[PATCH v2] Test needed for timer_create with CLOCK_MONOTONIC
zack leung
zakthertemsdev at gmail.com
Wed Aug 4 14:35:06 UTC 2021
bump
On Thu, 29 Jul 2021 at 00:28, Zacchaeus Leung <zakthertemsdev at gmail.com>
wrote:
> the timer_create() method can use CLOCK_MONOTONIC but there was no test
> for this
> Closes #3888
> cpukit/include/rtems/posix/timer.h | 1 +
> cpukit/posix/src/psxtimercreate.c | 3 +-
> cpukit/posix/src/timergettime.c | 52 ++++++++++++++---------
> testsuites/psxtests/psxtimer02/psxtimer.c | 26 ++++++++++++
> 4 files changed, 60 insertions(+), 22 deletions(-)
> diff --git a/cpukit/include/rtems/posix/timer.h
> b/cpukit/include/rtems/posix/timer.h
> index bcbf07a65a..7ae089173a 100644
> --- a/cpukit/include/rtems/posix/timer.h
> +++ b/cpukit/include/rtems/posix/timer.h
> @@ -48,6 +48,7 @@ typedef struct {
> uint32_t ticks; /* Number of ticks of the initialization
> uint32_t overrun; /* Number of expirations of the timer
> struct timespec time; /* Time at which the timer was started
> + clockid_t clock_type; /* The type of timer */
> } POSIX_Timer_Control;
> diff --git a/cpukit/posix/src/psxtimercreate.c
> b/cpukit/posix/src/psxtimercreate.c
> index a63cf1d100..2b5a10140f 100644
> --- a/cpukit/posix/src/psxtimercreate.c
> +++ b/cpukit/posix/src/psxtimercreate.c
> @@ -40,7 +40,7 @@ int timer_create(
> POSIX_Timer_Control *ptimer;
> - if ( clock_id != CLOCK_REALTIME )
> + if ( clock_id != CLOCK_REALTIME && clock_id != CLOCK_MONOTONIC )
> rtems_set_errno_and_return_minus_one( EINVAL );
> if ( !timerid )
> @@ -91,6 +91,7 @@ int timer_create(
> ptimer->timer_data.it_value.tv_nsec = 0;
> ptimer->timer_data.it_interval.tv_sec = 0;
> ptimer->timer_data.it_interval.tv_nsec = 0;
> + ptimer->clock_type = clock_id;
> _Watchdog_Preinitialize( &ptimer->Timer, _Per_CPU_Get_snapshot() );
> _Watchdog_Initialize( &ptimer->Timer, _POSIX_Timer_TSR );
> diff --git a/cpukit/posix/src/timergettime.c
> b/cpukit/posix/src/timergettime.c
> index ee2a566f0e..b29d03efa1 100644
> --- a/cpukit/posix/src/timergettime.c
> +++ b/cpukit/posix/src/timergettime.c
> @@ -28,6 +28,7 @@
> #include <rtems/score/todimpl.h>
> #include <rtems/score/watchdogimpl.h>
> #include <rtems/seterr.h>
> +#include <rtems/timespec.h>
> * - When a timer is initialized, the value of the time in
> @@ -39,35 +40,44 @@
> int timer_gettime(
> timer_t timerid,
> struct itimerspec *value
> - ISR_lock_Context lock_context;
> - uint64_t now;
> - uint32_t remaining;
> + ISR_lock_Context lock_context;
> + Per_CPU_Control *cpu;
> + struct timespec now;
> + struct timespec expire;
> + struct timespec result;
> if ( !value )
> ptimer = _POSIX_Timer_Get( timerid, &lock_context );
> - if ( ptimer != NULL ) {
> - Per_CPU_Control *cpu;
> - cpu = _POSIX_Timer_Acquire_critical( ptimer, &lock_context );
> - now = cpu->Watchdog.ticks;
> - if ( now < ptimer->Timer.expire ) {
> - remaining = (uint32_t) ( ptimer->Timer.expire - now );
> - } else {
> - remaining = 0;
> + if ( ptimer == NULL ) {
> + rtems_set_errno_and_return_minus_one( EINVAL );
> - _Timespec_From_ticks( remaining, &value->it_value );
> - value->it_interval = ptimer->timer_data.it_interval;
> + cpu = _POSIX_Timer_Acquire_critical( ptimer, &lock_context );
> + rtems_timespec_from_ticks( ptimer->Timer.expire, &expire );
> - _POSIX_Timer_Release( cpu, &lock_context );
> - return 0;
> + if ( ptimer->clock_type == CLOCK_MONOTONIC ) {
> + _Timecounter_Nanouptime(&now);
> + if ( ptimer->clock_type == CLOCK_REALTIME ) {
> + _TOD_Get(&now);
> - rtems_set_errno_and_return_minus_one( EINVAL );
> + if ( rtems_timespec_less_than( &now, &expire ) ) {
> + rtems_timespec_subtract( &now, &expire, &result );
> + } else {
> + result.tv_nsec = 0;
> + result.tv_sec = 0;
> + value->it_value=result;
> + value->it_interval = ptimer->timer_data.it_interval;
> + _POSIX_Timer_Release( cpu, &lock_context );
> + return 0;
> \ No newline at end of file
> diff --git a/testsuites/psxtests/psxtimer02/psxtimer.c
> b/testsuites/psxtests/psxtimer02/psxtimer.c
> index 9f79d33c42..1a79369efb 100644
> --- a/testsuites/psxtests/psxtimer02/psxtimer.c
> +++ b/testsuites/psxtests/psxtimer02/psxtimer.c
> @@ -126,6 +126,32 @@ void *POSIX_Init (
> puts( "timer_delete - bad id - EINVAL" );
> status = timer_delete( timer );
> fatal_posix_service_status_errno( status, EINVAL, "bad id" );
> + puts( "timer_create (monotonic) - bad timer id pointer - EINVAL" );
> + status = timer_create( CLOCK_MONOTONIC, &event, NULL );
> + fatal_posix_service_status_errno( status, EINVAL, "bad timer id" );
> + puts( "timer_create (monotonic) - OK" );
> + status = timer_create( CLOCK_MONOTONIC, NULL, &timer );
> + posix_service_failed( status, "timer_create OK" );
> + puts( "timer_create (monotonic) - too many - EAGAIN" );
> + status = timer_create( CLOCK_MONOTONIC, NULL, &timer1 );
> + fatal_posix_service_status_errno( status, EAGAIN, "too many" );
> + clock_gettime( CLOCK_MONOTONIC, &now );
> + itimer.it_value = now;
> + itimer.it_value.tv_sec = itimer.it_value.tv_sec - 1;
> + puts( "timer_settime (monotonic) - bad itimer value - previous time -
> EINVAL" );
> + status = timer_settime( timer, TIMER_ABSTIME, &itimer, NULL );
> + fatal_posix_service_status_errno( status, EINVAL, "bad itimer value #3"
> + itimer.it_value.tv_sec = itimer.it_value.tv_sec + 1;
> + puts( "timer_settime (monotonic) - bad id - EINVAL" );
> + status = timer_settime( timer1, TIMER_ABSTIME, &itimer, NULL );
> + fatal_posix_service_status_errno( status, EINVAL, "bad id" );
> TEST_END();
> rtems_test_exit (0);
> 2.32.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210804/29ffa370/attachment.html>
