[PATCH v4] bsps: Move optfdt* files to shared parent directory
Joel Sherrill
joel at rtems.org
Mon Aug 9 17:37:36 UTC 2021
On Mon, Aug 9, 2021, 10:14 AM Pranav Dangi <dangipranav at gmail.com> wrote:
> Hi joel,
> I had sent you a rebased patch as a direct attachment, I will ping that
> thread once again. Did that fail too?
I just pushed a patch you sent me directly. Is it ok on master now?
--joel
> Thanks,
> pranav
> On Mon, 9 Aug 2021, 20:40 Joel Sherrill, <joel at rtems.org> wrote:
>> On Mon, Aug 9, 2021 at 10:00 AM Gedare Bloom <gedare at rtems.org> wrote:
>> > Hi Joel,
>> > On Fri, Jul 16, 2021 at 10:40 AM Joel Sherrill <joel at rtems.org> wrote:
>> > > I'm doing a build sweep of all BSPs. When that completes, I plan to
>> > > push this unless there are comments.
>> > Did/can you push this?
>> It doesn't apply for me. Could be a rebase is needed or it didn't survive
>> the email client. If it's just an email issue, just send it to me
>> directly as an
>> attachment possibly compressed to avoid any chance of email clients
>> getting smart.
>> Applying: bsps: Move optfdt* files to shared parent directory
>> error: patch failed: spec/build/bsps/arm/beagle/optfdtcpyro.yml:1
>> error: spec/build/bsps/arm/beagle/optfdtcpyro.yml: patch does not apply
>> error: patch failed: spec/build/bsps/arm/beagle/optfdtmxsz.yml:1
>> error: spec/build/bsps/arm/beagle/optfdtmxsz.yml: patch does not apply
>> error: patch failed: spec/build/bsps/arm/beagle/optfdtro.yml:1
>> error: spec/build/bsps/arm/beagle/optfdtro.yml: patch does not apply
>> error: patch failed: spec/build/bsps/arm/beagle/optfdtuboot.yml:1
>> error: spec/build/bsps/arm/beagle/optfdtuboot.yml: patch does not apply
>> error: patch failed: spec/build/bsps/arm/imx/optfdtcpyro.yml:1
>> error: spec/build/bsps/arm/imx/optfdtcpyro.yml: patch does not apply
>> error: patch failed: spec/build/bsps/arm/imx/optfdtmxsz.yml:1
>> error: spec/build/bsps/arm/imx/optfdtmxsz.yml: patch does not apply
>> error: patch failed: spec/build/bsps/arm/imx/optfdtro.yml:1
>> error: spec/build/bsps/arm/imx/optfdtro.yml: patch does not apply
>> error: patch failed: spec/build/bsps/arm/imx/optfdtuboot.yml:1
>> error: spec/build/bsps/arm/imx/optfdtuboot.yml: patch does not apply
>> error: patch failed: spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml:1
>> error: spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml: patch does not apply
>> error: patch failed: spec/build/bsps/powerpc/qoriq/optfdtro.yml:1
>> error: spec/build/bsps/powerpc/qoriq/optfdtro.yml: patch does not apply
>> error: patch failed: spec/build/bsps/riscv/riscv/optfdtcpyro.yml:1
>> error: spec/build/bsps/riscv/riscv/optfdtcpyro.yml: patch does not apply
>> error: patch failed: spec/build/bsps/riscv/riscv/optfdtmxsz.yml:1
>> error: spec/build/bsps/riscv/riscv/optfdtmxsz.yml: patch does not apply
>> error: patch failed: spec/build/bsps/riscv/riscv/optfdtro.yml:1
>> error: spec/build/bsps/riscv/riscv/optfdtro.yml: patch does not apply
>> error: patch failed: spec/build/bsps/riscv/riscv/optfdtuboot.yml:1
>> error: spec/build/bsps/riscv/riscv/optfdtuboot.yml: patch does not apply
>> Patch failed at 0001 bsps: Move optfdt* files to shared parent directory
>> The copy of the patch that failed is found in:
>> /home/joel/rtems-work/rtems/.git/rebase-apply/patch
>> > > On Fri, Jul 16, 2021 at 9:51 AM pranav <dangipranav at gmail.com> wrote:
>> > > > .../arm/altera-cyclone-v/bspalteracyclonev.yml | 8 ++++----
>> > > > spec/build/bsps/arm/beagle/grp.yml | 8 ++++----
>> > > > spec/build/bsps/arm/beagle/optfdtcpyro.yml | 16
>> > > > spec/build/bsps/arm/beagle/optfdtmxsz.yml | 17
>> > > > spec/build/bsps/arm/beagle/optfdtro.yml | 16
>> > > > spec/build/bsps/arm/beagle/optfdtuboot.yml | 16
>> > > > spec/build/bsps/arm/imx/bspimx.yml | 8 ++++----
>> > > > spec/build/bsps/arm/imx/optfdtcpyro.yml | 16
>> > > > spec/build/bsps/arm/imx/optfdtmxsz.yml | 17
>> > > > spec/build/bsps/arm/imx/optfdtro.yml | 16
>> > > > spec/build/bsps/arm/imx/optfdtuboot.yml | 16
>> > > > spec/build/bsps/arm/raspberrypi/grp.yml | 8 ++++++++
>> > > > .../{arm/altera-cyclone-v => }/optfdtcpyro.yml | 0
>> > > > .../{arm/altera-cyclone-v => }/optfdtmxsz.yml | 0
>> > > > .../{arm/altera-cyclone-v => }/optfdtro.yml | 0
>> > > > .../{arm/altera-cyclone-v => }/optfdtuboot.yml | 0
>> > > > spec/build/bsps/powerpc/qoriq/grp.yml | 4 ++--
>> > > > spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml | 17
>> > > > spec/build/bsps/powerpc/qoriq/optfdtro.yml | 16
>> > > > spec/build/bsps/riscv/riscv/grp.yml | 8 ++++----
>> > > > spec/build/bsps/riscv/riscv/optfdtcpyro.yml | 16
>> > > > spec/build/bsps/riscv/riscv/optfdtmxsz.yml | 17
>> > > > spec/build/bsps/riscv/riscv/optfdtro.yml | 16
>> > > > spec/build/bsps/riscv/riscv/optfdtuboot.yml | 16
>> > > > 24 files changed, 26 insertions(+), 246 deletions(-)
>> > > > delete mode 100644 spec/build/bsps/arm/beagle/optfdtcpyro.yml
>> > > > delete mode 100644 spec/build/bsps/arm/beagle/optfdtmxsz.yml
>> > > > delete mode 100644 spec/build/bsps/arm/beagle/optfdtro.yml
>> > > > delete mode 100644 spec/build/bsps/arm/beagle/optfdtuboot.yml
>> > > > delete mode 100644 spec/build/bsps/arm/imx/optfdtcpyro.yml
>> > > > delete mode 100644 spec/build/bsps/arm/imx/optfdtmxsz.yml
>> > > > delete mode 100644 spec/build/bsps/arm/imx/optfdtro.yml
>> > > > delete mode 100644 spec/build/bsps/arm/imx/optfdtuboot.yml
>> > > > rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtcpyro.yml
>> (100%)
>> > > > rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtmxsz.yml
>> (100%)
>> > > > rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtro.yml
>> (100%)
>> > > > rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtuboot.yml
>> (100%)
>> > > > delete mode 100644 spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml
>> > > > delete mode 100644 spec/build/bsps/powerpc/qoriq/optfdtro.yml
>> > > > delete mode 100644 spec/build/bsps/riscv/riscv/optfdtcpyro.yml
>> > > > delete mode 100644 spec/build/bsps/riscv/riscv/optfdtmxsz.yml
>> > > > delete mode 100644 spec/build/bsps/riscv/riscv/optfdtro.yml
>> > > > delete mode 100644 spec/build/bsps/riscv/riscv/optfdtuboot.yml
>> > > > diff --git
>> a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
>> b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
>> > > > index da567ddd79..a9f3f7dabf 100644
>> > > > --- a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
>> > > > +++ b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
>> > > > @@ -73,15 +73,15 @@ links:
>> > > > - role: build-dependency
>> > > > uid: optconuart1
>> > > > - uid: optfdtcpyro
>> > > > + uid: ../../optfdtcpyro
>> > > > uid: optfdten
>> > > > - uid: optfdtmxsz
>> > > > + uid: ../../optfdtmxsz
>> > > > - uid: optfdtro
>> > > > + uid: ../../optfdtro
>> > > > - uid: optfdtuboot
>> > > > + uid: ../../optfdtuboot
>> > > > uid: opti2cspeed
>> > > > diff --git a/spec/build/bsps/arm/beagle/grp.yml
>> b/spec/build/bsps/arm/beagle/grp.yml
>> > > > index 1375913fd0..3452c3e5c8 100644
>> > > > --- a/spec/build/bsps/arm/beagle/grp.yml
>> > > > +++ b/spec/build/bsps/arm/beagle/grp.yml
>> > > > @@ -22,13 +22,13 @@ links:
>> > > > uid: optdm3730
>> > > > - uid: optfdtcpyro
>> > > > - uid: optfdtmxsz
>> > > > - uid: optfdtro
>> > > > - uid: optfdtuboot
>> > > > uid: ../grp
>> > > > diff --git a/spec/build/bsps/arm/beagle/optfdtcpyro.yml
>> b/spec/build/bsps/arm/beagle/optfdtcpyro.yml
>> > > > deleted file mode 100644
>> > > > index 5ec59adf4d..0000000000
>> > > > --- a/spec/build/bsps/arm/beagle/optfdtcpyro.yml
>> > > > +++ /dev/null
>> > > > @@ -1,16 +0,0 @@
>> > > > -SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
>> > > > -actions:
>> > > > -- get-boolean: null
>> > > > -- define-condition: null
>> > > > -build-type: option
>> > > > -copyrights:
>> > > > -- Copyright (C) 2020 embedded brains GmbH (
>> http://www.embedded-brains.de)
>> > > > -default: true
>> > > > -default-by-family: []
>> > > > -default-by-variant: []
>> > > > -description: |
>> > > > - copy the FDT blob into the read-only load area via bsp_fdt_copy()
>> > > > -enabled-by: true
>> > > > -links: []
>> > > > -name: BSP_FDT_BLOB_COPY_TO_READ_ONLY_LOAD_AREA
>> > > > -type: build
>> > > > diff --git a/spec/build/bsps/arm/beagle/optfdtmxsz.yml
>> b/spec/build/bsps/arm/beagle/optfdtmxsz.yml
>> > > > index f3b2504e02..0000000000
>> > > > --- a/spec/build/bsps/arm/beagle/optfdtmxsz.yml
>> > > > +++ /dev/null
>> > > > @@ -1,17 +0,0 @@
>> > > > -actions:
>> > > > -- get-integer: null
>> > > > -- define: null
>> > > > -build-type: option
>> > > > -copyrights:
>> > > > -default: 262144
>> > > > -description: |
>> > > > - maximum size of the FDT blob in bytes
>> > > > -enabled-by: true
>> > > > -format: '{}'
>> > > > -links: []
>> > > > -name: BSP_FDT_BLOB_SIZE_MAX
>> > > > -type: build
>> > > > diff --git a/spec/build/bsps/arm/beagle/optfdtro.yml
>> b/spec/build/bsps/arm/beagle/optfdtro.yml
>> > > > index a72bc23c0e..0000000000
>> > > > --- a/spec/build/bsps/arm/beagle/optfdtro.yml
>> > > > +++ /dev/null
>> > > > @@ -1,16 +0,0 @@
>> > > > -actions:
>> > > > -build-type: option
>> > > > -copyrights:
>> > > > -default: true
>> > > > -description: |
>> > > > - place the FDT blob into the read-only data area
>> > > > -enabled-by: true
>> > > > -links: []
>> > > > -name: BSP_FDT_BLOB_READ_ONLY
>> > > > -type: build
>> > > > diff --git a/spec/build/bsps/arm/beagle/optfdtuboot.yml
>> b/spec/build/bsps/arm/beagle/optfdtuboot.yml
>> > > > index cfe94e577c..0000000000
>> > > > --- a/spec/build/bsps/arm/beagle/optfdtuboot.yml
>> > > > +++ /dev/null
>> > > > @@ -1,16 +0,0 @@
>> > > > -actions:
>> > > > -build-type: option
>> > > > -copyrights:
>> > > > -default: true
>> > > > -description: |
>> > > > - copy the U-Boot provided FDT to an internal storage
>> > > > -enabled-by: true
>> > > > -links: []
>> > > > -name: BSP_START_COPY_FDT_FROM_U_BOOT
>> > > > -type: build
>> > > > diff --git a/spec/build/bsps/arm/imx/bspimx.yml
>> b/spec/build/bsps/arm/imx/bspimx.yml
>> > > > index c65e02db2b..14719745f0 100644
>> > > > --- a/spec/build/bsps/arm/imx/bspimx.yml
>> > > > +++ b/spec/build/bsps/arm/imx/bspimx.yml
>> > > > @@ -61,13 +61,13 @@ links:
>> > > > uid: optconirq
>> > > > - uid: optfdtcpyro
>> > > > - uid: optfdtmxsz
>> > > > - uid: optfdtro
>> > > > - uid: optfdtuboot
>> > > > uid: optresetvec
>> > > > diff --git a/spec/build/bsps/arm/imx/optfdtcpyro.yml
>> b/spec/build/bsps/arm/imx/optfdtcpyro.yml
>> > > > --- a/spec/build/bsps/arm/imx/optfdtcpyro.yml
>> > > > +++ /dev/null
>> > > > @@ -1,16 +0,0 @@
>> > > > -actions:
>> > > > -build-type: option
>> > > > -copyrights:
>> > > > -default: true
>> > > > -description: |
>> > > > -enabled-by: true
>> > > > -links: []
>> > > > -type: build
>> > > > diff --git a/spec/build/bsps/arm/imx/optfdtmxsz.yml
>> b/spec/build/bsps/arm/imx/optfdtmxsz.yml
>> > > > --- a/spec/build/bsps/arm/imx/optfdtmxsz.yml
>> > > > +++ /dev/null
>> > > > @@ -1,17 +0,0 @@
>> > > > -actions:
>> > > > -- define: null
>> > > > -build-type: option
>> > > > -copyrights:
>> > > > -default: 262144
>> > > > -description: |
>> > > > -enabled-by: true
>> > > > -format: '{}'
>> > > > -links: []
>> > > > -type: build
>> > > > diff --git a/spec/build/bsps/arm/imx/optfdtro.yml
>> b/spec/build/bsps/arm/imx/optfdtro.yml
>> > > > --- a/spec/build/bsps/arm/imx/optfdtro.yml
>> > > > +++ /dev/null
>> > > > @@ -1,16 +0,0 @@
>> > > > -actions:
>> > > > -build-type: option
>> > > > -copyrights:
>> > > > -default: true
>> > > > -description: |
>> > > > -enabled-by: true
>> > > > -links: []
>> > > > -type: build
>> > > > diff --git a/spec/build/bsps/arm/imx/optfdtuboot.yml
>> b/spec/build/bsps/arm/imx/optfdtuboot.yml
>> > > > --- a/spec/build/bsps/arm/imx/optfdtuboot.yml
>> > > > +++ /dev/null
>> > > > @@ -1,16 +0,0 @@
>> > > > -actions:
>> > > > -build-type: option
>> > > > -copyrights:
>> > > > -default: true
>> > > > -description: |
>> > > > -enabled-by: true
>> > > > -links: []
>> > > > -type: build
>> > > > diff --git a/spec/build/bsps/arm/raspberrypi/grp.yml
>> b/spec/build/bsps/arm/raspberrypi/grp.yml
>> > > > index 7291e8b178..94627a9526 100644
>> > > > --- a/spec/build/bsps/arm/raspberrypi/grp.yml
>> > > > +++ b/spec/build/bsps/arm/raspberrypi/grp.yml
>> > > > @@ -41,6 +41,14 @@ links:
>> > > > uid: linkcmds
>> > > > uid: ../../bspopts
>> > > > +- role: build-dependency
>> > > > type: build
>> > > > use-after: []
>> > > > use-before: []
>> > > > diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtcpyro.yml
>> b/spec/build/bsps/optfdtcpyro.yml
>> > > > similarity index 100%
>> > > > rename from spec/build/bsps/arm/altera-cyclone-v/optfdtcpyro.yml
>> > > > rename to spec/build/bsps/optfdtcpyro.yml
>> > > > diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtmxsz.yml
>> b/spec/build/bsps/optfdtmxsz.yml
>> > > > rename from spec/build/bsps/arm/altera-cyclone-v/optfdtmxsz.yml
>> > > > rename to spec/build/bsps/optfdtmxsz.yml
>> > > > diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtro.yml
>> b/spec/build/bsps/optfdtro.yml
>> > > > rename from spec/build/bsps/arm/altera-cyclone-v/optfdtro.yml
>> > > > rename to spec/build/bsps/optfdtro.yml
>> > > > diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtuboot.yml
>> b/spec/build/bsps/optfdtuboot.yml
>> > > > rename from spec/build/bsps/arm/altera-cyclone-v/optfdtuboot.yml
>> > > > rename to spec/build/bsps/optfdtuboot.yml
>> > > > diff --git a/spec/build/bsps/powerpc/qoriq/grp.yml
>> b/spec/build/bsps/powerpc/qoriq/grp.yml
>> > > > index 3e295cb599..08533ded6f 100644
>> > > > --- a/spec/build/bsps/powerpc/qoriq/grp.yml
>> > > > +++ b/spec/build/bsps/powerpc/qoriq/grp.yml
>> > > > @@ -68,9 +68,9 @@ links:
>> > > > uid: optexcfixdhdlr
>> > > > - uid: optfdtmxsz
>> > > > - uid: optfdtro
>> > > > uid: opthid0
>> > > > diff --git a/spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml
>> b/spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml
>> > > > --- a/spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml
>> > > > +++ /dev/null
>> > > > @@ -1,17 +0,0 @@
>> > > > -actions:
>> > > > -- define: null
>> > > > -build-type: option
>> > > > -copyrights:
>> > > > -default: 262144
>> > > > -description: |
>> > > > -enabled-by: true
>> > > > -format: '{}'
>> > > > -links: []
>> > > > -type: build
>> > > > diff --git a/spec/build/bsps/powerpc/qoriq/optfdtro.yml
>> b/spec/build/bsps/powerpc/qoriq/optfdtro.yml
>> > > > --- a/spec/build/bsps/powerpc/qoriq/optfdtro.yml
>> > > > +++ /dev/null
>> > > > @@ -1,16 +0,0 @@
>> > > > -actions:
>> > > > -build-type: option
>> > > > -copyrights:
>> > > > -default: true
>> > > > -description: |
>> > > > -enabled-by: true
>> > > > -links: []
>> > > > -type: build
>> > > > diff --git a/spec/build/bsps/riscv/riscv/grp.yml
>> b/spec/build/bsps/riscv/riscv/grp.yml
>> > > > index 396f8986ec..77583d351e 100644
>> > > > --- a/spec/build/bsps/riscv/riscv/grp.yml
>> > > > +++ b/spec/build/bsps/riscv/riscv/grp.yml
>> > > > @@ -32,13 +32,13 @@ links:
>> > > > uid: optextirqmax
>> > > > - uid: optfdtcpyro
>> > > > - uid: optfdtmxsz
>> > > > - uid: optfdtro
>> > > > - uid: optfdtuboot
>> > > > uid: optfrdme310arty
>> > > > diff --git a/spec/build/bsps/riscv/riscv/optfdtcpyro.yml
>> b/spec/build/bsps/riscv/riscv/optfdtcpyro.yml
>> > > > --- a/spec/build/bsps/riscv/riscv/optfdtcpyro.yml
>> > > > +++ /dev/null
>> > > > @@ -1,16 +0,0 @@
>> > > > -actions:
>> > > > -build-type: option
>> > > > -copyrights:
>> > > > -default: true
>> > > > -description: |
>> > > > -enabled-by: true
>> > > > -links: []
>> > > > -type: build
>> > > > diff --git a/spec/build/bsps/riscv/riscv/optfdtmxsz.yml
>> b/spec/build/bsps/riscv/riscv/optfdtmxsz.yml
>> > > > index 8a07a2ad08..0000000000
>> > > > --- a/spec/build/bsps/riscv/riscv/optfdtmxsz.yml
>> > > > +++ /dev/null
>> > > > @@ -1,17 +0,0 @@
>> > > > -actions:
>> > > > -- define: null
>> > > > -build-type: option
>> > > > -copyrights:
>> > > > -default: 65536
>> > > > -description: |
>> > > > -enabled-by: true
>> > > > -format: '{}'
>> > > > -links: []
>> > > > -type: build
>> > > > diff --git a/spec/build/bsps/riscv/riscv/optfdtro.yml
>> b/spec/build/bsps/riscv/riscv/optfdtro.yml
>> > > > --- a/spec/build/bsps/riscv/riscv/optfdtro.yml
>> > > > +++ /dev/null
>> > > > @@ -1,16 +0,0 @@
>> > > > -actions:
>> > > > -build-type: option
>> > > > -copyrights:
>> > > > -default: true
>> > > > -description: |
>> > > > -enabled-by: true
>> > > > -links: []
>> > > > -type: build
>> > > > diff --git a/spec/build/bsps/riscv/riscv/optfdtuboot.yml
>> b/spec/build/bsps/riscv/riscv/optfdtuboot.yml
>> > > > --- a/spec/build/bsps/riscv/riscv/optfdtuboot.yml
>> > > > +++ /dev/null
>> > > > @@ -1,16 +0,0 @@
>> > > > -actions:
>> > > > -build-type: option
>> > > > -copyrights:
>> > > > -default: true
>> > > > -description: |
>> > > > -enabled-by: true
>> > > > -links: []
>> > > > -type: build
>> > > > 2.30.2
>> > > > _______________________________________________
>> > > > devel mailing list
>> > > > devel at rtems.org
>> > > > http://lists.rtems.org/mailman/listinfo/devel
>> > > devel mailing list
>> > > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210809/db0165ad/attachment-0001.html>
