[PATCH rtems-libbsd v2 0/5] Beagle BSP: USB Template Driver for CDC Ethernet
Chris Johns
chrisj at rtems.org
Mon Aug 9 00:39:24 UTC 2021
On 8/8/21 6:06 pm, Christian Mauderer wrote:
> Hello Husni,
> On 07/08/2021 21:56, Ahamed Husni wrote:
>> Hi Christian,
>> Are there any issues I should address in this patch set?
> I think the big open question is the one from Chris:
> https://lists.rtems.org/pipermail/devel/2021-July/068634.html
> You mentioned that you filtered the ones for the imported code. That's OK for
> most symbols if they are not relevant for the part where you work on. But Chris
> copied a whole block of "extern struct usb_temp_device_desc *". It's not clear
> for me whether you filtered some of them or whether they haven't been generated.
> If they are generated: Please keep them. Basically keep everything that is in
> one of the files that you touch, except if you have a good reason why the symbol
> should _not_ be added.
> If they are not generated: Please clearly say that.
The issue is the merging against my changes and as I have stated in the other
thread I have replaced the change script because it on worked on Linux plus the
sort order was something I could not match on other host platforms.
My changes address the sort order, tools used and I added the few symbols that
must have been missed over a period of time. That happens. I hope the updated
procedure is simpler and safer to use on any host platform we support.
