[PATCH] user: Update rsb-packages to reflect RTEMS 6 changes
Ray Garza
raymond.garza at oarcorp.com
Fri Aug 6 21:26:13 UTC 2021
This updates all references and examples in the rtems docs: user/start/rsb-packages.rst to RTEMS 6
user/start/rsb-packages.rst | 68 ++++++++++++++++++-------------------
1 file changed, 34 insertions(+), 34 deletions(-)
diff --git a/user/start/rsb-packages.rst b/user/start/rsb-packages.rst
index 3119318..891ea6a 100644
--- a/user/start/rsb-packages.rst
+++ b/user/start/rsb-packages.rst
@@ -19,8 +19,8 @@ Return to here once you have completed these steps.
You have chosen an installation prefix, the BSP to build, the tool's
architecure and prepared the source for the RSB in the previous sections. We
-have chosen :file:`$HOME/quick-start/rtems/5` as the installation prefix, the
-``erc32`` BSP and the SPARC architecture name of ``sparc-rtems5``, and unpacked
+have chosen :file:`$HOME/quick-start/rtems/6` as the installation prefix, the
+``erc32`` BSP and the SPARC architecture name of ``sparc-rtems6``, and unpacked
the RSB source in :file:`$HOME/quick-start/src`.
You are now able to build :ref:`BSP Packages` or 3rd party libraries of code if you
@@ -72,36 +72,36 @@ BSP.
.. code-block:: none
cd $HOME/quick-start/src/rsb/rtems
- ../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/5 \
+ ../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/6 \
--with-rtems-tests=yes bsps/erc32
This command should output something like this:
- RTEMS Source Builder - Set Builder, 5.1.0
+ RTEMS Source Builder - Set Builder, 6 (4e6dc6431435)
Build Set: bsps/erc32
- Build Set: 5/rtems-sparc.bset
- Build Set: 5/rtems-autotools.bset
- Build Set: 5/rtems-autotools-internal.bset
+ Build Set: 6/rtems-sparc.bset
+ Build Set: 6/rtems-autotools.bset
+ Build Set: 6/rtems-autotools-internal.bset
config: tools/rtems-autoconf-2.69-1.cfg
package: autoconf-2.69-x86_64-freebsd12.1-1
building: autoconf-2.69-x86_64-freebsd12.1-1
sizes: autoconf-2.69-x86_64-freebsd12.1-1: 7.505MB (installed: 0.000B)
- building: protobuf-2.6.1-sparc-rtems5-1
- sizes: protobuf-2.6.1-sparc-rtems5-1: 228.079MB (installed: 84.408MB)
- cleaning: protobuf-2.6.1-sparc-rtems5-1
- reporting: net/protobuf-2.6.1-1.cfg -> protobuf-2.6.1-sparc-rtems5-1.txt
- reporting: net/protobuf-2.6.1-1.cfg -> protobuf-2.6.1-sparc-rtems5-1.xml
- staging: protobuf-2.6.1-sparc-rtems5-1 -> $HOME/quick-start/src/rsb/rtems/build/tmp/sb-500-staging
- Build Set: Time 0:00:23.564992
- Build Set: Time 0:02:27.380299
+ building: protobuf-2.6.1-sparc-rtems6
+ sizes: protobuf-2.6.1-sparc-rtems6: 228.079MB (installed: 84.408MB)
+ cleaning: protobuf-2.6.1-sparc-rtems6
+ reporting: net/protobuf-2.6.1-1.cfg -> protobuf-2.6.1-sparc-rtems6.txt
+ reporting: net/protobuf-2.6.1-1.cfg -> protobuf-2.6.1-sparc-rtems6.xml
+ staging: protobuf-2.6.1-sparc-rtems6 -> $HOME/quick-start/src/rsb/rtems/build/tmp/sb-500-staging
+ Build Set: Time 0:00:27.784056
+ Build Set: Time 0:02:32.697406
installing: bsps/erc32 -> $HOME/quick-start/rtems/
clean staging: bsps/erc32
- Staging Size: 1.372GB
- Build Set: Time 0:24:17.83979
+ Staging Size: 1.401GB
+ Build Set: Time 0:25:08.37754
The RSB BSP build can be customised with following RSB command line options:
@@ -147,10 +147,10 @@ be a list of build sets. To view the avaliable build sets run this command:
RTEMS package naming is based on the naming FreeBSD uses in its ports
collection.
-This Quick Start Guide will build the BSD Library or :file:`5/rtems-libbsd`.
+This Quick Start Guide will build the BSD Library or :file:`6/rtems-libbsd`.
An RTEMS package is hosted on RTEMS so the tool suite name needs to be supplied
-using the ``--host`` option, e.g. ``--host=sparc-rtem5``. The BSP needs to be
+using the ``--host`` option, e.g. ``--host=sparc-rtem6``. The BSP needs to be
provided using the ``--with-rtems-bsp`` option,
e.g. ``--with-rtems-bsp=erc32``. The commands to build ``libbsd`` for the
``erc32`` BSP are:
@@ -158,25 +158,25 @@ e.g. ``--with-rtems-bsp=erc32``. The commands to build ``libbsd`` for the
- --host=sparc-rtems5 --with-rtems-bsp=erc32 5/rtems-libbsd
+ --host=sparc-rtems6 --with-rtems-bsp=erc32 6/rtems-libbsd
- Build Set: 5/rtems-libbsd
- config: tools/rtems-libbsd-5.cfg
- package: rtems-libbsd-v3cc039cdac77272a8e16b33ae5a53ccd89edf989-sparc-rtems5-1
- building: rtems-libbsd-v3cc039cdac77272a8e16b33ae5a53ccd89edf989-sparc-rtems5-1
- sizes: rtems-libbsd-v3cc039cdac77272a8e16b33ae5a53ccd89edf989-sparc-rtems5-1: 1.199GB (installed: 116.541MB)
- cleaning: rtems-libbsd-v3cc039cdac77272a8e16b33ae5a53ccd89edf989-sparc-rtems5-1
- reporting: tools/rtems-libbsd-5.cfg -> rtems-libbsd-v3cc039cdac77272a8e16b33ae5a53ccd89edf989-sparc-rtems5-1.txt
- reporting: tools/rtems-libbsd-5.cfg -> rtems-libbsd-v3cc039cdac77272a8e16b33ae5a53ccd89edf989-sparc-rtems5-1.xml
- installing: rtems-libbsd-v3cc039cdac77272a8e16b33ae5a53ccd89edf989-sparc-rtems5-1 -> $HOME/quick-start/rtems/5
- Build Set: Time 0:00:51.898231
+ Build Set: 6/rtems-libbsd
+ config: tools/rtems-libbsd-6.cfg
+ package: rtems-libbsd-v3cc039cdac77272a8e16b33ae5a53ccd89edf989-sparc-rtems6
+ building: rtems-libbsd-v3cc039cdac77272a8e16b33ae5a53ccd89edf989-sparc-rtems6
+ sizes: rtems-libbsd-v3cc039cdac77272a8e16b33ae5a53ccd89edf989-sparc-rtems6: 1.199GB (installed: 116.541MB)
+ cleaning: rtems-libbsd-v3cc039cdac77272a8e16b33ae5a53ccd89edf989-sparc-rtems6
+ reporting: tools/rtems-libbsd-6.cfg -> rtems-libbsd-v3cc039cdac77272a8e16b33ae5a53ccd89edf989-sparc-rtems6.txt
+ reporting: tools/rtems-libbsd-6.cfg -> rtems-libbsd-v3cc039cdac77272a8e16b33ae5a53ccd89edf989-sparc-rtems6.xml
+ installing: rtems-libbsd-v3cc039cdac77272a8e16b33ae5a53ccd89edf989-sparc-rtems6 -> $HOME/quick-start/rtems/6
+ Build Set: Time 0:00:55.045735
.. note::
2.27.0
