[PATCH rtems-libbsd v2 5/5] create-kernel-namespace for USB Template driver
Thu Jul 29 00:11:05 UTC 2021
On 28/7/21 9:56 pm, Husni Faiz wrote:
> Signed-off-by: Husni Faiz <ahamedhusni73 at gmail.com>
>  rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h | 5 +++++
>  1 file changed, 5 insertions(+)
> diff --git a/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h b/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
> index 97cdb625..ae56ad9c 100644
> --- a/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
> +++ b/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
> @@ -5279,6 +5279,7 @@
>  #define	usbd_do_request_proc _bsd_usbd_do_request_proc
>  #define	usbd_dummy_timeout _bsd_usbd_dummy_timeout
>  #define	usb_debug _bsd_usb_debug
> +#define	usb_decode_str_desc _bsd_usb_decode_str_desc
>  #define	usbd_enum_is_locked _bsd_usbd_enum_is_locked
>  #define	usbd_enum_lock _bsd_usbd_enum_lock
>  #define	usbd_enum_lock_sig _bsd_usbd_enum_lock_sig
> @@ -5515,8 +5516,12 @@
>  #define	usb_suspend_resume _bsd_usb_suspend_resume
>  #define	usb_temp_get_desc_p _bsd_usb_temp_get_desc_p
>  #define	usb_template _bsd_usb_template
> +#define	usb_template_cdce _bsd_usb_template_cdce
> +#define	usb_temp_setup _bsd_usb_temp_setup
>  #define	usb_temp_setup_by_index_p _bsd_usb_temp_setup_by_index_p
> +#define	usb_temp_sysctl _bsd_usb_temp_sysctl
>  #define	usb_temp_unload _bsd_usb_temp_unload
> +#define	usb_temp_unsetup _bsd_usb_temp_unsetup
>  #define	usb_temp_unsetup_p _bsd_usb_temp_unsetup_p
>  #define	usb_test_quirk _bsd_usb_test_quirk
>  #define	usb_test_quirk_p _bsd_usb_test_quirk_p
How were these additions done?
I ask because I see these externs in the template code ...
extern struct usb_temp_device_desc usb_template_audio;
extern struct usb_temp_device_desc usb_template_cdce;
extern struct usb_temp_device_desc usb_template_kbd;
extern struct usb_temp_device_desc usb_template_modem;
extern struct usb_temp_device_desc usb_template_mouse;
extern struct usb_temp_device_desc usb_template_msc;
extern struct usb_temp_device_desc usb_template_mtp;
extern struct usb_temp_device_desc usb_template_phone;
extern struct usb_temp_device_desc usb_template_serialnet;
extern struct usb_temp_device_desc usb_template_midi;
extern struct usb_temp_device_desc usb_template_multi;
extern struct usb_temp_device_desc usb_template_cdceem;
