Xilinx Zynq console rx not working
Kinsey Moore kinsey.moore at oarcorp.com
Mon Aug 16 14:04:45 UTC 2021
On 8/16/2021 08:40, mbenson at windhoverlabs.com wrote:
> I just built and ran the zc702 build on Qemu yesterday with no problems.  I ran the hello.exe sample.  But, I launched it using Vitis 2020.2 so maybe it was a qemu difference?  Master branch.  RTEMS 6.
> Sent from my iPhone
Output seems to work fine; it's the input that's not working properly.
You'll see this behavior if you run the fileio.exe test since it
requires interaction with the console. I haven't tried on hardware, so
that may also be a difference.
Kinsey
