[PATCH v4] Test needed for timer_create with CLOCK_MONOTONIC
zack leung
zakthertemsdev at gmail.com
Mon Aug 9 01:26:06 UTC 2021
Attached here are the testing logs for rtems-test for the leon3.
On Mon, 9 Aug 2021 at 01:14, Zacchaeus Leung <zakthertemsdev at gmail.com>
wrote:
> the timer_create() method can use CLOCK_MONOTONIC but there was no test
> for this. Also it implements the functionality to
> create a CLOCK_MONOTONIC timer and gettime() .
> Closes #3888
> cpukit/include/rtems/posix/timer.h | 1 +
> cpukit/posix/src/psxtimercreate.c | 3 +-
> cpukit/posix/src/timergettime.c | 50 ++++++++++++-------
> testsuites/psxtests/psxtimer02/psxtimer.c | 26 ++++++++++
> testsuites/psxtests/psxtimer02/psxtimer02.scn | 6 +++
> 5 files changed, 66 insertions(+), 20 deletions(-)
> diff --git a/cpukit/include/rtems/posix/timer.h
> b/cpukit/include/rtems/posix/timer.h
> index bcbf07a65a..7ae089173a 100644
> --- a/cpukit/include/rtems/posix/timer.h
> +++ b/cpukit/include/rtems/posix/timer.h
> @@ -48,6 +48,7 @@ typedef struct {
> uint32_t ticks; /* Number of ticks of the initialization
> uint32_t overrun; /* Number of expirations of the timer
> struct timespec time; /* Time at which the timer was started
> + clockid_t clock_type; /* The type of timer */
> } POSIX_Timer_Control;
> diff --git a/cpukit/posix/src/psxtimercreate.c
> b/cpukit/posix/src/psxtimercreate.c
> index a63cf1d100..2b5a10140f 100644
> --- a/cpukit/posix/src/psxtimercreate.c
> +++ b/cpukit/posix/src/psxtimercreate.c
> @@ -40,7 +40,7 @@ int timer_create(
> POSIX_Timer_Control *ptimer;
> - if ( clock_id != CLOCK_REALTIME )
> + if ( clock_id != CLOCK_REALTIME && clock_id != CLOCK_MONOTONIC )
> rtems_set_errno_and_return_minus_one( EINVAL );
> if ( !timerid )
> @@ -91,6 +91,7 @@ int timer_create(
> ptimer->timer_data.it_value.tv_nsec = 0;
> ptimer->timer_data.it_interval.tv_sec = 0;
> ptimer->timer_data.it_interval.tv_nsec = 0;
> + ptimer->clock_type = clock_id;
> _Watchdog_Preinitialize( &ptimer->Timer, _Per_CPU_Get_snapshot() );
> _Watchdog_Initialize( &ptimer->Timer, _POSIX_Timer_TSR );
> diff --git a/cpukit/posix/src/timergettime.c
> b/cpukit/posix/src/timergettime.c
> index ee2a566f0e..2ad841d517 100644
> --- a/cpukit/posix/src/timergettime.c
> +++ b/cpukit/posix/src/timergettime.c
> @@ -28,6 +28,7 @@
> #include <rtems/score/todimpl.h>
> #include <rtems/score/watchdogimpl.h>
> #include <rtems/seterr.h>
> +#include <rtems/timespec.h>
> * - When a timer is initialized, the value of the time in
> @@ -39,35 +40,46 @@
> int timer_gettime(
> timer_t timerid,
> struct itimerspec *value
> - ISR_lock_Context lock_context;
> - uint64_t now;
> - uint32_t remaining;
> + ISR_lock_Context lock_context;
> + Per_CPU_Control *cpu;
> + struct timespec now;
> + struct timespec expire;
> + struct timespec result;
> if ( !value )
> ptimer = _POSIX_Timer_Get( timerid, &lock_context );
> - if ( ptimer != NULL ) {
> - Per_CPU_Control *cpu;
> + if ( ptimer == NULL ) {
> + rtems_set_errno_and_return_minus_one( EINVAL );
> - cpu = _POSIX_Timer_Acquire_critical( ptimer, &lock_context );
> - now = cpu->Watchdog.ticks;
> + cpu = _POSIX_Timer_Acquire_critical( ptimer, &lock_context );
> + rtems_timespec_from_ticks( ptimer->Timer.expire, &expire );
> - if ( now < ptimer->Timer.expire ) {
> - remaining = (uint32_t) ( ptimer->Timer.expire - now );
> - } else {
> - remaining = 0;
> + if ( ptimer->clock_type == CLOCK_MONOTONIC ) {
> + _Timecounter_Nanouptime(&now);
> + } else if ( ptimer->clock_type == CLOCK_REALTIME ) {
> + _TOD_Get(&now);
> + } else {
> + _POSIX_Timer_Release( cpu, &lock_context );
> - _Timespec_From_ticks( remaining, &value->it_value );
> - value->it_interval = ptimer->timer_data.it_interval;
> - _POSIX_Timer_Release( cpu, &lock_context );
> - return 0;
> + if ( rtems_timespec_less_than( &now, &expire ) ) {
> + rtems_timespec_subtract( &now, &expire, &result );
> + } else {
> + result.tv_nsec = 0;
> + result.tv_sec = 0;
> - rtems_set_errno_and_return_minus_one( EINVAL );
> + value->it_value = result;
> + value->it_interval = ptimer->timer_data.it_interval;
> + return 0;
> diff --git a/testsuites/psxtests/psxtimer02/psxtimer.c
> b/testsuites/psxtests/psxtimer02/psxtimer.c
> index 9f79d33c42..1a79369efb 100644
> --- a/testsuites/psxtests/psxtimer02/psxtimer.c
> +++ b/testsuites/psxtests/psxtimer02/psxtimer.c
> @@ -126,6 +126,32 @@ void *POSIX_Init (
> puts( "timer_delete - bad id - EINVAL" );
> status = timer_delete( timer );
> fatal_posix_service_status_errno( status, EINVAL, "bad id" );
> + puts( "timer_create (monotonic) - bad timer id pointer - EINVAL" );
> + status = timer_create( CLOCK_MONOTONIC, &event, NULL );
> + fatal_posix_service_status_errno( status, EINVAL, "bad timer id" );
> + puts( "timer_create (monotonic) - OK" );
> + status = timer_create( CLOCK_MONOTONIC, NULL, &timer );
> + posix_service_failed( status, "timer_create OK" );
> + puts( "timer_create (monotonic) - too many - EAGAIN" );
> + status = timer_create( CLOCK_MONOTONIC, NULL, &timer1 );
> + fatal_posix_service_status_errno( status, EAGAIN, "too many" );
> + clock_gettime( CLOCK_MONOTONIC, &now );
> + itimer.it_value = now;
> + itimer.it_value.tv_sec = itimer.it_value.tv_sec - 1;
> + puts( "timer_settime (monotonic) - bad itimer value - previous time -
> EINVAL" );
> + status = timer_settime( timer, TIMER_ABSTIME, &itimer, NULL );
> + fatal_posix_service_status_errno( status, EINVAL, "bad itimer value #3"
> + itimer.it_value.tv_sec = itimer.it_value.tv_sec + 1;
> + puts( "timer_settime (monotonic) - bad id - EINVAL" );
> + status = timer_settime( timer1, TIMER_ABSTIME, &itimer, NULL );
> + fatal_posix_service_status_errno( status, EINVAL, "bad id" );
> TEST_END();
> rtems_test_exit (0);
> diff --git a/testsuites/psxtests/psxtimer02/psxtimer02.scn
> b/testsuites/psxtests/psxtimer02/psxtimer02.scn
> index e78425a32e..995bcda4e3 100644
> --- a/testsuites/psxtests/psxtimer02/psxtimer02.scn
> +++ b/testsuites/psxtests/psxtimer02/psxtimer02.scn
> @@ -13,4 +13,10 @@ timer_settime - bad itimer value - negative nanosecond
> - EINVAL
> timer_settime - bad clock value - EINVAL
> timer_delete - OK
> +timer_create (monotonic) - bad timer id pointer - EINVAL
> +timer_create (monotonic) - OK
> +timer_create (monotonic) - too many - EAGAIN
> +timer_settime (monotonic) - bad itimer value - previous time - EINVAL
> +timer_settime (monotonic) - bad id - EINVAL
> *** END OF POSIX Timers Test 02 ***
> 2.32.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210809/987e40e7/attachment-0001.html>
RTEMS Testing - Tester, 6.0.not_released
Command Line: /home/zack/quick-start/rtems/6/bin/rtems-test --rtems-bsp=leon3-sis build/sparc/leon3/
Host: Linux manjaro 5.9.16-1-MANJARO #1 SMP PREEMPT Mon Dec 21 22:00:46 UTC 2020 x86_64
Python: 3.9.6 (default, Jun 30 2021, 10:22:16) [GCC 11.1.0]
Host: Linux-5.9.16-1-MANJARO-x86_64-with-glibc2.33 (Linux manjaro 5.9.16-1-MANJARO #1 SMP PREEMPT Mon Dec 21 22:00:46 UTC 2020 x86_64 )
[ 6/596] p:0 f:0 u:0 e:0 I:0 B:0 t:0 L:0 i:0 W:0 | sparc/leon3: fsdosfsformat01.exe
[ 2/596] p:0 f:0 u:0 e:0 I:0 B:0 t:0 L:0 i:0 W:0 | sparc/leon3: linpack.exe
[ 3/596] p:0 f:0 u:0 e:0 I:0 B:0 t:0 L:0 i:0 W:0 | sparc/leon3: whetstone.exe
[ 8/596] p:0 f:0 u:0 e:0 I:0 B:0 t:0 L:0 i:0 W:0 | sparc/leon3: fsdosfsname02.exe
[ 1/596] p:0 f:0 u:0 e:0 I:0 B:0 t:0 L:0 i:0 W:0 | sparc/leon3: dhrystone.exe
[ 7/596] p:0 f:0 u:0 e:0 I:0 B:0 t:0 L:0 i:0 W:0 | sparc/leon3: fsdosfsname01.exe
[ 4/596] p:0 f:0 u:0 e:0 I:0 B:0 t:0 L:0 i:0 W:0 | sparc/leon3: fsbdpart01.exe
[ 5/596] p:0 f:0 u:0 e:0 I:0 B:0 t:0 L:0 i:0 W:0 | sparc/leon3: fsclose01.exe
[ 10/596] p:3 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: fsdosfswrite01.exe
[ 9/596] p:3 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: fsdosfssync01.exe
[ 13/596] p:3 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: fsimfsconfig02.exe
[ 12/596] p:3 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: fsimfsconfig01.exe
[ 11/596] p:3 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: fsfseeko01.exe
[ 14/596] p:3 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: fsimfsconfig03.exe
[ 15/596] p:9 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: fsimfsgeneric01.exe
[ 16/596] p:9 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: fsjffs2gc01.exe
[ 18/596] p:9 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: fsrfsbitmap01.exe
[ 19/596] p:9 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: fsrofs01.exe
[ 20/596] p:9 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: imfs_fserror.exe
[ 17/596] p:9 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: fsnofs01.exe
[ 25/596] p:15 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: imfs_fsscandir01.exe
[ 24/596] p:15 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: imfs_fsrdwr.exe
[ 22/596] p:15 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: imfs_fspatheval.exe
[ 23/596] p:15 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: imfs_fspermission.exe
[ 21/596] p:15 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: imfs_fslink.exe
[ 26/596] p:15 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: imfs_fssymlink.exe
[ 27/596] p:20 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: imfs_fstime.exe
[ 29/596] p:20 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: jffs2_fslink.exe
[ 28/596] p:20 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: jffs2_fserror.exe
[ 30/596] p:20 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: jffs2_fspatheval.exe
[ 31/596] p:20 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: jffs2_fspermission.exe
[ 35/596] p:25 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: jffs2_fstime.exe
[ 32/596] p:25 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: jffs2_fsrdwr.exe
[ 36/596] p:25 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: mdosfs_fserror.exe
[ 34/596] p:25 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: jffs2_fssymlink.exe
[ 33/596] p:25 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: jffs2_fsscandir01.exe
[ 37/596] p:28 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: mdosfs_fspatheval.exe
[ 38/596] p:28 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: mdosfs_fsrdwr.exe
[ 39/596] p:28 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: mdosfs_fsscandir01.exe
[ 40/596] p:31 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: mdosfs_fsstatvfs.exe
[ 41/596] p:31 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: mdosfs_fstime.exe
[ 42/596] p:33 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: mimfs_fserror.exe
[ 43/596] p:34 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: mimfs_fslink.exe
[ 44/596] p:35 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: mimfs_fspatheval.exe
[ 45/596] p:36 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: mimfs_fspermission.exe
[ 47/596] p:36 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: mimfs_fsrename.exe
[ 46/596] p:36 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: mimfs_fsrdwr.exe
[ 48/596] p:40 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: mimfs_fsscandir01.exe
[ 50/596] p:40 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: mimfs_fstime.exe
[ 49/596] p:41 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: mimfs_fssymlink.exe
[ 51/596] p:42 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: mrfs_fserror.exe
[ 52/596] p:43 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: mrfs_fsfpathconf.exe
[ 53/596] p:43 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: mrfs_fslink.exe
[ 54/596] p:43 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: mrfs_fspatheval.exe
[ 55/596] p:46 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: mrfs_fspermission.exe
[ 56/596] p:46 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: mrfs_fsrdwr.exe
[ 57/596] p:47 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: mrfs_fsrename.exe
[ 60/596] p:49 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: mrfs_fstime.exe
[ 59/596] p:49 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: mrfs_fssymlink.exe
[ 58/596] p:49 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: mrfs_fsscandir01.exe
[ 61/596] p:51 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: block01.exe
[ 63/596] p:53 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: block03.exe
[ 64/596] p:54 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: block04.exe
[ 62/596] p:55 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: block02.exe
[ 65/596] p:55 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: block05.exe
[ 66/596] p:55 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: block06.exe
[ 67/596] p:58 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: block07.exe
[ 68/596] p:58 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: block08.exe
[ 69/596] p:58 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: block09.exe
[ 70/596] p:60 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: block10.exe
[ 71/596] p:61 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: block11.exe
[ 72/596] p:62 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: block12.exe
[ 73/596] p:62 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: block13.exe
[ 74/596] p:64 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: block14.exe
[ 75/596] p:64 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: block15.exe
[ 76/596] p:66 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: block16.exe
[ 77/596] p:66 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: block17.exe
[ 78/596] p:68 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: bspcmdline01.exe
[ 79/596] p:69 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: capture01.exe
[ 80/596] p:71 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: complex.exe
[ 81/596] p:71 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: cpuuse.exe
[ 82/596] p:72 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: crypt01.exe
[ 83/596] p:73 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: defaultconfig01.exe
[ 84/596] p:73 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: devfs01.exe
[ 85/596] p:75 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: devfs04.exe
[ 86/596] p:75 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: deviceio01.exe
[ 87/596] p:77 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: devnullfatal01.exe
[ 88/596] p:77 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: dl01.exe
[ 89/596] p:79 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: dl02.exe
[ 90/596] p:79 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: dl03.exe
[ 91/596] p:82 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: dl04.exe
[ 92/596] p:82 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: dl05.exe
[ 93/596] p:82 f:0 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: dl06.exe
[ 94/596] p:84 f:1 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: dl07.exe
[ 95/596] p:84 f:1 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: dl08.exe
[ 96/596] p:84 f:1 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: dl09.exe
[ 97/596] p:85 f:1 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: dl10.exe
[ 98/596] p:86 f:1 u:0 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: dumpbuf01.exe
[ 99/596] p:89 f:1 u:1 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: exit01.exe
[100/596] p:89 f:1 u:1 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: exit02.exe
[101/596] p:89 f:1 u:1 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: flashdisk01.exe
[102/596] p:89 f:1 u:1 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: getentropy01.exe
[103/596] p:91 f:1 u:1 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: gxx01.exe
[104/596] p:91 f:1 u:1 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: heapwalk.exe
[105/596] p:92 f:1 u:1 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: i2c01.exe
[106/596] p:94 f:1 u:1 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: irqs01.exe
[107/596] p:94 f:1 u:1 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: libfdt01.exe
[108/596] p:96 f:1 u:1 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: malloc02.exe
[109/596] p:98 f:1 u:1 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: malloc03.exe
[110/596] p:99 f:1 u:1 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: malloc04.exe
[111/596] p:99 f:1 u:1 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: malloctest.exe
[112/596] p:99 f:1 u:1 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: math.exe
[113/596] p:101 f:1 u:1 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: mathf.exe
[114/596] p:101 f:1 u:1 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: mathl.exe
[115/596] p:103 f:1 u:1 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: md501.exe
[116/596] p:105 f:1 u:1 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: monitor.exe
[117/596] p:105 f:1 u:1 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: monitor02.exe
[118/596] p:105 f:1 u:2 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: mouse01.exe
[119/596] p:108 f:1 u:2 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: newlib01.exe
[120/596] p:108 f:1 u:2 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: ofw01.exe
[121/596] p:108 f:1 u:2 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: putenvtest.exe
[122/596] p:108 f:1 u:2 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: pwdgrp01.exe
[123/596] p:111 f:1 u:2 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: pwdgrp02.exe
[124/596] p:111 f:1 u:2 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: rbheap01.exe
[125/596] p:111 f:1 u:2 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: rcxx01.exe
[127/596] p:113 f:1 u:2 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: record02.exe
[126/596] p:113 f:1 u:2 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: record01.exe
[128/596] p:115 f:1 u:2 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: rtmonuse.exe
[129/596] p:115 f:1 u:2 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sha.exe
[130/596] p:117 f:1 u:2 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: shell01.exe
[131/596] p:118 f:1 u:2 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sparsedisk01.exe
[132/596] p:118 f:1 u:2 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spi01.exe
[133/596] p:120 f:1 u:2 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: stackchk.exe
[134/596] p:122 f:1 u:2 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: stackchk01.exe
[135/596] p:122 f:1 u:2 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: stringto01.exe
[136/596] p:122 f:1 u:2 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tar01.exe
[137/596] p:125 f:1 u:2 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tar02.exe
[138/596] p:125 f:1 u:2 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tar03.exe
[139/596] p:125 f:1 u:2 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: termios.exe
[141/596] p:127 f:1 u:2 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: termios02.exe
[140/596] p:128 f:1 u:2 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: termios01.exe
[142/596] p:129 f:1 u:3 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: termios03.exe
[143/596] p:129 f:1 u:3 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: termios04.exe
[144/596] p:129 f:1 u:3 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: termios05.exe
[145/596] p:132 f:1 u:3 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: termios06.exe
[146/596] p:132 f:1 u:3 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: termios07.exe
[147/596] p:132 f:1 u:3 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: termios08.exe
[148/596] p:135 f:1 u:3 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: termios09.exe
[149/596] p:135 f:1 u:3 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: termios10.exe
[150/596] p:136 f:1 u:3 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: termios11.exe
[151/596] p:138 f:1 u:3 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: top.exe
[152/596] p:138 f:1 u:3 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: ttest01.exe
[153/596] p:138 f:1 u:3 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: ttest02.exe
[154/596] p:140 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tztest.exe
[155/596] p:140 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: uid01.exe
[156/596] p:140 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: utf8proc01.exe
[157/596] p:142 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psx01.exe
[158/596] p:142 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psx02.exe
[159/596] p:144 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psx03.exe
[161/596] p:146 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psx05.exe
[160/596] p:147 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psx04.exe
[162/596] p:147 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psx06.exe
[163/596] p:147 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psx07.exe
[164/596] p:149 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psx08.exe
[165/596] p:149 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psx09.exe
[166/596] p:151 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psx10.exe
[167/596] p:151 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psx11.exe
[168/596] p:152 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psx12.exe
[169/596] p:153 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psx13.exe
[170/596] p:155 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psx14.exe
[171/596] p:155 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psx15.exe
[173/596] p:157 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxaio01.exe
[172/596] p:158 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psx16.exe
[174/596] p:158 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxaio02.exe
[175/596] p:160 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxaio03.exe
[176/596] p:160 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxalarm01.exe
[178/596] p:162 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxautoinit02.exe
[177/596] p:162 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxautoinit01.exe
[179/596] p:163 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxbarrier01.exe
[181/596] p:167 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxcancel01.exe
[180/596] p:167 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxcancel.exe
[182/596] p:167 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxchroot01.exe
[183/596] p:167 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxclassic01.exe
[185/596] p:169 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxcleanup01.exe
[184/596] p:169 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxcleanup.exe
[188/596] p:173 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxclock01.exe
[187/596] p:174 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxclock.exe
[186/596] p:174 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxcleanup02.exe
[189/596] p:174 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxclockrealtime01.exe
[190/596] p:174 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxconcurrency01.exe
[192/596] p:176 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxcond02.exe
[191/596] p:177 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxcond01.exe
[193/596] p:178 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxconfig01.exe
[194/596] p:180 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxdevctl01.exe
[196/596] p:182 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxenosys.exe
[195/596] p:183 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxeintr_join.exe
[197/596] p:183 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxfatal01.exe
[198/596] p:183 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxfatal02.exe
[199/596] p:183 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxfchx01.exe
[201/596] p:187 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxfile01.exe
[200/596] p:187 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxfenv01.exe
[202/596] p:188 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxfile02.exe
[204/596] p:188 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxftw01.exe
[203/596] p:188 f:1 u:4 e:0 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxfilelock01.exe
[205/596] p:191 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxgetattrnp01.exe
[207/596] p:191 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxglobalcon01.exe
[206/596] p:192 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxgetrusage01.exe
[209/596] p:192 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxid01.exe
[208/596] p:192 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxglobalcon02.exe
[212/596] p:196 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxintrcritical01.exe
[210/596] p:197 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psximfs01.exe
[211/596] p:197 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psximfs02.exe
[213/596] p:197 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxinttypes01.exe
[214/596] p:198 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxitimer.exe
[215/596] p:200 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxkey01.exe
[216/596] p:201 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxkey02.exe
[217/596] p:202 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxkey03.exe
[218/596] p:202 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxkey04.exe
[219/596] p:202 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxkey05.exe
[220/596] p:207 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxkey06.exe
[222/596] p:207 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxkey08.exe
[221/596] p:207 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxkey07.exe
[223/596] p:207 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxkey09.exe
[224/596] p:208 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxkey10.exe
[226/596] p:210 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxmount.exe
[227/596] p:211 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxmsgq01.exe
[225/596] p:212 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxmmap01.exe
[229/596] p:212 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxmsgq03.exe
[228/596] p:213 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxmsgq02.exe
[230/596] p:214 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxmsgq04.exe
[231/596] p:215 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxmutexattr01.exe
[232/596] p:219 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxndbm01.exe
[233/596] p:219 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxobj01.exe
[234/596] p:219 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxonce01.exe
[236/596] p:219 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxpasswd02.exe
[235/596] p:219 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxpasswd01.exe
[239/596] p:224 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxreaddir.exe
[237/596] p:224 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxpipe01.exe
[238/596] p:224 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxrdwrv.exe
[241/596] p:224 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxsem01.exe
[240/596] p:224 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxrwlock01.exe
[245/596] p:230 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxsignal02.exe
[246/596] p:230 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxsignal03.exe
[242/596] p:230 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxshm01.exe
[244/596] p:230 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxsignal01.exe
[243/596] p:230 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxshm02.exe
[247/596] p:230 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxsignal04.exe
[250/596] p:236 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxsignal07.exe
[249/596] p:236 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxsignal06.exe
[248/596] p:237 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxsignal05.exe
[251/596] p:237 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxsignal08.exe
[252/596] p:237 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxspin01.exe
[253/596] p:237 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxstack01.exe
[254/596] p:237 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxstack02.exe
[255/596] p:244 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxstat.exe
[257/596] p:244 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxsysconf.exe
[258/596] p:244 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxthreadname01.exe
[256/596] p:244 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxstrsignal01.exe
[259/596] p:244 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtime.exe
[261/596] p:244 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtimer02.exe
[260/596] p:244 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtimer01.exe
[262/596] p:247 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtimes01.exe
[263/596] p:248 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxualarm.exe
[264/596] p:248 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxusleep.exe
[265/596] p:248 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmbarrier01.exe
[269/596] p:253 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmbarrierattr01.exe
[266/596] p:253 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmbarrier02.exe
[267/596] p:253 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmbarrier03.exe
[268/596] p:253 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmbarrier04.exe
[271/596] p:254 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmclocknanosleep01.exe
[270/596] p:255 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmcleanup01.exe
[272/596] p:261 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmclocknanosleep02.exe
[274/596] p:261 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmcond01.exe
[275/596] p:261 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmcond02.exe
[273/596] p:261 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmclocknanosleep03.exe
[276/596] p:261 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmcond03.exe
[277/596] p:261 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmcond04.exe
[278/596] p:261 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmcond05.exe
[282/596] p:268 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmcond09.exe
[280/596] p:268 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmcond07.exe
[279/596] p:268 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmcond06.exe
[281/596] p:268 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmcond08.exe
[283/596] p:268 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmcond10.exe
[285/596] p:268 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmkey02.exe
[284/596] p:268 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmkey01.exe
[286/596] p:275 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmmq01.exe
[290/596] p:275 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmmutex02.exe
[289/596] p:275 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmmutex01.exe
[288/596] p:275 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmmqrcvblock02.exe
[287/596] p:275 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmmqrcvblock01.exe
[292/596] p:275 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmmutex04.exe
[291/596] p:275 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmmutex03.exe
[293/596] p:282 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmmutex05.exe
[296/596] p:282 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmmutexattr01.exe
[295/596] p:282 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmmutex07.exe
[294/596] p:282 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmmutex06.exe
[297/596] p:282 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmnanosleep01.exe
[298/596] p:282 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmnanosleep02.exe
[299/596] p:282 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmonce01.exe
[301/596] p:289 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmrwlock02.exe
[300/596] p:289 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmrwlock01.exe
[304/596] p:289 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmrwlock05.exe
[303/596] p:289 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmrwlock04.exe
[302/596] p:289 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmrwlock03.exe
[305/596] p:289 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmrwlock06.exe
[306/596] p:289 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmrwlock07.exe
[308/596] p:296 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmsem02.exe
[309/596] p:296 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmsem03.exe
[310/596] p:296 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmsem04.exe
[307/596] p:296 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmsem01.exe
[311/596] p:296 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmsem05.exe
[312/596] p:296 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmsleep01.exe
[313/596] p:296 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmsleep02.exe
[315/596] p:303 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmthread02.exe
[317/596] p:303 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmthread04.exe
[314/596] p:303 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmthread01.exe
[318/596] p:303 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmthread05.exe
[316/596] p:303 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmthread03.exe
[319/596] p:303 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmthread06.exe
[320/596] p:303 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: psxtmthreadattr01.exe
[323/596] p:310 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: rhmlatency.exe
[322/596] p:310 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: rhilatency.exe
[321/596] p:310 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: rhdeadlockbrk.exe
[325/596] p:310 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: rhtaskpreempt.exe
[324/596] p:310 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: rhsemshuffle.exe
[326/596] p:310 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: rhtaskswitch.exe
[327/596] p:311 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: base_sp.exe
[328/596] p:311 f:1 u:4 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: capture.exe
[329/596] p:312 f:1 u:5 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: cdtest.exe
[330/596] p:312 f:1 u:5 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: fileio.exe
[331/596] p:313 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: hello.exe
[332/596] p:314 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: iostream.exe
[334/596] p:315 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: nsecs.exe
[333/596] p:315 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: minimum.exe
[336/596] p:317 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: ticker.exe
[335/596] p:317 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: paranoia.exe
[337/596] p:321 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: unlimited.exe
[338/596] p:321 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp01.exe
[339/596] p:321 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp02.exe
[340/596] p:321 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp03.exe
[341/596] p:322 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp04.exe
[342/596] p:324 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp05.exe
[343/596] p:324 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp06.exe
[344/596] p:326 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp07.exe
[345/596] p:326 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp08.exe
[347/596] p:328 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp12.exe
[346/596] p:329 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp11.exe
[348/596] p:331 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp13.exe
[349/596] p:331 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp14.exe
[350/596] p:332 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp15.exe
[351/596] p:332 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp16.exe
[352/596] p:333 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp17.exe
[353/596] p:335 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp18.exe
[354/596] p:337 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp19.exe
[355/596] p:338 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp20.exe
[356/596] p:338 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp2038.exe
[357/596] p:338 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp21.exe
[358/596] p:340 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp22.exe
[359/596] p:340 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp23.exe
[360/596] p:341 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp24.exe
[361/596] p:343 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp25.exe
[362/596] p:343 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp26.exe
[363/596] p:344 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp27.exe
[365/596] p:347 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp29.exe
[366/596] p:347 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp30.exe
[364/596] p:347 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp27a.exe
[367/596] p:348 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp31.exe
[368/596] p:350 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp32.exe
[369/596] p:350 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp33.exe
[370/596] p:352 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp34.exe
[372/596] p:353 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp37.exe
[371/596] p:353 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp35.exe
[373/596] p:354 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp38.exe
[374/596] p:357 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp40.exe
[375/596] p:358 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp41.exe
[376/596] p:358 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp42.exe
[377/596] p:358 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp43.exe
[378/596] p:363 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp44.exe
[381/596] p:363 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp47.exe
[380/596] p:363 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp46.exe
[379/596] p:363 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp45.exe
[382/596] p:363 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp48.exe
[383/596] p:367 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp49.exe
[384/596] p:367 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp50.exe
[385/596] p:367 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp51.exe
[386/596] p:367 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp52.exe
[389/596] p:372 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp55.exe
[390/596] p:372 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp56.exe
[387/596] p:372 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp53.exe
[388/596] p:372 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp54.exe
[391/596] p:372 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp57.exe
[392/596] p:377 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp58.exe
[393/596] p:377 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp59.exe
[394/596] p:377 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp60.exe
[395/596] p:377 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp62.exe
[396/596] p:377 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp63.exe
[397/596] p:381 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp64.exe
[398/596] p:381 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp65.exe
[400/596] p:381 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp67.exe
[399/596] p:381 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp66.exe
[401/596] p:385 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp68.exe
[404/596] p:385 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp71.exe
[402/596] p:385 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp69.exe
[403/596] p:386 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp70.exe
[405/596] p:386 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp72.exe
[407/596] p:388 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp74.exe
[406/596] p:388 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp73.exe
[409/596] p:392 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp76.exe
[408/596] p:392 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp75.exe
[410/596] p:392 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sp77.exe
[411/596] p:393 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spassoc01.exe
[412/596] p:393 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spatomic01.exe
[413/596] p:399 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spcache01.exe
[414/596] p:399 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spcbssched01.exe
[415/596] p:399 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spcbssched02.exe
[416/596] p:399 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spcbssched03.exe
[417/596] p:399 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spchain.exe
[418/596] p:400 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spclock_err01.exe
[419/596] p:401 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spclock_err02.exe
[420/596] p:402 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spclock_todhook01.exe
[421/596] p:402 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spconfig01.exe
[422/596] p:404 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spconfig02.exe
[423/596] p:408 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spconsole01.exe
[424/596] p:408 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spcontext01.exe
[426/596] p:408 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spcpuset01.exe
[425/596] p:408 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spcpucounter01.exe
[427/596] p:408 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spcxx01.exe
[428/596] p:412 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spedfsched01.exe
[429/596] p:412 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spedfsched02.exe
[430/596] p:412 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spedfsched03.exe
[431/596] p:412 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spedfsched04.exe
[432/596] p:413 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sperror01.exe
[433/596] p:416 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sperror02.exe
[434/596] p:416 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sperror03.exe
[435/596] p:416 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spevent_err03.exe
[436/596] p:417 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: speventsystem01.exe
[438/596] p:420 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spextensions01.exe
[437/596] p:420 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: speventtransient01.exe
[439/596] p:420 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spfatal01.exe
[441/596] p:422 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spfatal04.exe
[440/596] p:423 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spfatal03.exe
[442/596] p:423 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spfatal05.exe
[443/596] p:425 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spfatal09.exe
[444/596] p:426 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spfatal10.exe
[445/596] p:426 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spfatal11.exe
[446/596] p:427 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spfatal12.exe
[447/596] p:429 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spfatal14.exe
[448/596] p:429 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spfatal15.exe
[450/596] p:431 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spfatal25.exe
[449/596] p:432 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spfatal24.exe
[451/596] p:432 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spfatal26.exe
[452/596] p:434 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spfatal28.exe
[453/596] p:434 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spfatal29.exe
[454/596] p:437 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spfatal30.exe
[455/596] p:437 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spfatal31.exe
[456/596] p:437 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spfatal32.exe
[458/596] p:440 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spfatal34.exe
[457/596] p:440 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spfatal33.exe
[459/596] p:440 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spfifo01.exe
[460/596] p:443 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spfifo02.exe
[461/596] p:443 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spfifo03.exe
[462/596] p:443 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spfifo04.exe
[463/596] p:446 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spfifo05.exe
[464/596] p:446 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spfreechain01.exe
[465/596] p:446 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spglobalcon01.exe
[466/596] p:449 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spglobalcon02.exe
[467/596] p:449 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spheapprot.exe
[468/596] p:449 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spinternalerror01.exe
[469/596] p:453 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spinternalerror02.exe
[470/596] p:453 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spintr_err01.exe
[471/596] p:453 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spintrcritical01.exe
[472/596] p:453 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spintrcritical02.exe
[473/596] p:455 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spintrcritical03.exe
[474/596] p:458 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spintrcritical04.exe
[475/596] p:458 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spintrcritical05.exe
[476/596] p:458 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spintrcritical08.exe
[477/596] p:458 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spintrcritical09.exe
[478/596] p:460 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spintrcritical10.exe
[479/596] p:460 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spintrcritical11.exe
[480/596] p:462 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spintrcritical12.exe
[481/596] p:462 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spintrcritical13.exe
[482/596] p:463 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spintrcritical14.exe
[483/596] p:465 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spintrcritical15.exe
[484/596] p:465 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spintrcritical16.exe
[485/596] p:469 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spintrcritical18.exe
[486/596] p:469 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spintrcritical20.exe
[487/596] p:469 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spintrcritical21.exe
[488/596] p:469 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spintrcritical22.exe
[489/596] p:470 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spintrcritical23.exe
[490/596] p:473 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spintrcritical24.exe
[491/596] p:473 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: splinkersets01.exe
[492/596] p:473 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spmisc01.exe
[493/596] p:475 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spmkdir.exe
[494/596] p:476 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spmountmgr01.exe
[495/596] p:477 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spmrsp01.exe
[496/596] p:478 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spmsgq_err01.exe
[497/596] p:479 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spmsgq_err02.exe
[498/596] p:479 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spmutex01.exe
[499/596] p:480 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spnsext01.exe
[500/596] p:482 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spobjgetnext.exe
[501/596] p:482 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sppagesize.exe
[503/596] p:484 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sppercpudata01.exe
[502/596] p:484 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sppartition_err01.exe
[504/596] p:487 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spport_err01.exe
[505/596] p:487 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spprintk.exe
[506/596] p:487 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spprivenv01.exe
[507/596] p:489 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spprofiling01.exe
[508/596] p:490 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spqreslib.exe
[509/596] p:490 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spratemon_err01.exe
[510/596] p:492 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sprbtree01.exe
[511/596] p:493 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spregion_err01.exe
[512/596] p:493 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sprmsched01.exe
[513/596] p:494 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sprmsched02.exe
[514/596] p:495 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spscheduler01.exe
[515/596] p:496 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spsem01.exe
[516/596] p:497 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spsem02.exe
[517/596] p:498 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spsem03.exe
[518/596] p:499 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spsem_err01.exe
[519/596] p:501 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spsem_err02.exe
[521/596] p:502 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spsimplesched01.exe
[520/596] p:502 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spsignal_err01.exe
[522/596] p:504 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spsimplesched02.exe
[523/596] p:504 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spsimplesched03.exe
[524/596] p:506 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spsize.exe
[525/596] p:506 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spstdthreads01.exe
[526/596] p:509 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spstkalloc.exe
[527/596] p:510 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spstkalloc02.exe
[529/596] p:510 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spsyslock01.exe
[528/596] p:511 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spsysinit01.exe
[530/596] p:511 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sptask_err01.exe
[532/596] p:514 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sptask_err03.exe
[531/596] p:515 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sptask_err02.exe
[533/596] p:515 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sptask_err04.exe
[534/596] p:516 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sptasknopreempt01.exe
[535/596] p:516 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spthread01.exe
[537/596] p:519 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spthreadq01.exe
[536/596] p:520 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spthreadlife01.exe
[538/596] p:521 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sptimecounter01.exe
[540/596] p:521 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sptimecounter03.exe
[539/596] p:521 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sptimecounter02.exe
[541/596] p:523 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sptimecounter04.exe
[542/596] p:524 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sptimer_err01.exe
[543/596] p:524 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sptimer_err02.exe
[544/596] p:525 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sptimerserver01.exe
[545/596] p:527 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sptimespec01.exe
[546/596] p:528 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sptls01.exe
[547/596] p:528 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sptls02.exe
[548/596] p:530 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sptls03.exe
[549/596] p:530 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: sptls04.exe
[550/596] p:531 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spversion01.exe
[551/596] p:533 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spwatchdog.exe
[552/596] p:535 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: spwkspace.exe
[554/596] p:535 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm02.exe
[553/596] p:535 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm01.exe
[556/596] p:537 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm04.exe
[555/596] p:538 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm03.exe
[558/596] p:541 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm06.exe
[557/596] p:541 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm05.exe
[559/596] p:541 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm07.exe
[560/596] p:541 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm08.exe
[562/596] p:544 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm10.exe
[563/596] p:545 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm11.exe
[561/596] p:545 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm09.exe
[564/596] p:546 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm12.exe
[567/596] p:549 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm15.exe
[565/596] p:549 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm13.exe
[566/596] p:549 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm14.exe
[568/596] p:550 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm16.exe
[569/596] p:550 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm17.exe
[570/596] p:555 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm18.exe
[571/596] p:555 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm19.exe
[572/596] p:555 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm20.exe
[573/596] p:555 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm21.exe
[574/596] p:556 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm22.exe
[577/596] p:559 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm25.exe
[575/596] p:560 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm23.exe
[576/596] p:560 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm24.exe
[578/596] p:560 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm26.exe
[579/596] p:560 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm27.exe
[580/596] p:564 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm28.exe
[581/596] p:565 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm29.exe
[582/596] p:565 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm30.exe
[583/596] p:565 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm31.exe
[584/596] p:565 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm32.exe
[587/596] p:569 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm35.exe
[586/596] p:570 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm34.exe
[585/596] p:570 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm33.exe
[588/596] p:570 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tm36.exe
[589/596] p:570 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tmck.exe
[590/596] p:576 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tmcontext01.exe
[591/596] p:576 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tmfine01.exe
[592/596] p:576 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tmonetoone.exe
[593/596] p:576 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: tmtimer01.exe
[594/596] p:576 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: ts-performance-0.exe
[595/596] p:577 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: ts-validation-0.exe
[596/596] p:577 f:1 u:6 e:1 I:0 B:3 t:0 L:0 i:0 W:0 | sparc/leon3: ts-validation-1.exe
Result: failed Time: 0:00:00.256902 dl06.exe
=> exe: /home/zack/quick-start/rtems/6/bin/sparc-rtems6-sis -leon3 -nouartrx -r -tlim 200 s -m 4 build/sparc/leon3/testsuites/libtests/dl06.exe
] SIS - SPARC/RISCV instruction simulator 2.27, copyright Jiri Gaisler 2020
] Bug-reports to jiri at gaisler.se
] LEON3 emulation enabled, 4 cpus online, delta 50 clocks
] Loaded build/sparc/leon3/testsuites/libtests/dl06.exe, entry 0x40000000
=> test start: libdl (RTL) 6
] *** BEGIN OF TEST libdl (RTL) 6 ***
] *** TEST VERSION: 6.0.0.67c033d39a42d3594afae35f3ea1bf131e0dbd87
] *** TEST STATE: EXPECTED_PASS
] *** TEST BUILD: RTEMS_POSIX_API
] *** TEST TOOLS: 10.3.1 20210409 (RTEMS 6, RSB c938bd7cbe16bd03d3b382f2d7cfee6a86aa9424, Newlib 0c0f3df)
] load: /dl06.rap
] dlopen failed: offset past end of file: offset=10121 size=10121
] cpu 0 in error mode (tt = 0x80)
] 3269750 4000d640: 91d02000 ta 0x0
Result: failed Time: 0:00:02.509576 ts-validation-0.exe
=> exe: /home/zack/quick-start/rtems/6/bin/sparc-rtems6-sis -leon3 -nouartrx -r -tlim 200 s -m 4 build/sparc/leon3/testsuites/validation/ts-validation-0.exe
] Loaded build/sparc/leon3/testsuites/validation/ts-validation-0.exe, entry 0x40000000
=> test start: Validation0
] *** BEGIN OF TEST Validation0 ***
] A:Validation0
] S:Platform:RTEMS
] S:Compiler:10.3.1 20210409 (RTEMS 6, RSB c938bd7cbe16bd03d3b382f2d7cfee6a86aa9424, Newlib 0c0f3df)
] S:Version:6.0.0.67c033d39a42d3594afae35f3ea1bf131e0dbd87
] S:BSP:leon3
] S:BuildLabel:DEFAULT
] S:TargetHash:SHA256:3Y1G8SMm2FRTpZB5_0NhbpDnatbEYmbDLLW58d-wXuY=
] S:RTEMS_DEBUG:0
] S:RTEMS_MULTIPROCESSING:0
] S:RTEMS_POSIX_API:1
] S:RTEMS_PROFILING:0
] S:RTEMS_SMP:0
] B:RtemsTaskReqCreateErrors
] E:RtemsTaskReqCreateErrors:N:1460:F:0:D:0.424947
] B:RtemsTaskReqConstructErrors
] E:RtemsTaskReqConstructErrors:N:4625:F:0:D:1.110636
] B:RtemsSignalReqSend
] E:RtemsSignalReqSend:N:659:F:0:D:0.005123
] B:RtemsSignalReqCatch
] E:RtemsSignalReqCatch:N:577:F:0:D:0.002561
] B:RtemsObjectValObject
] E:RtemsObjectValObject:N:1:F:0:D:0.000416
] B:RtemsMessageReqConstructErrors
] E:RtemsMessageReqConstructErrors:N:1731:F:0:D:0.038804
] B:RtemsIntrReqVectorIsEnabled
] E:RtemsIntrReqVectorIsEnabled:N:156:F:0:D:0.001329
] B:RtemsIntrReqVectorEnable
] E:RtemsIntrReqVectorEnable:N:974:F:0:D:0.006024
] B:RtemsIntrReqVectorDisable
] E:RtemsIntrReqVectorDisable:N:968:F:0:D:0.005984
] B:RtemsIntrReqSetAffinity
] E:RtemsIntrReqSetAffinity:N:202:F:0:D:0.000975
] B:RtemsIntrReqRaiseOn
] E:RtemsIntrReqRaiseOn:N:61:F:0:D:0.000872
] E:RtemsIntrReqRaise:N:57:F:0:D:0.000827
] B:RtemsIntrReqIsPending
] F:18:0:UI1/Valid/Obj/Yes:tc-intr-is-pending.c:263
] F:21:0:UI1/Valid/Obj/Yes:tc-intr-is-pending.c:263
] F:28:0:UI1/Valid/Obj/Yes:tc-intr-is-pending.c:263
] F:55:0:UI1/Valid/Obj/Yes:tc-intr-is-pending.c:266
] F:75:0:UI1/Valid/Obj/No:tc-intr-is-pending.c:263
] F:78:0:UI1/Valid/Obj/No:tc-intr-is-pending.c:263
] F:85:0:UI1/Valid/Obj/No:tc-intr-is-pending.c:263
] F:112:0:UI1/Valid/Obj/No:tc-intr-is-pending.c:266
] E:RtemsIntrReqIsPending:N:126:F:8:D:0.003893
] B:RtemsIntrReqHandlerIterate
] E:RtemsIntrReqHandlerIterate:N:30:F:0:D:0.000358
] B:RtemsIntrReqGetAttributes
] E:RtemsIntrReqGetAttributes:N:68:F:0:D:0.000362
] B:RtemsIntrReqGetAffinity
] E:RtemsIntrReqGetAffinity:N:133:F:0:D:0.000714
] B:RtemsIntrReqEntryRemove
] E:RtemsIntrReqEntryRemove:N:4489:F:0:D:0.030869
] B:RtemsIntrReqEntryInstall
] E:RtemsIntrReqEntryInstall:N:13463:F:0:D:0.091093
] B:RtemsIntrReqClear
] E:RtemsIntrReqClear:N:56:F:0:D:0.000822
] B:RtemsBarrierReqWait
] E:RtemsBarrierReqWait:N:90:F:0:D:0.004438
] B:RtemsBarrierReqRelease
] E:RtemsBarrierReqRelease:N:39:F:0:D:0.000700
] B:RtemsBarrierReqDelete
] E:RtemsBarrierReqDelete:N:26:F:0:D:0.000591
] B:RtemsBarrierReqCreate
] E:RtemsBarrierReqCreate:N:178:F:0:D:0.003295
] Z:Validation0:C:23:N:30169:F:8:D:1.744571
] Y:ReportHash:SHA256:jK1F9K89NWy2K5Mgp3FVfgLY-ziqrQmoc8WaKRl9V4s=
] 87588450 4000f180: 91d02000 ta 0x0
Passed: 584
Failed: 2
User Input: 6
Expected Fail: 1
Indeterminate: 0
Benchmark: 3
Timeout: 0
Test too long: 0
Invalid: 0
Wrong Version: 0
Wrong Build: 0
Wrong Tools: 0
Total: 596
Failures:
dl06.exe
ts-validation-0.exe
User Input:
dl10.exe
monitor.exe
termios.exe
top.exe
capture.exe
fileio.exe
Expected Fail:
psxfenv01.exe
Benchmark:
linpack.exe
whetstone.exe
dhrystone.exe
Average test time: 0:00:00.296752
Testing time : 0:02:56.864198
