[PATCH] bsps/arm: fix off-by-1 in gicv3 processor count
Sebastian Huber
Wed Aug 4 17:45:51 UTC 2021
On 04/08/2021 19:18, Gedare Bloom wrote:
> Hi Sebastian,
> On Wed, Aug 4, 2021 at 11:15 AM Gedare Bloom<gedare at rtems.org> wrote:
>> bsps/shared/dev/irq/arm-gicv3.c | 4 ++--
>> 1 file changed, 2 insertions(+), 2 deletions(-)
>> diff --git a/bsps/shared/dev/irq/arm-gicv3.c b/bsps/shared/dev/irq/arm-gicv3.c
>> index ea123d325e..95021f6ddf 100644
>> --- a/bsps/shared/dev/irq/arm-gicv3.c
>> +++ b/bsps/shared/dev/irq/arm-gicv3.c
>> @@ -551,11 +551,11 @@ uint32_t arm_gic_irq_processor_count(void)
>> for (i = 0; i < CPU_MAXIMUM_PROCESSORS; ++i) {
>> volatile gic_redist *redist = gicv3_get_redist(i);
>> + ++cpu_count;
>> if ((redist->icrtyper & GIC_REDIST_ICRTYPER_LAST) != 0) {
>> break;
>> - ++cpu_count;
> Can you check my thinking here? I'm trying to implement SMP support
> for the versal on aarch64. The call to arm_gic_irq_processor_count()
> returns 1 through this code path. Since cpu_count is initialized to 0,
> I think we need to increment it each time we find an active processor,
> until we find the last active processor, which we also need to include
> in the count, because the cpu_count should be NUM_PROC + 1?
> After I make this change, I encounter other problems with the
> secondary processor initialization, but at least it tries to
> initialize/wait for core#1 then.
The current logic is based on this text in the Cortex-R52 TRM for
GICR_TYPER[Last]:
"In a processor configured with an interrupt export port, this bit is
set for the Redistributor associated with
the export port. Otherwise, in a system with n cores, this bit is set
core n-1."
I don't know how you can figure out if a processor has an interrupt
export port. Maybe there are better ways to figure out the processor
count. I would have a look at the Linux or U-Boot sources.
Independent of this, I had problems with the software generated
interrupts on Qemu and AArch64. They worked only once. This cases the
new interrupt manager tests to fail with a timeout.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
