[PATCH v1 0/5] Fix ostream format errors
Ryan Long
ryan.long at oarcorp.com
Wed Aug 4 15:54:19 UTC 2021
Hi,
The last "Restore ostream format" patch set didn't fix the Coverity issues.
We verified that resetiosflags() will get rid of the issues complaints about
std::left and std::right changing the stream's format, I noticed that it
didn't complain if std::setfill(' ') was used after changing the setfill value
to something else.
I don't know if Coverity will recognize storing the precision value and
restoring it as a fix for the setprecision() calls, but the only other
option is to just set the precision value to 6 (the default value).
Thanks,
Ryan
Ryan Long (5):
rtems-utils.h: Remove ostream_guard
rtems-exeinfo.cpp: Reset cout stream flags
CoverageMapBase.cc: Restore ostream format
ReportsHtml.cc: Restore ostream format
ReportsText.cc: Restore ostream format
linkers/rtems-exeinfo.cpp | 11 ++++-------
rtemstoolkit/rtems-utils.h | 20 --------------------
tester/covoar/CoverageMapBase.cc | 6 +-----
tester/covoar/ReportsHtml.cc | 11 +++++------
tester/covoar/ReportsText.cc | 12 +++++-------
5 files changed, 15 insertions(+), 45 deletions(-)
1.8.3.1
