[rtems commit] Test needed for timer_create with CLOCK_MONOTONC
Joel Sherrill joel.sherrill at gmail.com
Wed Aug 11 17:56:36 UTC 2021
He passed me the correct one via Discord and I ran tests on leon3 and two
failed like his results.
On Wed, Aug 11, 2021, 12:09 PM Gedare Bloom <gedare at rtems.org> wrote:
> this was the wrong patch version.
> On Wed, Aug 11, 2021 at 11:03 AM Joel Sherrill <joel at rtems.org> wrote:
> > Module:    rtems
> > Branch:    master
> > Commit:    8df57649b09f31a58660d9b3c2478195f15f40ce
> > Changeset:
> http://git.rtems.org/rtems/commit/?id=8df57649b09f31a58660d9b3c2478195f15f40ce
> > Author:    Zacchaeus Leung <zakthertemsdev at outlook.com>
> > Date:      Fri Aug  6 11:20:41 2021 -0400
> > the timer_create() method can use CLOCK_MONOTONIC
> > but there was  no test for this.
> > Also it implements the functionality to
> > create a CLOCK_MONOTONIC timer and gettime() .
> > Closes #3888
> >  cpukit/include/rtems/posix/timer.h            |  1 +
> >  cpukit/posix/src/psxtimercreate.c             |  3 +-
> >  cpukit/posix/src/timergettime.c               | 48
> >  testsuites/psxtests/psxtimer02/psxtimer.c     | 26 +++++++++++++++
> >  testsuites/psxtests/psxtimer02/psxtimer02.scn |  5 +++
> >  5 files changed, 64 insertions(+), 19 deletions(-)
> > diff --git a/cpukit/include/rtems/posix/timer.h
> b/cpukit/include/rtems/posix/timer.h
> > index bcbf07a..7ae0891 100644
> > --- a/cpukit/include/rtems/posix/timer.h
> > +++ b/cpukit/include/rtems/posix/timer.h
> > @@ -48,6 +48,7 @@ typedef struct {
> >    uint32_t          ticks;      /* Number of ticks of the
> initialization */
> >    uint32_t          overrun;    /* Number of expirations of the timer
> >    struct timespec   time;       /* Time at which the timer was started
> > +  clockid_t         clock_type; /* The type of timer */
> >  } POSIX_Timer_Control;
> > diff --git a/cpukit/posix/src/psxtimercreate.c
> b/cpukit/posix/src/psxtimercreate.c
> > index a63cf1d..2b5a101 100644
> > --- a/cpukit/posix/src/psxtimercreate.c
> > +++ b/cpukit/posix/src/psxtimercreate.c
> > @@ -40,7 +40,7 @@ int timer_create(
> >    POSIX_Timer_Control *ptimer;
> > -  if ( clock_id != CLOCK_REALTIME )
> > +  if (  clock_id != CLOCK_REALTIME && clock_id != CLOCK_MONOTONIC )
> >      rtems_set_errno_and_return_minus_one( EINVAL );
> >    if ( !timerid )
> > @@ -91,6 +91,7 @@ int timer_create(
> >    ptimer->timer_data.it_value.tv_nsec    = 0;
> >    ptimer->timer_data.it_interval.tv_sec  = 0;
> >    ptimer->timer_data.it_interval.tv_nsec = 0;
> > +  ptimer->clock_type = clock_id;
> >    _Watchdog_Preinitialize( &ptimer->Timer, _Per_CPU_Get_snapshot() );
> >    _Watchdog_Initialize( &ptimer->Timer, _POSIX_Timer_TSR );
> > diff --git a/cpukit/posix/src/timergettime.c
> b/cpukit/posix/src/timergettime.c
> > index ee2a566..f4b2596 100644
> > --- a/cpukit/posix/src/timergettime.c
> > +++ b/cpukit/posix/src/timergettime.c
> > @@ -28,6 +28,7 @@
> >  #include <rtems/score/todimpl.h>
> >  #include <rtems/score/watchdogimpl.h>
> >  #include <rtems/seterr.h>
> > +#include <rtems/timespec.h>
> >   *          - When a timer is initialized, the value of the time in
> > @@ -42,32 +43,43 @@ int timer_gettime(
> > -  ISR_lock_Context     lock_context;
> > -  uint64_t             now;
> > -  uint32_t             remaining;
> > +  ISR_lock_Context lock_context;
> > +  Per_CPU_Control *cpu;
> > +  struct timespec now;
> > +  struct timespec expire;
> > +  struct timespec result;
> >    if ( !value )
> >    ptimer = _POSIX_Timer_Get( timerid, &lock_context );
> > -  if ( ptimer != NULL ) {
> > -    Per_CPU_Control *cpu;
> > +  if ( ptimer == NULL ) {
> > +    rtems_set_errno_and_return_minus_one( EINVAL );
> > -    cpu = _POSIX_Timer_Acquire_critical( ptimer, &lock_context );
> > -    now = cpu->Watchdog.ticks;
> > +  cpu = _POSIX_Timer_Acquire_critical( ptimer, &lock_context );
> > +  rtems_timespec_from_ticks( ptimer->Timer.expire, &expire );
> > -    if ( now < ptimer->Timer.expire ) {
> > -      remaining = (uint32_t) ( ptimer->Timer.expire - now );
> > -    } else {
> > -      remaining = 0;
> > +  if ( ptimer->clock_type == CLOCK_MONOTONIC ) {
> > +  _Timecounter_Nanouptime(&now);
> > +  } else  if (ptimer->clock_type == CLOCK_REALTIME) {
> > +    _TOD_Get(&now);
> > +  } else {
> > +    _POSIX_Timer_Release( cpu, &lock_context );
> > -    _Timespec_From_ticks( remaining, &value->it_value );
> > -    value->it_interval = ptimer->timer_data.it_interval;
> > -    _POSIX_Timer_Release( cpu, &lock_context );
> > -    return 0;
> > + if ( rtems_timespec_less_than( &now, &expire ) ) {
> > +      rtems_timespec_subtract( &now, &expire, &result );
> > +  } else {
> > +    result.tv_nsec = 0;
> > +    result.tv_sec  = 0;
> > -  rtems_set_errno_and_return_minus_one( EINVAL );
> > +  value->it_value = result;
> > +  value->it_interval = ptimer->timer_data.it_interval;
> > +  return 0;
> > \ No newline at end of file
> > diff --git a/testsuites/psxtests/psxtimer02/psxtimer.c
> b/testsuites/psxtests/psxtimer02/psxtimer.c
> > index 9f79d33..874a789 100644
> > --- a/testsuites/psxtests/psxtimer02/psxtimer.c
> > +++ b/testsuites/psxtests/psxtimer02/psxtimer.c
> > @@ -127,6 +127,32 @@ void *POSIX_Init (
> >    status = timer_delete( timer );
> >    fatal_posix_service_status_errno( status, EINVAL, "bad id" );
> > +  puts( "timer_create (monotonic) - bad timer id pointer - EINVAL" );
> > +  status = timer_create( CLOCK_MONOTONIC, &event, NULL );
> > +  fatal_posix_service_status_errno( status, EINVAL, "bad timer id" );
> > +  puts( "timer_create (monotonic) - OK" );
> > +  status = timer_create( CLOCK_MONOTONIC, NULL, &timer );
> > +  posix_service_failed( status, "timer_create OK" );
> > +  puts( "timer_create (monotonic) - too many - EAGAIN" );
> > +  status = timer_create( CLOCK_MONOTONIC, NULL, &timer1 );
> > +  fatal_posix_service_status_errno( status, EAGAIN, "too many" );
> > +  clock_gettime( CLOCK_MONOTONIC, &now );
> > +  itimer.it_value = now;
> > +  itimer.it_value.tv_sec = itimer.it_value.tv_sec - 1;
> > +  puts( "timer_settime (monotonic) - bad itimer value - previous time -
> EINVAL" );
> > +  status = timer_settime( timer, TIMER_ABSTIME, &itimer, NULL );
> > +  fatal_posix_service_status_errno( status, EINVAL, "bad itimer value
> #3" );
> > +  itimer.it_value.tv_sec = itimer.it_value.tv_sec + 1;
> > +  puts( "timer_settime (monotonic) - bad id - EINVAL" );
> > +  status = timer_settime( timer1, TIMER_ABSTIME, &itimer, NULL );
> > +  fatal_posix_service_status_errno( status, EINVAL, "bad id" );
> >    TEST_END();
> >    rtems_test_exit (0);
> > diff --git a/testsuites/psxtests/psxtimer02/psxtimer02.scn
> b/testsuites/psxtests/psxtimer02/psxtimer02.scn
> > index e78425a..71638aa 100644
> > --- a/testsuites/psxtests/psxtimer02/psxtimer02.scn
> > +++ b/testsuites/psxtests/psxtimer02/psxtimer02.scn
> > @@ -13,4 +13,9 @@ timer_settime - bad itimer value - negative nanosecond
> - EINVAL
> >  timer_settime - bad clock value - EINVAL
> >  timer_delete - OK
> >  timer_delete - bad id - EINVAL
> > +timer_create (monotonic) - bad timer id pointer - EINVAL
> > +timer_create (monotonic) - OK
> > +timer_create (monotonic) - too many - EAGAIN
> > +timer_settime (monotonic) - bad itimer value - previous time - EINVAL
> > +timer_settime (monotonic) - bad id - EINVAL
> >  *** END OF POSIX Timers Test 02 ***
> > vc mailing list
> > vc at rtems.org
> > http://lists.rtems.org/mailman/listinfo/vc
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210811/3eedaaf7/attachment.html>
