[PATCH rtems-libbsd v2 0/5] Beagle BSP: USB Template Driver for CDC Ethernet
Christian MAUDERER christian.mauderer at embedded-brains.de
Mon Aug 2 06:39:55 UTC 2021
Hello Husni,
Am 01.08.21 um 19:59 schrieb Ahamed Husni:
> Hi Christian,
> On Sun, Aug 1, 2021 at 4:57 PM Christian Mauderer <oss at c-mauderer.de
> <mailto:oss at c-mauderer.de>> wrote:
>     Hello Husni,
>     just tested that and it works fine. With a simple curl I can reach
>     about
>     8.5 MByte/s sending to the beagle and 19.5 MByte/s receiving from it.
> That's 68 Mbps for sending. That's an acceptable speed isn't it?
At the moment I would be OK with basically any speed. It was just some
information so that someone who finds the mail knows what he can expect.
It would be interesting to see how the speeds compare to a FreeBSD setup
on the Beagle. If there is no bug in our port, it should be about the same.
Best regards
Christian
>     Please take a look at the points that Chris Johns asked. As soon as
>     these are addressed, I think the patches could be merged.
> I just replied to it now. Sorry for the delay.
>     Please also make the documentation that you started for this more
>     public
>     visible. In other words: Send it as patches to the list and not only as
>     a link to some branch!
> Noted.
>     Best regards
>     Christian
>     On 28/07/2021 13:56, Husni Faiz wrote:
>      > This set of patches import the drivers from freebsd and
>      > configures it for the beagle bsp.
>      > Github Branch for the commits
>      > https://github.com/drac98/rtems-libbsd/commits/usb-cdce
>     <https://github.com/drac98/rtems-libbsd/commits/usb-cdce>
>      > Patch for 6-freebsd-12 branch
>      > https://github.com/drac98/rtems-libbsd/commits/usb-cdce12
>     <https://github.com/drac98/rtems-libbsd/commits/usb-cdce12>
>      > Husni Faiz (5):
>      >    usb_template:Import CDC Ethernet
>      >    usb_template: Configure template driver only for CDC Ethernet
>      >    nexus-devices: Include CDC Ethernet for Beagle
>      >    libbsd.py: add usb template files
>      >    create-kernel-namespace for USB Template driver
>      >   buildset/default.ini                          |    1 +
>      >   buildset/minimal.ini                          |    3 +-
>      >   freebsd/sys/dev/usb/template/usb_template.c   | 1493
>      >   freebsd/sys/dev/usb/template/usb_template.h   |  130 ++
>      >   .../sys/dev/usb/template/usb_template_cdce.c  |  355 ++++
>      >   freebsd/sys/dev/usb/usb_device.c              |    8 +-
>      >   libbsd.py                                     |   25 +
>      >   rtemsbsd/include/bsp/nexus-devices.h          |    5 +
>      >   .../machine/rtems-bsd-kernel-namespace.h      |    5 +
>      >   .../include/machine/rtems-bsd-nexus-bus.h     |   19 +
>      >   10 files changed, 2041 insertions(+), 3 deletions(-)
>      >   create mode 100644 freebsd/sys/dev/usb/template/usb_template.c
>      >   create mode 100644 freebsd/sys/dev/usb/template/usb_template.h
>      >   create mode 100644 freebsd/sys/dev/usb/template/usb_template_cdce.c
> devel mailing list
> devel at rtems.org
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
