[PATCH 1/2] testsuites: added compile tests for new APIs
Matt Joyce
mfjoyce2004 at gmail.com
Fri Aug 6 13:42:14 UTC 2021
Added compile only tests for new POSIX standard APIs
pthread_rwlock_clockrdlock() and
pthread_rwlock_clockwrlock() in
testsuites/psxtests/psxhdrs/pthread
spec/build/testsuites/psxtests/libpsxhdrs.yml | 2 +
.../pthread/pthread_rwlock_clockrdlock.c | 59 +++++++++++++++++++
.../pthread/pthread_rwlock_clockwrlock.c | 59 +++++++++++++++++++
3 files changed, 120 insertions(+)
create mode 100644 testsuites/psxtests/psxhdrs/pthread/pthread_rwlock_clockrdlock.c
create mode 100644 testsuites/psxtests/psxhdrs/pthread/pthread_rwlock_clockwrlock.c
diff --git a/spec/build/testsuites/psxtests/libpsxhdrs.yml b/spec/build/testsuites/psxtests/libpsxhdrs.yml
index 6a0ab6d4f7..5e9f808db5 100644
--- a/spec/build/testsuites/psxtests/libpsxhdrs.yml
+++ b/spec/build/testsuites/psxtests/libpsxhdrs.yml
@@ -464,6 +464,8 @@ source:
- testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_setprotocol.c
- testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_setpshared.c
- testsuites/psxtests/psxhdrs/pthread/pthread_once.c
+- testsuites/psxtests/psxhdrs/pthread/pthread_rwlock_clockrdlock.c
+- testsuites/psxtests/psxhdrs/pthread/pthread_rwlock_clockwrlock.c
- testsuites/psxtests/psxhdrs/pthread/pthread_self.c
- testsuites/psxtests/psxhdrs/pthread/pthread_setcancelstate.c
- testsuites/psxtests/psxhdrs/pthread/pthread_setcanceltype.c
diff --git a/testsuites/psxtests/psxhdrs/pthread/pthread_rwlock_clockrdlock.c b/testsuites/psxtests/psxhdrs/pthread/pthread_rwlock_clockrdlock.c
new file mode 100644
index 0000000000..d21919e688
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/pthread/pthread_rwlock_clockrdlock.c
@@ -0,0 +1,59 @@
+* @file
+* @brief pthread_rwlock_clockrdlock() API Conformance Test
+* Copyright (C) 2021 Matthew Joyce
+* Redistribution and use in source and binary forms, with or without
+* modification, are permitted provided that the following conditions
+* are met:
+* 1. Redistributions of source code must retain the above copyright
+* notice, this list of conditions and the following disclaimer.
+* 2. Redistributions in binary form must reproduce the above copyright
+* notice, this list of conditions and the following disclaimer in the
+* documentation and/or other materials provided with the distribution.
+* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+* POSSIBILITY OF SUCH DAMAGE.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <pthread.h>
+#ifndef _POSIX_THREADS
+#error "rtems is supposed to have pthread_rwlock_clockrdlock"
+#endif
+#ifndef _POSIX_TIMEOUTS
+#endif
+#ifndef _POSIX_READER_WRITER_LOCKS
+#endif
+int test( void );
+int test( void )
+ pthread_rwlock_t rwlock = PTHREAD_RWLOCK_INITIALIZER;
+ clockid_t clock_id = CLOCK_REALTIME;
+ const struct timespec abstime;
+ int result2;
+ result2 = pthread_rwlock_clockrdlock( &rwlock, clock_id, &abstime );
+ return result2;
diff --git a/testsuites/psxtests/psxhdrs/pthread/pthread_rwlock_clockwrlock.c b/testsuites/psxtests/psxhdrs/pthread/pthread_rwlock_clockwrlock.c
index 0000000000..b081d1db56
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/pthread/pthread_rwlock_clockwrlock.c
@@ -0,0 +1,59 @@
+* @file
+* @brief pthread_rwlock_clockwrlock() API Conformance Test
+* are met:
+#endif
+#error "rtems is supposed to have pthread_rwlock_clockwrlock"
+#endif
+#endif
+#endif
+int test( void );
+int test( void )
+ int result;
+ result = pthread_rwlock_clockwrlock( &rwlock, clock_id, &abstime );
+ return result;
2.31.1
