[PATCH v4] bsps: Move optfdt* files to shared parent directory
Gedare Bloom
gedare at rtems.org
Mon Aug 9 14:59:59 UTC 2021
Hi Joel,
On Fri, Jul 16, 2021 at 10:40 AM Joel Sherrill <joel at rtems.org> wrote:
> I'm doing a build sweep of all BSPs. When that completes, I plan to
> push this unless there are comments.
Did/can you push this?
> On Fri, Jul 16, 2021 at 9:51 AM pranav <dangipranav at gmail.com> wrote:
> > .../arm/altera-cyclone-v/bspalteracyclonev.yml | 8 ++++----
> > spec/build/bsps/arm/beagle/grp.yml | 8 ++++----
> > spec/build/bsps/arm/beagle/optfdtcpyro.yml | 16 ----------------
> > spec/build/bsps/arm/beagle/optfdtmxsz.yml | 17 -----------------
> > spec/build/bsps/arm/beagle/optfdtro.yml | 16 ----------------
> > spec/build/bsps/arm/beagle/optfdtuboot.yml | 16 ----------------
> > spec/build/bsps/arm/imx/bspimx.yml | 8 ++++----
> > spec/build/bsps/arm/imx/optfdtcpyro.yml | 16 ----------------
> > spec/build/bsps/arm/imx/optfdtmxsz.yml | 17 -----------------
> > spec/build/bsps/arm/imx/optfdtro.yml | 16 ----------------
> > spec/build/bsps/arm/imx/optfdtuboot.yml | 16 ----------------
> > spec/build/bsps/arm/raspberrypi/grp.yml | 8 ++++++++
> > .../{arm/altera-cyclone-v => }/optfdtcpyro.yml | 0
> > .../{arm/altera-cyclone-v => }/optfdtmxsz.yml | 0
> > .../{arm/altera-cyclone-v => }/optfdtro.yml | 0
> > .../{arm/altera-cyclone-v => }/optfdtuboot.yml | 0
> > spec/build/bsps/powerpc/qoriq/grp.yml | 4 ++--
> > spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml | 17 -----------------
> > spec/build/bsps/powerpc/qoriq/optfdtro.yml | 16 ----------------
> > spec/build/bsps/riscv/riscv/grp.yml | 8 ++++----
> > spec/build/bsps/riscv/riscv/optfdtcpyro.yml | 16 ----------------
> > spec/build/bsps/riscv/riscv/optfdtmxsz.yml | 17 -----------------
> > spec/build/bsps/riscv/riscv/optfdtro.yml | 16 ----------------
> > spec/build/bsps/riscv/riscv/optfdtuboot.yml | 16 ----------------
> > 24 files changed, 26 insertions(+), 246 deletions(-)
> > delete mode 100644 spec/build/bsps/arm/beagle/optfdtcpyro.yml
> > delete mode 100644 spec/build/bsps/arm/beagle/optfdtmxsz.yml
> > delete mode 100644 spec/build/bsps/arm/beagle/optfdtro.yml
> > delete mode 100644 spec/build/bsps/arm/beagle/optfdtuboot.yml
> > delete mode 100644 spec/build/bsps/arm/imx/optfdtcpyro.yml
> > delete mode 100644 spec/build/bsps/arm/imx/optfdtmxsz.yml
> > delete mode 100644 spec/build/bsps/arm/imx/optfdtro.yml
> > delete mode 100644 spec/build/bsps/arm/imx/optfdtuboot.yml
> > rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtcpyro.yml (100%)
> > rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtmxsz.yml (100%)
> > rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtro.yml (100%)
> > rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtuboot.yml (100%)
> > delete mode 100644 spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml
> > delete mode 100644 spec/build/bsps/powerpc/qoriq/optfdtro.yml
> > delete mode 100644 spec/build/bsps/riscv/riscv/optfdtcpyro.yml
> > delete mode 100644 spec/build/bsps/riscv/riscv/optfdtmxsz.yml
> > delete mode 100644 spec/build/bsps/riscv/riscv/optfdtro.yml
> > delete mode 100644 spec/build/bsps/riscv/riscv/optfdtuboot.yml
> > diff --git a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
> > index da567ddd79..a9f3f7dabf 100644
> > --- a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
> > +++ b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
> > @@ -73,15 +73,15 @@ links:
> > - role: build-dependency
> > uid: optconuart1
> > - uid: optfdtcpyro
> > + uid: ../../optfdtcpyro
> > uid: optfdten
> > - uid: optfdtmxsz
> > + uid: ../../optfdtmxsz
> > - uid: optfdtro
> > + uid: ../../optfdtro
> > - uid: optfdtuboot
> > + uid: ../../optfdtuboot
> > uid: opti2cspeed
> > diff --git a/spec/build/bsps/arm/beagle/grp.yml b/spec/build/bsps/arm/beagle/grp.yml
> > index 1375913fd0..3452c3e5c8 100644
> > --- a/spec/build/bsps/arm/beagle/grp.yml
> > +++ b/spec/build/bsps/arm/beagle/grp.yml
> > @@ -22,13 +22,13 @@ links:
> > uid: optdm3730
> > - uid: optfdtcpyro
> > - uid: optfdtmxsz
> > - uid: optfdtro
> > - uid: optfdtuboot
> > uid: ../grp
> > diff --git a/spec/build/bsps/arm/beagle/optfdtcpyro.yml b/spec/build/bsps/arm/beagle/optfdtcpyro.yml
> > deleted file mode 100644
> > index 5ec59adf4d..0000000000
> > --- a/spec/build/bsps/arm/beagle/optfdtcpyro.yml
> > +++ /dev/null
> > @@ -1,16 +0,0 @@
> > -SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> > -actions:
> > -- get-boolean: null
> > -- define-condition: null
> > -build-type: option
> > -copyrights:
> > -- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
> > -default: true
> > -default-by-family: []
> > -default-by-variant: []
> > -description: |
> > - copy the FDT blob into the read-only load area via bsp_fdt_copy()
> > -enabled-by: true
> > -links: []
> > -name: BSP_FDT_BLOB_COPY_TO_READ_ONLY_LOAD_AREA
> > -type: build
> > diff --git a/spec/build/bsps/arm/beagle/optfdtmxsz.yml b/spec/build/bsps/arm/beagle/optfdtmxsz.yml
> > index f3b2504e02..0000000000
> > --- a/spec/build/bsps/arm/beagle/optfdtmxsz.yml
> > +++ /dev/null
> > @@ -1,17 +0,0 @@
> > -actions:
> > -- get-integer: null
> > -- define: null
> > -build-type: option
> > -copyrights:
> > -default: 262144
> > -description: |
> > - maximum size of the FDT blob in bytes
> > -enabled-by: true
> > -format: '{}'
> > -links: []
> > -name: BSP_FDT_BLOB_SIZE_MAX
> > -type: build
> > diff --git a/spec/build/bsps/arm/beagle/optfdtro.yml b/spec/build/bsps/arm/beagle/optfdtro.yml
> > index a72bc23c0e..0000000000
> > --- a/spec/build/bsps/arm/beagle/optfdtro.yml
> > +++ /dev/null
> > @@ -1,16 +0,0 @@
> > -actions:
> > -build-type: option
> > -copyrights:
> > -default: true
> > -description: |
> > - place the FDT blob into the read-only data area
> > -enabled-by: true
> > -links: []
> > -name: BSP_FDT_BLOB_READ_ONLY
> > -type: build
> > diff --git a/spec/build/bsps/arm/beagle/optfdtuboot.yml b/spec/build/bsps/arm/beagle/optfdtuboot.yml
> > index cfe94e577c..0000000000
> > --- a/spec/build/bsps/arm/beagle/optfdtuboot.yml
> > +++ /dev/null
> > @@ -1,16 +0,0 @@
> > -actions:
> > -build-type: option
> > -copyrights:
> > -default: true
> > -description: |
> > - copy the U-Boot provided FDT to an internal storage
> > -enabled-by: true
> > -links: []
> > -name: BSP_START_COPY_FDT_FROM_U_BOOT
> > -type: build
> > diff --git a/spec/build/bsps/arm/imx/bspimx.yml b/spec/build/bsps/arm/imx/bspimx.yml
> > index c65e02db2b..14719745f0 100644
> > --- a/spec/build/bsps/arm/imx/bspimx.yml
> > +++ b/spec/build/bsps/arm/imx/bspimx.yml
> > @@ -61,13 +61,13 @@ links:
> > uid: optconirq
> > - uid: optfdtcpyro
> > - uid: optfdtmxsz
> > - uid: optfdtro
> > - uid: optfdtuboot
> > uid: optresetvec
> > diff --git a/spec/build/bsps/arm/imx/optfdtcpyro.yml b/spec/build/bsps/arm/imx/optfdtcpyro.yml
> > --- a/spec/build/bsps/arm/imx/optfdtcpyro.yml
> > +++ /dev/null
> > @@ -1,16 +0,0 @@
> > -actions:
> > -build-type: option
> > -copyrights:
> > -default: true
> > -description: |
> > -enabled-by: true
> > -links: []
> > -type: build
> > diff --git a/spec/build/bsps/arm/imx/optfdtmxsz.yml b/spec/build/bsps/arm/imx/optfdtmxsz.yml
> > --- a/spec/build/bsps/arm/imx/optfdtmxsz.yml
> > +++ /dev/null
> > @@ -1,17 +0,0 @@
> > -actions:
> > -- define: null
> > -build-type: option
> > -copyrights:
> > -default: 262144
> > -description: |
> > -enabled-by: true
> > -format: '{}'
> > -links: []
> > -type: build
> > diff --git a/spec/build/bsps/arm/imx/optfdtro.yml b/spec/build/bsps/arm/imx/optfdtro.yml
> > --- a/spec/build/bsps/arm/imx/optfdtro.yml
> > +++ /dev/null
> > @@ -1,16 +0,0 @@
> > -actions:
> > -build-type: option
> > -copyrights:
> > -default: true
> > -description: |
> > -enabled-by: true
> > -links: []
> > -type: build
> > diff --git a/spec/build/bsps/arm/imx/optfdtuboot.yml b/spec/build/bsps/arm/imx/optfdtuboot.yml
> > --- a/spec/build/bsps/arm/imx/optfdtuboot.yml
> > +++ /dev/null
> > @@ -1,16 +0,0 @@
> > -actions:
> > -build-type: option
> > -copyrights:
> > -default: true
> > -description: |
> > -enabled-by: true
> > -links: []
> > -type: build
> > diff --git a/spec/build/bsps/arm/raspberrypi/grp.yml b/spec/build/bsps/arm/raspberrypi/grp.yml
> > index 7291e8b178..94627a9526 100644
> > --- a/spec/build/bsps/arm/raspberrypi/grp.yml
> > +++ b/spec/build/bsps/arm/raspberrypi/grp.yml
> > @@ -41,6 +41,14 @@ links:
> > uid: linkcmds
> > uid: ../../bspopts
> > +- role: build-dependency
> > type: build
> > use-after: []
> > use-before: []
> > diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtcpyro.yml b/spec/build/bsps/optfdtcpyro.yml
> > similarity index 100%
> > rename from spec/build/bsps/arm/altera-cyclone-v/optfdtcpyro.yml
> > rename to spec/build/bsps/optfdtcpyro.yml
> > diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtmxsz.yml b/spec/build/bsps/optfdtmxsz.yml
> > rename from spec/build/bsps/arm/altera-cyclone-v/optfdtmxsz.yml
> > rename to spec/build/bsps/optfdtmxsz.yml
> > diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtro.yml b/spec/build/bsps/optfdtro.yml
> > rename from spec/build/bsps/arm/altera-cyclone-v/optfdtro.yml
> > rename to spec/build/bsps/optfdtro.yml
> > diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtuboot.yml b/spec/build/bsps/optfdtuboot.yml
> > rename from spec/build/bsps/arm/altera-cyclone-v/optfdtuboot.yml
> > rename to spec/build/bsps/optfdtuboot.yml
> > diff --git a/spec/build/bsps/powerpc/qoriq/grp.yml b/spec/build/bsps/powerpc/qoriq/grp.yml
> > index 3e295cb599..08533ded6f 100644
> > --- a/spec/build/bsps/powerpc/qoriq/grp.yml
> > +++ b/spec/build/bsps/powerpc/qoriq/grp.yml
> > @@ -68,9 +68,9 @@ links:
> > uid: optexcfixdhdlr
> > - uid: optfdtmxsz
> > - uid: optfdtro
> > uid: opthid0
> > diff --git a/spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml b/spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml
> > --- a/spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml
> > +++ /dev/null
> > @@ -1,17 +0,0 @@
> > -actions:
> > -- define: null
> > -build-type: option
> > -copyrights:
> > -default: 262144
> > -description: |
> > -enabled-by: true
> > -format: '{}'
> > -links: []
> > -type: build
> > diff --git a/spec/build/bsps/powerpc/qoriq/optfdtro.yml b/spec/build/bsps/powerpc/qoriq/optfdtro.yml
> > --- a/spec/build/bsps/powerpc/qoriq/optfdtro.yml
> > +++ /dev/null
> > @@ -1,16 +0,0 @@
> > -actions:
> > -build-type: option
> > -copyrights:
> > -default: true
> > -description: |
> > -enabled-by: true
> > -links: []
> > -type: build
> > diff --git a/spec/build/bsps/riscv/riscv/grp.yml b/spec/build/bsps/riscv/riscv/grp.yml
> > index 396f8986ec..77583d351e 100644
> > --- a/spec/build/bsps/riscv/riscv/grp.yml
> > +++ b/spec/build/bsps/riscv/riscv/grp.yml
> > @@ -32,13 +32,13 @@ links:
> > uid: optextirqmax
> > - uid: optfdtcpyro
> > - uid: optfdtmxsz
> > - uid: optfdtro
> > - uid: optfdtuboot
> > uid: optfrdme310arty
> > diff --git a/spec/build/bsps/riscv/riscv/optfdtcpyro.yml b/spec/build/bsps/riscv/riscv/optfdtcpyro.yml
> > --- a/spec/build/bsps/riscv/riscv/optfdtcpyro.yml
> > +++ /dev/null
> > @@ -1,16 +0,0 @@
> > -actions:
> > -build-type: option
> > -copyrights:
> > -default: true
> > -description: |
> > -enabled-by: true
> > -links: []
> > -type: build
> > diff --git a/spec/build/bsps/riscv/riscv/optfdtmxsz.yml b/spec/build/bsps/riscv/riscv/optfdtmxsz.yml
> > index 8a07a2ad08..0000000000
> > --- a/spec/build/bsps/riscv/riscv/optfdtmxsz.yml
> > +++ /dev/null
> > @@ -1,17 +0,0 @@
> > -actions:
> > -- define: null
> > -build-type: option
> > -copyrights:
> > -default: 65536
> > -description: |
> > -enabled-by: true
> > -format: '{}'
> > -links: []
> > -type: build
> > diff --git a/spec/build/bsps/riscv/riscv/optfdtro.yml b/spec/build/bsps/riscv/riscv/optfdtro.yml
> > --- a/spec/build/bsps/riscv/riscv/optfdtro.yml
> > +++ /dev/null
> > @@ -1,16 +0,0 @@
> > -actions:
> > -build-type: option
> > -copyrights:
> > -default: true
> > -description: |
> > -enabled-by: true
> > -links: []
> > -type: build
> > diff --git a/spec/build/bsps/riscv/riscv/optfdtuboot.yml b/spec/build/bsps/riscv/riscv/optfdtuboot.yml
> > --- a/spec/build/bsps/riscv/riscv/optfdtuboot.yml
> > +++ /dev/null
> > @@ -1,16 +0,0 @@
> > -actions:
> > -build-type: option
> > -copyrights:
> > -default: true
> > -description: |
> > -enabled-by: true
> > -links: []
> > -type: build
> > 2.30.2
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
