[PATCH] bsps/arm: fix off-by-1 in gicv3 processor count
Wed Aug 4 17:50:51 UTC 2021
On 04/08/2021 19:45, Sebastian Huber wrote:
> On 04/08/2021 19:18, Gedare Bloom wrote:
>> Hi Sebastian,
>> On Wed, Aug 4, 2021 at 11:15 AM Gedare Bloom<gedare at rtems.org>  wrote:
>>>   bsps/shared/dev/irq/arm-gicv3.c | 4 ++--
>>>   1 file changed, 2 insertions(+), 2 deletions(-)
>>> diff --git a/bsps/shared/dev/irq/arm-gicv3.c
>>> b/bsps/shared/dev/irq/arm-gicv3.c
>>> index ea123d325e..95021f6ddf 100644
>>> --- a/bsps/shared/dev/irq/arm-gicv3.c
>>> +++ b/bsps/shared/dev/irq/arm-gicv3.c
>>> @@ -551,11 +551,11 @@ uint32_t arm_gic_irq_processor_count(void)
>>>       for (i = 0; i < CPU_MAXIMUM_PROCESSORS; ++i) {
>>>         volatile gic_redist *redist = gicv3_get_redist(i);
>>> +      ++cpu_count;
>>>         if ((redist->icrtyper & GIC_REDIST_ICRTYPER_LAST) != 0) {
>>>           break;
>>> -      ++cpu_count;
>> Can you check my thinking here? I'm trying to implement SMP support
>> for the versal on aarch64. The call to arm_gic_irq_processor_count()
>> returns 1 through this code path. Since cpu_count is initialized to 0,
>> I think we need to increment it each time we find an active processor,
>> until we find the last active processor, which we also need to include
>> in the count, because the cpu_count should be NUM_PROC + 1?
>> After I make this change, I encounter other problems with the
>> secondary processor initialization, but at least it tries to
>> initialize/wait for core#1 then.
> The current logic is based on this text in the Cortex-R52 TRM for
> GICR_TYPER[Last]:
> "In a processor configured with an interrupt export port, this bit is
> set for the Redistributor associated with
> the export port. Otherwise, in a system with n cores, this bit is set
> core n-1."
> I don't know how you can figure out if a processor has an interrupt
> export port. Maybe there are better ways to figure out the processor
> count. I would have a look at the Linux or U-Boot sources.
> Independent of this, I had problems with the software generated
> interrupts on Qemu and AArch64. They worked only once. This cases the
> new interrupt manager tests to fail with a timeout.
I have to check this on the FVP simulator. Maybe this simulator has two
interrupt export ports or we have an off by one error.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
