[PATCH] user: Update rsb-packages to reflect RTEMS 6 changes
Mon Aug 9 15:07:01 UTC 2021
I have to think about this. The approach taken here just replaces 5.1
-> 6, it isn't updating the screengrabs. This means the tutorial isn't
"real" but that might be fine.
The other issue is that when we release, then this has to become 6 ->
6.1 in the release, and 6 -> 7 in the master. How we manage this
becomes part of the release overhead.
On Fri, Aug 6, 2021 at 3:27 PM Ray Garza <raymond.garza at oarcorp.com> wrote:
> This updates all references and examples in the rtems docs: user/start/rsb-packages.rst to RTEMS 6
>  user/start/rsb-packages.rst | 68 ++++++++++++++++++-------------------
>  1 file changed, 34 insertions(+), 34 deletions(-)
> diff --git a/user/start/rsb-packages.rst b/user/start/rsb-packages.rst
> index 3119318..891ea6a 100644
> --- a/user/start/rsb-packages.rst
> +++ b/user/start/rsb-packages.rst
> @@ -19,8 +19,8 @@ Return to here once you have completed these steps.
>  You have chosen an installation prefix, the BSP to build, the tool's
>  architecure and prepared the source for the RSB in the previous sections.  We
> -have chosen :file:`$HOME/quick-start/rtems/5` as the installation prefix, the
> -``erc32`` BSP and the SPARC architecture name of ``sparc-rtems5``, and unpacked
> +have chosen :file:`$HOME/quick-start/rtems/6` as the installation prefix, the
> +``erc32`` BSP and the SPARC architecture name of ``sparc-rtems6``, and unpacked
>  the RSB source in :file:`$HOME/quick-start/src`.
>  You are now able to build :ref:`BSP Packages` or 3rd party libraries of code if you
> @@ -72,36 +72,36 @@ BSP.
>  .. code-block:: none
>      cd $HOME/quick-start/src/rsb/rtems
> -    ../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/5 \
> +    ../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/6 \
>          --with-rtems-tests=yes bsps/erc32
>  This command should output something like this:
> -    RTEMS Source Builder - Set Builder, 5.1.0
> +    RTEMS Source Builder - Set Builder, 6 (4e6dc6431435)
>      Build Set: bsps/erc32
> -    Build Set: 5/rtems-sparc.bset
> -    Build Set: 5/rtems-autotools.bset
> -    Build Set: 5/rtems-autotools-internal.bset
> +    Build Set: 6/rtems-sparc.bset
> +    Build Set: 6/rtems-autotools.bset
> +    Build Set: 6/rtems-autotools-internal.bset
>      config: tools/rtems-autoconf-2.69-1.cfg
>      package: autoconf-2.69-x86_64-freebsd12.1-1
>      building: autoconf-2.69-x86_64-freebsd12.1-1
>      sizes: autoconf-2.69-x86_64-freebsd12.1-1: 7.505MB (installed: 0.000B)
> -    building: protobuf-2.6.1-sparc-rtems5-1
> -    sizes: protobuf-2.6.1-sparc-rtems5-1: 228.079MB (installed: 84.408MB)
> -    cleaning: protobuf-2.6.1-sparc-rtems5-1
> -    reporting: net/protobuf-2.6.1-1.cfg -> protobuf-2.6.1-sparc-rtems5-1.txt
> -    reporting: net/protobuf-2.6.1-1.cfg -> protobuf-2.6.1-sparc-rtems5-1.xml
> -    staging: protobuf-2.6.1-sparc-rtems5-1 -> $HOME/quick-start/src/rsb/rtems/build/tmp/sb-500-staging
> -    Build Set: Time 0:00:23.564992
> -    Build Set: Time 0:02:27.380299
> +    building: protobuf-2.6.1-sparc-rtems6
> +    sizes: protobuf-2.6.1-sparc-rtems6: 228.079MB (installed: 84.408MB)
> +    cleaning: protobuf-2.6.1-sparc-rtems6
> +    reporting: net/protobuf-2.6.1-1.cfg -> protobuf-2.6.1-sparc-rtems6.txt
> +    reporting: net/protobuf-2.6.1-1.cfg -> protobuf-2.6.1-sparc-rtems6.xml
> +    staging: protobuf-2.6.1-sparc-rtems6 -> $HOME/quick-start/src/rsb/rtems/build/tmp/sb-500-staging
> +    Build Set: Time 0:00:27.784056
> +    Build Set: Time 0:02:32.697406
>      installing: bsps/erc32 -> $HOME/quick-start/rtems/
>      clean staging: bsps/erc32
> -    Staging Size: 1.372GB
> -    Build Set: Time 0:24:17.83979
> +    Staging Size: 1.401GB
> +    Build Set: Time 0:25:08.37754
>  The RSB BSP build can be customised with following RSB command line options:
> @@ -147,10 +147,10 @@ be a list of build sets. To view the avaliable build sets run this command:
>  RTEMS package naming is based on the naming FreeBSD uses in its ports
>  collection.
> -This Quick Start Guide will build the BSD Library or :file:`5/rtems-libbsd`.
> +This Quick Start Guide will build the BSD Library or :file:`6/rtems-libbsd`.
>  An RTEMS package is hosted on RTEMS so the tool suite name needs to be supplied
> -using the ``--host`` option, e.g. ``--host=sparc-rtem5``. The BSP needs to be
> +using the ``--host`` option, e.g. ``--host=sparc-rtem6``. The BSP needs to be
>  provided using the ``--with-rtems-bsp`` option,
>  e.g. ``--with-rtems-bsp=erc32``. The commands to build ``libbsd`` for the
>  ``erc32`` BSP are:
> @@ -158,25 +158,25 @@ e.g. ``--with-rtems-bsp=erc32``. The commands to build ``libbsd`` for the
> -      --host=sparc-rtems5 --with-rtems-bsp=erc32 5/rtems-libbsd
> +      --host=sparc-rtems6 --with-rtems-bsp=erc32 6/rtems-libbsd
> -    Build Set: 5/rtems-libbsd
> -    config: tools/rtems-libbsd-5.cfg
> -    package: rtems-libbsd-v3cc039cdac77272a8e16b33ae5a53ccd89edf989-sparc-rtems5-1
> -    building: rtems-libbsd-v3cc039cdac77272a8e16b33ae5a53ccd89edf989-sparc-rtems5-1
> -    sizes: rtems-libbsd-v3cc039cdac77272a8e16b33ae5a53ccd89edf989-sparc-rtems5-1: 1.199GB (installed: 116.541MB)
> -    cleaning: rtems-libbsd-v3cc039cdac77272a8e16b33ae5a53ccd89edf989-sparc-rtems5-1
> -    reporting: tools/rtems-libbsd-5.cfg -> rtems-libbsd-v3cc039cdac77272a8e16b33ae5a53ccd89edf989-sparc-rtems5-1.txt
> -    reporting: tools/rtems-libbsd-5.cfg -> rtems-libbsd-v3cc039cdac77272a8e16b33ae5a53ccd89edf989-sparc-rtems5-1.xml
> -    installing: rtems-libbsd-v3cc039cdac77272a8e16b33ae5a53ccd89edf989-sparc-rtems5-1 -> $HOME/quick-start/rtems/5
> -    Build Set: Time 0:00:51.898231
> +    Build Set: 6/rtems-libbsd
> +    config: tools/rtems-libbsd-6.cfg
> +    package: rtems-libbsd-v3cc039cdac77272a8e16b33ae5a53ccd89edf989-sparc-rtems6
> +    building: rtems-libbsd-v3cc039cdac77272a8e16b33ae5a53ccd89edf989-sparc-rtems6
> +    sizes: rtems-libbsd-v3cc039cdac77272a8e16b33ae5a53ccd89edf989-sparc-rtems6: 1.199GB (installed: 116.541MB)
> +    cleaning: rtems-libbsd-v3cc039cdac77272a8e16b33ae5a53ccd89edf989-sparc-rtems6
> +    reporting: tools/rtems-libbsd-6.cfg -> rtems-libbsd-v3cc039cdac77272a8e16b33ae5a53ccd89edf989-sparc-rtems6.txt
> +    reporting: tools/rtems-libbsd-6.cfg -> rtems-libbsd-v3cc039cdac77272a8e16b33ae5a53ccd89edf989-sparc-rtems6.xml
> +    installing: rtems-libbsd-v3cc039cdac77272a8e16b33ae5a53ccd89edf989-sparc-rtems6 -> $HOME/quick-start/rtems/6
> +    Build Set: Time 0:00:55.045735
>  .. note::
> 2.27.0
> devel mailing list
> devel at rtems.org
