[PATCH v4] Test needed for timer_create with CLOCK_MONOTONIC
Zacchaeus Leung
zakthertemsdev at gmail.com
Mon Aug 9 00:55:06 UTC 2021
the timer_create() method can use CLOCK_MONOTONIC but there was no test for this. Also it implements the functionality to
create a CLOCK_MONOTONIC timer and gettime() .
Closes #3888
cpukit/include/rtems/posix/timer.h | 1 +
cpukit/posix/src/psxtimercreate.c | 3 +-
cpukit/posix/src/timergettime.c | 50 ++++++++++++-------
testsuites/psxtests/psxtimer02/psxtimer.c | 26 ++++++++++
testsuites/psxtests/psxtimer02/psxtimer02.scn | 6 +++
5 files changed, 66 insertions(+), 20 deletions(-)
diff --git a/cpukit/include/rtems/posix/timer.h b/cpukit/include/rtems/posix/timer.h
index bcbf07a65a..7ae089173a 100644
--- a/cpukit/include/rtems/posix/timer.h
+++ b/cpukit/include/rtems/posix/timer.h
@@ -48,6 +48,7 @@ typedef struct {
uint32_t ticks; /* Number of ticks of the initialization */
uint32_t overrun; /* Number of expirations of the timer */
struct timespec time; /* Time at which the timer was started */
+ clockid_t clock_type; /* The type of timer */
} POSIX_Timer_Control;
diff --git a/cpukit/posix/src/psxtimercreate.c b/cpukit/posix/src/psxtimercreate.c
index a63cf1d100..2b5a10140f 100644
--- a/cpukit/posix/src/psxtimercreate.c
+++ b/cpukit/posix/src/psxtimercreate.c
@@ -40,7 +40,7 @@ int timer_create(
POSIX_Timer_Control *ptimer;
- if ( clock_id != CLOCK_REALTIME )
+ if ( clock_id != CLOCK_REALTIME && clock_id != CLOCK_MONOTONIC )
rtems_set_errno_and_return_minus_one( EINVAL );
if ( !timerid )
@@ -91,6 +91,7 @@ int timer_create(
ptimer->timer_data.it_value.tv_nsec = 0;
ptimer->timer_data.it_interval.tv_sec = 0;
ptimer->timer_data.it_interval.tv_nsec = 0;
+ ptimer->clock_type = clock_id;
_Watchdog_Preinitialize( &ptimer->Timer, _Per_CPU_Get_snapshot() );
_Watchdog_Initialize( &ptimer->Timer, _POSIX_Timer_TSR );
diff --git a/cpukit/posix/src/timergettime.c b/cpukit/posix/src/timergettime.c
index ee2a566f0e..2ad841d517 100644
--- a/cpukit/posix/src/timergettime.c
+++ b/cpukit/posix/src/timergettime.c
@@ -28,6 +28,7 @@
#include <rtems/seterr.h>
+#include <rtems/timespec.h>
* - When a timer is initialized, the value of the time in
@@ -39,35 +40,46 @@
int timer_gettime(
timer_t timerid,
struct itimerspec *value
- ISR_lock_Context lock_context;
- uint64_t now;
- uint32_t remaining;
+ ISR_lock_Context lock_context;
+ Per_CPU_Control *cpu;
+ struct timespec now;
+ struct timespec expire;
+ struct timespec result;
if ( !value )
ptimer = _POSIX_Timer_Get( timerid, &lock_context );
- if ( ptimer != NULL ) {
- Per_CPU_Control *cpu;
+ if ( ptimer == NULL ) {
+ rtems_set_errno_and_return_minus_one( EINVAL );
- cpu = _POSIX_Timer_Acquire_critical( ptimer, &lock_context );
- now = cpu->Watchdog.ticks;
+ cpu = _POSIX_Timer_Acquire_critical( ptimer, &lock_context );
+ rtems_timespec_from_ticks( ptimer->Timer.expire, &expire );
- if ( now < ptimer->Timer.expire ) {
- remaining = (uint32_t) ( ptimer->Timer.expire - now );
- } else {
- remaining = 0;
+ if ( ptimer->clock_type == CLOCK_MONOTONIC ) {
+ _Timecounter_Nanouptime(&now);
+ } else if ( ptimer->clock_type == CLOCK_REALTIME ) {
+ _TOD_Get(&now);
+ } else {
+ _POSIX_Timer_Release( cpu, &lock_context );
- _Timespec_From_ticks( remaining, &value->it_value );
- value->it_interval = ptimer->timer_data.it_interval;
- _POSIX_Timer_Release( cpu, &lock_context );
- return 0;
+ if ( rtems_timespec_less_than( &now, &expire ) ) {
+ rtems_timespec_subtract( &now, &expire, &result );
+ } else {
+ result.tv_nsec = 0;
+ result.tv_sec = 0;
- rtems_set_errno_and_return_minus_one( EINVAL );
+ value->it_value = result;
+ value->it_interval = ptimer->timer_data.it_interval;
+ return 0;
diff --git a/testsuites/psxtests/psxtimer02/psxtimer.c b/testsuites/psxtests/psxtimer02/psxtimer.c
index 9f79d33c42..1a79369efb 100644
--- a/testsuites/psxtests/psxtimer02/psxtimer.c
+++ b/testsuites/psxtests/psxtimer02/psxtimer.c
@@ -126,6 +126,32 @@ void *POSIX_Init (
puts( "timer_delete - bad id - EINVAL" );
status = timer_delete( timer );
fatal_posix_service_status_errno( status, EINVAL, "bad id" );
+ puts( "timer_create (monotonic) - bad timer id pointer - EINVAL" );
+ status = timer_create( CLOCK_MONOTONIC, &event, NULL );
+ fatal_posix_service_status_errno( status, EINVAL, "bad timer id" );
+ puts( "timer_create (monotonic) - OK" );
+ status = timer_create( CLOCK_MONOTONIC, NULL, &timer );
+ posix_service_failed( status, "timer_create OK" );
+ puts( "timer_create (monotonic) - too many - EAGAIN" );
+ status = timer_create( CLOCK_MONOTONIC, NULL, &timer1 );
+ fatal_posix_service_status_errno( status, EAGAIN, "too many" );
+ clock_gettime( CLOCK_MONOTONIC, &now );
+ itimer.it_value = now;
+ itimer.it_value.tv_sec = itimer.it_value.tv_sec - 1;
+ puts( "timer_settime (monotonic) - bad itimer value - previous time - EINVAL" );
+ status = timer_settime( timer, TIMER_ABSTIME, &itimer, NULL );
+ fatal_posix_service_status_errno( status, EINVAL, "bad itimer value #3" );
+ itimer.it_value.tv_sec = itimer.it_value.tv_sec + 1;
+ puts( "timer_settime (monotonic) - bad id - EINVAL" );
+ status = timer_settime( timer1, TIMER_ABSTIME, &itimer, NULL );
+ fatal_posix_service_status_errno( status, EINVAL, "bad id" );
TEST_END();
rtems_test_exit (0);
diff --git a/testsuites/psxtests/psxtimer02/psxtimer02.scn b/testsuites/psxtests/psxtimer02/psxtimer02.scn
index e78425a32e..995bcda4e3 100644
--- a/testsuites/psxtests/psxtimer02/psxtimer02.scn
+++ b/testsuites/psxtests/psxtimer02/psxtimer02.scn
@@ -13,4 +13,10 @@ timer_settime - bad itimer value - negative nanosecond - EINVAL
timer_settime - bad clock value - EINVAL
timer_delete - OK
+timer_create (monotonic) - bad timer id pointer - EINVAL
+timer_create (monotonic) - OK
+timer_create (monotonic) - too many - EAGAIN
+timer_settime (monotonic) - bad itimer value - previous time - EINVAL
+timer_settime (monotonic) - bad id - EINVAL
*** END OF POSIX Timers Test 02 ***
2.32.0
