[PATCH] tester: Add realview_pbx_a9_qemu_smp configuration
Sebastian Huber
Wed Aug 4 12:40:34 UTC 2021
Add a configuration for the arm/realview_pbx_a9_qemu BSP to run the tests if it
was built with SMP support enabled.
.../testing/bsps/realview_pbx_a9_qemu_smp.ini | 38 +++++++++++++++++++
1 file changed, 38 insertions(+)
create mode 100644 tester/rtems/testing/bsps/realview_pbx_a9_qemu_smp.ini
diff --git a/tester/rtems/testing/bsps/realview_pbx_a9_qemu_smp.ini b/tester/rtems/testing/bsps/realview_pbx_a9_qemu_smp.ini
new file mode 100644
index 0000000..0193141
--- /dev/null
+++ b/tester/rtems/testing/bsps/realview_pbx_a9_qemu_smp.ini
@@ -0,0 +1,38 @@
+# RTEMS Tools Project (http://www.rtems.org/)
+# Copyright 2010-2014 Chris Johns (chrisj at rtems.org)
+# All rights reserved.
+# This file is part of the RTEMS Tools package in 'rtems-tools'.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions are met:
+# 1. Redistributions of source code must retain the above copyright notice,
+# this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright notice,
+# this list of conditions and the following disclaimer in the documentation
+# and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
+# The Realview PBX A9 BSP with SMP support enabled.
+[realview_pbx_a9_qemu_smp]
+bsp = realview_pbx_a9_qemu
+arch = arm
+tester = %{_rtscripts}/qemu.cfg
+bsp_qemu_opts = %{qemu_opts_base} %{qemu_opts_no_net} -M realview-pbx-a9 -m 256M -smp 4
2.26.2
