[PATCH] tester: Add realview_pbx_a9_qemu_smp configuration
Gedare Bloom
gedare at rtems.org
Wed Aug 4 14:46:04 UTC 2021
ok
On Wed, Aug 4, 2021 at 6:41 AM Sebastian Huber
> Add a configuration for the arm/realview_pbx_a9_qemu BSP to run the tests if it
> was built with SMP support enabled.
> .../testing/bsps/realview_pbx_a9_qemu_smp.ini | 38 +++++++++++++++++++
> 1 file changed, 38 insertions(+)
> create mode 100644 tester/rtems/testing/bsps/realview_pbx_a9_qemu_smp.ini
> diff --git a/tester/rtems/testing/bsps/realview_pbx_a9_qemu_smp.ini b/tester/rtems/testing/bsps/realview_pbx_a9_qemu_smp.ini
> new file mode 100644
> index 0000000..0193141
> --- /dev/null
> +++ b/tester/rtems/testing/bsps/realview_pbx_a9_qemu_smp.ini
> @@ -0,0 +1,38 @@
> +# RTEMS Tools Project (http://www.rtems.org/)
> +# Copyright 2010-2014 Chris Johns (chrisj at rtems.org)
> +# All rights reserved.
> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
> +# Redistribution and use in source and binary forms, with or without
> +# modification, are permitted provided that the following conditions are met:
> +# 1. Redistributions of source code must retain the above copyright notice,
> +# this list of conditions and the following disclaimer.
> +# 2. Redistributions in binary form must reproduce the above copyright notice,
> +# this list of conditions and the following disclaimer in the documentation
> +# and/or other materials provided with the distribution.
> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> +# POSSIBILITY OF SUCH DAMAGE.
> +# The Realview PBX A9 BSP with SMP support enabled.
> +[realview_pbx_a9_qemu_smp]
> +bsp = realview_pbx_a9_qemu
> +arch = arm
> +tester = %{_rtscripts}/qemu.cfg
> +bsp_qemu_opts = %{qemu_opts_base} %{qemu_opts_no_net} -M realview-pbx-a9 -m 256M -smp 4
> 2.26.2
> devel mailing list
> devel at rtems.org
