Xilinx Zynq console rx not working
mbenson at windhoverlabs.com mbenson at windhoverlabs.com
Mon Aug 16 14:16:11 UTC 2021
Ah.  Yes.  I did not test input.  Thanks for the heads up.
Sent from my iPhone
> On Aug 16, 2021, at 09:04, Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
> On 8/16/2021 08:40, mbenson at windhoverlabs.com wrote:
>> I just built and ran the zc702 build on Qemu yesterday with no problems.  I ran the hello.exe sample.  But, I launched it using Vitis 2020.2 so maybe it was a qemu difference?  Master branch.  RTEMS 6.
>> Sent from my iPhone
> Output seems to work fine; it's the input that's not working properly. You'll see this behavior if you run the fileio.exe test since it requires interaction with the console. I haven't tried on hardware, so that may also be a difference.
> Kinsey
