[PATCH 1/5] score: Simplify _Thread_Create_idle_for_CPU()
Sebastian Huber
Mon Aug 16 11:15:27 UTC 2021
Online processors have a scheduler assigned.
cpukit/score/src/threadcreateidle.c | 8 +-------
1 file changed, 1 insertion(+), 7 deletions(-)
diff --git a/cpukit/score/src/threadcreateidle.c b/cpukit/score/src/threadcreateidle.c
index 395dcc9c12..f5ffc9bad8 100644
--- a/cpukit/score/src/threadcreateidle.c
+++ b/cpukit/score/src/threadcreateidle.c
@@ -38,13 +38,7 @@ static void _Thread_Create_idle_for_CPU( Per_CPU_Control *cpu )
memset( &config, 0, sizeof( config ) );
config.scheduler = _Scheduler_Get_by_CPU( cpu );
-#if defined(RTEMS_SMP)
- if ( config.scheduler == NULL ) {
- return;
-#endif
+ _Assert( config.scheduler != NULL );
config.priority = _Scheduler_Map_priority(
config.scheduler,
config.scheduler->maximum_priority
2.26.2
