[PATCH v4] bsps: Move optfdt* files to shared parent directory
Mon Aug 9 15:10:42 UTC 2021
On Mon, Aug 9, 2021 at 10:00 AM Gedare Bloom <gedare at rtems.org> wrote:
> Hi Joel,
> On Fri, Jul 16, 2021 at 10:40 AM Joel Sherrill <joel at rtems.org> wrote:
> > I'm doing a build sweep of all BSPs. When that completes, I plan to
> > push this unless there are comments.
> Did/can you push this?
It doesn't apply for me. Could be a rebase is needed or it didn't survive
the email client. If it's just an email issue, just send it to me directly as an
attachment possibly compressed to avoid any chance of email clients
getting smart.
Applying: bsps: Move optfdt* files to shared parent directory
error: patch failed: spec/build/bsps/arm/beagle/optfdtcpyro.yml:1
error: spec/build/bsps/arm/beagle/optfdtcpyro.yml: patch does not apply
error: patch failed: spec/build/bsps/arm/beagle/optfdtmxsz.yml:1
error: spec/build/bsps/arm/beagle/optfdtmxsz.yml: patch does not apply
error: patch failed: spec/build/bsps/arm/beagle/optfdtro.yml:1
error: spec/build/bsps/arm/beagle/optfdtro.yml: patch does not apply
error: patch failed: spec/build/bsps/arm/beagle/optfdtuboot.yml:1
error: spec/build/bsps/arm/beagle/optfdtuboot.yml: patch does not apply
error: patch failed: spec/build/bsps/arm/imx/optfdtcpyro.yml:1
error: spec/build/bsps/arm/imx/optfdtcpyro.yml: patch does not apply
error: patch failed: spec/build/bsps/arm/imx/optfdtmxsz.yml:1
error: spec/build/bsps/arm/imx/optfdtmxsz.yml: patch does not apply
error: patch failed: spec/build/bsps/arm/imx/optfdtro.yml:1
error: spec/build/bsps/arm/imx/optfdtro.yml: patch does not apply
error: patch failed: spec/build/bsps/arm/imx/optfdtuboot.yml:1
error: spec/build/bsps/arm/imx/optfdtuboot.yml: patch does not apply
error: patch failed: spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml:1
error: spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml: patch does not apply
error: patch failed: spec/build/bsps/powerpc/qoriq/optfdtro.yml:1
error: spec/build/bsps/powerpc/qoriq/optfdtro.yml: patch does not apply
error: patch failed: spec/build/bsps/riscv/riscv/optfdtcpyro.yml:1
error: spec/build/bsps/riscv/riscv/optfdtcpyro.yml: patch does not apply
error: patch failed: spec/build/bsps/riscv/riscv/optfdtmxsz.yml:1
error: spec/build/bsps/riscv/riscv/optfdtmxsz.yml: patch does not apply
error: patch failed: spec/build/bsps/riscv/riscv/optfdtro.yml:1
error: spec/build/bsps/riscv/riscv/optfdtro.yml: patch does not apply
error: patch failed: spec/build/bsps/riscv/riscv/optfdtuboot.yml:1
error: spec/build/bsps/riscv/riscv/optfdtuboot.yml: patch does not apply
Patch failed at 0001 bsps: Move optfdt* files to shared parent directory
The copy of the patch that failed is found in:
   /home/joel/rtems-work/rtems/.git/rebase-apply/patch
> > On Fri, Jul 16, 2021 at 9:51 AM pranav <dangipranav at gmail.com> wrote:
> > >  .../arm/altera-cyclone-v/bspalteracyclonev.yml  |  8 ++++----
> > >  spec/build/bsps/arm/beagle/grp.yml              |  8 ++++----
> > >  spec/build/bsps/arm/beagle/optfdtcpyro.yml      | 16 ----------------
> > >  spec/build/bsps/arm/beagle/optfdtmxsz.yml       | 17 -----------------
> > >  spec/build/bsps/arm/beagle/optfdtro.yml         | 16 ----------------
> > >  spec/build/bsps/arm/beagle/optfdtuboot.yml      | 16 ----------------
> > >  spec/build/bsps/arm/imx/bspimx.yml              |  8 ++++----
> > >  spec/build/bsps/arm/imx/optfdtcpyro.yml         | 16 ----------------
> > >  spec/build/bsps/arm/imx/optfdtmxsz.yml          | 17 -----------------
> > >  spec/build/bsps/arm/imx/optfdtro.yml            | 16 ----------------
> > >  spec/build/bsps/arm/imx/optfdtuboot.yml         | 16 ----------------
> > >  spec/build/bsps/arm/raspberrypi/grp.yml         |  8 ++++++++
> > >  .../{arm/altera-cyclone-v => }/optfdtcpyro.yml  |  0
> > >  .../{arm/altera-cyclone-v => }/optfdtmxsz.yml   |  0
> > >  .../{arm/altera-cyclone-v => }/optfdtro.yml     |  0
> > >  .../{arm/altera-cyclone-v => }/optfdtuboot.yml  |  0
> > >  spec/build/bsps/powerpc/qoriq/grp.yml           |  4 ++--
> > >  spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml    | 17 -----------------
> > >  spec/build/bsps/powerpc/qoriq/optfdtro.yml      | 16 ----------------
> > >  spec/build/bsps/riscv/riscv/grp.yml             |  8 ++++----
> > >  spec/build/bsps/riscv/riscv/optfdtcpyro.yml     | 16 ----------------
> > >  spec/build/bsps/riscv/riscv/optfdtmxsz.yml      | 17 -----------------
> > >  spec/build/bsps/riscv/riscv/optfdtro.yml        | 16 ----------------
> > >  spec/build/bsps/riscv/riscv/optfdtuboot.yml     | 16 ----------------
> > >  24 files changed, 26 insertions(+), 246 deletions(-)
> > >  delete mode 100644 spec/build/bsps/arm/beagle/optfdtcpyro.yml
> > >  delete mode 100644 spec/build/bsps/arm/beagle/optfdtmxsz.yml
> > >  delete mode 100644 spec/build/bsps/arm/beagle/optfdtro.yml
> > >  delete mode 100644 spec/build/bsps/arm/beagle/optfdtuboot.yml
> > >  delete mode 100644 spec/build/bsps/arm/imx/optfdtcpyro.yml
> > >  delete mode 100644 spec/build/bsps/arm/imx/optfdtmxsz.yml
> > >  delete mode 100644 spec/build/bsps/arm/imx/optfdtro.yml
> > >  delete mode 100644 spec/build/bsps/arm/imx/optfdtuboot.yml
> > >  rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtcpyro.yml (100%)
> > >  rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtmxsz.yml (100%)
> > >  rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtro.yml (100%)
> > >  rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtuboot.yml (100%)
> > >  delete mode 100644 spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml
> > >  delete mode 100644 spec/build/bsps/powerpc/qoriq/optfdtro.yml
> > >  delete mode 100644 spec/build/bsps/riscv/riscv/optfdtcpyro.yml
> > >  delete mode 100644 spec/build/bsps/riscv/riscv/optfdtmxsz.yml
> > >  delete mode 100644 spec/build/bsps/riscv/riscv/optfdtro.yml
> > >  delete mode 100644 spec/build/bsps/riscv/riscv/optfdtuboot.yml
> > > diff --git a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
> > > index da567ddd79..a9f3f7dabf 100644
> > > --- a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
> > > +++ b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
> > > @@ -73,15 +73,15 @@ links:
> > >  - role: build-dependency
> > >    uid: optconuart1
> > > -  uid: optfdtcpyro
> > > +  uid: ../../optfdtcpyro
> > >    uid: optfdten
> > > -  uid: optfdtmxsz
> > > +  uid: ../../optfdtmxsz
> > > -  uid: optfdtro
> > > +  uid: ../../optfdtro
> > > -  uid: optfdtuboot
> > > +  uid: ../../optfdtuboot
> > >    uid: opti2cspeed
> > > diff --git a/spec/build/bsps/arm/beagle/grp.yml b/spec/build/bsps/arm/beagle/grp.yml
> > > index 1375913fd0..3452c3e5c8 100644
> > > --- a/spec/build/bsps/arm/beagle/grp.yml
> > > +++ b/spec/build/bsps/arm/beagle/grp.yml
> > > @@ -22,13 +22,13 @@ links:
> > >    uid: optdm3730
> > > -  uid: optfdtcpyro
> > > -  uid: optfdtmxsz
> > > -  uid: optfdtro
> > > -  uid: optfdtuboot
> > >    uid: ../grp
> > > diff --git a/spec/build/bsps/arm/beagle/optfdtcpyro.yml b/spec/build/bsps/arm/beagle/optfdtcpyro.yml
> > > deleted file mode 100644
> > > index 5ec59adf4d..0000000000
> > > --- a/spec/build/bsps/arm/beagle/optfdtcpyro.yml
> > > +++ /dev/null
> > > @@ -1,16 +0,0 @@
> > > -SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> > > -actions:
> > > -- get-boolean: null
> > > -- define-condition: null
> > > -build-type: option
> > > -copyrights:
> > > -- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
> > > -default: true
> > > -default-by-family: []
> > > -default-by-variant: []
> > > -description: |
> > > -  copy the FDT blob into the read-only load area via bsp_fdt_copy()
> > > -enabled-by: true
> > > -links: []
> > > -name: BSP_FDT_BLOB_COPY_TO_READ_ONLY_LOAD_AREA
> > > -type: build
> > > diff --git a/spec/build/bsps/arm/beagle/optfdtmxsz.yml b/spec/build/bsps/arm/beagle/optfdtmxsz.yml
> > > index f3b2504e02..0000000000
> > > --- a/spec/build/bsps/arm/beagle/optfdtmxsz.yml
> > > +++ /dev/null
> > > @@ -1,17 +0,0 @@
> > > -actions:
> > > -- get-integer: null
> > > -- define: null
> > > -build-type: option
> > > -copyrights:
> > > -default: 262144
> > > -description: |
> > > -  maximum size of the FDT blob in bytes
> > > -enabled-by: true
> > > -format: '{}'
> > > -links: []
> > > -name: BSP_FDT_BLOB_SIZE_MAX
> > > -type: build
> > > diff --git a/spec/build/bsps/arm/beagle/optfdtro.yml b/spec/build/bsps/arm/beagle/optfdtro.yml
> > > index a72bc23c0e..0000000000
> > > --- a/spec/build/bsps/arm/beagle/optfdtro.yml
> > > +++ /dev/null
> > > @@ -1,16 +0,0 @@
> > > -actions:
> > > -build-type: option
> > > -copyrights:
> > > -default: true
> > > -description: |
> > > -  place the FDT blob into the read-only data area
> > > -enabled-by: true
> > > -links: []
> > > -name: BSP_FDT_BLOB_READ_ONLY
> > > -type: build
> > > diff --git a/spec/build/bsps/arm/beagle/optfdtuboot.yml b/spec/build/bsps/arm/beagle/optfdtuboot.yml
> > > index cfe94e577c..0000000000
> > > --- a/spec/build/bsps/arm/beagle/optfdtuboot.yml
> > > +++ /dev/null
> > > @@ -1,16 +0,0 @@
> > > -actions:
> > > -build-type: option
> > > -copyrights:
> > > -default: true
> > > -description: |
> > > -  copy the U-Boot provided FDT to an internal storage
> > > -enabled-by: true
> > > -links: []
> > > -name: BSP_START_COPY_FDT_FROM_U_BOOT
> > > -type: build
> > > diff --git a/spec/build/bsps/arm/imx/bspimx.yml b/spec/build/bsps/arm/imx/bspimx.yml
> > > index c65e02db2b..14719745f0 100644
> > > --- a/spec/build/bsps/arm/imx/bspimx.yml
> > > +++ b/spec/build/bsps/arm/imx/bspimx.yml
> > > @@ -61,13 +61,13 @@ links:
> > >    uid: optconirq
> > > -  uid: optfdtcpyro
> > > -  uid: optfdtmxsz
> > > -  uid: optfdtro
> > > -  uid: optfdtuboot
> > >    uid: optresetvec
> > > diff --git a/spec/build/bsps/arm/imx/optfdtcpyro.yml b/spec/build/bsps/arm/imx/optfdtcpyro.yml
> > > --- a/spec/build/bsps/arm/imx/optfdtcpyro.yml
> > > +++ /dev/null
> > > @@ -1,16 +0,0 @@
> > > -actions:
> > > -build-type: option
> > > -copyrights:
> > > -default: true
> > > -description: |
> > > -enabled-by: true
> > > -links: []
> > > -type: build
> > > diff --git a/spec/build/bsps/arm/imx/optfdtmxsz.yml b/spec/build/bsps/arm/imx/optfdtmxsz.yml
> > > --- a/spec/build/bsps/arm/imx/optfdtmxsz.yml
> > > +++ /dev/null
> > > @@ -1,17 +0,0 @@
> > > -actions:
> > > -- define: null
> > > -build-type: option
> > > -copyrights:
> > > -default: 262144
> > > -description: |
> > > -enabled-by: true
> > > -format: '{}'
> > > -links: []
> > > -type: build
> > > diff --git a/spec/build/bsps/arm/imx/optfdtro.yml b/spec/build/bsps/arm/imx/optfdtro.yml
> > > --- a/spec/build/bsps/arm/imx/optfdtro.yml
> > > +++ /dev/null
> > > @@ -1,16 +0,0 @@
> > > -actions:
> > > -build-type: option
> > > -copyrights:
> > > -default: true
> > > -description: |
> > > -enabled-by: true
> > > -links: []
> > > -type: build
> > > diff --git a/spec/build/bsps/arm/imx/optfdtuboot.yml b/spec/build/bsps/arm/imx/optfdtuboot.yml
> > > --- a/spec/build/bsps/arm/imx/optfdtuboot.yml
> > > +++ /dev/null
> > > @@ -1,16 +0,0 @@
> > > -actions:
> > > -build-type: option
> > > -copyrights:
> > > -default: true
> > > -description: |
> > > -enabled-by: true
> > > -links: []
> > > -type: build
> > > diff --git a/spec/build/bsps/arm/raspberrypi/grp.yml b/spec/build/bsps/arm/raspberrypi/grp.yml
> > > index 7291e8b178..94627a9526 100644
> > > --- a/spec/build/bsps/arm/raspberrypi/grp.yml
> > > +++ b/spec/build/bsps/arm/raspberrypi/grp.yml
> > > @@ -41,6 +41,14 @@ links:
> > >    uid: linkcmds
> > >    uid: ../../bspopts
> > > +- role: build-dependency
> > >  type: build
> > >  use-after: []
> > >  use-before: []
> > > diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtcpyro.yml b/spec/build/bsps/optfdtcpyro.yml
> > > similarity index 100%
> > > rename from spec/build/bsps/arm/altera-cyclone-v/optfdtcpyro.yml
> > > rename to spec/build/bsps/optfdtcpyro.yml
> > > diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtmxsz.yml b/spec/build/bsps/optfdtmxsz.yml
> > > rename from spec/build/bsps/arm/altera-cyclone-v/optfdtmxsz.yml
> > > rename to spec/build/bsps/optfdtmxsz.yml
> > > diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtro.yml b/spec/build/bsps/optfdtro.yml
> > > rename from spec/build/bsps/arm/altera-cyclone-v/optfdtro.yml
> > > rename to spec/build/bsps/optfdtro.yml
> > > diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtuboot.yml b/spec/build/bsps/optfdtuboot.yml
> > > rename from spec/build/bsps/arm/altera-cyclone-v/optfdtuboot.yml
> > > rename to spec/build/bsps/optfdtuboot.yml
> > > diff --git a/spec/build/bsps/powerpc/qoriq/grp.yml b/spec/build/bsps/powerpc/qoriq/grp.yml
> > > index 3e295cb599..08533ded6f 100644
> > > --- a/spec/build/bsps/powerpc/qoriq/grp.yml
> > > +++ b/spec/build/bsps/powerpc/qoriq/grp.yml
> > > @@ -68,9 +68,9 @@ links:
> > >    uid: optexcfixdhdlr
> > > -  uid: optfdtmxsz
> > > -  uid: optfdtro
> > >    uid: opthid0
> > > diff --git a/spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml b/spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml
> > > --- a/spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml
> > > +++ /dev/null
> > > @@ -1,17 +0,0 @@
> > > -actions:
> > > -- define: null
> > > -build-type: option
> > > -copyrights:
> > > -default: 262144
> > > -description: |
> > > -enabled-by: true
> > > -format: '{}'
> > > -links: []
> > > -type: build
> > > diff --git a/spec/build/bsps/powerpc/qoriq/optfdtro.yml b/spec/build/bsps/powerpc/qoriq/optfdtro.yml
> > > --- a/spec/build/bsps/powerpc/qoriq/optfdtro.yml
> > > +++ /dev/null
> > > @@ -1,16 +0,0 @@
> > > -actions:
> > > -build-type: option
> > > -copyrights:
> > > -default: true
> > > -description: |
> > > -enabled-by: true
> > > -links: []
> > > -type: build
> > > diff --git a/spec/build/bsps/riscv/riscv/grp.yml b/spec/build/bsps/riscv/riscv/grp.yml
> > > index 396f8986ec..77583d351e 100644
> > > --- a/spec/build/bsps/riscv/riscv/grp.yml
> > > +++ b/spec/build/bsps/riscv/riscv/grp.yml
> > > @@ -32,13 +32,13 @@ links:
> > >    uid: optextirqmax
> > > -  uid: optfdtcpyro
> > > -  uid: optfdtmxsz
> > > -  uid: optfdtro
> > > -  uid: optfdtuboot
> > >    uid: optfrdme310arty
> > > diff --git a/spec/build/bsps/riscv/riscv/optfdtcpyro.yml b/spec/build/bsps/riscv/riscv/optfdtcpyro.yml
> > > --- a/spec/build/bsps/riscv/riscv/optfdtcpyro.yml
> > > +++ /dev/null
> > > @@ -1,16 +0,0 @@
> > > -actions:
> > > -build-type: option
> > > -copyrights:
> > > -default: true
> > > -description: |
> > > -enabled-by: true
> > > -links: []
> > > -type: build
> > > diff --git a/spec/build/bsps/riscv/riscv/optfdtmxsz.yml b/spec/build/bsps/riscv/riscv/optfdtmxsz.yml
> > > index 8a07a2ad08..0000000000
> > > --- a/spec/build/bsps/riscv/riscv/optfdtmxsz.yml
> > > +++ /dev/null
> > > @@ -1,17 +0,0 @@
> > > -actions:
> > > -- define: null
> > > -build-type: option
> > > -copyrights:
> > > -default: 65536
> > > -description: |
> > > -enabled-by: true
> > > -format: '{}'
> > > -links: []
> > > -type: build
> > > diff --git a/spec/build/bsps/riscv/riscv/optfdtro.yml b/spec/build/bsps/riscv/riscv/optfdtro.yml
> > > --- a/spec/build/bsps/riscv/riscv/optfdtro.yml
> > > +++ /dev/null
> > > @@ -1,16 +0,0 @@
> > > -actions:
> > > -build-type: option
> > > -copyrights:
> > > -default: true
> > > -description: |
> > > -enabled-by: true
> > > -links: []
> > > -type: build
> > > diff --git a/spec/build/bsps/riscv/riscv/optfdtuboot.yml b/spec/build/bsps/riscv/riscv/optfdtuboot.yml
> > > --- a/spec/build/bsps/riscv/riscv/optfdtuboot.yml
> > > +++ /dev/null
> > > @@ -1,16 +0,0 @@
> > > -actions:
> > > -build-type: option
> > > -copyrights:
> > > -default: true
> > > -description: |
> > > -enabled-by: true
> > > -links: []
> > > -type: build
> > > 2.30.2
> > > _______________________________________________
> > > devel mailing list
> > > devel at rtems.org
> > > http://lists.rtems.org/mailman/listinfo/devel
> > devel mailing list
> > devel at rtems.org
