[PATCH rtems-libbsd v2 0/5] Beagle BSP: USB Template Driver for CDC Ethernet
Ahamed Husni
ahamedhusni73 at gmail.com
Sat Aug 7 19:56:45 UTC 2021
Hi Christian,
Are there any issues I should address in this patch set?
On Mon, Aug 2, 2021 at 12:09 PM Christian MAUDERER <
christian.mauderer at embedded-brains.de> wrote:
> Hello Husni,
> Am 01.08.21 um 19:59 schrieb Ahamed Husni:
> > Hi Christian,
> > On Sun, Aug 1, 2021 at 4:57 PM Christian Mauderer <oss at c-mauderer.de
> > <mailto:oss at c-mauderer.de>> wrote:
> > Hello Husni,
> > just tested that and it works fine. With a simple curl I can reach
> > about
> > 8.5 MByte/s sending to the beagle and 19.5 MByte/s receiving from it.
> > That's 68 Mbps for sending. That's an acceptable speed isn't it?
> At the moment I would be OK with basically any speed. It was just some
> information so that someone who finds the mail knows what he can expect.
> It would be interesting to see how the speeds compare to a FreeBSD setup
> on the Beagle. If there is no bug in our port, it should be about the same.
> Best regards
> Christian
> > Please take a look at the points that Chris Johns asked. As soon as
> > these are addressed, I think the patches could be merged.
> > I just replied to it now. Sorry for the delay.
> > Please also make the documentation that you started for this more
> > public
> > visible. In other words: Send it as patches to the list and not only
> as
> > a link to some branch!
> > Noted.
> > Best regards
> > Christian
> > On 28/07/2021 13:56, Husni Faiz wrote:
> > > This set of patches import the drivers from freebsd and
> > > configures it for the beagle bsp.
> > > Github Branch for the commits
> > > https://github.com/drac98/rtems-libbsd/commits/usb-cdce
> > <https://github.com/drac98/rtems-libbsd/commits/usb-cdce>
> > > Patch for 6-freebsd-12 branch
> > > https://github.com/drac98/rtems-libbsd/commits/usb-cdce12
> > <https://github.com/drac98/rtems-libbsd/commits/usb-cdce12>
> > > Husni Faiz (5):
> > > usb_template:Import CDC Ethernet
> > > usb_template: Configure template driver only for CDC Ethernet
> > > nexus-devices: Include CDC Ethernet for Beagle
> > > libbsd.py: add usb template files
> > > create-kernel-namespace for USB Template driver
> > > buildset/default.ini | 1 +
> > > buildset/minimal.ini | 3 +-
> > > freebsd/sys/dev/usb/template/usb_template.c | 1493
> > > freebsd/sys/dev/usb/template/usb_template.h | 130 ++
> > > .../sys/dev/usb/template/usb_template_cdce.c | 355 ++++
> > > freebsd/sys/dev/usb/usb_device.c | 8 +-
> > > libbsd.py | 25 +
> > > rtemsbsd/include/bsp/nexus-devices.h | 5 +
> > > .../machine/rtems-bsd-kernel-namespace.h | 5 +
> > > .../include/machine/rtems-bsd-nexus-bus.h | 19 +
> > > 10 files changed, 2041 insertions(+), 3 deletions(-)
> > > create mode 100644 freebsd/sys/dev/usb/template/usb_template.c
> > > create mode 100644 freebsd/sys/dev/usb/template/usb_template.h
> > > create mode 100644
> freebsd/sys/dev/usb/template/usb_template_cdce.c
> > devel mailing list
> > devel at rtems.org
> embedded brains GmbH
> Herr Christian MAUDERER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> phone: +49-89-18 94 741 - 18
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210808/6cd5e333/attachment.html>
