[PATCH rtems-docs] bsps/raspberrypi: Change firmware version, add SPI & I2C support
Wed Aug 18 19:17:08 UTC 2021
I spot checked the output and it looks good. I pushed this. Please
check that you like the formatting.
Thanks.
--joel
On Wed, Aug 18, 2021 at 8:52 AM Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
> Looks good to me.
> Kinsey
> On 8/16/2021 05:27, pranav wrote:
> >   user/bsps/arm/raspberrypi.rst | 51 ++++++++++++++++++++++++++++++-----
> >   1 file changed, 45 insertions(+), 6 deletions(-)
> > diff --git a/user/bsps/arm/raspberrypi.rst b/user/bsps/arm/raspberrypi.rst
> > index c26f4b5..11dcc30 100644
> > --- a/user/bsps/arm/raspberrypi.rst
> > +++ b/user/bsps/arm/raspberrypi.rst
> > @@ -5,8 +5,9 @@
> >   raspberrypi
> > -This BSP supports `Raspberry Pi 1` and `Raspberry Pi 2` currently.
> > -The support for `Raspberry Pi 3` is work under progress.
> > +The 'raspberrypi' BSP supports the single core models (Zero,  Zero W, A+, B+),
> > +and the 'raspberrypi2' BSP supports the Raspberry Pi 2, Raspberry Pi 3 A+, and Raspberry Pi 3.
> > +The Raspberry Pi 4 is not supported currently.
> >   The default bootloader on the Raspberry Pi which is used to boot Raspbian
> >   or other OS can be also used to boot RTEMS. U-boot can also be used.
> > @@ -19,10 +20,12 @@ The bootloader looks for a kernel image, by default the kernel images must
> >   have a name of the form ``kernel*.img`` but this can be changed by adding
> >   `kernel=<img_name>` to ``config.txt``.
> > -You must provide the required files for the GPU to proceed. These files
> > +You must provide the required firmware files on the SD card for the GPU to proceed,
> > +and thereby to boot RTEMS.
> > +The BSP currently boots up with an older version of the official firmware. These files
> >   can be downloaded from
> > -`the Raspberry Pi Firmware Repository <https://github.com/raspberrypi/firmware/tree/master/boot>`_.
> > -You can remove the ``kernel*.img`` files if you want too, but don't touch
> > +`the Raspberry Pi Firmware Repository <https://github.com/raspberrypi/firmware/tree/1.20200601/boot>`_.
> > +You can remove the ``kernel*.img`` files if you want to, but don't touch
> >   the other files.
> >   Copy these files in to a SD card with FAT filesystem.
> > @@ -46,10 +49,46 @@ Make sure you have these lines below, in your ``config.txt``.
> >   .. code-block:: none
> > -     enable_uart=1
> > +     dtoverlay=disable-bt
> >        kernel_address=0x200000
> >        kernel=kernel.img
> > +SPI Driver
> > +SPI drivers are registered by the ``rpi_spi_init(bool bidirectional_mode)`` function.
> > +.. code-block:: none
> > +     #include <assert.h>
> > +     #include <bsp.h>
> > +     void spi_init(void)
> > +       int rv;
> > +       rv = rpi_spi_init(false);
> > +       assert(rv == 0);
> > +I2C Driver
> > +I2C drivers are registered by the ``rpi_setup_i2c_bus()`` function.
> > +     #include <bsp.h>
> > +     void i2c_init(void)
> > +       int rv;
> > +       rv = rpi_setup_i2c_bus();
> > +       assert(rv == 0);
> >   Testing using QEMU
> devel mailing list
> devel at rtems.org
