[PATCH rtems-libbsd v4 09/19] kern: Import kern_prot.c fnd kern_resource.c for proc0
chrisj at rtems.org chrisj at rtems.org
Wed Aug 4 08:53:19 UTC 2021
Update #4475
 freebsd/sys/kern/kern_prot.c     | 2247 ++++++++++++++++++++++++++++++
 freebsd/sys/kern/kern_resource.c | 1539 ++++++++++++++++++++
 2 files changed, 3786 insertions(+)
 create mode 100644 freebsd/sys/kern/kern_prot.c
 create mode 100644 freebsd/sys/kern/kern_resource.c
diff --git a/freebsd/sys/kern/kern_prot.c b/freebsd/sys/kern/kern_prot.c
new file mode 100644
index 00000000..a62b6f76
--- /dev/null
+++ b/freebsd/sys/kern/kern_prot.c
@@ -0,0 +1,2247 @@
+ * SPDX-License-Identifier: BSD-3-Clause
+ * Copyright (c) 1982, 1986, 1989, 1990, 1991, 1993
+ *	The Regents of the University of California.
+ * (c) UNIX System Laboratories, Inc.
+ * Copyright (c) 2000-2001 Robert N. M. Watson.
+ * All rights reserved.
+ * All or some portions of this file are derived from material licensed
+ * to the University of California by American Telephone and Telegraph
+ * Co. or Unix System Laboratories, Inc. and are reproduced herein with
+ * the permission of UNIX System Laboratories, Inc.
+ * are met:
+ * 3. Neither the name of the University nor the names of its contributors
+ *    may be used to endorse or promote products derived from this software
+ *    without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ *	@(#)kern_prot.c	8.6 (Berkeley) 1/21/94
+ * System calls related to processes and protection
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+#include "opt_inet.h"
+#include "opt_inet6.h"
+#include <sys/param.h>
+#include <sys/systm.h>
+#include <sys/acct.h>
+#include <sys/kdb.h>
+#include <sys/kernel.h>
+#include <sys/lock.h>
+#include <sys/loginclass.h>
+#include <sys/malloc.h>
+#include <sys/mutex.h>
+#include <sys/refcount.h>
+#include <sys/sx.h>
+#include <sys/priv.h>
+#include <sys/proc.h>
+#include <sys/sysent.h>
+#include <sys/sysproto.h>
+#include <sys/jail.h>
+#include <sys/pioctl.h>
+#include <sys/racct.h>
+#include <sys/rctl.h>
+#include <sys/resourcevar.h>
+#include <sys/socket.h>
+#include <sys/socketvar.h>
+#include <sys/syscallsubr.h>
+#include <sys/sysctl.h>
+#ifdef REGRESSION
+FEATURE(regression,
+    "Kernel support for interfaces necessary for regression testing (SECURITY RISK!)");
+#endif
+#include <security/audit/audit.h>
+#include <security/mac/mac_framework.h>
+static MALLOC_DEFINE(M_CRED, "cred", "credentials");
+SYSCTL_NODE(_security, OID_AUTO, bsd, CTLFLAG_RW, 0, "BSD security policy");
+static void crsetgroups_locked(struct ucred *cr, int ngrp,
+    gid_t *groups);
+#ifndef _SYS_SYSPROTO_H_
+struct getpid_args {
+	int	dummy;
+#endif
+/* ARGSUSED */
+int
+sys_getpid(struct thread *td, struct getpid_args *uap)
+	struct proc *p = td->td_proc;
+	td->td_retval[0] = p->p_pid;
+#if defined(COMPAT_43)
+	if (SV_PROC_FLAG(p, SV_AOUT))
+		td->td_retval[1] = kern_getppid(td);
+#endif
+	return (0);
+struct getppid_args {
+        int     dummy;
+#endif
+/* ARGSUSED */
+int
+sys_getppid(struct thread *td, struct getppid_args *uap)
+	td->td_retval[0] = kern_getppid(td);
+	return (0);
+int
+kern_getppid(struct thread *td)
+	return (p->p_oppid);
+ * Get process group ID; note that POSIX getpgrp takes no parameter.
+struct getpgrp_args {
+        int     dummy;
+#endif
+int
+sys_getpgrp(struct thread *td, struct getpgrp_args *uap)
+	PROC_LOCK(p);
+	td->td_retval[0] = p->p_pgrp->pg_id;
+	PROC_UNLOCK(p);
+	return (0);
+/* Get an arbitrary pid's process group id */
+struct getpgid_args {
+	pid_t	pid;
+#endif
+int
+sys_getpgid(struct thread *td, struct getpgid_args *uap)
+	struct proc *p;
+	int error;
+	if (uap->pid == 0) {
+		p = td->td_proc;
+		PROC_LOCK(p);
+	} else {
+		p = pfind(uap->pid);
+		if (p == NULL)
+			return (ESRCH);
+		error = p_cansee(td, p);
+		if (error) {
+			PROC_UNLOCK(p);
+			return (error);
+	PROC_UNLOCK(p);
+	return (0);
+ * Get an arbitrary pid's session id.
+struct getsid_args {
+	pid_t	pid;
+#endif
+int
+sys_getsid(struct thread *td, struct getsid_args *uap)
+	struct proc *p;
+	int error;
+		p = td->td_proc;
+		PROC_LOCK(p);
+	} else {
+		if (p == NULL)
+			return (ESRCH);
+		if (error) {
+			PROC_UNLOCK(p);
+			return (error);
+	td->td_retval[0] = p->p_session->s_sid;
+	PROC_UNLOCK(p);
+	return (0);
+struct getuid_args {
+        int     dummy;
+#endif
+/* ARGSUSED */
+int
+sys_getuid(struct thread *td, struct getuid_args *uap)
+	td->td_retval[0] = td->td_ucred->cr_ruid;
+	td->td_retval[1] = td->td_ucred->cr_uid;
+#endif
+	return (0);
+struct geteuid_args {
+        int     dummy;
+#endif
+/* ARGSUSED */
+int
+sys_geteuid(struct thread *td, struct geteuid_args *uap)
+	td->td_retval[0] = td->td_ucred->cr_uid;
+	return (0);
+struct getgid_args {
+        int     dummy;
+#endif
+/* ARGSUSED */
+int
+sys_getgid(struct thread *td, struct getgid_args *uap)
+	td->td_retval[0] = td->td_ucred->cr_rgid;
+	td->td_retval[1] = td->td_ucred->cr_groups[0];
+#endif
+	return (0);
+ * Get effective group ID.  The "egid" is groups[0], and could be obtained
+ * via getgroups.  This syscall exists because it is somewhat painful to do
+ * correctly in a library function.
+struct getegid_args {
+        int     dummy;
+#endif
+/* ARGSUSED */
+int
+sys_getegid(struct thread *td, struct getegid_args *uap)
+	td->td_retval[0] = td->td_ucred->cr_groups[0];
+	return (0);
+struct getgroups_args {
+	u_int	gidsetsize;
+	gid_t	*gidset;
+#endif
+int
+sys_getgroups(struct thread *td, struct getgroups_args *uap)
+	struct ucred *cred;
+	u_int ngrp;
+	int error;
+	cred = td->td_ucred;
+	ngrp = cred->cr_ngroups;
+	if (uap->gidsetsize == 0) {
+		error = 0;
+		goto out;
+	if (uap->gidsetsize < ngrp)
+		return (EINVAL);
+	error = copyout(cred->cr_groups, uap->gidset, ngrp * sizeof(gid_t));
+out:
+	td->td_retval[0] = ngrp;
+	return (error);
+struct setsid_args {
+        int     dummy;
+#endif
+/* ARGSUSED */
+int
+sys_setsid(struct thread *td, struct setsid_args *uap)
+	struct pgrp *pgrp;
+	int error;
+	struct pgrp *newpgrp;
+	struct session *newsess;
+	error = 0;
+	pgrp = NULL;
+	newpgrp = malloc(sizeof(struct pgrp), M_PGRP, M_WAITOK | M_ZERO);
+	newsess = malloc(sizeof(struct session), M_SESSION, M_WAITOK | M_ZERO);
+	sx_xlock(&proctree_lock);
+	if (p->p_pgid == p->p_pid || (pgrp = pgfind(p->p_pid)) != NULL) {
+		if (pgrp != NULL)
+			PGRP_UNLOCK(pgrp);
+		error = EPERM;
+	} else {
+		(void)enterpgrp(p, p->p_pid, newpgrp, newsess);
+		newpgrp = NULL;
+		newsess = NULL;
+	sx_xunlock(&proctree_lock);
+	if (newpgrp != NULL)
+		free(newpgrp, M_PGRP);
+	if (newsess != NULL)
+		free(newsess, M_SESSION);
+	return (error);
+ * set process group (setpgid/old setpgrp)
+ * caller does setpgid(targpid, targpgid)
+ * pid must be caller or child of caller (ESRCH)
+ * if a child
+ *	pid must be in same session (EPERM)
+ *	pid can't have done an exec (EACCES)
+ * if pgid != pid
+ * 	there must exist some pid in same session having pgid (EPERM)
+ * pid must not be session leader (EPERM)
+struct setpgid_args {
+	int	pid;		/* target process id */
+	int	pgid;		/* target pgrp id */
+#endif
+/* ARGSUSED */
+int
+sys_setpgid(struct thread *td, struct setpgid_args *uap)
+	struct proc *curp = td->td_proc;
+	struct proc *targp;	/* target process */
+	struct pgrp *pgrp;	/* target pgrp */
+	int error;
+	if (uap->pgid < 0)
+		return (EINVAL);
+	error = 0;
+	if (uap->pid != 0 && uap->pid != curp->p_pid) {
+		if ((targp = pfind(uap->pid)) == NULL) {
+			error = ESRCH;
+			goto done;
+		if (!inferior(targp)) {
+			PROC_UNLOCK(targp);
+			error = ESRCH;
+			goto done;
+		if ((error = p_cansee(td, targp))) {
+			goto done;
+		if (targp->p_pgrp == NULL ||
+		    targp->p_session != curp->p_session) {
+			error = EPERM;
+			goto done;
+		if (targp->p_flag & P_EXEC) {
+			error = EACCES;
+			goto done;
+	} else
+		targp = curp;
+	if (SESS_LEADER(targp)) {
+		error = EPERM;
+		goto done;
+	if (uap->pgid == 0)
+		uap->pgid = targp->p_pid;
+	if ((pgrp = pgfind(uap->pgid)) == NULL) {
+		if (uap->pgid == targp->p_pid) {
+			error = enterpgrp(targp, uap->pgid, newpgrp,
+			    NULL);
+			if (error == 0)
+				newpgrp = NULL;
+		} else
+			error = EPERM;
+	} else {
+		if (pgrp == targp->p_pgrp) {
+			goto done;
+		if (pgrp->pg_id != targp->p_pid &&
+		    pgrp->pg_session != curp->p_session) {
+			error = EPERM;
+			goto done;
+		error = enterthispgrp(targp, pgrp);
+done:
+	KASSERT((error == 0) || (newpgrp != NULL),
+	    ("setpgid failed and newpgrp is NULL"));
+	return (error);
+ * Use the clause in B.4.2.2 that allows setuid/setgid to be 4.2/4.3BSD
+ * compatible.  It says that setting the uid/gid to euid/egid is a special
+ * case of "appropriate privilege".  Once the rules are expanded out, this
+ * basically means that setuid(nnn) sets all three id's, in all permitted
+ * cases unless _POSIX_SAVED_IDS is enabled.  In that case, setuid(getuid())
+ * does not set the saved id - this is dangerous for traditional BSD
+ * programs.  For this reason, we *really* do not want to set
+ * _POSIX_SAVED_IDS and do not want to clear POSIX_APPENDIX_B_4_2_2.
+#define POSIX_APPENDIX_B_4_2_2
+struct setuid_args {
+	uid_t	uid;
+#endif
+/* ARGSUSED */
+int
+sys_setuid(struct thread *td, struct setuid_args *uap)
+	struct ucred *newcred, *oldcred;
+	uid_t uid;
+	struct uidinfo *uip;
+	int error;
+	uid = uap->uid;
+	AUDIT_ARG_UID(uid);
+	newcred = crget();
+	uip = uifind(uid);
+	PROC_LOCK(p);
+	 * Copy credentials so other references do not see our changes.
+	oldcred = crcopysafe(p, newcred);
+#ifdef MAC
+	error = mac_cred_check_setuid(oldcred, uid);
+	if (error)
+		goto fail;
+#endif
+	 * See if we have "permission" by POSIX 1003.1 rules.
+	 * Note that setuid(geteuid()) is a special case of
+	 * "appropriate privileges" in appendix B.4.2.2.  We need
+	 * to use this clause to be compatible with traditional BSD
+	 * semantics.  Basically, it means that "setuid(xx)" sets all
+	 * three id's (assuming you have privs).
+	 * Notes on the logic.  We do things in three steps.
+	 * 1: We determine if the euid is going to change, and do EPERM
+	 *    right away.  We unconditionally change the euid later if this
+	 *    test is satisfied, simplifying that part of the logic.
+	 * 2: We determine if the real and/or saved uids are going to
+	 *    change.  Determined by compile options.
+	 * 3: Change euid last. (after tests in #2 for "appropriate privs")
+	if (uid != oldcred->cr_ruid &&		/* allow setuid(getuid()) */
+#ifdef _POSIX_SAVED_IDS
+	    uid != oldcred->cr_svuid &&		/* allow setuid(saved gid) */
+#endif
+#ifdef POSIX_APPENDIX_B_4_2_2	/* Use BSD-compat clause from B.4.2.2 */
+	    uid != oldcred->cr_uid &&		/* allow setuid(geteuid()) */
+#endif
+	    (error = priv_check_cred(oldcred, PRIV_CRED_SETUID, 0)) != 0)
+		goto fail;
+	 * Do we have "appropriate privileges" (are we root or uid == euid)
+	 * If so, we are changing the real uid and/or saved uid.
+	if (
+#ifdef POSIX_APPENDIX_B_4_2_2	/* Use the clause from B.4.2.2 */
+	    uid == oldcred->cr_uid ||
+#endif
+	    /* We are using privs. */
+	    priv_check_cred(oldcred, PRIV_CRED_SETUID, 0) == 0)
+#endif
+		 * Set the real uid and transfer proc count to new user.
+		if (uid != oldcred->cr_ruid) {
+			change_ruid(newcred, uip);
+			setsugid(p);
+		 * Set saved uid
+		 * XXX always set saved uid even if not _POSIX_SAVED_IDS, as
+		 * the security of seteuid() depends on it.  B.4.2.2 says it
+		 * is important that we should do this.
+		if (uid != oldcred->cr_svuid) {
+			change_svuid(newcred, uid);
+			setsugid(p);
+	 * In all permitted cases, we are changing the euid.
+	if (uid != oldcred->cr_uid) {
+		change_euid(newcred, uip);
+		setsugid(p);
+	proc_set_cred(p, newcred);
+#ifdef RACCT
+	racct_proc_ucred_changed(p, oldcred, newcred);
+	crhold(newcred);
+#endif
+	PROC_UNLOCK(p);
+#ifdef RCTL
+	rctl_proc_ucred_changed(p, newcred);
+	crfree(newcred);
+#endif
+	uifree(uip);
+	crfree(oldcred);
+	return (0);
+fail:
+	PROC_UNLOCK(p);
+	uifree(uip);
+	crfree(newcred);
+	return (error);
+struct seteuid_args {
+	uid_t	euid;
+#endif
+/* ARGSUSED */
+int
+sys_seteuid(struct thread *td, struct seteuid_args *uap)
+	uid_t euid;
+	struct uidinfo *euip;
+	int error;
+	euid = uap->euid;
+	AUDIT_ARG_EUID(euid);
+	euip = uifind(euid);
+	PROC_LOCK(p);
+#ifdef MAC
+	error = mac_cred_check_seteuid(oldcred, euid);
+	if (error)
+		goto fail;
+#endif
+	if (euid != oldcred->cr_ruid &&		/* allow seteuid(getuid()) */
+	    euid != oldcred->cr_svuid &&	/* allow seteuid(saved uid) */
+	    (error = priv_check_cred(oldcred, PRIV_CRED_SETEUID, 0)) != 0)
+		goto fail;
+	 * Everything's okay, do it.
+	if (oldcred->cr_uid != euid) {
+		change_euid(newcred, euip);
+		setsugid(p);
+	PROC_UNLOCK(p);
+	uifree(euip);
+	crfree(oldcred);
+	return (0);
+fail:
+	PROC_UNLOCK(p);
+	uifree(euip);
+	crfree(newcred);
+	return (error);
+struct setgid_args {
+	gid_t	gid;
+#endif
+/* ARGSUSED */
+int
+sys_setgid(struct thread *td, struct setgid_args *uap)
+	gid_t gid;
+	int error;
+	gid = uap->gid;
+	AUDIT_ARG_GID(gid);
+	PROC_LOCK(p);
+#ifdef MAC
+	error = mac_cred_check_setgid(oldcred, gid);
+	if (error)
+		goto fail;
+#endif
+	 * Note that setgid(getegid()) is a special case of
+	 * semantics.  Basically, it means that "setgid(xx)" sets all
+	 * For notes on the logic here, see setuid() above.
+	if (gid != oldcred->cr_rgid &&		/* allow setgid(getgid()) */
+	    gid != oldcred->cr_svgid &&		/* allow setgid(saved gid) */
+#endif
+	    gid != oldcred->cr_groups[0] && /* allow setgid(getegid()) */
+#endif
+	    (error = priv_check_cred(oldcred, PRIV_CRED_SETGID, 0)) != 0)
+		goto fail;
+	 * Do we have "appropriate privileges" (are we root or gid == egid)
+	 * If so, we are changing the real uid and saved gid.
+	if (
+#ifdef POSIX_APPENDIX_B_4_2_2	/* use the clause from B.4.2.2 */
+	    gid == oldcred->cr_groups[0] ||
+#endif
+	    priv_check_cred(oldcred, PRIV_CRED_SETGID, 0) == 0)
+#endif
+		 * Set real gid
+		if (oldcred->cr_rgid != gid) {
+			change_rgid(newcred, gid);
+			setsugid(p);
+		 * Set saved gid
+		 * XXX always set saved gid even if not _POSIX_SAVED_IDS, as
+		 * the security of setegid() depends on it.  B.4.2.2 says it
+		if (oldcred->cr_svgid != gid) {
+			change_svgid(newcred, gid);
+			setsugid(p);
+	 * In all cases permitted cases, we are changing the egid.
+	if (oldcred->cr_groups[0] != gid) {
+		change_egid(newcred, gid);
+		setsugid(p);
+	PROC_UNLOCK(p);
+	crfree(oldcred);
+	return (0);
+fail:
+	PROC_UNLOCK(p);
+	crfree(newcred);
+	return (error);
+struct setegid_args {
+	gid_t	egid;
+#endif
+/* ARGSUSED */
+int
+sys_setegid(struct thread *td, struct setegid_args *uap)
+	gid_t egid;
+	int error;
+	egid = uap->egid;
+	AUDIT_ARG_EGID(egid);
+	PROC_LOCK(p);
+#ifdef MAC
+	error = mac_cred_check_setegid(oldcred, egid);
+	if (error)
+		goto fail;
+#endif
+	if (egid != oldcred->cr_rgid &&		/* allow setegid(getgid()) */
+	    egid != oldcred->cr_svgid &&	/* allow setegid(saved gid) */
+	    (error = priv_check_cred(oldcred, PRIV_CRED_SETEGID, 0)) != 0)
+		goto fail;
+	if (oldcred->cr_groups[0] != egid) {
+		change_egid(newcred, egid);
+		setsugid(p);
+	PROC_UNLOCK(p);
+	crfree(oldcred);
+	return (0);
+fail:
+	PROC_UNLOCK(p);
+	crfree(newcred);
+	return (error);
+struct setgroups_args {
+	u_int	gidsetsize;
+	gid_t	*gidset;
+#endif
+/* ARGSUSED */
+int
+sys_setgroups(struct thread *td, struct setgroups_args *uap)
+	gid_t smallgroups[XU_NGROUPS];
+	gid_t *groups;
+	u_int gidsetsize;
+	int error;
+	gidsetsize = uap->gidsetsize;
+	if (gidsetsize > ngroups_max + 1)
+		return (EINVAL);
+	if (gidsetsize > XU_NGROUPS)
+		groups = malloc(gidsetsize * sizeof(gid_t), M_TEMP, M_WAITOK);
+	else
+		groups = smallgroups;
+	error = copyin(uap->gidset, groups, gidsetsize * sizeof(gid_t));
+	if (error == 0)
+		error = kern_setgroups(td, gidsetsize, groups);
+		free(groups, M_TEMP);
+	return (error);
+int
+kern_setgroups(struct thread *td, u_int ngrp, gid_t *groups)
+	int error;
+	MPASS(ngrp <= ngroups_max + 1);
+	AUDIT_ARG_GROUPSET(groups, ngrp);
+	crextend(newcred, ngrp);
+	PROC_LOCK(p);
+#ifdef MAC
+	error = mac_cred_check_setgroups(oldcred, ngrp, groups);
+	if (error)
+		goto fail;
+#endif
+	error = priv_check_cred(oldcred, PRIV_CRED_SETGROUPS, 0);
+	if (error)
+		goto fail;
+	if (ngrp == 0) {
+		 * setgroups(0, NULL) is a legitimate way of clearing the
+		 * groups vector on non-BSD systems (which generally do not
+		 * have the egid in the groups[0]).  We risk security holes
+		 * when running non-BSD software if we do not do the same.
+		newcred->cr_ngroups = 1;
+	} else {
+		crsetgroups_locked(newcred, ngrp, groups);
+	setsugid(p);
+	PROC_UNLOCK(p);
+	crfree(oldcred);
+	return (0);
+fail:
+	PROC_UNLOCK(p);
+	crfree(newcred);
+	return (error);
+struct setreuid_args {
+	uid_t	ruid;
+	uid_t	euid;
+#endif
+/* ARGSUSED */
+int
+sys_setreuid(struct thread *td, struct setreuid_args *uap)
+	uid_t euid, ruid;
+	struct uidinfo *euip, *ruip;
+	int error;
+	euid = uap->euid;
+	ruid = uap->ruid;
+	AUDIT_ARG_RUID(ruid);
+	ruip = uifind(ruid);
+	PROC_LOCK(p);
+#ifdef MAC
+	error = mac_cred_check_setreuid(oldcred, ruid, euid);
+	if (error)
+		goto fail;
+#endif
+	if (((ruid != (uid_t)-1 && ruid != oldcred->cr_ruid &&
+	      ruid != oldcred->cr_svuid) ||
+	     (euid != (uid_t)-1 && euid != oldcred->cr_uid &&
+	      euid != oldcred->cr_ruid && euid != oldcred->cr_svuid)) &&
+	    (error = priv_check_cred(oldcred, PRIV_CRED_SETREUID, 0)) != 0)
+		goto fail;
+	if (euid != (uid_t)-1 && oldcred->cr_uid != euid) {
+		setsugid(p);
+	if (ruid != (uid_t)-1 && oldcred->cr_ruid != ruid) {
+		change_ruid(newcred, ruip);
+		setsugid(p);
+	if ((ruid != (uid_t)-1 || newcred->cr_uid != newcred->cr_ruid) &&
+	    newcred->cr_svuid != newcred->cr_uid) {
+		change_svuid(newcred, newcred->cr_uid);
+		setsugid(p);
+#ifdef RACCT
+	crhold(newcred);
+#endif
+	PROC_UNLOCK(p);
+#ifdef RCTL
+	crfree(newcred);
+#endif
+	uifree(ruip);
+	uifree(euip);
+	crfree(oldcred);
+	return (0);
+fail:
+	PROC_UNLOCK(p);
+	uifree(ruip);
+	uifree(euip);
+	crfree(newcred);
+	return (error);
+struct setregid_args {
+	gid_t	rgid;
+	gid_t	egid;
+#endif
+/* ARGSUSED */
+int
+sys_setregid(struct thread *td, struct setregid_args *uap)
+	gid_t egid, rgid;
+	int error;
+	egid = uap->egid;
+	rgid = uap->rgid;
+	AUDIT_ARG_RGID(rgid);
+	PROC_LOCK(p);
+#ifdef MAC
+	error = mac_cred_check_setregid(oldcred, rgid, egid);
+	if (error)
+		goto fail;
+#endif
+	if (((rgid != (gid_t)-1 && rgid != oldcred->cr_rgid &&
+	    rgid != oldcred->cr_svgid) ||
+	     (egid != (gid_t)-1 && egid != oldcred->cr_groups[0] &&
+	     egid != oldcred->cr_rgid && egid != oldcred->cr_svgid)) &&
+	    (error = priv_check_cred(oldcred, PRIV_CRED_SETREGID, 0)) != 0)
+		goto fail;
+	if (egid != (gid_t)-1 && oldcred->cr_groups[0] != egid) {
+		setsugid(p);
+	if (rgid != (gid_t)-1 && oldcred->cr_rgid != rgid) {
+		change_rgid(newcred, rgid);
+		setsugid(p);
+	if ((rgid != (gid_t)-1 || newcred->cr_groups[0] != newcred->cr_rgid) &&
+	    newcred->cr_svgid != newcred->cr_groups[0]) {
+		change_svgid(newcred, newcred->cr_groups[0]);
+		setsugid(p);
+	PROC_UNLOCK(p);
+	crfree(oldcred);
+	return (0);
+fail:
+	PROC_UNLOCK(p);
+	crfree(newcred);
+	return (error);
+ * setresuid(ruid, euid, suid) is like setreuid except control over the saved
+ * uid is explicit.
+struct setresuid_args {
+	uid_t	ruid;
+	uid_t	euid;
+	uid_t	suid;
+#endif
+/* ARGSUSED */
+int
+sys_setresuid(struct thread *td, struct setresuid_args *uap)
+	uid_t euid, ruid, suid;
+	int error;
+	euid = uap->euid;
+	ruid = uap->ruid;
+	suid = uap->suid;
+	AUDIT_ARG_SUID(suid);
+	PROC_LOCK(p);
+#ifdef MAC
+	error = mac_cred_check_setresuid(oldcred, ruid, euid, suid);
+	if (error)
+		goto fail;
+#endif
+	     ruid != oldcred->cr_svuid &&
+	      ruid != oldcred->cr_uid) ||
+	     (euid != (uid_t)-1 && euid != oldcred->cr_ruid &&
+	      euid != oldcred->cr_uid) ||
+	     (suid != (uid_t)-1 && suid != oldcred->cr_ruid &&
+	    suid != oldcred->cr_svuid &&
+	      suid != oldcred->cr_uid)) &&
+	    (error = priv_check_cred(oldcred, PRIV_CRED_SETRESUID, 0)) != 0)
+		goto fail;
+		setsugid(p);
+		setsugid(p);
+	if (suid != (uid_t)-1 && oldcred->cr_svuid != suid) {
+		change_svuid(newcred, suid);
+		setsugid(p);
+#ifdef RACCT
+	crhold(newcred);
+#endif
+	PROC_UNLOCK(p);
+#ifdef RCTL
+	crfree(newcred);
+#endif
+	uifree(ruip);
+	uifree(euip);
+	crfree(oldcred);
+	return (0);
+fail:
+	PROC_UNLOCK(p);
+	uifree(ruip);
+	uifree(euip);
+	crfree(newcred);
+	return (error);
+ * setresgid(rgid, egid, sgid) is like setregid except control over the saved
+ * gid is explicit.
+struct setresgid_args {
+	gid_t	rgid;
+	gid_t	egid;
+	gid_t	sgid;
+#endif
+/* ARGSUSED */
+int
+sys_setresgid(struct thread *td, struct setresgid_args *uap)
+	gid_t egid, rgid, sgid;
+	int error;
+	egid = uap->egid;
+	rgid = uap->rgid;
+	sgid = uap->sgid;
+	AUDIT_ARG_SGID(sgid);
+	PROC_LOCK(p);
+#ifdef MAC
+	error = mac_cred_check_setresgid(oldcred, rgid, egid, sgid);
+	if (error)
+		goto fail;
+#endif
+	      rgid != oldcred->cr_svgid &&
+	      rgid != oldcred->cr_groups[0]) ||
+	     (egid != (gid_t)-1 && egid != oldcred->cr_rgid &&
+	      egid != oldcred->cr_groups[0]) ||
+	     (sgid != (gid_t)-1 && sgid != oldcred->cr_rgid &&
+	      sgid != oldcred->cr_svgid &&
+	      sgid != oldcred->cr_groups[0])) &&
+	    (error = priv_check_cred(oldcred, PRIV_CRED_SETRESGID, 0)) != 0)
+		goto fail;
+		setsugid(p);
+		setsugid(p);
+	if (sgid != (gid_t)-1 && oldcred->cr_svgid != sgid) {
+		change_svgid(newcred, sgid);
+		setsugid(p);
+	PROC_UNLOCK(p);
+	crfree(oldcred);
+	return (0);
+fail:
+	PROC_UNLOCK(p);
+	crfree(newcred);
+	return (error);
+struct getresuid_args {
+	uid_t	*ruid;
+	uid_t	*euid;
+	uid_t	*suid;
+#endif
+/* ARGSUSED */
+int
+sys_getresuid(struct thread *td, struct getresuid_args *uap)
+	int error1 = 0, error2 = 0, error3 = 0;
+	if (uap->ruid)
+		error1 = copyout(&cred->cr_ruid,
+		    uap->ruid, sizeof(cred->cr_ruid));
+	if (uap->euid)
+		error2 = copyout(&cred->cr_uid,
+		    uap->euid, sizeof(cred->cr_uid));
+	if (uap->suid)
+		error3 = copyout(&cred->cr_svuid,
+		    uap->suid, sizeof(cred->cr_svuid));
+	return (error1 ? error1 : error2 ? error2 : error3);
+struct getresgid_args {
+	gid_t	*rgid;
+	gid_t	*egid;
+	gid_t	*sgid;
+#endif
+/* ARGSUSED */
+int
+sys_getresgid(struct thread *td, struct getresgid_args *uap)
+	if (uap->rgid)
+		error1 = copyout(&cred->cr_rgid,
+		    uap->rgid, sizeof(cred->cr_rgid));
+	if (uap->egid)
+		error2 = copyout(&cred->cr_groups[0],
+		    uap->egid, sizeof(cred->cr_groups[0]));
+	if (uap->sgid)
+		error3 = copyout(&cred->cr_svgid,
+		    uap->sgid, sizeof(cred->cr_svgid));
+struct issetugid_args {
+	int dummy;
+#endif
+/* ARGSUSED */
+int
+sys_issetugid(struct thread *td, struct issetugid_args *uap)
+	 * Note: OpenBSD sets a P_SUGIDEXEC flag set at execve() time,
+	 * we use P_SUGID because we consider changing the owners as
+	 * "tainting" as well.
+	 * This is significant for procs that start as root and "become"
+	 * a user without an exec - programs cannot know *everything*
+	 * that libc *might* have put in their data segment.
+	td->td_retval[0] = (p->p_flag & P_SUGID) ? 1 : 0;
+	return (0);
+int
+sys___setugid(struct thread *td, struct __setugid_args *uap)
+#ifdef REGRESSION
+	struct proc *p;
+	p = td->td_proc;
+	switch (uap->flag) {
+	case 0:
+		PROC_LOCK(p);
+		p->p_flag &= ~P_SUGID;
+		PROC_UNLOCK(p);
+		return (0);
+	case 1:
+		PROC_LOCK(p);
+		p->p_flag |= P_SUGID;
+		PROC_UNLOCK(p);
+		return (0);
+	default:
+		return (EINVAL);
+#else /* !REGRESSION */
+	return (ENOSYS);
+#endif /* REGRESSION */
+ * Check if gid is a member of the group set.
+int
+groupmember(gid_t gid, struct ucred *cred)
+	int l;
+	int h;
+	int m;
+	if (cred->cr_groups[0] == gid)
+		return(1);
+	 * If gid was not our primary group, perform a binary search
+	 * of the supplemental groups.  This is possible because we
+	 * sort the groups in crsetgroups().
+	l = 1;
+	h = cred->cr_ngroups;
+	while (l < h) {
+		m = l + ((h - l) / 2);
+		if (cred->cr_groups[m] < gid)
+			l = m + 1;
+		else
+			h = m;
+	if ((l < cred->cr_ngroups) && (cred->cr_groups[l] == gid))
+		return (1);
+	return (0);
+ * Test the active securelevel against a given level.  securelevel_gt()
+ * implements (securelevel > level).  securelevel_ge() implements
+ * (securelevel >= level).  Note that the logic is inverted -- these
+ * functions return EPERM on "success" and 0 on "failure".
+ * Due to care taken when setting the securelevel, we know that no jail will
+ * be less secure that its parent (or the physical system), so it is sufficient
+ * to test the current jail only.
+ * XXXRW: Possibly since this has to do with privilege, it should move to
+ * kern_priv.c.
+int
+securelevel_gt(struct ucred *cr, int level)
+	return (cr->cr_prison->pr_securelevel > level ? EPERM : 0);
+int
+securelevel_ge(struct ucred *cr, int level)
+	return (cr->cr_prison->pr_securelevel >= level ? EPERM : 0);
+ * 'see_other_uids' determines whether or not visibility of processes
+ * and sockets with credentials holding different real uids is possible
+ * using a variety of system MIBs.
+ * XXX: data declarations should be together near the beginning of the file.
+static int	see_other_uids = 1;
+SYSCTL_INT(_security_bsd, OID_AUTO, see_other_uids, CTLFLAG_RW,
+    &see_other_uids, 0,
+    "Unprivileged processes may see subjects/objects with different real uid");
+ * Determine if u1 "can see" the subject specified by u2, according to the
+ * 'see_other_uids' policy.
+ * Returns: 0 for permitted, ESRCH otherwise
+ * Locks: none
+ * References: *u1 and *u2 must not change during the call
+ *             u1 may equal u2, in which case only one reference is required
+int
+cr_canseeotheruids(struct ucred *u1, struct ucred *u2)
+	if (!see_other_uids && u1->cr_ruid != u2->cr_ruid) {
+		if (priv_check_cred(u1, PRIV_SEEOTHERUIDS, 0) != 0)
+			return (ESRCH);
+	return (0);
+ * 'see_other_gids' determines whether or not visibility of processes
+ * and sockets with credentials holding different real gids is possible
+static int	see_other_gids = 1;
+SYSCTL_INT(_security_bsd, OID_AUTO, see_other_gids, CTLFLAG_RW,
+    &see_other_gids, 0,
+    "Unprivileged processes may see subjects/objects with different real gid");
+ * Determine if u1 can "see" the subject specified by u2, according to the
+ * 'see_other_gids' policy.
+ * Locks: none
+int
+cr_canseeothergids(struct ucred *u1, struct ucred *u2)
+	int i, match;
+	if (!see_other_gids) {
+		match = 0;
+		for (i = 0; i < u1->cr_ngroups; i++) {
+			if (groupmember(u1->cr_groups[i], u2))
+				match = 1;
+			if (match)
+				break;
+		if (!match) {
+			if (priv_check_cred(u1, PRIV_SEEOTHERGIDS, 0) != 0)
+				return (ESRCH);
+	return (0);
+ * 'see_jail_proc' determines whether or not visibility of processes and
+ * sockets with credentials holding different jail ids is possible using a
+ * variety of system MIBs.
+static int	see_jail_proc = 1;
+SYSCTL_INT(_security_bsd, OID_AUTO, see_jail_proc, CTLFLAG_RW,
+    &see_jail_proc, 0,
+    "Unprivileged processes may see subjects/objects with different jail ids");
+ * 'see_jail_proc' policy.
+ * Locks: none
+int
+cr_canseejailproc(struct ucred *u1, struct ucred *u2)
+	if (u1->cr_uid == 0)
+		return (0);
+	return (!see_jail_proc && u1->cr_prison != u2->cr_prison ? ESRCH : 0);
+ * Determine if u1 "can see" the subject specified by u2.
+ * Returns: 0 for permitted, an errno value otherwise
+ * Locks: none
+int
+cr_cansee(struct ucred *u1, struct ucred *u2)
+	int error;
+	if ((error = prison_check(u1, u2)))
+		return (error);
+#ifdef MAC
+	if ((error = mac_cred_check_visible(u1, u2)))
+		return (error);
+#endif
+	if ((error = cr_canseeotheruids(u1, u2)))
+		return (error);
+	if ((error = cr_canseeothergids(u1, u2)))
+		return (error);
+	if ((error = cr_canseejailproc(u1, u2)))
+		return (error);
+	return (0);
+ * Determine if td "can see" the subject specified by p.
+ * Locks: Sufficient locks to protect p->p_ucred must be held.  td really
+ *        should be curthread.
+ * References: td and p must be valid for the lifetime of the call
+int
+p_cansee(struct thread *td, struct proc *p)
+	/* Wrap cr_cansee() for all functionality. */
+	KASSERT(td == curthread, ("%s: td not curthread", __func__));
+	PROC_LOCK_ASSERT(p, MA_OWNED);
+	return (cr_cansee(td->td_ucred, p->p_ucred));
+ * 'conservative_signals' prevents the delivery of a broad class of
+ * signals by unprivileged processes to processes that have changed their
+ * credentials since the last invocation of execve().  This can prevent
+ * the leakage of cached information or retained privileges as a result
+ * of a common class of signal-related vulnerabilities.  However, this
+ * may interfere with some applications that expect to be able to
+ * deliver these signals to peer processes after having given up
+ * privilege.
+static int	conservative_signals = 1;
+SYSCTL_INT(_security_bsd, OID_AUTO, conservative_signals, CTLFLAG_RW,
+    &conservative_signals, 0, "Unprivileged processes prevented from "
+    "sending certain signals to processes whose credentials have changed");
+ * Determine whether cred may deliver the specified signal to proc.
+ * Returns: 0 for permitted, an errno value otherwise.
+ * Locks: A lock must be held for proc.
+ * References: cred and proc must be valid for the lifetime of the call.
+int
+cr_cansignal(struct ucred *cred, struct proc *proc, int signum)
+	int error;
+	PROC_LOCK_ASSERT(proc, MA_OWNED);
+	 * Jail semantics limit the scope of signalling to proc in the
+	 * same jail as cred, if cred is in jail.
+	error = prison_check(cred, proc->p_ucred);
+	if (error)
+		return (error);
+#ifdef MAC
+	if ((error = mac_proc_check_signal(cred, proc, signum)))
+		return (error);
+#endif
+	if ((error = cr_canseeotheruids(cred, proc->p_ucred)))
+		return (error);
+	if ((error = cr_canseeothergids(cred, proc->p_ucred)))
+		return (error);
+	 * UNIX signal semantics depend on the status of the P_SUGID
+	 * bit on the target process.  If the bit is set, then additional
+	 * restrictions are placed on the set of available signals.
+	if (conservative_signals && (proc->p_flag & P_SUGID)) {
+		switch (signum) {
+		case 0:
+		case SIGKILL:
+		case SIGINT:
+		case SIGTERM:
+		case SIGALRM:
+		case SIGSTOP:
+		case SIGTTIN:
+		case SIGTTOU:
+		case SIGTSTP:
+		case SIGHUP:
+		case SIGUSR1:
+		case SIGUSR2:
+			 * Generally, permit job and terminal control
+			 * signals.
+			break;
+		default:
+			/* Not permitted without privilege. */
+			error = priv_check_cred(cred, PRIV_SIGNAL_SUGID, 0);
+			if (error)
+				return (error);
+	 * Generally, the target credential's ruid or svuid must match the
+	 * subject credential's ruid or euid.
+	if (cred->cr_ruid != proc->p_ucred->cr_ruid &&
+	    cred->cr_ruid != proc->p_ucred->cr_svuid &&
+	    cred->cr_uid != proc->p_ucred->cr_ruid &&
+	    cred->cr_uid != proc->p_ucred->cr_svuid) {
+		error = priv_check_cred(cred, PRIV_SIGNAL_DIFFCRED, 0);
+		if (error)
+			return (error);
+	return (0);
+ * Determine whether td may deliver the specified signal to p.
+ * Locks: Sufficient locks to protect various components of td and p
+ *        must be held.  td must be curthread, and a lock must be
+ *        held for p.
+int
+p_cansignal(struct thread *td, struct proc *p, int signum)
+	if (td->td_proc == p)
+		return (0);
+	 * UNIX signalling semantics require that processes in the same
+	 * session always be able to deliver SIGCONT to one another,
+	 * overriding the remaining protections.
+	/* XXX: This will require an additional lock of some sort. */
+	if (signum == SIGCONT && td->td_proc->p_session == p->p_session)
+		return (0);
+	 * Some compat layers use SIGTHR and higher signals for
+	 * communication between different kernel threads of the same
+	 * process, so that they expect that it's always possible to
+	 * deliver them, even for suid applications where cr_cansignal() can
+	 * deny such ability for security consideration.  It should be
+	 * pretty safe to do since the only way to create two processes
+	 * with the same p_leader is via rfork(2).
+	if (td->td_proc->p_leader != NULL && signum >= SIGTHR &&
+	    signum < SIGTHR + 4 && td->td_proc->p_leader == p->p_leader)
+		return (0);
+	return (cr_cansignal(td->td_ucred, p, signum));
+ * Determine whether td may reschedule p.
+ *        be held for p.
+int
+p_cansched(struct thread *td, struct proc *p)
+	int error;
+		return (0);
+	if ((error = prison_check(td->td_ucred, p->p_ucred)))
+		return (error);
+#ifdef MAC
+	if ((error = mac_proc_check_sched(td->td_ucred, p)))
+		return (error);
+#endif
+	if ((error = cr_canseeotheruids(td->td_ucred, p->p_ucred)))
+		return (error);
+	if ((error = cr_canseeothergids(td->td_ucred, p->p_ucred)))
+		return (error);
+	if (td->td_ucred->cr_ruid != p->p_ucred->cr_ruid &&
+	    td->td_ucred->cr_uid != p->p_ucred->cr_ruid) {
+		error = priv_check(td, PRIV_SCHED_DIFFCRED);
+		if (error)
+			return (error);
+	return (0);
+ * The 'unprivileged_proc_debug' flag may be used to disable a variety of
+ * unprivileged inter-process debugging services, including some procfs
+ * functionality, ptrace(), and ktrace().  In the past, inter-process
+ * debugging has been involved in a variety of security problems, and sites
+ * not requiring the service might choose to disable it when hardening
+ * systems.
+ * XXX: Should modifying and reading this variable require locking?
+static int	unprivileged_proc_debug = 1;
+SYSCTL_INT(_security_bsd, OID_AUTO, unprivileged_proc_debug, CTLFLAG_RW,
+    &unprivileged_proc_debug, 0,
+    "Unprivileged processes may use process debugging facilities");
+ * Determine whether td may debug p.
+ *        be held for p.
+int
+p_candebug(struct thread *td, struct proc *p)
+	int credentialchanged, error, grpsubset, i, uidsubset;
+	if (!unprivileged_proc_debug) {
+		error = priv_check(td, PRIV_DEBUG_UNPRIV);
+		if (error)
+			return (error);
+		return (0);
+		return (error);
+#ifdef MAC
+	if ((error = mac_proc_check_debug(td->td_ucred, p)))
+		return (error);
+#endif
+		return (error);
+		return (error);
+	 * Is p's group set a subset of td's effective group set?  This
+	 * includes p's egid, group access list, rgid, and svgid.
+	grpsubset = 1;
+	for (i = 0; i < p->p_ucred->cr_ngroups; i++) {
+		if (!groupmember(p->p_ucred->cr_groups[i], td->td_ucred)) {
+			grpsubset = 0;
+			break;
+	grpsubset = grpsubset &&
+	    groupmember(p->p_ucred->cr_rgid, td->td_ucred) &&
+	    groupmember(p->p_ucred->cr_svgid, td->td_ucred);
+	 * Are the uids present in p's credential equal to td's
+	 * effective uid?  This includes p's euid, svuid, and ruid.
+	uidsubset = (td->td_ucred->cr_uid == p->p_ucred->cr_uid &&
+	    td->td_ucred->cr_uid == p->p_ucred->cr_svuid &&
+	    td->td_ucred->cr_uid == p->p_ucred->cr_ruid);
+	 * Has the credential of the process changed since the last exec()?
+	credentialchanged = (p->p_flag & P_SUGID);
+	 * If p's gids aren't a subset, or the uids aren't a subset,
+	 * or the credential has changed, require appropriate privilege
+	 * for td to debug p.
+	if (!grpsubset || !uidsubset) {
+		error = priv_check(td, PRIV_DEBUG_DIFFCRED);
+		if (error)
+			return (error);
+	if (credentialchanged) {
+		error = priv_check(td, PRIV_DEBUG_SUGID);
+		if (error)
+			return (error);
+	/* Can't trace init when securelevel > 0. */
+	if (p == initproc) {
+		error = securelevel_gt(td->td_ucred, 0);
+		if (error)
+			return (error);
+	 * Can't trace a process that's currently exec'ing.
+	 * XXX: Note, this is not a security policy decision, it's a
+	 * basic correctness/functionality decision.  Therefore, this check
+	 * should be moved to the caller's of p_candebug().
+	if ((p->p_flag & P_INEXEC) != 0)
+		return (EBUSY);
+	/* Denied explicitely */
+	if ((p->p_flag2 & P2_NOTRACE) != 0) {
+		error = priv_check(td, PRIV_DEBUG_DENIED);
+		if (error != 0)
+			return (error);
+	return (0);
+ * Determine whether the subject represented by cred can "see" a socket.
+ * Returns: 0 for permitted, ENOENT otherwise.
+int
+cr_canseesocket(struct ucred *cred, struct socket *so)
+	int error;
+	error = prison_check(cred, so->so_cred);
+	if (error)
+		return (ENOENT);
+#ifdef MAC
+	error = mac_socket_check_visible(cred, so);
+	if (error)
+		return (error);
+#endif
+	if (cr_canseeotheruids(cred, so->so_cred))
+		return (ENOENT);
+	if (cr_canseeothergids(cred, so->so_cred))
+		return (ENOENT);
+	return (0);
+ * Determine whether td can wait for the exit of p.
+ *        be held for p.
+int
+p_canwait(struct thread *td, struct proc *p)
+	int error;
+		return (error);
+#ifdef MAC
+	if ((error = mac_proc_check_wait(td->td_ucred, p)))
+		return (error);
+#endif
+#if 0
+	/* XXXMAC: This could have odd effects on some shells. */
+		return (error);
+#endif
+	return (0);
+ * Allocate a zeroed cred structure.
+struct ucred *
+crget(void)
+	struct ucred *cr;
+	cr = malloc(sizeof(*cr), M_CRED, M_WAITOK | M_ZERO);
+	refcount_init(&cr->cr_ref, 1);
+#ifdef AUDIT
+	audit_cred_init(cr);
+#endif
+#ifdef MAC
+	mac_cred_init(cr);
+#endif
+	cr->cr_groups = cr->cr_smallgroups;
+	cr->cr_agroups =
+	    sizeof(cr->cr_smallgroups) / sizeof(cr->cr_smallgroups[0]);
+	return (cr);
+ * Claim another reference to a ucred structure.
+struct ucred *
+crhold(struct ucred *cr)
+	refcount_acquire(&cr->cr_ref);
+	return (cr);
+ * Free a cred structure.  Throws away space when ref count gets to 0.
+void
+crfree(struct ucred *cr)
+	KASSERT(cr->cr_ref > 0, ("bad ucred refcount: %d", cr->cr_ref));
+	KASSERT(cr->cr_ref != 0xdeadc0de, ("dangling reference to ucred"));
+	if (refcount_release(&cr->cr_ref)) {
+		 * Some callers of crget(), such as nfs_statfs(),
+		 * allocate a temporary credential, but don't
+		 * allocate a uidinfo structure.
+		if (cr->cr_uidinfo != NULL)
+			uifree(cr->cr_uidinfo);
+		if (cr->cr_ruidinfo != NULL)
+			uifree(cr->cr_ruidinfo);
+		 * Free a prison, if any.
+		if (cr->cr_prison != NULL)
+			prison_free(cr->cr_prison);
+		if (cr->cr_loginclass != NULL)
+			loginclass_free(cr->cr_loginclass);
+#ifdef AUDIT
+		audit_cred_destroy(cr);
+#endif
+#ifdef MAC
+		mac_cred_destroy(cr);
+#endif
+		if (cr->cr_groups != cr->cr_smallgroups)
+			free(cr->cr_groups, M_CRED);
+		free(cr, M_CRED);
+ * Copy a ucred's contents from a template.  Does not block.
+void
+crcopy(struct ucred *dest, struct ucred *src)
+	KASSERT(dest->cr_ref == 1, ("crcopy of shared ucred"));
+	bcopy(&src->cr_startcopy, &dest->cr_startcopy,
+	    (unsigned)((caddr_t)&src->cr_endcopy -
+		(caddr_t)&src->cr_startcopy));
+	crsetgroups(dest, src->cr_ngroups, src->cr_groups);
+	uihold(dest->cr_uidinfo);
+	uihold(dest->cr_ruidinfo);
+	prison_hold(dest->cr_prison);
+	loginclass_hold(dest->cr_loginclass);
+#ifdef AUDIT
+	audit_cred_copy(src, dest);
+#endif
+#ifdef MAC
+	mac_cred_copy(src, dest);
+#endif
+ * Dup cred struct to a new held one.
+struct ucred *
+crdup(struct ucred *cr)
+	struct ucred *newcr;
+	newcr = crget();
+	crcopy(newcr, cr);
+	return (newcr);
+ * Fill in a struct xucred based on a struct ucred.
+void
+cru2x(struct ucred *cr, struct xucred *xcr)
+	int ngroups;
+	bzero(xcr, sizeof(*xcr));
+	xcr->cr_version = XUCRED_VERSION;
+	xcr->cr_uid = cr->cr_uid;
+	ngroups = MIN(cr->cr_ngroups, XU_NGROUPS);
+	xcr->cr_ngroups = ngroups;
+	bcopy(cr->cr_groups, xcr->cr_groups,
+	    ngroups * sizeof(*cr->cr_groups));
+ * Set initial process credentials.
+ * Callers are responsible for providing the reference for provided credentials.
+void
+proc_set_cred_init(struct proc *p, struct ucred *newcred)
+	p->p_ucred = newcred;
+ * Change process credentials.
+ * Callers are responsible for providing the reference for passed credentials
+ * and for freeing old ones.
+ * Process has to be locked except when it does not have credentials (as it
+ * should not be visible just yet) or when newcred is NULL (as this can be
+ * only used when the process is about to be freed, at which point it should
+ * not be visible anymore).
+struct ucred *
+proc_set_cred(struct proc *p, struct ucred *newcred)
+	struct ucred *oldcred;
+	MPASS(p->p_ucred != NULL);
+	if (newcred == NULL)
+		MPASS(p->p_state == PRS_ZOMBIE);
+	else
+	oldcred = p->p_ucred;
+	if (newcred != NULL)
+		PROC_UPDATE_COW(p);
+	return (oldcred);
+struct ucred *
+crcopysafe(struct proc *p, struct ucred *cr)
+	int groups;
+	while (cr->cr_agroups < oldcred->cr_agroups) {
+		groups = oldcred->cr_agroups;
+		PROC_UNLOCK(p);
+		crextend(cr, groups);
+		PROC_LOCK(p);
+	crcopy(cr, oldcred);
+	return (oldcred);
+ * Extend the passed in credential to hold n items.
+void
+crextend(struct ucred *cr, int n)
+	int cnt;
+	/* Truncate? */
+	if (n <= cr->cr_agroups)
+		return;
+	 * We extend by 2 each time since we're using a power of two
+	 * allocator until we need enough groups to fill a page.
+	 * Once we're allocating multiple pages, only allocate as many
+	 * as we actually need.  The case of processes needing a
+	 * non-power of two number of pages seems more likely than
+	 * a real world process that adds thousands of groups one at a
+	 * time.
+	if ( n < PAGE_SIZE / sizeof(gid_t) ) {
+		if (cr->cr_agroups == 0)
+			cnt = MINALLOCSIZE / sizeof(gid_t);
+		else
+			cnt = cr->cr_agroups * 2;
+		while (cnt < n)
+			cnt *= 2;
+	} else
+		cnt = roundup2(n, PAGE_SIZE / sizeof(gid_t));
+	/* Free the old array. */
+	cr->cr_groups = malloc(cnt * sizeof(gid_t), M_CRED, M_WAITOK | M_ZERO);
+	cr->cr_agroups = cnt;
+ * Copy groups in to a credential, preserving any necessary invariants.
+ * Currently this includes the sorting of all supplemental gids.
+ * crextend() must have been called before hand to ensure sufficient
+ * space is available.
+static void
+crsetgroups_locked(struct ucred *cr, int ngrp, gid_t *groups)
+	int i;
+	int j;
+	gid_t g;
+	KASSERT(cr->cr_agroups >= ngrp, ("cr_ngroups is too small"));
+	bcopy(groups, cr->cr_groups, ngrp * sizeof(gid_t));
+	cr->cr_ngroups = ngrp;
+	 * Sort all groups except cr_groups[0] to allow groupmember to
+	 * perform a binary search.
+	 * XXX: If large numbers of groups become common this should
+	 * be replaced with shell sort like linux uses or possibly
+	 * heap sort.
+	for (i = 2; i < ngrp; i++) {
+		g = cr->cr_groups[i];
+		for (j = i-1; j >= 1 && g < cr->cr_groups[j]; j--)
+			cr->cr_groups[j + 1] = cr->cr_groups[j];
+		cr->cr_groups[j + 1] = g;
+ * Copy groups in to a credential after expanding it if required.
+ * Truncate the list to (ngroups_max + 1) if it is too large.
+void
+crsetgroups(struct ucred *cr, int ngrp, gid_t *groups)
+	if (ngrp > ngroups_max + 1)
+		ngrp = ngroups_max + 1;
+	crextend(cr, ngrp);
+	crsetgroups_locked(cr, ngrp, groups);
+ * Get login name, if available.
+struct getlogin_args {
+	char	*namebuf;
+	u_int	namelen;
+#endif
+/* ARGSUSED */
+int
+sys_getlogin(struct thread *td, struct getlogin_args *uap)
+	char login[MAXLOGNAME];
+	size_t len;
+	if (uap->namelen > MAXLOGNAME)
+		uap->namelen = MAXLOGNAME;
+	PROC_LOCK(p);
+	SESS_LOCK(p->p_session);
+	len = strlcpy(login, p->p_session->s_login, uap->namelen) + 1;
+	SESS_UNLOCK(p->p_session);
+	PROC_UNLOCK(p);
+	if (len > uap->namelen)
+		return (ERANGE);
+	return (copyout(login, uap->namebuf, len));
+ * Set login name.
+struct setlogin_args {
+	char	*namebuf;
+#endif
+/* ARGSUSED */
+int
+sys_setlogin(struct thread *td, struct setlogin_args *uap)
+	int error;
+	char logintmp[MAXLOGNAME];
+	CTASSERT(sizeof(p->p_session->s_login) >= sizeof(logintmp));
+	error = priv_check(td, PRIV_PROC_SETLOGIN);
+	if (error)
+		return (error);
+	error = copyinstr(uap->namebuf, logintmp, sizeof(logintmp), NULL);
+	if (error != 0) {
+		if (error == ENAMETOOLONG)
+			error = EINVAL;
+		return (error);
+	AUDIT_ARG_LOGIN(logintmp);
+	PROC_LOCK(p);
+	strcpy(p->p_session->s_login, logintmp);
+	PROC_UNLOCK(p);
+	return (0);
+void
+setsugid(struct proc *p)
+	if (!(p->p_pfsflags & PF_ISUGID))
+		p->p_stops = 0;
+ * Change a process's effective uid.
+ * Side effects: newcred->cr_uid and newcred->cr_uidinfo will be modified.
+ * References: newcred must be an exclusive credential reference for the
+ *             duration of the call.
+void
+change_euid(struct ucred *newcred, struct uidinfo *euip)
+	newcred->cr_uid = euip->ui_uid;
+	uihold(euip);
+	uifree(newcred->cr_uidinfo);
+	newcred->cr_uidinfo = euip;
+ * Change a process's effective gid.
+ * Side effects: newcred->cr_gid will be modified.
+void
+change_egid(struct ucred *newcred, gid_t egid)
+	newcred->cr_groups[0] = egid;
+ * Change a process's real uid.
+ * Side effects: newcred->cr_ruid will be updated, newcred->cr_ruidinfo
+ *               will be updated, and the old and new cr_ruidinfo proc
+ *               counts will be updated.
+void
+change_ruid(struct ucred *newcred, struct uidinfo *ruip)
+	(void)chgproccnt(newcred->cr_ruidinfo, -1, 0);
+	newcred->cr_ruid = ruip->ui_uid;
+	uihold(ruip);
+	uifree(newcred->cr_ruidinfo);
+	newcred->cr_ruidinfo = ruip;
+	(void)chgproccnt(newcred->cr_ruidinfo, 1, 0);
+ * Change a process's real gid.
+ * Side effects: newcred->cr_rgid will be updated.
+void
+change_rgid(struct ucred *newcred, gid_t rgid)
+	newcred->cr_rgid = rgid;
+ * Change a process's saved uid.
+ * Side effects: newcred->cr_svuid will be updated.
+void
+change_svuid(struct ucred *newcred, uid_t svuid)
+	newcred->cr_svuid = svuid;
+ * Change a process's saved gid.
+ * Side effects: newcred->cr_svgid will be updated.
+void
+change_svgid(struct ucred *newcred, gid_t svgid)
+	newcred->cr_svgid = svgid;
diff --git a/freebsd/sys/kern/kern_resource.c b/freebsd/sys/kern/kern_resource.c
index 00000000..49b1e0fe
--- /dev/null
+++ b/freebsd/sys/kern/kern_resource.c
@@ -0,0 +1,1539 @@
+ * Copyright (c) 1982, 1986, 1991, 1993
+ *	The Regents of the University of California.  All rights reserved.
+ * are met:
+ * SUCH DAMAGE.
+ *	@(#)kern_resource.c	8.5 (Berkeley) 1/21/94
+#include <sys/file.h>
+#include <sys/rwlock.h>
+#include <sys/sched.h>
+#include <sys/time.h>
+#include <sys/umtx.h>
+#include <vm/vm.h>
+#include <vm/vm_param.h>
+#include <vm/pmap.h>
+#include <vm/vm_map.h>
+static MALLOC_DEFINE(M_PLIMIT, "plimit", "plimit structures");
+static MALLOC_DEFINE(M_UIDINFO, "uidinfo", "uidinfo structures");
+#define	UIHASH(uid)	(&uihashtbl[(uid) & uihash])
+static struct rwlock uihashtbl_lock;
+static LIST_HEAD(uihashhead, uidinfo) *uihashtbl;
+static u_long uihash;		/* size of hash table - 1 */
+static void	calcru1(struct proc *p, struct rusage_ext *ruxp,
+		    struct timeval *up, struct timeval *sp);
+static int	donice(struct thread *td, struct proc *chgp, int n);
+static struct uidinfo *uilookup(uid_t uid);
+static void	ruxagg_locked(struct rusage_ext *rux, struct thread *td);
+ * Resource controls and accounting.
+struct getpriority_args {
+	int	which;
+	int	who;
+#endif
+int
+sys_getpriority(struct thread *td, struct getpriority_args *uap)
+	struct proc *p;
+	struct pgrp *pg;
+	int error, low;
+	error = 0;
+	low = PRIO_MAX + 1;
+	switch (uap->which) {
+	case PRIO_PROCESS:
+		if (uap->who == 0)
+			low = td->td_proc->p_nice;
+		else {
+			p = pfind(uap->who);
+			if (p == NULL)
+				break;
+			if (p_cansee(td, p) == 0)
+				low = p->p_nice;
+			PROC_UNLOCK(p);
+		break;
+	case PRIO_PGRP:
+		sx_slock(&proctree_lock);
+		if (uap->who == 0) {
+			pg = td->td_proc->p_pgrp;
+			PGRP_LOCK(pg);
+		} else {
+			pg = pgfind(uap->who);
+			if (pg == NULL) {
+				sx_sunlock(&proctree_lock);
+				break;
+		LIST_FOREACH(p, &pg->pg_members, p_pglist) {
+			PROC_LOCK(p);
+			if (p->p_state == PRS_NORMAL &&
+			    p_cansee(td, p) == 0) {
+				if (p->p_nice < low)
+					low = p->p_nice;
+			PROC_UNLOCK(p);
+		PGRP_UNLOCK(pg);
+		break;
+	case PRIO_USER:
+			uap->who = td->td_ucred->cr_uid;
+		sx_slock(&allproc_lock);
+		FOREACH_PROC_IN_SYSTEM(p) {
+			PROC_LOCK(p);
+			    p_cansee(td, p) == 0 &&
+			    p->p_ucred->cr_uid == uap->who) {
+					low = p->p_nice;
+			PROC_UNLOCK(p);
+		sx_sunlock(&allproc_lock);
+		break;
+	default:
+		error = EINVAL;
+		break;
+	if (low == PRIO_MAX + 1 && error == 0)
+		error = ESRCH;
+	td->td_retval[0] = low;
+	return (error);
+struct setpriority_args {
+	int	which;
+	int	who;
+	int	prio;
+#endif
+int
+sys_setpriority(struct thread *td, struct setpriority_args *uap)
+	struct proc *curp, *p;
+	struct pgrp *pg;
+	int found = 0, error = 0;
+	curp = td->td_proc;
+			PROC_LOCK(curp);
+			error = donice(td, curp, uap->prio);
+			PROC_UNLOCK(curp);
+		} else {
+			if (p == NULL)
+				break;
+			if (error == 0)
+				error = donice(td, p, uap->prio);
+			PROC_UNLOCK(p);
+		found++;
+		break;
+	case PRIO_PGRP:
+			pg = curp->p_pgrp;
+			PGRP_LOCK(pg);
+		} else {
+			if (pg == NULL) {
+				break;
+			PROC_LOCK(p);
+				found++;
+			PROC_UNLOCK(p);
+		PGRP_UNLOCK(pg);
+		break;
+	case PRIO_USER:
+			PROC_LOCK(p);
+			    p->p_ucred->cr_uid == uap->who &&
+				found++;
+			PROC_UNLOCK(p);
+		break;
+	default:
+		error = EINVAL;
+		break;
+	if (found == 0 && error == 0)
+		error = ESRCH;
+	return (error);
+ * Set "nice" for a (whole) process.
+static int
+donice(struct thread *td, struct proc *p, int n)
+	int error;
+	if ((error = p_cansched(td, p)))
+		return (error);
+	if (n > PRIO_MAX)
+		n = PRIO_MAX;
+	if (n < PRIO_MIN)
+		n = PRIO_MIN;
+	if (n < p->p_nice && priv_check(td, PRIV_SCHED_SETPRIORITY) != 0)
+		return (EACCES);
+	sched_nice(p, n);
+	return (0);
+static int unprivileged_idprio;
+SYSCTL_INT(_security_bsd, OID_AUTO, unprivileged_idprio, CTLFLAG_RW,
+    &unprivileged_idprio, 0, "Allow non-root users to set an idle priority");
+ * Set realtime priority for LWP.
+struct rtprio_thread_args {
+	int		function;
+	lwpid_t		lwpid;
+	struct rtprio	*rtp;
+#endif
+int
+sys_rtprio_thread(struct thread *td, struct rtprio_thread_args *uap)
+	struct proc *p;
+	struct rtprio rtp;
+	struct thread *td1;
+	int cierror, error;
+	/* Perform copyin before acquiring locks if needed. */
+	if (uap->function == RTP_SET)
+		cierror = copyin(uap->rtp, &rtp, sizeof(struct rtprio));
+	else
+		cierror = 0;
+	if (uap->lwpid == 0 || uap->lwpid == td->td_tid) {
+		p = td->td_proc;
+		td1 = td;
+		PROC_LOCK(p);
+	} else {
+		/* Only look up thread in current process */
+		td1 = tdfind(uap->lwpid, curproc->p_pid);
+		if (td1 == NULL)
+			return (ESRCH);
+		p = td1->td_proc;
+	switch (uap->function) {
+	case RTP_LOOKUP:
+		if ((error = p_cansee(td, p)))
+			break;
+		pri_to_rtp(td1, &rtp);
+		PROC_UNLOCK(p);
+		return (copyout(&rtp, uap->rtp, sizeof(struct rtprio)));
+	case RTP_SET:
+		if ((error = p_cansched(td, p)) || (error = cierror))
+			break;
+		/* Disallow setting rtprio in most cases if not superuser. */
+		 * Realtime priority has to be restricted for reasons which
+		 * should be obvious.  However, for idleprio processes, there is
+		 * a potential for system deadlock if an idleprio process gains
+		 * a lock on a resource that other processes need (and the
+		 * idleprio process can't run due to a CPU-bound normal
+		 * process).  Fix me!  XXX
+		 * This problem is not only related to idleprio process.
+		 * A user level program can obtain a file lock and hold it
+		 * indefinitely.  Additionally, without idleprio processes it is
+		 * still conceivable that a program with low priority will never
+		 * get to run.  In short, allowing this feature might make it
+		 * easier to lock a resource indefinitely, but it is not the
+		 * only thing that makes it possible.
+		if (RTP_PRIO_BASE(rtp.type) == RTP_PRIO_REALTIME ||
+		    (RTP_PRIO_BASE(rtp.type) == RTP_PRIO_IDLE &&
+		    unprivileged_idprio == 0)) {
+			error = priv_check(td, PRIV_SCHED_RTPRIO);
+			if (error)
+				break;
+		error = rtp_to_pri(&rtp, td1);
+		break;
+	default:
+		error = EINVAL;
+		break;
+	PROC_UNLOCK(p);
+	return (error);
+ * Set realtime priority.
+struct rtprio_args {
+	int		function;
+	pid_t		pid;
+#endif
+int
+sys_rtprio(struct thread *td, struct rtprio_args *uap)
+	struct proc *p;
+	struct thread *tdp;
+	else
+		cierror = 0;
+		p = td->td_proc;
+		PROC_LOCK(p);
+	} else {
+		if (p == NULL)
+			return (ESRCH);
+	case RTP_LOOKUP:
+			break;
+		 * Return OUR priority if no pid specified,
+		 * or if one is, report the highest priority
+		 * in the process.  There isn't much more you can do as
+		 * there is only room to return a single priority.
+		 * Note: specifying our own pid is not the same
+		 * as leaving it zero.
+			pri_to_rtp(td, &rtp);
+		} else {
+			struct rtprio rtp2;
+			rtp.type = RTP_PRIO_IDLE;
+			rtp.prio = RTP_PRIO_MAX;
+			FOREACH_THREAD_IN_PROC(p, tdp) {
+				pri_to_rtp(tdp, &rtp2);
+				if (rtp2.type <  rtp.type ||
+				    (rtp2.type == rtp.type &&
+				    rtp2.prio < rtp.prio)) {
+					rtp.type = rtp2.type;
+					rtp.prio = rtp2.prio;
+		PROC_UNLOCK(p);
+	case RTP_SET:
+			break;
+		 * Disallow setting rtprio in most cases if not superuser.
+		 * See the comment in sys_rtprio_thread about idprio
+		 * threads holding a lock.
+		    !unprivileged_idprio)) {
+			if (error)
+				break;
+		 * If we are setting our own priority, set just our
+		 * thread but if we are doing another process,
+		 * do all the threads on that process. If we
+		 * specify our own pid we do the latter.
+			error = rtp_to_pri(&rtp, td);
+		} else {
+			FOREACH_THREAD_IN_PROC(p, td) {
+				if ((error = rtp_to_pri(&rtp, td)) != 0)
+					break;
+		break;
+	default:
+		error = EINVAL;
+		break;
+	PROC_UNLOCK(p);
+	return (error);
+int
+rtp_to_pri(struct rtprio *rtp, struct thread *td)
+	u_char  newpri, oldclass, oldpri;
+	switch (RTP_PRIO_BASE(rtp->type)) {
+	case RTP_PRIO_REALTIME:
+		if (rtp->prio > RTP_PRIO_MAX)
+			return (EINVAL);
+		newpri = PRI_MIN_REALTIME + rtp->prio;
+		break;
+	case RTP_PRIO_NORMAL:
+		if (rtp->prio > (PRI_MAX_TIMESHARE - PRI_MIN_TIMESHARE))
+			return (EINVAL);
+		newpri = PRI_MIN_TIMESHARE + rtp->prio;
+		break;
+	case RTP_PRIO_IDLE:
+			return (EINVAL);
+		newpri = PRI_MIN_IDLE + rtp->prio;
+		break;
+	default:
+		return (EINVAL);
+	thread_lock(td);
+	oldclass = td->td_pri_class;
+	sched_class(td, rtp->type);	/* XXX fix */
+	oldpri = td->td_user_pri;
+	sched_user_prio(td, newpri);
+	if (td->td_user_pri != oldpri && (oldclass != RTP_PRIO_NORMAL ||
+	    td->td_pri_class != RTP_PRIO_NORMAL))
+		sched_prio(td, td->td_user_pri);
+	if (TD_ON_UPILOCK(td) && oldpri != newpri) {
+		critical_enter();
+		thread_unlock(td);
+		umtx_pi_adjust(td, oldpri);
+		critical_exit();
+	} else
+	return (0);
+void
+pri_to_rtp(struct thread *td, struct rtprio *rtp)
+	thread_lock(td);
+	switch (PRI_BASE(td->td_pri_class)) {
+	case PRI_REALTIME:
+		rtp->prio = td->td_base_user_pri - PRI_MIN_REALTIME;
+		break;
+	case PRI_TIMESHARE:
+		rtp->prio = td->td_base_user_pri - PRI_MIN_TIMESHARE;
+		break;
+	case PRI_IDLE:
+		rtp->prio = td->td_base_user_pri - PRI_MIN_IDLE;
+		break;
+	default:
+		break;
+	rtp->type = td->td_pri_class;
+struct osetrlimit_args {
+	u_int	which;
+	struct	orlimit *rlp;
+#endif
+int
+osetrlimit(struct thread *td, struct osetrlimit_args *uap)
+	struct orlimit olim;
+	struct rlimit lim;
+	int error;
+	if ((error = copyin(uap->rlp, &olim, sizeof(struct orlimit))))
+		return (error);
+	lim.rlim_cur = olim.rlim_cur;
+	lim.rlim_max = olim.rlim_max;
+	error = kern_setrlimit(td, uap->which, &lim);
+	return (error);
+struct ogetrlimit_args {
+	u_int	which;
+#endif
+int
+ogetrlimit(struct thread *td, struct ogetrlimit_args *uap)
+	struct rlimit rl;
+	int error;
+	if (uap->which >= RLIM_NLIMITS)
+		return (EINVAL);
+	lim_rlimit(td, uap->which, &rl);
+	 * XXX would be more correct to convert only RLIM_INFINITY to the
+	 * old RLIM_INFINITY and fail with EOVERFLOW for other larger
+	 * values.  Most 64->32 and 32->16 conversions, including not
+	 * unimportant ones of uids are even more broken than what we
+	 * do here (they blindly truncate).  We don't do this correctly
+	 * here since we have little experience with EOVERFLOW yet.
+	 * Elsewhere, getuid() can't fail...
+	olim.rlim_cur = rl.rlim_cur > 0x7fffffff ? 0x7fffffff : rl.rlim_cur;
+	olim.rlim_max = rl.rlim_max > 0x7fffffff ? 0x7fffffff : rl.rlim_max;
+	error = copyout(&olim, uap->rlp, sizeof(olim));
+	return (error);
+#endif /* COMPAT_43 */
+struct __setrlimit_args {
+	u_int	which;
+	struct	rlimit *rlp;
+#endif
+int
+sys_setrlimit(struct thread *td, struct __setrlimit_args *uap)
+	struct rlimit alim;
+	int error;
+	if ((error = copyin(uap->rlp, &alim, sizeof(struct rlimit))))
+		return (error);
+	error = kern_setrlimit(td, uap->which, &alim);
+	return (error);
+static void
+lim_cb(void *arg)
+	struct rlimit rlim;
+	struct thread *td;
+	struct proc *p;
+	p = arg;
+	 * Check if the process exceeds its cpu resource allocation.  If
+	 * it reaches the max, arrange to kill the process in ast().
+	if (p->p_cpulimit == RLIM_INFINITY)
+		return;
+	PROC_STATLOCK(p);
+		ruxagg(p, td);
+	PROC_STATUNLOCK(p);
+	if (p->p_rux.rux_runtime > p->p_cpulimit * cpu_tickrate()) {
+		lim_rlimit_proc(p, RLIMIT_CPU, &rlim);
+		if (p->p_rux.rux_runtime >= rlim.rlim_max * cpu_tickrate()) {
+			killproc(p, "exceeded maximum CPU limit");
+		} else {
+			if (p->p_cpulimit < rlim.rlim_max)
+				p->p_cpulimit += 5;
+			kern_psignal(p, SIGXCPU);
+	if ((p->p_flag & P_WEXIT) == 0)
+		callout_reset_sbt(&p->p_limco, SBT_1S, 0,
+		    lim_cb, p, C_PREL(1));
+int
+kern_setrlimit(struct thread *td, u_int which, struct rlimit *limp)
+	return (kern_proc_setrlimit(td, td->td_proc, which, limp));
+int
+kern_proc_setrlimit(struct thread *td, struct proc *p, u_int which,
+    struct rlimit *limp)
+	struct plimit *newlim, *oldlim;
+	struct rlimit *alimp;
+	struct rlimit oldssiz;
+	int error;
+	if (which >= RLIM_NLIMITS)
+		return (EINVAL);
+	 * Preserve historical bugs by treating negative limits as unsigned.
+	if (limp->rlim_cur < 0)
+		limp->rlim_cur = RLIM_INFINITY;
+	if (limp->rlim_max < 0)
+		limp->rlim_max = RLIM_INFINITY;
+	oldssiz.rlim_cur = 0;
+	newlim = lim_alloc();
+	PROC_LOCK(p);
+	oldlim = p->p_limit;
+	alimp = &oldlim->pl_rlimit[which];
+	if (limp->rlim_cur > alimp->rlim_max ||
+	    limp->rlim_max > alimp->rlim_max)
+		if ((error = priv_check(td, PRIV_PROC_SETRLIMIT))) {
+			PROC_UNLOCK(p);
+			lim_free(newlim);
+			return (error);
+	if (limp->rlim_cur > limp->rlim_max)
+		limp->rlim_cur = limp->rlim_max;
+	lim_copy(newlim, oldlim);
+	alimp = &newlim->pl_rlimit[which];
+	switch (which) {
+	case RLIMIT_CPU:
+		if (limp->rlim_cur != RLIM_INFINITY &&
+		    p->p_cpulimit == RLIM_INFINITY)
+		p->p_cpulimit = limp->rlim_cur;
+		break;
+	case RLIMIT_DATA:
+		if (limp->rlim_cur > maxdsiz)
+			limp->rlim_cur = maxdsiz;
+		if (limp->rlim_max > maxdsiz)
+			limp->rlim_max = maxdsiz;
+		break;
+	case RLIMIT_STACK:
+		if (limp->rlim_cur > maxssiz)
+			limp->rlim_cur = maxssiz;
+		if (limp->rlim_max > maxssiz)
+			limp->rlim_max = maxssiz;
+		oldssiz = *alimp;
+		if (p->p_sysent->sv_fixlimit != NULL)
+			p->p_sysent->sv_fixlimit(&oldssiz,
+			    RLIMIT_STACK);
+		break;
+	case RLIMIT_NOFILE:
+		if (limp->rlim_cur > maxfilesperproc)
+			limp->rlim_cur = maxfilesperproc;
+		if (limp->rlim_max > maxfilesperproc)
+			limp->rlim_max = maxfilesperproc;
+		break;
+	case RLIMIT_NPROC:
+		if (limp->rlim_cur > maxprocperuid)
+			limp->rlim_cur = maxprocperuid;
+		if (limp->rlim_max > maxprocperuid)
+			limp->rlim_max = maxprocperuid;
+		if (limp->rlim_cur < 1)
+			limp->rlim_cur = 1;
+		if (limp->rlim_max < 1)
+			limp->rlim_max = 1;
+		break;
+		p->p_sysent->sv_fixlimit(limp, which);
+	*alimp = *limp;
+	p->p_limit = newlim;
+	PROC_UNLOCK(p);
+	lim_free(oldlim);
+	if (which == RLIMIT_STACK &&
+	     * Skip calls from exec_new_vmspace(), done when stack is
+	     * not mapped yet.
+	    (td != curthread || (p->p_flag & P_INEXEC) == 0)) {
+		 * Stack is allocated to the max at exec time with only
+		 * "rlim_cur" bytes accessible.  If stack limit is going
+		 * up make more accessible, if going down make inaccessible.
+		if (limp->rlim_cur != oldssiz.rlim_cur) {
+			vm_offset_t addr;
+			vm_size_t size;
+			vm_prot_t prot;
+			if (limp->rlim_cur > oldssiz.rlim_cur) {
+				prot = p->p_sysent->sv_stackprot;
+				size = limp->rlim_cur - oldssiz.rlim_cur;
+				addr = p->p_sysent->sv_usrstack -
+				    limp->rlim_cur;
+			} else {
+				prot = VM_PROT_NONE;
+				size = oldssiz.rlim_cur - limp->rlim_cur;
+				    oldssiz.rlim_cur;
+			addr = trunc_page(addr);
+			size = round_page(size);
+			(void)vm_map_protect(&p->p_vmspace->vm_map,
+			    addr, addr + size, prot, FALSE);
+	return (0);
+struct __getrlimit_args {
+	u_int	which;
+#endif
+/* ARGSUSED */
+int
+sys_getrlimit(struct thread *td, struct __getrlimit_args *uap)
+	int error;
+		return (EINVAL);
+	lim_rlimit(td, uap->which, &rlim);
+	error = copyout(&rlim, uap->rlp, sizeof(struct rlimit));
+	return (error);
+ * Transform the running time and tick information for children of proc p
+ * into user and system time usage.
+void
+calccru(struct proc *p, struct timeval *up, struct timeval *sp)
+	calcru1(p, &p->p_crux, up, sp);
+ * Transform the running time and tick information in proc p into user
+ * and system time usage.  If appropriate, include the current time slice
+ * on this CPU.
+void
+calcru(struct proc *p, struct timeval *up, struct timeval *sp)
+	uint64_t runtime, u;
+	PROC_STATLOCK_ASSERT(p, MA_OWNED);
+	 * If we are getting stats for the current process, then add in the
+	 * stats that this thread has accumulated in its current time slice.
+	 * We reset the thread and CPU state as if we had performed a context
+	 * switch right here.
+	td = curthread;
+	if (td->td_proc == p) {
+		u = cpu_ticks();
+		runtime = u - PCPU_GET(switchtime);
+		td->td_runtime += runtime;
+		td->td_incruntime += runtime;
+		PCPU_SET(switchtime, u);
+	/* Make sure the per-thread stats are current. */
+		if (td->td_incruntime == 0)
+			continue;
+		ruxagg(p, td);
+	calcru1(p, &p->p_rux, up, sp);
+/* Collect resource usage for a single thread. */
+void
+rufetchtd(struct thread *td, struct rusage *ru)
+	struct proc *p;
+	p = td->td_proc;
+	THREAD_LOCK_ASSERT(td, MA_OWNED);
+	 * If we are getting stats for the current thread, then add in the
+	if (td == curthread) {
+		u = cpu_ticks();
+	ruxagg(p, td);
+	*ru = td->td_ru;
+	calcru1(p, &td->td_rux, &ru->ru_utime, &ru->ru_stime);
+/* XXX: the MI version is too slow to use: */
+#ifndef __HAVE_INLINE_FLSLL
+#define	flsll(x)	(fls((x) >> 32) != 0 ? fls((x) >> 32) + 32 : fls(x))
+#endif
+static uint64_t
+mul64_by_fraction(uint64_t a, uint64_t b, uint64_t c)
+	uint64_t acc, bh, bl;
+	int i, s, sa, sb;
+	 * Calculate (a * b) / c accurately enough without overflowing.  c
+	 * must be nonzero, and its top bit must be 0.  a or b must be
+	 * <= c, and the implementation is tuned for b <= c.
+	 * The comments about times are for use in calcru1() with units of
+	 * microseconds for 'a' and stathz ticks at 128 Hz for b and c.
+	 * Let n be the number of top zero bits in c.  Each iteration
+	 * either returns, or reduces b by right shifting it by at least n.
+	 * The number of iterations is at most 1 + 64 / n, and the error is
+	 * at most the number of iterations.
+	 * It is very unusual to need even 2 iterations.  Previous
+	 * implementations overflowed essentially by returning early in the
+	 * first iteration, with n = 38 giving overflow at 105+ hours and
+	 * n = 32 giving overlow at at 388+ days despite a more careful
+	 * calculation.  388 days is a reasonable uptime, and the calculation
+	 * needs to work for the uptime times the number of CPUs since 'a'
+	 * is per-process.
+	if (a >= (uint64_t)1 << 63)
+		return (0);		/* Unsupported arg -- can't happen. */
+	acc = 0;
+	for (i = 0; i < 128; i++) {
+		sa = flsll(a);
+		sb = flsll(b);
+		if (sa + sb <= 64)
+			/* Up to 105 hours on first iteration. */
+			return (acc + (a * b) / c);
+		if (a >= c) {
+			 * This reduction is based on a = q * c + r, with the
+			 * remainder r < c.  'a' may be large to start, and
+			 * moving bits from b into 'a' at the end of the loop
+			 * sets the top bit of 'a', so the reduction makes
+			 * significant progress.
+			acc += (a / c) * b;
+			a %= c;
+			sa = flsll(a);
+				/* Up to 388 days on first iteration. */
+		 * This step writes a * b as a * ((bh << s) + bl) =
+		 * a * (bh << s) + a * bl = (a << s) * bh + a * bl.  The 2
+		 * additive terms are handled separately.  Splitting in
+		 * this way is linear except for rounding errors.
+		 * s = 64 - sa is the maximum such that a << s fits in 64
+		 * bits.  Since a < c and c has at least 1 zero top bit,
+		 * sa < 64 and s > 0.  Thus this step makes progress by
+		 * reducing b (it increases 'a', but taking remainders on
+		 * the next iteration completes the reduction).
+		 * Finally, the choice for s is just what is needed to keep
+		 * a * bl from overflowing, so we don't need complications
+		 * like a recursive call mul64_by_fraction(a, bl, c) to
+		 * handle the second additive term.
+		s = 64 - sa;
+		bh = b >> s;
+		bl = b - (bh << s);
+		acc += (a * bl) / c;
+		a <<= s;
+		b = bh;
+	return (0);		/* Algorithm failure -- can't happen. */
+static void
+calcru1(struct proc *p, struct rusage_ext *ruxp, struct timeval *up,
+    struct timeval *sp)
+	/* {user, system, interrupt, total} {ticks, usec}: */
+	uint64_t ut, uu, st, su, it, tt, tu;
+	ut = ruxp->rux_uticks;
+	st = ruxp->rux_sticks;
+	it = ruxp->rux_iticks;
+	tt = ut + st + it;
+	if (tt == 0) {
+		/* Avoid divide by zero */
+		st = 1;
+		tt = 1;
+	tu = cputick2usec(ruxp->rux_runtime);
+	if ((int64_t)tu < 0) {
+		/* XXX: this should be an assert /phk */
+		printf("calcru: negative runtime of %jd usec for pid %d (%s)\n",
+		    (intmax_t)tu, p->p_pid, p->p_comm);
+		tu = ruxp->rux_tu;
+	/* Subdivide tu.  Avoid overflow in the multiplications. */
+	if (__predict_true(tu <= ((uint64_t)1 << 38) && tt <= (1 << 26))) {
+		/* Up to 76 hours when stathz is 128. */
+		uu = (tu * ut) / tt;
+		su = (tu * st) / tt;
+	} else {
+		uu = mul64_by_fraction(tu, ut, tt);
+		su = mul64_by_fraction(tu, st, tt);
+	if (tu >= ruxp->rux_tu) {
+		 * The normal case, time increased.
+		 * Enforce monotonicity of bucketed numbers.
+		if (uu < ruxp->rux_uu)
+			uu = ruxp->rux_uu;
+		if (su < ruxp->rux_su)
+			su = ruxp->rux_su;
+	} else if (tu + 3 > ruxp->rux_tu || 101 * tu > 100 * ruxp->rux_tu) {
+		 * When we calibrate the cputicker, it is not uncommon to
+		 * see the presumably fixed frequency increase slightly over
+		 * time as a result of thermal stabilization and NTP
+		 * discipline (of the reference clock).  We therefore ignore
+		 * a bit of backwards slop because we  expect to catch up
+		 * shortly.  We use a 3 microsecond limit to catch low
+		 * counts and a 1% limit for high counts.
+	} else { /* tu < ruxp->rux_tu */
+		 * What happened here was likely that a laptop, which ran at
+		 * a reduced clock frequency at boot, kicked into high gear.
+		 * The wisdom of spamming this message in that case is
+		 * dubious, but it might also be indicative of something
+		 * serious, so lets keep it and hope laptops can be made
+		 * more truthful about their CPU speed via ACPI.
+		printf("calcru: runtime went backwards from %ju usec "
+		    "to %ju usec for pid %d (%s)\n",
+		    (uintmax_t)ruxp->rux_tu, (uintmax_t)tu,
+		    p->p_pid, p->p_comm);
+	ruxp->rux_uu = uu;
+	ruxp->rux_su = su;
+	ruxp->rux_tu = tu;
+	up->tv_sec = uu / 1000000;
+	up->tv_usec = uu % 1000000;
+	sp->tv_sec = su / 1000000;
+	sp->tv_usec = su % 1000000;
+#ifndef _SYS_SYSPROTO_H_
+struct getrusage_args {
+	int	who;
+	struct	rusage *rusage;
+#endif
+int
+sys_getrusage(struct thread *td, struct getrusage_args *uap)
+	struct rusage ru;
+	int error;
+	error = kern_getrusage(td, uap->who, &ru);
+	if (error == 0)
+		error = copyout(&ru, uap->rusage, sizeof(struct rusage));
+	return (error);
+int
+kern_getrusage(struct thread *td, int who, struct rusage *rup)
+	struct proc *p;
+	int error;
+	error = 0;
+	p = td->td_proc;
+	PROC_LOCK(p);
+	switch (who) {
+	case RUSAGE_SELF:
+		rufetchcalc(p, rup, &rup->ru_utime,
+		    &rup->ru_stime);
+		break;
+	case RUSAGE_CHILDREN:
+		*rup = p->p_stats->p_cru;
+		calccru(p, &rup->ru_utime, &rup->ru_stime);
+		break;
+	case RUSAGE_THREAD:
+		PROC_STATLOCK(p);
+		thread_lock(td);
+		rufetchtd(td, rup);
+		break;
+	default:
+		error = EINVAL;
+	PROC_UNLOCK(p);
+	return (error);
+void
+rucollect(struct rusage *ru, struct rusage *ru2)
+	long *ip, *ip2;
+	int i;
+	if (ru->ru_maxrss < ru2->ru_maxrss)
+		ru->ru_maxrss = ru2->ru_maxrss;
+	ip = &ru->ru_first;
+	ip2 = &ru2->ru_first;
+	for (i = &ru->ru_last - &ru->ru_first; i >= 0; i--)
+		*ip++ += *ip2++;
+void
+ruadd(struct rusage *ru, struct rusage_ext *rux, struct rusage *ru2,
+    struct rusage_ext *rux2)
+	rux->rux_runtime += rux2->rux_runtime;
+	rux->rux_uticks += rux2->rux_uticks;
+	rux->rux_sticks += rux2->rux_sticks;
+	rux->rux_iticks += rux2->rux_iticks;
+	rux->rux_uu += rux2->rux_uu;
+	rux->rux_su += rux2->rux_su;
+	rux->rux_tu += rux2->rux_tu;
+	rucollect(ru, ru2);
+ * Aggregate tick counts into the proc's rusage_ext.
+static void
+ruxagg_locked(struct rusage_ext *rux, struct thread *td)
+	PROC_STATLOCK_ASSERT(td->td_proc, MA_OWNED);
+	rux->rux_runtime += td->td_incruntime;
+	rux->rux_uticks += td->td_uticks;
+	rux->rux_sticks += td->td_sticks;
+	rux->rux_iticks += td->td_iticks;
+void
+ruxagg(struct proc *p, struct thread *td)
+	thread_lock(td);
+	ruxagg_locked(&p->p_rux, td);
+	ruxagg_locked(&td->td_rux, td);
+	td->td_incruntime = 0;
+	td->td_uticks = 0;
+	td->td_iticks = 0;
+	td->td_sticks = 0;
+ * Update the rusage_ext structure and fetch a valid aggregate rusage
+ * for proc p if storage for one is supplied.
+void
+rufetch(struct proc *p, struct rusage *ru)
+	*ru = p->p_ru;
+	if (p->p_numthreads > 0)  {
+			ruxagg(p, td);
+			rucollect(ru, &td->td_ru);
+ * Atomically perform a rufetch and a calcru together.
+ * Consumers, can safely assume the calcru is executed only once
+ * rufetch is completed.
+void
+rufetchcalc(struct proc *p, struct rusage *ru, struct timeval *up,
+	PROC_STATLOCK(p);
+	rufetch(p, ru);
+	calcru(p, up, sp);
+ * Allocate a new resource limits structure and initialize its
+ * reference count and mutex pointer.
+struct plimit *
+lim_alloc()
+	struct plimit *limp;
+	limp = malloc(sizeof(struct plimit), M_PLIMIT, M_WAITOK);
+	refcount_init(&limp->pl_refcnt, 1);
+	return (limp);
+struct plimit *
+lim_hold(struct plimit *limp)
+	refcount_acquire(&limp->pl_refcnt);
+	return (limp);
+void
+lim_fork(struct proc *p1, struct proc *p2)
+	PROC_LOCK_ASSERT(p1, MA_OWNED);
+	PROC_LOCK_ASSERT(p2, MA_OWNED);
+	p2->p_limit = lim_hold(p1->p_limit);
+	callout_init_mtx(&p2->p_limco, &p2->p_mtx, 0);
+	if (p1->p_cpulimit != RLIM_INFINITY)
+		callout_reset_sbt(&p2->p_limco, SBT_1S, 0,
+		    lim_cb, p2, C_PREL(1));
+void
+lim_free(struct plimit *limp)
+	if (refcount_release(&limp->pl_refcnt))
+		free((void *)limp, M_PLIMIT);
+ * Make a copy of the plimit structure.
+ * We share these structures copy-on-write after fork.
+void
+lim_copy(struct plimit *dst, struct plimit *src)
+	KASSERT(dst->pl_refcnt <= 1, ("lim_copy to shared limit"));
+	bcopy(src->pl_rlimit, dst->pl_rlimit, sizeof(src->pl_rlimit));
+ * Return the hard limit for a particular system resource.  The
+ * which parameter specifies the index into the rlimit array.
+rlim_t
+lim_max(struct thread *td, int which)
+	struct rlimit rl;
+	lim_rlimit(td, which, &rl);
+	return (rl.rlim_max);
+rlim_t
+lim_max_proc(struct proc *p, int which)
+	struct rlimit rl;
+	lim_rlimit_proc(p, which, &rl);
+ * Return the current (soft) limit for a particular system resource.
+ * The which parameter which specifies the index into the rlimit array
+rlim_t
+lim_cur(struct thread *td, int which)
+	struct rlimit rl;
+	return (rl.rlim_cur);
+rlim_t
+lim_cur_proc(struct proc *p, int which)
+	struct rlimit rl;
+ * Return a copy of the entire rlimit structure for the system limit
+ * specified by 'which' in the rlimit structure pointed to by 'rlp'.
+void
+lim_rlimit(struct thread *td, int which, struct rlimit *rlp)
+	struct proc *p = td->td_proc;
+	MPASS(td == curthread);
+	KASSERT(which >= 0 && which < RLIM_NLIMITS,
+	    ("request for invalid resource limit"));
+	*rlp = td->td_limit->pl_rlimit[which];
+		p->p_sysent->sv_fixlimit(rlp, which);
+void
+lim_rlimit_proc(struct proc *p, int which, struct rlimit *rlp)
+	*rlp = p->p_limit->pl_rlimit[which];
+void
+uihashinit()
+	uihashtbl = hashinit(maxproc / 16, M_UIDINFO, &uihash);
+	rw_init(&uihashtbl_lock, "uidinfo hash");
+ * Look up a uidinfo struct for the parameter uid.
+ * uihashtbl_lock must be locked.
+ * Increase refcount on uidinfo struct returned.
+uilookup(uid_t uid)
+	struct uihashhead *uipp;
+	struct uidinfo *uip;
+	rw_assert(&uihashtbl_lock, RA_LOCKED);
+	uipp = UIHASH(uid);
+	LIST_FOREACH(uip, uipp, ui_hash)
+		if (uip->ui_uid == uid) {
+			uihold(uip);
+			break;
+	return (uip);
+ * Find or allocate a struct uidinfo for a particular uid.
+ * Returns with uidinfo struct referenced.
+ * uifree() should be called on a struct uidinfo when released.
+struct uidinfo *
+uifind(uid_t uid)
+	struct uidinfo *new_uip, *uip;
+	struct ucred *cred;
+	cred = curthread->td_ucred;
+	if (cred->cr_uidinfo->ui_uid == uid) {
+		uip = cred->cr_uidinfo;
+		uihold(uip);
+		return (uip);
+	} else if (cred->cr_ruidinfo->ui_uid == uid) {
+		uip = cred->cr_ruidinfo;
+		uihold(uip);
+		return (uip);
+	rw_rlock(&uihashtbl_lock);
+	uip = uilookup(uid);
+	rw_runlock(&uihashtbl_lock);
+	if (uip != NULL)
+		return (uip);
+	new_uip = malloc(sizeof(*new_uip), M_UIDINFO, M_WAITOK | M_ZERO);
+	racct_create(&new_uip->ui_racct);
+	refcount_init(&new_uip->ui_ref, 1);
+	new_uip->ui_uid = uid;
+	rw_wlock(&uihashtbl_lock);
+	 * There's a chance someone created our uidinfo while we
+	 * were in malloc and not holding the lock, so we have to
+	 * make sure we don't insert a duplicate uidinfo.
+	if ((uip = uilookup(uid)) == NULL) {
+		LIST_INSERT_HEAD(UIHASH(uid), new_uip, ui_hash);
+		rw_wunlock(&uihashtbl_lock);
+		uip = new_uip;
+	} else {
+		racct_destroy(&new_uip->ui_racct);
+		free(new_uip, M_UIDINFO);
+	return (uip);
+ * Place another refcount on a uidinfo struct.
+void
+uihold(struct uidinfo *uip)
+	refcount_acquire(&uip->ui_ref);
+ * Since uidinfo structs have a long lifetime, we use an
+ * opportunistic refcounting scheme to avoid locking the lookup hash
+ * for each release.
+ * If the refcount hits 0, we need to free the structure,
+ * which means we need to lock the hash.
+ * Optimal case:
+ *   After locking the struct and lowering the refcount, if we find
+ *   that we don't need to free, simply unlock and return.
+ * Suboptimal case:
+ *   If refcount lowering results in need to free, bump the count
+ *   back up, lose the lock and acquire the locks in the proper
+ *   order to try again.
+void
+uifree(struct uidinfo *uip)
+	int old;
+	/* Prepare for optimal case. */
+	old = uip->ui_ref;
+	if (old > 1 && atomic_cmpset_int(&uip->ui_ref, old, old - 1))
+		return;
+	/* Prepare for suboptimal case. */
+	if (refcount_release(&uip->ui_ref) == 0) {
+		return;
+	racct_destroy(&uip->ui_racct);
+	LIST_REMOVE(uip, ui_hash);
+	if (uip->ui_sbsize != 0)
+		printf("freeing uidinfo: uid = %d, sbsize = %ld\n",
+		    uip->ui_uid, uip->ui_sbsize);
+	if (uip->ui_proccnt != 0)
+		printf("freeing uidinfo: uid = %d, proccnt = %ld\n",
+		    uip->ui_uid, uip->ui_proccnt);
+	if (uip->ui_vmsize != 0)
+		printf("freeing uidinfo: uid = %d, swapuse = %lld\n",
+		    uip->ui_uid, (unsigned long long)uip->ui_vmsize);
+	free(uip, M_UIDINFO);
+#ifdef RACCT
+void
+ui_racct_foreach(void (*callback)(struct racct *racct,
+    void *arg2, void *arg3), void (*pre)(void), void (*post)(void),
+	struct uihashhead *uih;
+	if (pre != NULL)
+		(pre)();
+	for (uih = &uihashtbl[uihash]; uih >= uihashtbl; uih--) {
+		LIST_FOREACH(uip, uih, ui_hash) {
+			(callback)(uip->ui_racct, arg2, arg3);
+	if (post != NULL)
+		(post)();
+#endif
+static inline int
+chglimit(struct uidinfo *uip, long *limit, int diff, rlim_t max, const char *name)
+	long new;
+	/* Don't allow them to exceed max, but allow subtraction. */
+	new = atomic_fetchadd_long(limit, (long)diff) + diff;
+	if (diff > 0 && max != 0) {
+		if (new < 0 || new > max) {
+			atomic_subtract_long(limit, (long)diff);
+			return (0);
+	} else if (new < 0)
+		printf("negative %s for uid = %d\n", name, uip->ui_uid);
+	return (1);
+ * Change the count associated with number of processes
+ * a given user is using.  When 'max' is 0, don't enforce a limit
+int
+chgproccnt(struct uidinfo *uip, int diff, rlim_t max)
+	return (chglimit(uip, &uip->ui_proccnt, diff, max, "proccnt"));
+ * Change the total socket buffer size a user has used.
+int
+chgsbsize(struct uidinfo *uip, u_int *hiwat, u_int to, rlim_t max)
+	int diff, rv;
+	diff = to - *hiwat;
+	if (diff > 0 && max == 0) {
+		rv = 0;
+	} else {
+		rv = chglimit(uip, &uip->ui_sbsize, diff, max, "sbsize");
+		if (rv != 0)
+			*hiwat = to;
+	return (rv);
+ * Change the count associated with number of pseudo-terminals
+int
+chgptscnt(struct uidinfo *uip, int diff, rlim_t max)
+	return (chglimit(uip, &uip->ui_ptscnt, diff, max, "ptscnt"));
+int
+chgkqcnt(struct uidinfo *uip, int diff, rlim_t max)
+	return (chglimit(uip, &uip->ui_kqcnt, diff, max, "kqcnt"));
+int
+chgumtxcnt(struct uidinfo *uip, int diff, rlim_t max)
+	return (chglimit(uip, &uip->ui_umtxcnt, diff, max, "umtxcnt"));
2.24.1
