[PATCH v2] Test needed for timer_create with CLOCK_MONOTONIC
Wed Aug 4 16:02:44 UTC 2021
On Wed, Jul 28, 2021 at 6:28 PM Zacchaeus Leung
<zakthertemsdev at gmail.com> wrote:
> the timer_create() method can use CLOCK_MONOTONIC but there was  no test for this
> Closes #3888
>  cpukit/include/rtems/posix/timer.h        |  1 +
>  cpukit/posix/src/psxtimercreate.c         |  3 +-
>  cpukit/posix/src/timergettime.c           | 52 ++++++++++++++---------
>  testsuites/psxtests/psxtimer02/psxtimer.c | 26 ++++++++++++
>  4 files changed, 60 insertions(+), 22 deletions(-)
> diff --git a/cpukit/include/rtems/posix/timer.h b/cpukit/include/rtems/posix/timer.h
> index bcbf07a65a..7ae089173a 100644
> --- a/cpukit/include/rtems/posix/timer.h
> +++ b/cpukit/include/rtems/posix/timer.h
> @@ -48,6 +48,7 @@ typedef struct {
>    uint32_t          ticks;      /* Number of ticks of the initialization */
>    uint32_t          overrun;    /* Number of expirations of the timer    */
>    struct timespec   time;       /* Time at which the timer was started   */
> +  clockid_t         clock_type; /* The type of timer */
>  } POSIX_Timer_Control;
> diff --git a/cpukit/posix/src/psxtimercreate.c b/cpukit/posix/src/psxtimercreate.c
> index a63cf1d100..2b5a10140f 100644
> --- a/cpukit/posix/src/psxtimercreate.c
> +++ b/cpukit/posix/src/psxtimercreate.c
> @@ -40,7 +40,7 @@ int timer_create(
>    POSIX_Timer_Control *ptimer;
> -  if ( clock_id != CLOCK_REALTIME )
> +  if (  clock_id != CLOCK_REALTIME && clock_id != CLOCK_MONOTONIC )
>      rtems_set_errno_and_return_minus_one( EINVAL );
>    if ( !timerid )
> @@ -91,6 +91,7 @@ int timer_create(
>    ptimer->timer_data.it_value.tv_nsec    = 0;
>    ptimer->timer_data.it_interval.tv_sec  = 0;
>    ptimer->timer_data.it_interval.tv_nsec = 0;
> +  ptimer->clock_type = clock_id;
>    _Watchdog_Preinitialize( &ptimer->Timer, _Per_CPU_Get_snapshot() );
>    _Watchdog_Initialize( &ptimer->Timer, _POSIX_Timer_TSR );
> diff --git a/cpukit/posix/src/timergettime.c b/cpukit/posix/src/timergettime.c
> index ee2a566f0e..b29d03efa1 100644
> --- a/cpukit/posix/src/timergettime.c
> +++ b/cpukit/posix/src/timergettime.c
> @@ -28,6 +28,7 @@
>  #include <rtems/score/todimpl.h>
>  #include <rtems/score/watchdogimpl.h>
>  #include <rtems/seterr.h>
> +#include <rtems/timespec.h>
>   *          - When a timer is initialized, the value of the time in
> @@ -39,35 +40,44 @@
>  int timer_gettime(
>    timer_t            timerid,
>    struct itimerspec *value
> -  ISR_lock_Context     lock_context;
> -  uint64_t             now;
> -  uint32_t             remaining;
> +  ISR_lock_Context lock_context;
> +  Per_CPU_Control *cpu;
> +  struct timespec now;
> +  struct timespec expire;
> +  struct timespec result;
>    if ( !value )
>    ptimer = _POSIX_Timer_Get( timerid, &lock_context );
> -  if ( ptimer != NULL ) {
> -    Per_CPU_Control *cpu;
> -    cpu = _POSIX_Timer_Acquire_critical( ptimer, &lock_context );
> -    now = cpu->Watchdog.ticks;
> -    if ( now < ptimer->Timer.expire ) {
> -      remaining = (uint32_t) ( ptimer->Timer.expire - now );
> -    } else {
> -      remaining = 0;
> +  if ( ptimer == NULL ) {
> +    rtems_set_errno_and_return_minus_one( EINVAL );
> -    _Timespec_From_ticks( remaining, &value->it_value );
> -    value->it_interval = ptimer->timer_data.it_interval;
> +  cpu = _POSIX_Timer_Acquire_critical( ptimer, &lock_context );
> +  rtems_timespec_from_ticks( ptimer->Timer.expire, &expire );
> -    _POSIX_Timer_Release( cpu, &lock_context );
> -    return 0;
> +  if ( ptimer->clock_type == CLOCK_MONOTONIC ) {
> +  _Timecounter_Nanouptime(&now);
> +  if ( ptimer->clock_type == CLOCK_REALTIME ) {
Minor nit: this could be 'else if'
> +    _TOD_Get(&now);
Here you could add an assert that ptimer->clock_type ==
CLOCK_MONOTONIC || ptimer->clock_type == CLOCK_REALTIME. Or you can
add:
 else {
and make sure to test by calling this function directly with an
invalid clock_type. This of course depends on making the above into
'else if'.
> -  rtems_set_errno_and_return_minus_one( EINVAL );
> + if ( rtems_timespec_less_than( &now, &expire ) ) {
> +      rtems_timespec_subtract( &now, &expire, &result );
> +    } else {
> +      result.tv_nsec = 0;
> +      result.tv_sec  = 0;
> +  value->it_value=result;
add spaces around =
> +  value->it_interval = ptimer->timer_data.it_interval;
> +  _POSIX_Timer_Release( cpu, &lock_context );
> +  return 0;
> \ No newline at end of file
> diff --git a/testsuites/psxtests/psxtimer02/psxtimer.c b/testsuites/psxtests/psxtimer02/psxtimer.c
> index 9f79d33c42..1a79369efb 100644
> --- a/testsuites/psxtests/psxtimer02/psxtimer.c
> +++ b/testsuites/psxtests/psxtimer02/psxtimer.c
> @@ -126,6 +126,32 @@ void *POSIX_Init (
>    puts( "timer_delete - bad id - EINVAL" );
>    status = timer_delete( timer );
>    fatal_posix_service_status_errno( status, EINVAL, "bad id" );
> +  puts( "timer_create (monotonic) - bad timer id pointer - EINVAL" );
> +  status = timer_create( CLOCK_MONOTONIC, &event, NULL );
> +  fatal_posix_service_status_errno( status, EINVAL, "bad timer id" );
> +  puts( "timer_create (monotonic) - OK" );
> +  status = timer_create( CLOCK_MONOTONIC, NULL, &timer );
> +  posix_service_failed( status, "timer_create OK" );
> +  puts( "timer_create (monotonic) - too many - EAGAIN" );
> +  status = timer_create( CLOCK_MONOTONIC, NULL, &timer1 );
> +  fatal_posix_service_status_errno( status, EAGAIN, "too many" );
> +  clock_gettime( CLOCK_MONOTONIC, &now );
> +  itimer.it_value = now;
> +  itimer.it_value.tv_sec = itimer.it_value.tv_sec - 1;
> +  puts( "timer_settime (monotonic) - bad itimer value - previous time - EINVAL" );
> +  status = timer_settime( timer, TIMER_ABSTIME, &itimer, NULL );
> +  fatal_posix_service_status_errno( status, EINVAL, "bad itimer value #3" );
> +  itimer.it_value.tv_sec = itimer.it_value.tv_sec + 1;
> +  puts( "timer_settime (monotonic) - bad id - EINVAL" );
> +  status = timer_settime( timer1, TIMER_ABSTIME, &itimer, NULL );
> +  fatal_posix_service_status_errno( status, EINVAL, "bad id" );
>    TEST_END();
>    rtems_test_exit (0);
> 2.32.0
> devel mailing list
> devel at rtems.org
