[rtems commit] Test needed for timer_create with CLOCK_MONOTONC
Gedare Bloom
gedare at rtems.org
Wed Aug 11 17:09:26 UTC 2021
this was the wrong patch version.
On Wed, Aug 11, 2021 at 11:03 AM Joel Sherrill <joel at rtems.org> wrote:
> Module: rtems
> Branch: master
> Commit: 8df57649b09f31a58660d9b3c2478195f15f40ce
> Changeset: http://git.rtems.org/rtems/commit/?id=8df57649b09f31a58660d9b3c2478195f15f40ce
> Author: Zacchaeus Leung <zakthertemsdev at outlook.com>
> Date: Fri Aug 6 11:20:41 2021 -0400
> the timer_create() method can use CLOCK_MONOTONIC
> but there was no test for this.
> Also it implements the functionality to
> create a CLOCK_MONOTONIC timer and gettime() .
> Closes #3888
> cpukit/include/rtems/posix/timer.h | 1 +
> cpukit/posix/src/psxtimercreate.c | 3 +-
> cpukit/posix/src/timergettime.c | 48 +++++++++++++++++----------
> testsuites/psxtests/psxtimer02/psxtimer.c | 26 +++++++++++++++
> testsuites/psxtests/psxtimer02/psxtimer02.scn | 5 +++
> 5 files changed, 64 insertions(+), 19 deletions(-)
> diff --git a/cpukit/include/rtems/posix/timer.h b/cpukit/include/rtems/posix/timer.h
> index bcbf07a..7ae0891 100644
> --- a/cpukit/include/rtems/posix/timer.h
> +++ b/cpukit/include/rtems/posix/timer.h
> @@ -48,6 +48,7 @@ typedef struct {
> uint32_t ticks; /* Number of ticks of the initialization */
> uint32_t overrun; /* Number of expirations of the timer */
> struct timespec time; /* Time at which the timer was started */
> + clockid_t clock_type; /* The type of timer */
> } POSIX_Timer_Control;
> diff --git a/cpukit/posix/src/psxtimercreate.c b/cpukit/posix/src/psxtimercreate.c
> index a63cf1d..2b5a101 100644
> --- a/cpukit/posix/src/psxtimercreate.c
> +++ b/cpukit/posix/src/psxtimercreate.c
> @@ -40,7 +40,7 @@ int timer_create(
> POSIX_Timer_Control *ptimer;
> - if ( clock_id != CLOCK_REALTIME )
> + if ( clock_id != CLOCK_REALTIME && clock_id != CLOCK_MONOTONIC )
> rtems_set_errno_and_return_minus_one( EINVAL );
> if ( !timerid )
> @@ -91,6 +91,7 @@ int timer_create(
> ptimer->timer_data.it_value.tv_nsec = 0;
> ptimer->timer_data.it_interval.tv_sec = 0;
> ptimer->timer_data.it_interval.tv_nsec = 0;
> + ptimer->clock_type = clock_id;
> _Watchdog_Preinitialize( &ptimer->Timer, _Per_CPU_Get_snapshot() );
> _Watchdog_Initialize( &ptimer->Timer, _POSIX_Timer_TSR );
> diff --git a/cpukit/posix/src/timergettime.c b/cpukit/posix/src/timergettime.c
> index ee2a566..f4b2596 100644
> --- a/cpukit/posix/src/timergettime.c
> +++ b/cpukit/posix/src/timergettime.c
> @@ -28,6 +28,7 @@
> #include <rtems/score/todimpl.h>
> #include <rtems/score/watchdogimpl.h>
> #include <rtems/seterr.h>
> +#include <rtems/timespec.h>
> * - When a timer is initialized, the value of the time in
> @@ -42,32 +43,43 @@ int timer_gettime(
> - ISR_lock_Context lock_context;
> - uint64_t now;
> - uint32_t remaining;
> + ISR_lock_Context lock_context;
> + Per_CPU_Control *cpu;
> + struct timespec now;
> + struct timespec expire;
> + struct timespec result;
> if ( !value )
> ptimer = _POSIX_Timer_Get( timerid, &lock_context );
> - if ( ptimer != NULL ) {
> - Per_CPU_Control *cpu;
> + if ( ptimer == NULL ) {
> + rtems_set_errno_and_return_minus_one( EINVAL );
> - cpu = _POSIX_Timer_Acquire_critical( ptimer, &lock_context );
> - now = cpu->Watchdog.ticks;
> + cpu = _POSIX_Timer_Acquire_critical( ptimer, &lock_context );
> + rtems_timespec_from_ticks( ptimer->Timer.expire, &expire );
> - if ( now < ptimer->Timer.expire ) {
> - remaining = (uint32_t) ( ptimer->Timer.expire - now );
> - } else {
> - remaining = 0;
> + if ( ptimer->clock_type == CLOCK_MONOTONIC ) {
> + _Timecounter_Nanouptime(&now);
> + } else if (ptimer->clock_type == CLOCK_REALTIME) {
> + _TOD_Get(&now);
> + } else {
> + _POSIX_Timer_Release( cpu, &lock_context );
> - _Timespec_From_ticks( remaining, &value->it_value );
> - value->it_interval = ptimer->timer_data.it_interval;
> - _POSIX_Timer_Release( cpu, &lock_context );
> - return 0;
> + if ( rtems_timespec_less_than( &now, &expire ) ) {
> + rtems_timespec_subtract( &now, &expire, &result );
> + } else {
> + result.tv_nsec = 0;
> + result.tv_sec = 0;
> - rtems_set_errno_and_return_minus_one( EINVAL );
> + value->it_value = result;
> + value->it_interval = ptimer->timer_data.it_interval;
> + return 0;
> \ No newline at end of file
> diff --git a/testsuites/psxtests/psxtimer02/psxtimer.c b/testsuites/psxtests/psxtimer02/psxtimer.c
> index 9f79d33..874a789 100644
> --- a/testsuites/psxtests/psxtimer02/psxtimer.c
> +++ b/testsuites/psxtests/psxtimer02/psxtimer.c
> @@ -127,6 +127,32 @@ void *POSIX_Init (
> status = timer_delete( timer );
> fatal_posix_service_status_errno( status, EINVAL, "bad id" );
> + puts( "timer_create (monotonic) - bad timer id pointer - EINVAL" );
> + status = timer_create( CLOCK_MONOTONIC, &event, NULL );
> + fatal_posix_service_status_errno( status, EINVAL, "bad timer id" );
> + puts( "timer_create (monotonic) - OK" );
> + status = timer_create( CLOCK_MONOTONIC, NULL, &timer );
> + posix_service_failed( status, "timer_create OK" );
> + puts( "timer_create (monotonic) - too many - EAGAIN" );
> + status = timer_create( CLOCK_MONOTONIC, NULL, &timer1 );
> + fatal_posix_service_status_errno( status, EAGAIN, "too many" );
> + clock_gettime( CLOCK_MONOTONIC, &now );
> + itimer.it_value = now;
> + itimer.it_value.tv_sec = itimer.it_value.tv_sec - 1;
> + puts( "timer_settime (monotonic) - bad itimer value - previous time - EINVAL" );
> + status = timer_settime( timer, TIMER_ABSTIME, &itimer, NULL );
> + fatal_posix_service_status_errno( status, EINVAL, "bad itimer value #3" );
> + itimer.it_value.tv_sec = itimer.it_value.tv_sec + 1;
> + puts( "timer_settime (monotonic) - bad id - EINVAL" );
> + status = timer_settime( timer1, TIMER_ABSTIME, &itimer, NULL );
> + fatal_posix_service_status_errno( status, EINVAL, "bad id" );
> TEST_END();
> rtems_test_exit (0);
> diff --git a/testsuites/psxtests/psxtimer02/psxtimer02.scn b/testsuites/psxtests/psxtimer02/psxtimer02.scn
> index e78425a..71638aa 100644
> --- a/testsuites/psxtests/psxtimer02/psxtimer02.scn
> +++ b/testsuites/psxtests/psxtimer02/psxtimer02.scn
> @@ -13,4 +13,9 @@ timer_settime - bad itimer value - negative nanosecond - EINVAL
> timer_settime - bad clock value - EINVAL
> timer_delete - OK
> timer_delete - bad id - EINVAL
> +timer_create (monotonic) - bad timer id pointer - EINVAL
> +timer_create (monotonic) - OK
> +timer_create (monotonic) - too many - EAGAIN
> +timer_settime (monotonic) - bad itimer value - previous time - EINVAL
> +timer_settime (monotonic) - bad id - EINVAL
> *** END OF POSIX Timers Test 02 ***
> vc mailing list
> vc at rtems.org
> http://lists.rtems.org/mailman/listinfo/vc
