[PATCH v4] bsps: Move optfdt* files to shared parent directory
Pranav Dangi dangipranav at gmail.com
Mon Aug 9 15:14:23 UTC 2021
Hi joel,
I had sent you a rebased patch as a direct attachment, I will ping that
thread once again. Did that fail too?
Thanks,
pranav
On Mon, 9 Aug 2021, 20:40 Joel Sherrill, <joel at rtems.org> wrote:
> On Mon, Aug 9, 2021 at 10:00 AM Gedare Bloom <gedare at rtems.org> wrote:
> > Hi Joel,
> > On Fri, Jul 16, 2021 at 10:40 AM Joel Sherrill <joel at rtems.org> wrote:
> > > I'm doing a build sweep of all BSPs. When that completes, I plan to
> > > push this unless there are comments.
> > Did/can you push this?
> It doesn't apply for me. Could be a rebase is needed or it didn't survive
> the email client. If it's just an email issue, just send it to me directly
> as an
> attachment possibly compressed to avoid any chance of email clients
> getting smart.
> Applying: bsps: Move optfdt* files to shared parent directory
> error: patch failed: spec/build/bsps/arm/beagle/optfdtcpyro.yml:1
> error: spec/build/bsps/arm/beagle/optfdtcpyro.yml: patch does not apply
> error: patch failed: spec/build/bsps/arm/beagle/optfdtmxsz.yml:1
> error: spec/build/bsps/arm/beagle/optfdtmxsz.yml: patch does not apply
> error: patch failed: spec/build/bsps/arm/beagle/optfdtro.yml:1
> error: spec/build/bsps/arm/beagle/optfdtro.yml: patch does not apply
> error: patch failed: spec/build/bsps/arm/beagle/optfdtuboot.yml:1
> error: spec/build/bsps/arm/beagle/optfdtuboot.yml: patch does not apply
> error: patch failed: spec/build/bsps/arm/imx/optfdtcpyro.yml:1
> error: spec/build/bsps/arm/imx/optfdtcpyro.yml: patch does not apply
> error: patch failed: spec/build/bsps/arm/imx/optfdtmxsz.yml:1
> error: spec/build/bsps/arm/imx/optfdtmxsz.yml: patch does not apply
> error: patch failed: spec/build/bsps/arm/imx/optfdtro.yml:1
> error: spec/build/bsps/arm/imx/optfdtro.yml: patch does not apply
> error: patch failed: spec/build/bsps/arm/imx/optfdtuboot.yml:1
> error: spec/build/bsps/arm/imx/optfdtuboot.yml: patch does not apply
> error: patch failed: spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml:1
> error: spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml: patch does not apply
> error: patch failed: spec/build/bsps/powerpc/qoriq/optfdtro.yml:1
> error: spec/build/bsps/powerpc/qoriq/optfdtro.yml: patch does not apply
> error: patch failed: spec/build/bsps/riscv/riscv/optfdtcpyro.yml:1
> error: spec/build/bsps/riscv/riscv/optfdtcpyro.yml: patch does not apply
> error: patch failed: spec/build/bsps/riscv/riscv/optfdtmxsz.yml:1
> error: spec/build/bsps/riscv/riscv/optfdtmxsz.yml: patch does not apply
> error: patch failed: spec/build/bsps/riscv/riscv/optfdtro.yml:1
> error: spec/build/bsps/riscv/riscv/optfdtro.yml: patch does not apply
> error: patch failed: spec/build/bsps/riscv/riscv/optfdtuboot.yml:1
> error: spec/build/bsps/riscv/riscv/optfdtuboot.yml: patch does not apply
> Patch failed at 0001 bsps: Move optfdt* files to shared parent directory
> The copy of the patch that failed is found in:
>    /home/joel/rtems-work/rtems/.git/rebase-apply/patch
> > > On Fri, Jul 16, 2021 at 9:51 AM pranav <dangipranav at gmail.com> wrote:
> > > >  .../arm/altera-cyclone-v/bspalteracyclonev.yml  |  8 ++++----
> > > >  spec/build/bsps/arm/beagle/grp.yml              |  8 ++++----
> > > >  spec/build/bsps/arm/beagle/optfdtcpyro.yml      | 16
> > > >  spec/build/bsps/arm/beagle/optfdtmxsz.yml       | 17
> > > >  spec/build/bsps/arm/beagle/optfdtro.yml         | 16
> > > >  spec/build/bsps/arm/beagle/optfdtuboot.yml      | 16
> > > >  spec/build/bsps/arm/imx/bspimx.yml              |  8 ++++----
> > > >  spec/build/bsps/arm/imx/optfdtcpyro.yml         | 16
> > > >  spec/build/bsps/arm/imx/optfdtmxsz.yml          | 17
> > > >  spec/build/bsps/arm/imx/optfdtro.yml            | 16
> > > >  spec/build/bsps/arm/imx/optfdtuboot.yml         | 16
> > > >  spec/build/bsps/arm/raspberrypi/grp.yml         |  8 ++++++++
> > > >  .../{arm/altera-cyclone-v => }/optfdtcpyro.yml  |  0
> > > >  .../{arm/altera-cyclone-v => }/optfdtmxsz.yml   |  0
> > > >  .../{arm/altera-cyclone-v => }/optfdtro.yml     |  0
> > > >  .../{arm/altera-cyclone-v => }/optfdtuboot.yml  |  0
> > > >  spec/build/bsps/powerpc/qoriq/grp.yml           |  4 ++--
> > > >  spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml    | 17
> > > >  spec/build/bsps/powerpc/qoriq/optfdtro.yml      | 16
> > > >  spec/build/bsps/riscv/riscv/grp.yml             |  8 ++++----
> > > >  spec/build/bsps/riscv/riscv/optfdtcpyro.yml     | 16
> > > >  spec/build/bsps/riscv/riscv/optfdtmxsz.yml      | 17
> > > >  spec/build/bsps/riscv/riscv/optfdtro.yml        | 16
> > > >  spec/build/bsps/riscv/riscv/optfdtuboot.yml     | 16
> > > >  24 files changed, 26 insertions(+), 246 deletions(-)
> > > >  delete mode 100644 spec/build/bsps/arm/beagle/optfdtcpyro.yml
> > > >  delete mode 100644 spec/build/bsps/arm/beagle/optfdtmxsz.yml
> > > >  delete mode 100644 spec/build/bsps/arm/beagle/optfdtro.yml
> > > >  delete mode 100644 spec/build/bsps/arm/beagle/optfdtuboot.yml
> > > >  delete mode 100644 spec/build/bsps/arm/imx/optfdtcpyro.yml
> > > >  delete mode 100644 spec/build/bsps/arm/imx/optfdtmxsz.yml
> > > >  delete mode 100644 spec/build/bsps/arm/imx/optfdtro.yml
> > > >  delete mode 100644 spec/build/bsps/arm/imx/optfdtuboot.yml
> > > >  rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtcpyro.yml
> (100%)
> > > >  rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtmxsz.yml
> (100%)
> > > >  rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtro.yml
> (100%)
> > > >  rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtuboot.yml
> (100%)
> > > >  delete mode 100644 spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml
> > > >  delete mode 100644 spec/build/bsps/powerpc/qoriq/optfdtro.yml
> > > >  delete mode 100644 spec/build/bsps/riscv/riscv/optfdtcpyro.yml
> > > >  delete mode 100644 spec/build/bsps/riscv/riscv/optfdtmxsz.yml
> > > >  delete mode 100644 spec/build/bsps/riscv/riscv/optfdtro.yml
> > > >  delete mode 100644 spec/build/bsps/riscv/riscv/optfdtuboot.yml
> > > > diff --git
> a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
> b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
> > > > index da567ddd79..a9f3f7dabf 100644
> > > > --- a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
> > > > +++ b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
> > > > @@ -73,15 +73,15 @@ links:
> > > >  - role: build-dependency
> > > >    uid: optconuart1
> > > > -  uid: optfdtcpyro
> > > > +  uid: ../../optfdtcpyro
> > > >    uid: optfdten
> > > > -  uid: optfdtmxsz
> > > > +  uid: ../../optfdtmxsz
> > > > -  uid: optfdtro
> > > > +  uid: ../../optfdtro
> > > > -  uid: optfdtuboot
> > > > +  uid: ../../optfdtuboot
> > > >    uid: opti2cspeed
> > > > diff --git a/spec/build/bsps/arm/beagle/grp.yml
> b/spec/build/bsps/arm/beagle/grp.yml
> > > > index 1375913fd0..3452c3e5c8 100644
> > > > --- a/spec/build/bsps/arm/beagle/grp.yml
> > > > +++ b/spec/build/bsps/arm/beagle/grp.yml
> > > > @@ -22,13 +22,13 @@ links:
> > > >    uid: optdm3730
> > > > -  uid: optfdtcpyro
> > > > -  uid: optfdtmxsz
> > > > -  uid: optfdtro
> > > > -  uid: optfdtuboot
> > > >    uid: ../grp
> > > > diff --git a/spec/build/bsps/arm/beagle/optfdtcpyro.yml
> b/spec/build/bsps/arm/beagle/optfdtcpyro.yml
> > > > deleted file mode 100644
> > > > index 5ec59adf4d..0000000000
> > > > --- a/spec/build/bsps/arm/beagle/optfdtcpyro.yml
> > > > +++ /dev/null
> > > > @@ -1,16 +0,0 @@
> > > > -SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> > > > -actions:
> > > > -- get-boolean: null
> > > > -- define-condition: null
> > > > -build-type: option
> > > > -copyrights:
> > > > -- Copyright (C) 2020 embedded brains GmbH (
> http://www.embedded-brains.de)
> > > > -default: true
> > > > -default-by-family: []
> > > > -default-by-variant: []
> > > > -description: |
> > > > -  copy the FDT blob into the read-only load area via bsp_fdt_copy()
> > > > -enabled-by: true
> > > > -links: []
> > > > -name: BSP_FDT_BLOB_COPY_TO_READ_ONLY_LOAD_AREA
> > > > -type: build
> > > > diff --git a/spec/build/bsps/arm/beagle/optfdtmxsz.yml
> b/spec/build/bsps/arm/beagle/optfdtmxsz.yml
> > > > index f3b2504e02..0000000000
> > > > --- a/spec/build/bsps/arm/beagle/optfdtmxsz.yml
> > > > +++ /dev/null
> > > > @@ -1,17 +0,0 @@
> > > > -actions:
> > > > -- get-integer: null
> > > > -- define: null
> > > > -build-type: option
> > > > -copyrights:
> > > > -default: 262144
> > > > -description: |
> > > > -  maximum size of the FDT blob in bytes
> > > > -enabled-by: true
> > > > -format: '{}'
> > > > -links: []
> > > > -name: BSP_FDT_BLOB_SIZE_MAX
> > > > -type: build
> > > > diff --git a/spec/build/bsps/arm/beagle/optfdtro.yml
> b/spec/build/bsps/arm/beagle/optfdtro.yml
> > > > index a72bc23c0e..0000000000
> > > > --- a/spec/build/bsps/arm/beagle/optfdtro.yml
> > > > +++ /dev/null
> > > > @@ -1,16 +0,0 @@
> > > > -actions:
> > > > -build-type: option
> > > > -copyrights:
> > > > -default: true
> > > > -description: |
> > > > -  place the FDT blob into the read-only data area
> > > > -enabled-by: true
> > > > -links: []
> > > > -name: BSP_FDT_BLOB_READ_ONLY
> > > > -type: build
> > > > diff --git a/spec/build/bsps/arm/beagle/optfdtuboot.yml
> b/spec/build/bsps/arm/beagle/optfdtuboot.yml
> > > > index cfe94e577c..0000000000
> > > > --- a/spec/build/bsps/arm/beagle/optfdtuboot.yml
> > > > +++ /dev/null
> > > > @@ -1,16 +0,0 @@
> > > > -actions:
> > > > -build-type: option
> > > > -copyrights:
> > > > -default: true
> > > > -description: |
> > > > -  copy the U-Boot provided FDT to an internal storage
> > > > -enabled-by: true
> > > > -links: []
> > > > -name: BSP_START_COPY_FDT_FROM_U_BOOT
> > > > -type: build
> > > > diff --git a/spec/build/bsps/arm/imx/bspimx.yml
> b/spec/build/bsps/arm/imx/bspimx.yml
> > > > index c65e02db2b..14719745f0 100644
> > > > --- a/spec/build/bsps/arm/imx/bspimx.yml
> > > > +++ b/spec/build/bsps/arm/imx/bspimx.yml
> > > > @@ -61,13 +61,13 @@ links:
> > > >    uid: optconirq
> > > > -  uid: optfdtcpyro
> > > > -  uid: optfdtmxsz
> > > > -  uid: optfdtro
> > > > -  uid: optfdtuboot
> > > >    uid: optresetvec
> > > > diff --git a/spec/build/bsps/arm/imx/optfdtcpyro.yml
> b/spec/build/bsps/arm/imx/optfdtcpyro.yml
> > > > --- a/spec/build/bsps/arm/imx/optfdtcpyro.yml
> > > > +++ /dev/null
> > > > @@ -1,16 +0,0 @@
> > > > -actions:
> > > > -build-type: option
> > > > -copyrights:
> > > > -default: true
> > > > -description: |
> > > > -enabled-by: true
> > > > -links: []
> > > > -type: build
> > > > diff --git a/spec/build/bsps/arm/imx/optfdtmxsz.yml
> b/spec/build/bsps/arm/imx/optfdtmxsz.yml
> > > > --- a/spec/build/bsps/arm/imx/optfdtmxsz.yml
> > > > +++ /dev/null
> > > > @@ -1,17 +0,0 @@
> > > > -actions:
> > > > -- define: null
> > > > -build-type: option
> > > > -copyrights:
> > > > -default: 262144
> > > > -description: |
> > > > -enabled-by: true
> > > > -format: '{}'
> > > > -links: []
> > > > -type: build
> > > > diff --git a/spec/build/bsps/arm/imx/optfdtro.yml
> b/spec/build/bsps/arm/imx/optfdtro.yml
> > > > --- a/spec/build/bsps/arm/imx/optfdtro.yml
> > > > +++ /dev/null
> > > > @@ -1,16 +0,0 @@
> > > > -actions:
> > > > -build-type: option
> > > > -copyrights:
> > > > -default: true
> > > > -description: |
> > > > -enabled-by: true
> > > > -links: []
> > > > -type: build
> > > > diff --git a/spec/build/bsps/arm/imx/optfdtuboot.yml
> b/spec/build/bsps/arm/imx/optfdtuboot.yml
> > > > --- a/spec/build/bsps/arm/imx/optfdtuboot.yml
> > > > +++ /dev/null
> > > > @@ -1,16 +0,0 @@
> > > > -actions:
> > > > -build-type: option
> > > > -copyrights:
> > > > -default: true
> > > > -description: |
> > > > -enabled-by: true
> > > > -links: []
> > > > -type: build
> > > > diff --git a/spec/build/bsps/arm/raspberrypi/grp.yml
> b/spec/build/bsps/arm/raspberrypi/grp.yml
> > > > index 7291e8b178..94627a9526 100644
> > > > --- a/spec/build/bsps/arm/raspberrypi/grp.yml
> > > > +++ b/spec/build/bsps/arm/raspberrypi/grp.yml
> > > > @@ -41,6 +41,14 @@ links:
> > > >    uid: linkcmds
> > > >    uid: ../../bspopts
> > > > +- role: build-dependency
> > > >  type: build
> > > >  use-after: []
> > > >  use-before: []
> > > > diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtcpyro.yml
> b/spec/build/bsps/optfdtcpyro.yml
> > > > similarity index 100%
> > > > rename from spec/build/bsps/arm/altera-cyclone-v/optfdtcpyro.yml
> > > > rename to spec/build/bsps/optfdtcpyro.yml
> > > > diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtmxsz.yml
> b/spec/build/bsps/optfdtmxsz.yml
> > > > rename from spec/build/bsps/arm/altera-cyclone-v/optfdtmxsz.yml
> > > > rename to spec/build/bsps/optfdtmxsz.yml
> > > > diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtro.yml
> b/spec/build/bsps/optfdtro.yml
> > > > rename from spec/build/bsps/arm/altera-cyclone-v/optfdtro.yml
> > > > rename to spec/build/bsps/optfdtro.yml
> > > > diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtuboot.yml
> b/spec/build/bsps/optfdtuboot.yml
> > > > rename from spec/build/bsps/arm/altera-cyclone-v/optfdtuboot.yml
> > > > rename to spec/build/bsps/optfdtuboot.yml
> > > > diff --git a/spec/build/bsps/powerpc/qoriq/grp.yml
> b/spec/build/bsps/powerpc/qoriq/grp.yml
> > > > index 3e295cb599..08533ded6f 100644
> > > > --- a/spec/build/bsps/powerpc/qoriq/grp.yml
> > > > +++ b/spec/build/bsps/powerpc/qoriq/grp.yml
> > > > @@ -68,9 +68,9 @@ links:
> > > >    uid: optexcfixdhdlr
> > > > -  uid: optfdtmxsz
> > > > -  uid: optfdtro
> > > >    uid: opthid0
> > > > diff --git a/spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml
> b/spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml
> > > > --- a/spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml
> > > > +++ /dev/null
> > > > @@ -1,17 +0,0 @@
> > > > -actions:
> > > > -- define: null
> > > > -build-type: option
> > > > -copyrights:
> > > > -default: 262144
> > > > -description: |
> > > > -enabled-by: true
> > > > -format: '{}'
> > > > -links: []
> > > > -type: build
> > > > diff --git a/spec/build/bsps/powerpc/qoriq/optfdtro.yml
> b/spec/build/bsps/powerpc/qoriq/optfdtro.yml
> > > > --- a/spec/build/bsps/powerpc/qoriq/optfdtro.yml
> > > > +++ /dev/null
> > > > @@ -1,16 +0,0 @@
> > > > -actions:
> > > > -build-type: option
> > > > -copyrights:
> > > > -default: true
> > > > -description: |
> > > > -enabled-by: true
> > > > -links: []
> > > > -type: build
> > > > diff --git a/spec/build/bsps/riscv/riscv/grp.yml
> b/spec/build/bsps/riscv/riscv/grp.yml
> > > > index 396f8986ec..77583d351e 100644
> > > > --- a/spec/build/bsps/riscv/riscv/grp.yml
> > > > +++ b/spec/build/bsps/riscv/riscv/grp.yml
> > > > @@ -32,13 +32,13 @@ links:
> > > >    uid: optextirqmax
> > > > -  uid: optfdtcpyro
> > > > -  uid: optfdtmxsz
> > > > -  uid: optfdtro
> > > > -  uid: optfdtuboot
> > > >    uid: optfrdme310arty
> > > > diff --git a/spec/build/bsps/riscv/riscv/optfdtcpyro.yml
> b/spec/build/bsps/riscv/riscv/optfdtcpyro.yml
> > > > --- a/spec/build/bsps/riscv/riscv/optfdtcpyro.yml
> > > > +++ /dev/null
> > > > @@ -1,16 +0,0 @@
> > > > -actions:
> > > > -build-type: option
> > > > -copyrights:
> > > > -default: true
> > > > -description: |
> > > > -enabled-by: true
> > > > -links: []
> > > > -type: build
> > > > diff --git a/spec/build/bsps/riscv/riscv/optfdtmxsz.yml
> b/spec/build/bsps/riscv/riscv/optfdtmxsz.yml
> > > > index 8a07a2ad08..0000000000
> > > > --- a/spec/build/bsps/riscv/riscv/optfdtmxsz.yml
> > > > +++ /dev/null
> > > > @@ -1,17 +0,0 @@
> > > > -actions:
> > > > -- define: null
> > > > -build-type: option
> > > > -copyrights:
> > > > -default: 65536
> > > > -description: |
> > > > -enabled-by: true
> > > > -format: '{}'
> > > > -links: []
> > > > -type: build
> > > > diff --git a/spec/build/bsps/riscv/riscv/optfdtro.yml
> b/spec/build/bsps/riscv/riscv/optfdtro.yml
> > > > --- a/spec/build/bsps/riscv/riscv/optfdtro.yml
> > > > +++ /dev/null
> > > > @@ -1,16 +0,0 @@
> > > > -actions:
> > > > -build-type: option
> > > > -copyrights:
> > > > -default: true
> > > > -description: |
> > > > -enabled-by: true
> > > > -links: []
> > > > -type: build
> > > > diff --git a/spec/build/bsps/riscv/riscv/optfdtuboot.yml
> b/spec/build/bsps/riscv/riscv/optfdtuboot.yml
> > > > --- a/spec/build/bsps/riscv/riscv/optfdtuboot.yml
> > > > +++ /dev/null
> > > > @@ -1,16 +0,0 @@
> > > > -actions:
> > > > -build-type: option
> > > > -copyrights:
> > > > -default: true
> > > > -description: |
> > > > -enabled-by: true
> > > > -links: []
> > > > -type: build
> > > > 2.30.2
> > > > _______________________________________________
> > > > devel mailing list
> > > > devel at rtems.org
> > > > http://lists.rtems.org/mailman/listinfo/devel
> > > devel mailing list
> > > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210809/51e98b03/attachment-0001.html>
