RTEMS Tools on 5 release can't be build with modern LLVM
Christian MAUDERER christian.mauderer at embedded-brains.de
Mon Aug 16 15:08:37 UTC 2021
Hello Joel,
Am 16.08.21 um 17:03 schrieb Joel Sherrill:
> On Mon, Aug 16, 2021 at 9:49 AM Christian MAUDERER
> <christian.mauderer at embedded-brains.de> wrote:
>> Hello,
>> I noted that I can't build the RTEMS 5 toolchain if I have a modern LLVM
>> installed using the RTEMS source builder. Therefore I would like to
>> backport the patch 37ad446d9dce3 ([1]) to the 5 branch. Is that OK? If
>> someone acknowledges it, I would do the following steps without further
>> review (but of course with testing):
>> 1. Create a ticket for the problem.
>> 2. In rtems-tools: Cherry pick the patch 37ad446d9dce3 to the 5 branch.
>> 3. In rtems-source-builder: Backport the patch 91932d0a0 [2] to the 5
>> branch (or rather re-create it because it will be a different commit and
>> a different hash).
> I'm ok with this. I remember doing a patch for the opposite direction.
> I couldn't
> build on an older gcc because it assumed a different language version as
> default. gcc 4.8 as on CentOS 7 assumes C++03. Newer versions assume C++11
> as the base. Similarly newer gcc's seem to default to C11.
Thanks. I'll wait a bit more before adding the patches in case someone
else want's to object.
> I posted a few weeks ago that users should really be careful to always use
> -std and consciously pick what they want.
In this case, the version of the standard depends quite a lot on the
LLVM headers. LLVM seems to love using new features.
Best regards
Christian
> --joel
>> Best regards
>> Christian
>> [1]
>> https://git.rtems.org/rtems-tools/commit/?id=37ad446d9dce3438d6d32e1caf56d3fdccdd2ad0
>> [2]
>> https://git.rtems.org/rtems-source-builder/commit/?id=91932d0a0c86400366f9c75a62123b6488ff458a
>> embedded brains GmbH
>> Herr Christian MAUDERER
>> Dornierstr. 4
>> 82178 Puchheim
>> Germany
>> email: christian.mauderer at embedded-brains.de
>> phone: +49-89-18 94 741 - 18
>> fax:   +49-89-18 94 741 - 08
>> Registergericht: Amtsgericht München
>> Registernummer: HRB 157899
>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>> Unsere Datenschutzerklärung finden Sie hier:
>> https://embedded-brains.de/datenschutzerklaerung/
>> devel mailing list
>> devel at rtems.org
Dornierstr. 4
82178 Puchheim
Germany
