bsd_mutex *m)
+rtems_bsd_mutex_name(struct lock_object *lk)
 	return (m->queue.Queue.name);
 static inline void
-rtems_bsd_mutex_destroy(struct lock_object *lock, rtems_bsd_mutex *m)
+rtems_bsd_mutex_destroy(struct lock_object *lk)
 	BSD_ASSERT(m->queue.Queue.heads == NULL);
-	if (rtems_bsd_mutex_owned(m)) {
+	if (rtems_bsd_mutex_owned(lk)) {
 		m->nest_level = 0;
-		rtems_bsd_mutex_unlock(m);
+		rtems_bsd_mutex_unlock(lk);
+#if RTEMS_DEBUG
+	TAILQ_REMOVE(&_bsd_mutexlist, m, mutex_list);
 	_Thread_queue_Destroy(&m->queue);
-	lock_destroy(lock);
+	lock_destroy(lk);
 #ifdef __cplusplus
diff --git a/rtemsbsd/include/machine/rtems-bsd-thread.h b/rtemsbsd/include/machine/rtems-bsd-thread.h
index 28286b8e..6b9259c4 100644
--- a/rtemsbsd/include/machine/rtems-bsd-thread.h
+++ b/rtemsbsd/include/machine/rtems-bsd-thread.h
@@ -45,6 +45,7 @@
 #include <sys/proc.h>
 extern sbintime_t rtems_bsd_sbt_per_watchdog_tick;
diff --git a/rtemsbsd/rtems/rtems-kernel-epoch.c b/rtemsbsd/rtems/rtems-kernel-epoch.c
index 642b5854..858aa4ba 100644
--- a/rtemsbsd/rtems/rtems-kernel-epoch.c
+++ b/rtemsbsd/rtems/rtems-kernel-epoch.c
@@ -32,8 +32,8 @@
 #include <sys/types.h>
 #include <sys/kernel.h>
-#include <sys/epoch.h>
 #include <sys/mutex.h>
+#include <sys/epoch.h>
 #include <sys/sx.h>
 #include <sys/systm.h>
diff --git a/rtemsbsd/rtems/rtems-kernel-jail.c b/rtemsbsd/rtems/rtems-kernel-jail.c
index e53e4cc2..da538856 100644
--- a/rtemsbsd/rtems/rtems-kernel-jail.c
+++ b/rtemsbsd/rtems/rtems-kernel-jail.c
@@ -97,10 +97,12 @@ struct prison prison0 = {
    * structure.
   .pr_mtx = {
-    .lock_object = { .lo_flags = LO_INITIALIZED },
-    .mutex = {
-      .queue = THREAD_QUEUE_INITIALIZER("jail mutex"),
-      .nest_level = 0
+    .lock_object = {
+      .lo_flags = LO_INITIALIZED,
+      .lo_mtx = {
+	.queue = THREAD_QUEUE_INITIALIZER("jail mutex"),
+	.nest_level = 0
diff --git a/rtemsbsd/rtems/rtems-kernel-lockmgr.c b/rtemsbsd/rtems/rtems-kernel-lockmgr.c
new file mode 100644
index 00000000..518f6831
--- /dev/null
+++ b/rtemsbsd/rtems/rtems-kernel-lockmgr.c
@@ -0,0 +1,579 @@
+ * @file
+ * @ingroup rtems_bsd_rtems
+ * @brief TODO.
+ * Copyright (c) 2020 Chris Johns.  All rights reserved.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <machine/rtems-bsd-kernel-space.h>
+#include <machine/rtems-bsd-muteximpl.h>
+#include <machine/rtems-bsd-thread.h>
+#include <sys/types.h>
+#include <sys/param.h>
+#include <sys/systm.h>
+#include <sys/conf.h>
+#include <sys/lock.h>
+#include <sys/lockmgr.h>
+#include <sys/mutex.h>
+#include <sys/proc.h>
+#ifdef DEBUG_LOCKS
+#define STACK_PRINT(lk) printf("caller: %p\n", (lk)->lk_stack)
+#define STACK_SAVE(lk) (lk)->lk_stack = __builtin_return_address(0)
+#define STACK_ZERO(lk) (lk)->lk_stack = NULL
+#else
+#endif
+static void assert_lockmgr(const struct lock_object *lock, int how);
+static void lock_lockmgr(struct lock_object *lock, uintptr_t how);
+static uintptr_t unlock_lockmgr(struct lock_object *lock);
+#define lockmgr_xlocked(lk)    \
+	rtems_bsd_mutex_owned( \
+	    RTEMS_DECONST(struct lock_object *, &lk->lock_object))
+#define lockmgr_disowned(lk)    \
+	!rtems_bsd_mutex_owned( \
+struct lock_class lock_class_lockmgr = {
+	.lc_name = "lockmgr",
+	.lc_flags = LC_RECURSABLE | LC_SLEEPABLE | LC_SLEEPLOCK | LC_UPGRADABLE,
+	.lc_assert = assert_lockmgr,
+#ifdef DDB
+	.lc_ddb_show = db_show_lockmgr,
+#endif
+	.lc_lock = lock_lockmgr,
+	.lc_unlock = unlock_lockmgr,
+#ifdef KDTRACE_HOOKS
+	.lc_owner = owner_lockmgr,
+#endif
+static void
+assert_lockmgr(const struct lock_object *lock, int what)
+	panic("lockmgr locks do not support assertions");
+static void
+lock_lockmgr(struct lock_object *lock, uintptr_t how)
+	panic("lockmgr locks do not support sleep interlocking : lock");
+static uintptr_t
+unlock_lockmgr(struct lock_object *lock)
+	panic("lockmgr locks do not support sleep interlocking: unlock");
+static struct thread *
+lockmgr_xholder(const struct lock *lk)
+	uintptr_t x;
+	x = lk->lk_lock;
+	if ((x & LK_SHARE))
+		return NULL;
+	return rtems_bsd_get_thread(lk->lock_object.lo_mtx.queue.Queue.owner);
+static void
+lockmgr_exit(u_int flags, struct lock_object *ilk, int wakeup_swapper)
+	if (flags & LK_INTERLOCK) {
+		struct lock_class *class = LOCK_CLASS(ilk);
+		class->lc_unlock(ilk);
+#ifdef RTEMS_BSD_LOCKMGR_TRACE
+static void
+lockmgr_trace(const char *label, const char dir, const struct lock *lk)
+	printf("bsd: lck: %s %c lk=%p (%s) lk_lock=%08x rec=%d mtx=%c/%d\n",
+	    label, dir, lk, lk->lock_object.lo_mtx.queue.Queue.name,
+	    lk->lk_lock, lk->lk_recurse,
+	    lk->lock_object.lo_mtx.queue.Queue.owner != NULL ? 'L' : 'U',
+	    lk->lock_object.lo_mtx.nest_level);
+#else
+#define lockmgr_trace(lm, d, lk)
+#endif
+static int
+lockmgr_slock_hard(struct lock *lk, u_int flags, struct lock_object *ilk,
+    const char *file, int line)
+	uintptr_t x;
+	lockmgr_trace("slock", 'I', lk);
+	rtems_bsd_mutex_lock(&lk->lock_object);
+	x = lk->lk_lock;
+	atomic_store_rel_ptr(&lk->lk_lock, x + LK_ONE_SHARER);
+	lockmgr_trace("slock", 'O', lk);
+	LOCK_LOG_LOCK("SLOCK", &lk->lock_object, 0, lk->lk_recurse, file, line);
+	lockmgr_exit(flags, ilk, 0);
+	return 0;
+static int
+lockmgr_xlock_hard(struct lock *lk, u_int flags, struct lock_object *ilk,
+	int error = 0;
+	lockmgr_trace("xlock", 'I', lk);
+	if ((flags & LK_NOWAIT) != 0) {
+		if (!rtems_bsd_mutex_trylock(&lk->lock_object))
+			error = EBUSY;
+	} else {
+	if (error == 0) {
+		atomic_store_rel_ptr(&lk->lk_lock, 0);
+		lockmgr_trace("xlock", 'O', lk);
+	return error;
+static int
+lockmgr_upgrade(struct lock *lk, u_int flags, struct lock_object *ilk,
+	uintptr_t x, v;
+	int error = 0;
+	 * RTEMS does not support shared locks so locking a shared
+	 * lock is locking an exclusive lock. This logic is here to
+	 * track the shared vs exclusive logic so the VFS does not get
+	 * upset.
+	LOCK_LOG_LOCK("XUPGRADE", &lk->lock_object, 0, 0, file, line);
+	lockmgr_trace("xupgrade", 'I', lk);
+	v = lk->lk_lock;
+	x = v & ~LK_SHARE;
+	atomic_store_rel_ptr(&lk->lk_lock, x);
+	lockmgr_trace("xupgrade", 'O', lk);
+	return error;
+static int
+lockmgr_downgrade(struct lock *lk, u_int flags, struct lock_object *ilk,
+	uintptr_t x;
+	LOCK_LOG_LOCK("XDOWNGRADE", &lk->lock_object, 0, 0, file, line);
+	lockmgr_trace("xdowngrade", 'I', lk);
+	x = lk->lk_lock;
+	x &= LK_ALL_WAITERS;
+	lockmgr_trace("xdowngrade", 'O', lk);
+	return 0;
+int
+lockmgr_lock_fast_path(struct lock *lk, u_int flags, struct lock_object *ilk,
+	uintptr_t x, tid;
+	u_int op;
+	bool locked;
+	if (__predict_false(panicstr != NULL))
+		return (0);
+	op = flags & LK_TYPE_MASK;
+	locked = false;
+	switch (op) {
+	case LK_SHARED:
+		if (!__predict_false(lk->lock_object.lo_flags & LK_NOSHARE))
+			return (lockmgr_slock_hard(lk, flags, ilk, file, line));
+		/* fall through */
+	case LK_EXCLUSIVE:
+		return (lockmgr_xlock_hard(lk, flags, ilk, file, line));
+		break;
+	case LK_UPGRADE:
+	case LK_TRYUPGRADE:
+		return (lockmgr_upgrade(lk, flags, ilk, file, line));
+		break;
+	case LK_DOWNGRADE:
+		return (lockmgr_downgrade(lk, flags, ilk, file, line));
+		break;
+	default:
+		break;
+	panic("unsupported lockmgr op: %d\n", op);
+static int
+lockmgr_sunlock_hard(struct lock *lk, uintptr_t x, u_int flags,
+    struct lock_object *ilk, const char *file, int line)
+	uintptr_t v;
+	int error = 0;
+	LOCK_LOG_LOCK(
+	    "SUNLOCK", &lk->lock_object, 0, lk->lk_recurse, file, line);
+	lockmgr_trace("sunlock", 'I', lk);
+	x = lk->lk_lock;
+	if (x == LK_UNLOCKED)
+		panic("sunlock not locked");
+	atomic_store_rel_ptr(&lk->lk_lock, x - LK_ONE_SHARER);
+	rtems_bsd_mutex_unlock(&lk->lock_object);
+	lockmgr_trace("sunlock", 'O', lk);
+	return error;
+static int
+lockmgr_xunlock_hard(struct lock *lk, uintptr_t x, u_int flags,
+	int error = 0;
+	LOCK_LOG_LOCK(
+	    "XUNLOCK", &lk->lock_object, 0, lk->lk_recurse, file, line);
+	lockmgr_trace("xunlock", 'I', lk);
+	if (lk->lk_recurse == 0) {
+		uintptr_t v, x;
+		x = lk->lk_lock;
+		if (x != 0)
+			x -= LK_ONE_SHARER;
+		v = x | LK_SHARE;
+		atomic_store_rel_ptr(&lk->lk_lock, v);
+	lockmgr_trace("xunlock", 'O', lk);
+	return error;
+int
+lockmgr_unlock_fast_path(struct lock *lk, u_int flags, struct lock_object *ilk)
+	struct lock_class *class;
+	uintptr_t x, tid;
+	const char *file;
+	int line;
+		return (0);
+	file = __FILE__;
+	line = __LINE__;
+	x = lk->lk_lock;
+	if (__predict_true(x & LK_SHARE) != 0) {
+		return (lockmgr_sunlock_hard(lk, x, flags, ilk, file, line));
+	} else {
+		return (lockmgr_xunlock_hard(lk, x, flags, ilk, file, line));
+int
+lockstatus(const struct lock *lk)
+	uintptr_t v, x;
+	int ret = 0;
+	ret = LK_SHARED;
+	x = lk->lk_lock;
+	if ((x & LK_SHARE) == 0) {
+		v = rtems_bsd_mutex_owned(
+		    RTEMS_DECONST(struct lock_object *, &lk->lock_object));
+		if (v)
+			ret = LK_EXCLUSIVE;
+		else
+			ret = LK_EXCLOTHER;
+	} else if (x == LK_UNLOCKED) {
+		ret = 0;
+	lockmgr_trace("status", 'O', lk);
+	return (ret);
+void
+lockallowrecurse(struct lock *lk)
+	lk->lock_object.lo_flags |= LO_RECURSABLE;
+void
+lockallowshare(struct lock *lk)
+	lk->lock_object.lo_flags &= ~LK_NOSHARE;
+void
+lockdisablerecurse(struct lock *lk)
+	lk->lock_object.lo_flags &= ~LO_RECURSABLE;
+void
+lockdisableshare(struct lock *lk)
+	lk->lock_object.lo_flags |= LK_NOSHARE;
+void
+lockinit(struct lock *lk, int pri, const char *wmesg, int timo, int flags)
+	int iflags;
+	MPASS((flags & ~LK_INIT_MASK) == 0);
+	ASSERT_ATOMIC_LOAD_PTR(lk->lk_lock,
+	    ("%s: lockmgr not aligned for %s: %p", __func__, wmesg,
+		&lk->lk_lock));
+	iflags = LO_SLEEPABLE | LO_UPGRADABLE;
+	if (flags & LK_CANRECURSE)
+		iflags |= LO_RECURSABLE;
+	if ((flags & LK_NODUP) == 0)
+		iflags |= LO_DUPOK;
+	if (flags & LK_NOPROFILE)
+		iflags |= LO_NOPROFILE;
+	if ((flags & LK_NOWITNESS) == 0)
+		iflags |= LO_WITNESS;
+	if (flags & LK_QUIET)
+		iflags |= LO_QUIET;
+	if (flags & LK_IS_VNODE)
+		iflags |= LO_IS_VNODE;
+	iflags |= flags & (LK_ADAPTIVE | LK_NOSHARE);
+	rtems_bsd_mutex_init(
+	    &lk->lock_object, &lock_class_lockmgr, wmesg, NULL, iflags);
+	lk->lk_lock = LK_UNLOCKED;
+	lk->lk_exslpfail = 0;
+	lk->lk_timo = timo;
+	lk->lk_pri = pri;
+	STACK_ZERO(lk);
+void
+lockdestroy(struct lock *lk)
+	KASSERT(lk->lk_lock == LK_UNLOCKED, ("lockmgr still held"));
+	KASSERT(lk->lk_recurse == 0, ("lockmgr still recursed"));
+	KASSERT(lk->lk_exslpfail == 0, ("lockmgr still exclusive waiters"));
+	rtems_bsd_mutex_destroy(&lk->lock_object);
+void
+lockmgr_printinfo(const struct lock *lk)
+	struct thread *td;
+	uintptr_t x;
+	if (lk->lk_lock == LK_UNLOCKED)
+		printf("lock type %s: UNLOCKED\n", lk->lock_object.lo_name);
+	else if (lk->lk_lock & LK_SHARE)
+		printf("lock type %s: SHARED (count %ju)\n",
+		    lk->lock_object.lo_name,
+		    (uintmax_t)LK_SHARERS(lk->lk_lock));
+	else {
+		td = lockmgr_xholder(lk);
+		if (td == NULL)
+			printf("lock type %s: not owned\n",
+			    lk->lock_object.lo_name);
+		else
+			printf("lock type %s: EXCL by thread %p "
+			       "(pid %d, rtems, tid %d)\n",
+			    lk->lock_object.lo_name, td, td->td_proc->p_pid,
+			    td->td_tid);
+	x = lk->lk_lock;
+	if (x & LK_EXCLUSIVE_WAITERS)
+		printf(" with exclusive waiters pending\n");
+	if (x & LK_SHARED_WAITERS)
+		printf(" with shared waiters pending\n");
+	if (x & LK_EXCLUSIVE_SPINNERS)
+		printf(" with exclusive spinners pending\n");
+	STACK_PRINT(lk);
+int
+__lockmgr_args(struct lock *lk, u_int flags, struct lock_object *ilk,
+    const char *wmesg, int prio, int timo, const char *file, int line)
+	uintptr_t x;
+	u_int op = (flags & LK_TYPE_MASK);
+	int error = 0;
+	if (panicstr != NULL)
+		return (0);
+	class = (flags & LK_INTERLOCK) ? LOCK_CLASS(ilk) : NULL;
+	if (lk->lock_object.lo_flags & LK_NOSHARE) {
+		switch (op) {
+		case LK_SHARED:
+			op = LK_EXCLUSIVE;
+			break;
+		case LK_UPGRADE:
+			return (0);
+	switch (op) {
+	case LK_SHARED:
+		break;
+	case LK_UPGRADE:
+		break;
+		break;
+		error = lockmgr_downgrade(lk, flags, ilk, file, line);
+		break;
+	case LK_RELEASE:
+		lockmgr_trace("release", '-', lk);
+		x = lk->lk_lock;
+			    lk, x, flags, ilk, file, line));
+		} else {
+		break;
+	case LK_DRAIN:
+		break;
+	default:
+		panic("%s: unknown lockmgr request 0x%x\n", __func__, op);
+	return (error);
+void
+_lockmgr_disown(struct lock *lk, const char *file, int line)
+#ifdef INVARIANT_SUPPORT
+#ifndef INVARIANTS
+#undef _lockmgr_assert
+#endif
+void
+_lockmgr_assert(const struct lock *lk, int what, const char *file, int line)
+	int slocked = 0;
+		return;
+	switch (what) {
+	case KA_SLOCKED:
+	case KA_SLOCKED | KA_NOTRECURSED:
+	case KA_SLOCKED | KA_RECURSED:
+		slocked = 1;
+	case KA_LOCKED:
+	case KA_LOCKED | KA_NOTRECURSED:
+	case KA_LOCKED | KA_RECURSED:
+#ifdef WITNESS
+		 * We cannot trust WITNESS if the lock is held in exclusive
+		 * mode and a call to lockmgr_disown() happened.
+		 * Workaround this skipping the check if the lock is held in
+		 * exclusive mode even for the KA_LOCKED case.
+		if (slocked || (lk->lk_lock & LK_SHARE)) {
+			witness_assert(&lk->lock_object, what, file, line);
+			break;
+#endif
+		if (lk->lk_lock == LK_UNLOCKED ||
+		    ((lk->lk_lock & LK_SHARE) == 0 &&
+			(slocked ||
+			    (!lockmgr_xlocked(lk) && !lockmgr_disowned(lk)))))
+			panic("Lock %s not %slocked @ %s:%d\n",
+			    lk->lock_object.lo_name, slocked ? "share" : "",
+			    file, line);
+		if ((lk->lk_lock & LK_SHARE) == 0) {
+			if (lockmgr_recursed(lk)) {
+				if (what & KA_NOTRECURSED)
+					panic("Lock %s recursed @ %s:%d\n",
+					    lk->lock_object.lo_name, file,
+					    line);
+			} else if (what & KA_RECURSED)
+				panic("Lock %s not recursed @ %s:%d\n",
+				    lk->lock_object.lo_name, file, line);
+		break;
+	case KA_XLOCKED:
+	case KA_XLOCKED | KA_NOTRECURSED:
+	case KA_XLOCKED | KA_RECURSED:
+		if (!lockmgr_xlocked(lk) && !lockmgr_disowned(lk))
+			panic("Lock %s not exclusively locked @ %s:%d\n",
+		break;
+	case KA_UNLOCKED:
+		if (lockmgr_xlocked(lk) || lockmgr_disowned(lk))
+			panic("Lock %s exclusively locked @ %s:%d\n",
+		break;
+	default:
+		panic("Unknown lockmgr assertion: %d @ %s:%d\n", what, file,
+		    line);
+#endif
diff --git a/rtemsbsd/rtems/rtems-kernel-mutex.c b/rtemsbsd/rtems/rtems-kernel-mutex.c
index 47f36832..7cd3851a 100644
--- a/rtemsbsd/rtems/rtems-kernel-mutex.c
+++ b/rtemsbsd/rtems/rtems-kernel-mutex.c
@@ -48,6 +48,11 @@
+#if RTEMS_DEBUG
+struct _bsd_mutex_list _bsd_mutexlist = TAILQ_HEAD_INITIALIZER(_bsd_mutexlist);
+rtems_mutex _bsd_mutexlist_lock = RTEMS_MUTEX_INITIALIZER("mmutexlist");
 static void	assert_mtx(const struct lock_object *lock, int what);
 static void	lock_mtx(struct lock_object *lock, uintptr_t how);
 static uintptr_t unlock_mtx(struct lock_object *lock);
@@ -110,26 +115,26 @@ mtx_init(struct mtx *m, const char *name, const char *type, int opts)
 	if (opts & MTX_RECURSE)
-	rtems_bsd_mutex_init(&m->lock_object, &m->mutex, class, name, type,
+	rtems_bsd_mutex_init(&m->lock_object, class, name, type,
 	    flags);
 void
 _mtx_lock_flags(struct mtx *m, int opts, const char *file, int line)
-	rtems_bsd_mutex_lock(&m->lock_object, &m->mutex);
+	rtems_bsd_mutex_lock(&m->lock_object);
 int
 mtx_trylock_flags_(struct mtx *m, int opts, const char *file, int line)
-	return (rtems_bsd_mutex_trylock(&m->lock_object, &m->mutex));
+	return (rtems_bsd_mutex_trylock(&m->lock_object));
 void
 _mtx_unlock_flags(struct mtx *m, int opts, const char *file, int line)
-	rtems_bsd_mutex_unlock(&m->mutex);
+	rtems_bsd_mutex_unlock(&m->lock_object);
@@ -139,7 +144,7 @@ _mtx_unlock_flags(struct mtx *m, int opts, const char *file, int line)
 void
 _mtx_assert(struct mtx *m, int what, const char *file, int line)
-	const char *name = rtems_bsd_mutex_name(&m->mutex);
+	const char *name = rtems_bsd_mutex_name(&m->lock_object);
 	switch (what) {
 	case MA_OWNED:
@@ -168,12 +173,12 @@ _mtx_assert(struct mtx *m, int what, const char *file, int line)
 int mtx_owned(struct mtx *m)
-	return (rtems_bsd_mutex_owned(&m->mutex));
+	return (rtems_bsd_mutex_owned(&m->lock_object));
 int mtx_recursed(struct mtx *m)
-	return (rtems_bsd_mutex_recursed(&m->mutex));
+	return (rtems_bsd_mutex_recursed(&m->lock_object));
 void
@@ -188,7 +193,7 @@ void
 mtx_destroy(struct mtx *m)
-	rtems_bsd_mutex_destroy(&m->lock_object, &m->mutex);
+	rtems_bsd_mutex_destroy(&m->lock_object);
 void
diff --git a/rtemsbsd/rtems/rtems-kernel-muteximpl.c b/rtemsbsd/rtems/rtems-kernel-muteximpl.c
index 8a832b4e..a57d1bc8 100644
--- a/rtemsbsd/rtems/rtems-kernel-muteximpl.c
+++ b/rtemsbsd/rtems/rtems-kernel-muteximpl.c
@@ -43,12 +43,13 @@
 void
-rtems_bsd_mutex_lock_more(struct lock_object *lock, rtems_bsd_mutex *m,
+rtems_bsd_mutex_lock_more(struct lock_object *lk,
 			_Thread_queue_Release(&m->queue, queue_context);
 			panic("mutex lock: %s: not LO_RECURSABLE\n",
diff --git a/rtemsbsd/rtems/rtems-kernel-rwlock.c b/rtemsbsd/rtems/rtems-kernel-rwlock.c
index c204c04f..a4e98edd 100644
--- a/rtemsbsd/rtems/rtems-kernel-rwlock.c
+++ b/rtemsbsd/rtems/rtems-kernel-rwlock.c
@@ -70,9 +70,9 @@ struct lock_class lock_class_rw = {
 	.lc_unlock = unlock_rw,
-#define	rw_wowner(rw) rtems_bsd_mutex_owner(&(rw)->mutex)
+#define	rw_wowner(rw) rtems_bsd_mutex_owner(&(rw)->lock_object)
-#define	rw_recursed(rw) rtems_bsd_mutex_recursed(&(rw)->mutex)
+#define	rw_recursed(rw) rtems_bsd_mutex_recursed(&(rw)->lock_object)
 void
 assert_rw(const struct lock_object *lock, int what)
@@ -101,11 +101,9 @@ rw_init_flags(struct rwlock *rw, const char *name, int opts)
 	int flags;
-	flags = LO_UPGRADABLE;
-	if (opts & RW_RECURSE)
-		flags |= LO_RECURSABLE;
+	flags = LO_UPGRADABLE | LO_RECURSABLE;
-	rtems_bsd_mutex_init(&rw->lock_object, &rw->mutex, &lock_class_rw,
+	rtems_bsd_mutex_init(&rw->lock_object, &lock_class_rw,
 	    name, NULL, flags);
@@ -113,7 +111,7 @@ void
 rw_destroy(struct rwlock *rw)
-	rtems_bsd_mutex_destroy(&rw->lock_object, &rw->mutex);
+	rtems_bsd_mutex_destroy(&rw->lock_object);
 void
@@ -128,43 +126,43 @@ rw_sysinit(void *arg)
 int
 rw_wowned(struct rwlock *rw)
-	return (rtems_bsd_mutex_owned(&rw->mutex));
+	return (rtems_bsd_mutex_owned(&rw->lock_object));
 void
 _rw_wlock(struct rwlock *rw, const char *file, int line)
-	rtems_bsd_mutex_lock(&rw->lock_object, &rw->mutex);
+	rtems_bsd_mutex_lock(&rw->lock_object);
 int
 _rw_try_wlock(struct rwlock *rw, const char *file, int line)
-	return (rtems_bsd_mutex_trylock(&rw->lock_object, &rw->mutex));
+	return (rtems_bsd_mutex_trylock(&rw->lock_object));
 void
 _rw_wunlock(struct rwlock *rw, const char *file, int line)
-	rtems_bsd_mutex_unlock(&rw->mutex);
+	rtems_bsd_mutex_unlock(&rw->lock_object);
 void
 _rw_rlock(struct rwlock *rw, const char *file, int line)
 int
 _rw_try_rlock(struct rwlock *rw, const char *file, int line)
 void
 _rw_runlock(struct rwlock *rw, const char *file, int line)
 int
@@ -188,7 +186,7 @@ _rw_downgrade(struct rwlock *rw, const char *file, int line)
 void
 _rw_assert(const struct rwlock *rw, int what, const char *file, int line)
-	const char *name = rtems_bsd_mutex_name(&rw->mutex);
+	const char *name = rtems_bsd_mutex_name(&rw->lock_object);
 	switch (what) {
 	case RA_LOCKED:
diff --git a/rtemsbsd/rtems/rtems-kernel-sx.c b/rtemsbsd/rtems/rtems-kernel-sx.c
index 4f8bea4d..827b3397 100644
--- a/rtemsbsd/rtems/rtems-kernel-sx.c
+++ b/rtemsbsd/rtems/rtems-kernel-sx.c
@@ -59,9 +59,9 @@ struct lock_class lock_class_sx = {
 	.lc_unlock = unlock_sx,
-#define	sx_xholder(sx) rtems_bsd_mutex_owner(&(sx)->mutex)
+#define	sx_xholder(sx) rtems_bsd_mutex_owner(&(sx)->lock_object)
-#define	sx_recursed(sx) rtems_bsd_mutex_recursed(&(sx)->mutex)
+#define	sx_recursed(sx) rtems_bsd_mutex_recursed(&(sx)->lock_object)
 void
 assert_sx(const struct lock_object *lock, int what)
@@ -90,7 +90,7 @@ sx_sysinit(void *arg)
 	struct sx_args *sargs = arg;
-	sx_init(sargs->sa_sx, sargs->sa_desc);
+	sx_init_flags(sargs->sa_sx, sargs->sa_desc, sargs->sa_flags);
 void
@@ -102,7 +102,7 @@ sx_init_flags(struct sx *sx, const char *description, int opts)
 	if (opts & SX_RECURSE)
-	rtems_bsd_mutex_init(&sx->lock_object, &sx->mutex, &lock_class_sx,
+	rtems_bsd_mutex_init(&sx->lock_object, &lock_class_sx,
 	    description, NULL, flags);
@@ -110,14 +110,14 @@ void
 sx_destroy(struct sx *sx)
-	rtems_bsd_mutex_destroy(&sx->lock_object, &sx->mutex);
+	rtems_bsd_mutex_destroy(&sx->lock_object);
 int
 _sx_slock_int(struct sx *sx, int opts LOCK_FILE_LINE_ARG_DEF)
-	rtems_bsd_mutex_lock(&sx->lock_object, &sx->mutex);
+	rtems_bsd_mutex_lock(&sx->lock_object);
 	return (0);
@@ -125,14 +125,14 @@ int
 sx_try_slock_int(struct sx *sx LOCK_FILE_LINE_ARG_DEF)
-	return (rtems_bsd_mutex_trylock(&sx->lock_object, &sx->mutex));
+	return (rtems_bsd_mutex_trylock(&sx->lock_object));
 void
 _sx_sunlock_int(struct sx *sx LOCK_FILE_LINE_ARG_DEF)
-	rtems_bsd_mutex_unlock(&sx->mutex);
+	rtems_bsd_mutex_unlock(&sx->lock_object);
 int
@@ -142,6 +142,13 @@ sx_try_upgrade_int(struct sx *sx LOCK_FILE_LINE_ARG_DEF)
 	return (1);
+int
+sx_try_upgrade_(struct sx *sx, const char *file, int line)
+	return (1);
 void
 sx_downgrade_int(struct sx *sx LOCK_FILE_LINE_ARG_DEF)
@@ -149,6 +156,13 @@ sx_downgrade_int(struct sx *sx LOCK_FILE_LINE_ARG_DEF)
 	/* Do nothing */
+int
+sx_try_downgrade_(struct sx *sx, const char *file, int line)
+	return (1);
  * In the non-WITNESS case, sx_assert() can only detect that at least
@@ -158,7 +172,7 @@ sx_downgrade_int(struct sx *sx LOCK_FILE_LINE_ARG_DEF)
 void
 _sx_assert(const struct sx *sx, int what, const char *file, int line)
-	const char *name = rtems_bsd_mutex_name(&sx->mutex);
+	const char *name = rtems_bsd_mutex_name(&sx->lock_object);
 	switch (what) {
 	case SA_SLOCKED:
@@ -205,5 +219,5 @@ _sx_assert(const struct sx *sx, int what, const char *file, int line)
 int
 sx_xlocked(struct sx *sx)
-	return (rtems_bsd_mutex_owned(&sx->mutex));
+	return (rtems_bsd_mutex_owned(&sx->lock_object));
2.24.1
