[PATCH v1 2/5] rtems-exeinfo.cpp: Reset cout stream flags
Ryan Long
ryan.long at oarcorp.com
Wed Aug 4 15:54:21 UTC 2021
CID 1503006: Not restoring ostream format
CID 1503007: Not restoring ostream format
Remove ostream_guard, add restiosflags() call, and store the value of precision
before it is changed restore it afterwards.
Closes #4469
linkers/rtems-exeinfo.cpp | 11 ++++-------
1 file changed, 4 insertions(+), 7 deletions(-)
diff --git a/linkers/rtems-exeinfo.cpp b/linkers/rtems-exeinfo.cpp
index c9bf5b6..fe484ea 100644
--- a/linkers/rtems-exeinfo.cpp
+++ b/linkers/rtems-exeinfo.cpp
@@ -47,14 +47,11 @@
#include <rld-files.h>
#include <rld-process.h>
#include <rld-rtems.h>
-#include <rtems-utils.h>
#ifndef HAVE_KILL
#define kill(p,s) raise(s)
#endif
-typedef rtems::utils::ostream_guard ostream_guard;
namespace rld
namespace exeinfo
@@ -369,7 +366,6 @@ namespace rld
rld::strings all_flags;
- ostream_guard old_state( std::cout );
size_t source_max = 0;
@@ -481,7 +477,8 @@ namespace rld
std::cout << " | "
<< std::setw (source_max + 1) << std::left
- << rld::path::basename (s.source);
+ << rld::path::basename (s.source)
+ << std::resetiosflags( std::ios_base::left );
if (!s.flags.empty ())
bool first = true;
@@ -636,7 +633,6 @@ namespace rld
void image::output_tls ()
symbols::symbol* tls_data_begin = symbols.find_global("_TLS_Data_begin");
symbols::symbol* tls_data_end = symbols.find_global("_TLS_Data_end");
@@ -714,7 +710,8 @@ namespace rld
<< " data addr : 0x" << std::setw (8) << tls_data_begin->value ()
<< std::endl
<< std::dec << std::setfill (' ')
- << std::endl;
+ << std::endl
+ << std::resetiosflags( std::ios_base::right );
void image::config(const std::string name)
1.8.3.1
