[PATCH 2/2] testsuites: added compile tests for new APIs
Matt Joyce mfjoyce2004 at gmail.com
Fri Aug 6 13:42:15 UTC 2021
Added compile only tests for new POSIX standard APIs pthread_cond_clockwait and
pthread_mutex_clocklock in testsuites/psxtests/psxhdrs/pthread
 spec/build/testsuites/psxtests/libpsxhdrs.yml |  2 +
 .../psxhdrs/pthread/pthread_cond_clockwait.c  | 54 ++++++++++++++++++
 .../psxhdrs/pthread/pthread_mutex_clocklock.c | 56 +++++++++++++++++++
 3 files changed, 112 insertions(+)
 create mode 100644 testsuites/psxtests/psxhdrs/pthread/pthread_cond_clockwait.c
 create mode 100644 testsuites/psxtests/psxhdrs/pthread/pthread_mutex_clocklock.c
diff --git a/spec/build/testsuites/psxtests/libpsxhdrs.yml b/spec/build/testsuites/psxtests/libpsxhdrs.yml
index 5e9f808db5..d7fc430a36 100644
--- a/spec/build/testsuites/psxtests/libpsxhdrs.yml
+++ b/spec/build/testsuites/psxtests/libpsxhdrs.yml
@@ -432,6 +432,7 @@ source:
 - testsuites/psxtests/psxhdrs/pthread/pthread_cond_signal.c
 - testsuites/psxtests/psxhdrs/pthread/pthread_cond_timedwait.c
 - testsuites/psxtests/psxhdrs/pthread/pthread_cond_wait.c
+- testsuites/psxtests/psxhdrs/pthread/pthread_cond_clockwait.c
 - testsuites/psxtests/psxhdrs/pthread/pthread_condattr_destroy.c
 - testsuites/psxtests/psxhdrs/pthread/pthread_condattr_getpshared.c
 - testsuites/psxtests/psxhdrs/pthread/pthread_condattr_init.c
@@ -453,6 +454,7 @@ source:
 - testsuites/psxtests/psxhdrs/pthread/pthread_mutex_lock.c
 - testsuites/psxtests/psxhdrs/pthread/pthread_mutex_setprioceiling.c
 - testsuites/psxtests/psxhdrs/pthread/pthread_mutex_timedlock.c
+- testsuites/psxtests/psxhdrs/pthread/pthread_mutex_clocklock.c
 - testsuites/psxtests/psxhdrs/pthread/pthread_mutex_trylock.c
 - testsuites/psxtests/psxhdrs/pthread/pthread_mutex_unlock.c
 - testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_destroy.c
diff --git a/testsuites/psxtests/psxhdrs/pthread/pthread_cond_clockwait.c b/testsuites/psxtests/psxhdrs/pthread/pthread_cond_clockwait.c
new file mode 100644
index 0000000000..427f5063c9
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/pthread/pthread_cond_clockwait.c
@@ -0,0 +1,54 @@
+* @file
+* @brief pthread_cond_clockwait() API Conformance Test
+* Copyright (C) 2021 Matthew Joyce
+* Redistribution and use in source and binary forms, with or without
+* modification, are permitted provided that the following conditions
+* are met:
+* 1. Redistributions of source code must retain the above copyright
+*    notice, this list of conditions and the following disclaimer.
+* 2. Redistributions in binary form must reproduce the above copyright
+*    notice, this list of conditions and the following disclaimer in the
+*    documentation and/or other materials provided with the distribution.
+* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+* POSSIBILITY OF SUCH DAMAGE.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <pthread.h>
+#ifndef _POSIX_THREADS
+#error "rtems is supposed to have pthread_cond_clockwait"
+#endif
+int test( void );
+int test( void )
+  pthread_cond_t        cond  = PTHREAD_COND_INITIALIZER;
+  pthread_mutex_t       mutex = PTHREAD_MUTEX_INITIALIZER;
+  clockid_t             clock_id = CLOCK_REALTIME;
+  const struct timespec abstime;
+  int result;
+  result = pthread_cond_clockwait( &cond, &mutex, clock_id, &abstime );
+  return result;
diff --git a/testsuites/psxtests/psxhdrs/pthread/pthread_mutex_clocklock.c b/testsuites/psxtests/psxhdrs/pthread/pthread_mutex_clocklock.c
index 0000000000..22f94b5991
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/pthread/pthread_mutex_clocklock.c
@@ -0,0 +1,56 @@
+* @file
+* @brief pthread_mutex_clocklock() API Conformance Test
+* are met:
+#endif
+#error "rtems is supposed to have pthread_mutex_clocklock"
+#endif
+#ifndef _POSIX_TIMEOUTS
+#endif
+int test( void );
+int test( void )
+  int result;
+  result = pthread_mutex_clocklock( &mutex, clock_id, &abstime );
+  return result;
2.31.1
